791|1
504
【得捷电子Follow me第4期】终极任务二:ftp服务 [复制链接]
27a4aad1e1a28d8d5c44e603262e660c
w5x00_ftp_server.uf2 (104 KB, 下载次数: 0)
七:终极任务二:使用外部存储器,组建简易FTP文件服务器,并能正常上传下载文件。
7.1 准备
基于ftp的example和前面的入门任务和基础任务一。
添加代码
修改CMakeLists.txt为如下
set(TARGET_NAME w5x00_ftp_server)
aux_source_directory(ZLG_GUI ZLG_GUI_SOURCES)
include_directories(ZLG_GUI/include .)
add_executable(${TARGET_NAME}
        ${TARGET_NAME}.c
        ls013.c
        ls013_lcd.c
        ${ZLG_GUI_SOURCES}
target_link_libraries(${TARGET_NAME} PRIVATE
        pico_stdlib
        hardware_spi
        hardware_dma
        hardware_clocks
        ETHERNET_FILES
        IOLIBRARY_FILES
        FTPSERVER_FILES
pico_enable_stdio_usb(${TARGET_NAME} 1)
pico_enable_stdio_uart(${TARGET_NAME} 0)
pico_add_extra_outputs(${TARGET_NAME})
7.2 代码
 * Copyright (c) 2021 WIZnet Co.,Ltd
 * SPDX-License-Identifier: BSD-3-Clause
 * Includes
#include <stdio.h>
#include "port_common.h"
#include "wizchip_conf.h"
#include "w5x00_spi.h"
#include "ftpd.h"
#include "ls013_lcd.h"
#include "config.h"
 * Macros
/* Clock */
#define PLL_SYS_KHZ (133 * 1000)
/* Buffer */
#define ETHERNET_BUF_MAX_SIZE (1024 * 2)
 * Variables
/* Network */
static wiz_NetInfo g_net_info =
        .mac = {0x00, 0x08, 0xDC, 0x12, 0x34, 0x56}, // MAC address
        .ip = {192, 168, 31, 111},                     // IP address
        .sn = {255, 255, 255, 0},                    // Subnet Mask
        .gw = {192, 168, 31, 1},                     // Gateway
        .dns = {8, 8, 8, 8},                         // DNS server
        .dhcp = NETINFO_STATIC                       // DHCP enable/disable
/* FTP */
static uint8_t g_ftp_buf[ETHERNET_BUF_MAX_SIZE] = {
    0,
 * Functions
/* Clock */
static void set_clock_khz(void);
 * Main
int main()
    /* Initialize */
    uint8_t retval = 0;
    set_clock_khz();
    stdio_init_all();
    wizchip_spi_initialize();
    wizchip_cris_initialize();
    wizchip_reset();
    wizchip_initialize();
    wizchip_check();
    network_initialize(g_net_info);
    ftpd_init(g_net_info.ip);
    /* Get network information */
    print_network_information(g_net_info);
    GUI_Initialize();
    GUI_SetColor(1,0);
    GUI_PutString8_8(10,10,"ftp server test");
    /* Infinite loop */
    while (1)
        /* Run FTP server */
        if ((retval = ftpd_run(g_ftp_buf)) < 0)
            printf(" FTP server error : %d\n", retval);
            GUI_PutString8_8(10,20,"ftp server err");
            while (1)
        else
            GUI_PutString8_8(10,20,"ftp server ok");
        GUI_Exec();
 * Functions
/* Clock */
    // set a system clock frequency in khz
    set_sys_clock_khz(PLL_SYS_KHZ, true);
    // configure the specified clock
    clock_configure(
        clk_peri,
        0,                                                // No glitchless mux
        CLOCKS_CLK_PERI_CTRL_AUXSRC_VALUE_CLKSRC_PLL_SYS, // System PLL on AUX mux
        PLL_SYS_KHZ * 1000,                               // Input frequency
        PLL_SYS_KHZ * 1000                                // Output (must be same as no divider)
7.3 测试
下载运行D:\BOARD\followme4\RP2040-HAT-C\build\examples\ftp\server\w5x00_ftp_server.uf2
使用FileZilla连接,可以下载上传文件
7.4 增加eeprom读写
参考以下文章使用IO模拟IIC可以驱动各种IIC设备,使用QWIIC转接板可以接各种QWIIC接口的传感器。以下在tfp基础上实现EEPROM读写。
https://mp.weixin.qq.com/s/vlhy7z8XrgxXJoAtYuXw0g 超级精简系列之四:超级精简的IO模拟IIC的C实现:EEPROM编辑工具应用
https://mp.weixin.qq.com/s/ESzWWqxHpQevsWfjV0s2VQ 超级精简系列之三:超级精简的IO模拟IIC的C实现
添加代码
实现IO接口
#include "pico/stdlib.h"
#include "io_iic.h"
#include "eeprom.h"
static void io_iic_port_init(void)
    gpio_init(5);
    gpio_set_dir(5, GPIO_OUT);
    gpio_put(5, 0);
    gpio_init(6);
    gpio_set_dir(6, GPIO_OUT);
    gpio_put(6, 0);
static void io_iic_port_deinit(void)
static void io_iic_port_scl_write(uint8_t val)
    if(val == 0)
        gpio_put(5, 0);
    else
        gpio_put(5, 1);
static void io_iic_port_sda_write(uint8_t val)
    if(val == 0)
        gpio_put(6, 0);
    else
        gpio_put(6, 1);
static void io_iic_port_sda_2read(void)
    gpio_set_dir(6, GPIO_IN);
static uint8_t io_iic_port_sda_read(void)
    return gpio_get(6);
static void io_iic_port_delay(uint32_t delay)
    sleep_us(delay);
static io_iic_dev_st io_iic_dev=
.scl_write = io_iic_port_scl_write,
.sda_2read = io_iic_port_sda_2read,
.sda_read = io_iic_port_sda_read,
.sda_write = io_iic_port_sda_write,
.delayus = 10,
.delay_pf = io_iic_port_delay,
.init = io_iic_port_init,
.deinit = io_iic_port_deinit,
实现IIC接口
static void    eeprom_iic_port_init(void)
    io_iic_init(&io_iic_dev);
static void    eeprom_iic_port_deinit(void)
    io_iic_deinit(&io_iic_dev);
static void    eeprom_iic_port_start(void)
    io_iic_start(&io_iic_dev);
static void    eeprom_iic_port_stop(void)
    io_iic_stop(&io_iic_dev);
static int eeprom_iic_port_read(uint8_t* val ,uint8_t ack)
    return io_iic_read(&io_iic_dev, val ,ack);
static int     eeprom_iic_port_write(uint8_t val)
    return io_iic_write(&io_iic_dev, val);
eeprom_dev_st eepromdev=
    .addr = 0,
    .read = eeprom_iic_port_read,
    .start = eeprom_iic_port_start,
    .stop = eeprom_iic_port_stop,
    .write = eeprom_iic_port_write,
    .init = eeprom_iic_port_init,
    .deinit = eeprom_iic_port_deinit,
读写测试
//读命令实现
void printeepromfunc(uint8_t* param)
    uint8_t buffer[16];
    uint32_t addr;
    uint32_t len;
    uint8_t* p = param;
    int res;
    //if(3 == sscanf((const char*)param, "%*s %s %d %d", type, &addr, &len))
    while(1)
        if((*p > 'z') || (*p < 'a'))
            break;
        else
            p++;
    while(1)
        if(*p != ' ')
            break;
        else
            p++;
    addr = atoi((const char*)p);
    while(1)
        if((*p > '9') || (*p < '0'))
            break;
        else
            p++;
    while(1)
        if(*p != ' ')
            break;
        else
            p++;
    len = atoi((const char*)p);
    uint32_t toread;
    uint32_t read = 0;
    eeprom_init(&eepromdev);
    while(read < len)
        toread = ((len-read) > sizeof(buffer)) ? sizeof(buffer) : (len-read);
        if(0 != (res = eeprom_random_read(&eepromdev, addr+read, buffer, toread)))
            printf("read err %d\r\n",res);
            eeprom_deinit(&eepromdev);
            return;
        read += toread;
        for(uint32_t i=0; i<toread ;i++)
            printf("%02x ",buffer);
        printf("\r\n");
//写命令实现
static uint8_t char2hex(uint8_t ch)
  if((ch<='9') && (ch>='0'))
    return ch-'0';
  else if((ch<='f') && (ch>='a'))
    return ch-'a' + 10;
  else if((ch<='F') && (ch>='A'))
    return ch-'A' + 10;
  return 0;
void writeeepromfunc(uint8_t* param)
    uint8_t buffer[16];
    uint32_t addr;
    uint32_t len=0;
    uint8_t* p = param;
    uint8_t flag;
    uint8_t tmp;
    int res;
    while(1)
            break;
        else
            p++;
        while(1)
        if(*p != ' ')
            break;
        else
            p++;
    while(1)
            break;
        else
            p++;
    while(1)
        if(*p != ' ')
            break;
        else
            p++;
    flag = 0;
    while(*p)
        if(flag == 0)
            tmp = char2hex(*p) << 4;
            flag = 1;
        else if(flag == 1)
            tmp |= char2hex(*p);
            flag = 0;
            buffer[len++] = tmp;
            if(len>=16)
            break;
        p++;
    if(0 != (res = eeprom_page_write(&eepromdev, addr, buffer, len)))
        printf("write err %d\r\n",res);
        return;
    printf("\r\n");
读写测试
Printeepromfunc(“printeeprom 0 256”);
c0 a9 21 01 10 00 00 00 1b 89 ab eb b7 fd 47 e4
e1 c5 ed eb e4 1f f3 96 2d d3 2b 55 de e6 cb aa
ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
修改8字节
Writeeepromfunc(“writeeeprom 8 46881faa2ffdb2e9”)
修改后查看
c0 a9 21 01 10 00 00 00 46 88 1f aa 2f fd b2 e9
27a4aad1e1a28d8d5c44e603262e660c.mp4
7.8 MB, 下载次数: 0
ftp服务传输速率怎么样?   详情 回复 发表于 2024-2-18 17:02
7244
ftp服务传输速率怎么样?
