672|4
5802
44
顶级发射连接器测试板(40ghz) [复制链接]
SIGNAL02.pdf (3.88 MB, 下载次数: 0, 售价: 1 分芯积分)
SIGNAL01.pdf (11 MB, 下载次数: 0, 售价: 1 分芯积分)
此帖出自无线连接论坛
先盛赞一下楼主,先收藏起来,慢慢研究研究,顶起来   详情 回复 发表于 2023-11-26 20:22
射频【放大器】#无线电系统
5802
44
The Ground Contact with the PC BoardFor a GCPW the top ground spacing can be matched to the ground contact points of the connector. For a microstrip line there is no top ground so there is not much to optimize to improve performance. If a short GCPW section is added to edge of a microstrip line, this gives a structure that can be optimized to the connector.
与PC板的接地接点对于GCPW,顶部接地间距可以与连接器的接地接触点相匹配。对于微带线来说,没有顶部接地,所以没有太多的优化来提高性能。如果一个短的GCPW部分添加到微带线的边缘,这就给出了一个可以优化连接器的结构。
此帖出自无线连接论坛
射频【放大器】#无线电系统
5802
44
RF Advantages of a Solderless Connection Soldering is the traditional way of creating the electrical connection between the connector and the PC board. When modeling the transition a predictable geometry is required for the model to be valid, especially at a point as critical as where the pin makes contact with the board.
焊接是在连接器和PC板之间建立电气连接的传统方式。在对过渡进行建模时,需要一个可预测的几何形状才能使模型有效,特别是在引脚与电路板接触的关键位置。
此帖出自无线连接论坛
射频【放大器】#无线电系统
5802
44
40 GHz and 70 GHz Launch DifferencesThe launch design will have its own frequency range limitation. The sizing and spacing launch geometry is proportional to the wavelength of the energy that is traveling through the transition. Having the smaller geometry is a challenge to the limitations of board fabrication processes and leads more inconsistency in the performance of the high frequency boards after fabrication. The lower frequency boards are not as sensitive to the variations inherent in board processing and perform more consistently between individual boards after fabrication.On the left are 40 GHz and 70 GHz bandwidth grounded coplanar waveguide (GCPW) and microstrip test boards. These are standard Signal Microwave test boards made using 8mil thick Rogers RO4003 material with an FR-4 stiffener.Shown in the close-ups are comparisons of the 40 GHz launch designs and 70GHz launch designs. The 70 GHz launch has different size vias, notably the first vias on either side of the trace, and they are spaced closer to the trace and the edge of the board. The 40GHz launch designs have larger vias and are not spaced as tight.
40GHz和70GHz发射差发射设计会有自己的频率范围限制。发射几何形状的尺寸和间距与穿越跃迁的能量波长成正比。拥有更小的几何形状是对电路板制造工艺限制的挑战,并导致制造后高频板的性能更加不一致。低频板对板加工中固有的变化不那么敏感,并且在制造后各个板之间的性能更加一致。左边是40 GHz和70 GHz带宽接地共面波导(GCPW)和微带测试板。这些都是标准的Signal Microwave测试板,采用8mil厚的Rogers RO4003材料,带有FR-4加强筋。特写中显示的是40GHz发射设计和70千兆赫发射设计的比较。70 GHz发射具有不同尺寸的过孔,特别是在走线两侧的第一个过孔,它们的间隔更靠近走线和电路板边缘。40GHz发射设计的过孔更大,间隔也没有那么紧。
Top Ground Launch for Multi-Layer BoardsTop Ground LaunchFor both microstrip and GCPW transmission lines, when implemented in a multi-layer board configuration, the ground layer for the microwave transmission line is buried. The connector will not have access to it no matter how the connector is configured.The launch designs developed by Signal Microwave incorporate a short section to transition the ground connection from the top of the board to the buried ground layer.The small set of vias at the edge of the microstrip board is a GCPW section used to transfer the energy from the connector to the board using only the top ground connection of the connector.Signal Microwave Board ConstructionThe 8 mil RO4003 top layer is processed seperately including vias and plating. Then the RO4003 layer is laminated to the FR-4 layer which acts as a stiffener. The FR-4 layer does not have through vias that can cause resonances and no back drilling is required多层板的地面发射地面顶发射对于微带和GCPW传输线,当在多层板配置中实现时,微波传输线的接地层是埋置的。无论连接器如何配置,连接器都无法访问它。由信号微波公司开发的发射设计包括一个短的部分,将地面连接从板的顶部过渡到埋地层。微带板边缘的一小组通孔是GCPW部分,用于仅使用连接器的顶部接地连接将能量从连接器转移到板上。信号微波板结构8 mil RO4003顶层分别处理,包括过孔和电镀。然后将RO4003层与FR-4层叠合,作为加强层。FR-4层没有可能引起共振的通孔,也不需要回钻
此帖出自无线连接论坛
射频【放大器】#无线电系统
701
此帖出自无线连接论坛
