850|1
220
【得捷电子Follow me第3期】任务完成汇总 [复制链接]
任务1:使用MicroPython系统(必做任务)
熟悉Seeed Studio XIAO ESP32C3开发板基本操作,安装esptool,并给开发板刷写MicroPython系统,完成入门程序的运行
搭配器件:Seeed Studio XIAO ESP32C3
下面进行第一步:
安装Thonny版本是4.14的。
Thonny, Python IDE for beginners
https://thonny.org/
或者直接进仓库下载:
链接已隐藏,如需查看请登录或者注册
进入下载连接在最下面就可以看到:
安装好后的版本:
再安装BIN文件到ESP32中:
https://micropython.org/download/esp32c3/
将ESP32-C3 XIAO的开发板,通过USB转Type-C的线缆,链接到电脑上。运行Tohonny exe,在【运行】->【解析器页面】->选择Micropython (ESP32),然后在端口选择ESP32-C3 XIAO在电脑上虚拟出来的COM口。如下所示:
打列软件后,在右下角选择ESP32与对应的端口就说明,环境与板子已成功,表明可以进行下一步了。
任务2:驱动扩展板上的OLED屏幕(必做任务)
使用扩展板上的OLED屏幕显示文字和图形
搭配器件:Seeed Studio XIAO ESP32C3Seeed Studio Expansion Board Base for XIAO
首先第一步就是要安装那个库文件。
这里需要注意的是,有点不好装成功,但是要开梯子才可以装成功,而且要4.14的版本,我也是一直安装失败,最后才装成功,我这里是装好的,安装成功后,卸载会显示。
来两个照片:
关键代码:
# 汉字字典
character_dict = {
    '鲣':[0x20,0x40,0x21,0x7e,0x7d,0x52,0x45,0x52,0x89,0x54,0x7d,0x48,0x55,0x54,0x54,0x62,0x7c,0x10,0x54,0x10,0x54,0xfe,0x7c,0x10,0x0,0x10,0x1c,0x10,0xe1,0xfe,0x40,0x0],
    '电': [0x01,0x01,0x01,0x3F,0x21,0x21,0x21,0x3F,0x21,0x21,0x21,0x3F,0x21,0x01,0x01,0x00,0x00,0x00,0x00,0xF8,0x08,0x08,0x08,0xF8,0x08,0x08,0x08,0xF8,0x0A,0x02,0x02,0xFE],
    '压': [0x00,0x3F,0x20,0x20,0x20,0x20,0x20,0x2F,0x20,0x20,0x20,0x20,0x20,0x40,0x5F,0x80,0x00,0xFE,0x00,0x80,0x80,0x80,0x80,0xFC,0x80,0x80,0x90,0x88,0x88,0x80,0xFE,0x00],
    '流': [0x00,0x20,0x17,0x10,0x81,0x42,0x47,0x10,0x10,0x22,0xE2,0x22,0x22,0x22,0x24,0x08,0x80,0x40,0xFE,0x80,0x10,0x08,0xFC,0x04,0x00,0x48,0x48,0x48,0x48,0x4A,0x4A,0x46],
    '测': [0x00,0x27,0x14,0x14,0x85,0x45,0x45,0x15,0x15,0x25,0xE5,0x21,0x22,0x22,0x24,0x08,0x04,0xC4,0x44,0x54,0x54,0x54,0x54,0x54,0x54,0x54,0x54,0x04,0x84,0x44,0x14,0x08],
    '量': [0x00,0x1F,0x10,0x1F,0x10,0xFF,0x00,0x1F,0x11,0x1F,0x11,0x1F,0x01,0x1F,0x01,0x7F,0x00,0xF0,0x10,0xF0,0x10,0xFE,0x00,0xF0,0x10,0xF0,0x10,0xF0,0x00,0xF0,0x00,0xFC],
    '得':[0x08,0x0B,0x12,0x23,0x4A,0x0B,0x10,0x33,0x50,0x97,0x10,0x12,0x11,0x10,0x10,0x10,0x00,0xF8,0x08,0xF8,0x08,0xF8,0x00,0xFC,0x10,0xFE,0x10,0x10,0x10,0x10,0x50,0x20],
    '捷':[0x20,0x20,0x27,0x20,0xFB,0x20,0x27,0x28,0x33,0xE0,0x22,0x22,0x22,0x25,0xA4,0x48,0x40,0x40,0xFE,0x40,0xF8,0x48,0xFE,0x48,0xF8,0x40,0x40,0x7C,0x40,0x40,0xFE,0x00],
    "第":[0x20,0x3F,0x48,0x85,0x3F,0x01,0x01,0x3F,0x21,0x21,0x3F,0x03,0x05,0x19,0xE1,0x01,0x40,0x7E,0x90,0x08,0xF8,0x08,0x08,0xF8,0x00,0x00,0xFC,0x04,0x04,0x28,0x10,0x00],
     '三':[0x00,0x00,0x7F,0x00,0x00,0x00,0x00,0x3F,0x00,0x00,0x00,0x00,0x00,0xFF,0x00,0x00,0x00,0x00,0xFC,0x00,0x00,0x00,0x00,0xF8,0x00,0x00,0x00,0x00,0x00,0xFE,0x00,0x00],
     '期':[0x22,0x22,0x7F,0x22,0x22,0x3E,0x22,0x22,0x3E,0x22,0x22,0xFF,0x04,0x22,0x41,0x82,0x00,0x7C,0x44,0x44,0x44,0x7C,0x44,0x44,0x44,0x7C,0x44,0x44,0x84,0x84,0x14,0x08],
    'A': [0x00,0x00,0x00,0x10,0x10,0x18,0x28,0x28,0x24,0x3C,0x44,0x42,0x42,0xE7,0x00,0x00],
    'V': [0x00,0x00,0x00,0xE7,0x42,0x42,0x44,0x24,0x24,0x28,0x28,0x18,0x10,0x10,0x00,0x00],
    ':': [0x00,0x00,0x00,0x00,0x00,0x00,0x18,0x18,0x00,0x00,0x00,0x00,0x18,0x18,0x00,0x00],
    '-': [0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x7E,0x00,0x00,0x00,0x00,0x00,0x00,0x00],
    '.': [0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x60,0x60,0x00,0x00],
    '0': [0x00,0x00,0x00,0x18,0x24,0x42,0x42,0x42,0x42,0x42,0x42,0x42,0x24,0x18,0x00,0x00],
    '1': [0x00,0x00,0x00,0x08,0x38,0x08,0x08,0x08,0x08,0x08,0x08,0x08,0x08,0x3E,0x00,0x00],
    '2': [0x00,0x00,0x00,0x3C,0x42,0x42,0x42,0x02,0x04,0x08,0x10,0x20,0x42,0x7E,0x00,0x00],
    '3': [0x00,0x00,0x00,0x3C,0x42,0x42,0x02,0x04,0x18,0x04,0x02,0x42,0x42,0x3C,0x00,0x00],
    '4': [0x00,0x00,0x00,0x04,0x0C,0x0C,0x14,0x24,0x24,0x44,0x7F,0x04,0x04,0x1F,0x00,0x00],
    '5': [0x00,0x00,0x00,0x7E,0x40,0x40,0x40,0x78,0x44,0x02,0x02,0x42,0x44,0x38,0x00,0x00],
    '6': [0x00,0x00,0x00,0x18,0x24,0x40,0x40,0x5C,0x62,0x42,0x42,0x42,0x22,0x1C,0x00,0x00],
    '7': [0x00,0x00,0x00,0x7E,0x42,0x04,0x04,0x08,0x08,0x10,0x10,0x10,0x10,0x10,0x00,0x00],
    '8': [0x00,0x00,0x00,0x3C,0x42,0x42,0x42,0x24,0x18,0x24,0x42,0x42,0x42,0x3C,0x00,0x00],
    '9': [0x00,0x00,0x00,0x38,0x44,0x42,0x42,0x42,0x46,0x3A,0x02,0x02,0x24,0x18,0x00,0x00]
# 显示中文
def display_zh_character(character, x, y):
    num_list = character_dict[character]
    for i in range(16):
        left = bin(num_list[i]).replace('0b', '')
        right = bin(num_list[i + 16]).replace('0b', '')
        # 补 0
        while len(left) < 8:
            left = '0' + left
        while len(right) < 8:
            right = '0' + right
        num_binary = left+right
        for j in range(len(num_binary)):
            oled.pixel(x + j, y + i, int(num_binary[j]))
# 显示英文、数字和其他符号
def display_en_character(character, x, y):
    for i in range(16):
        # 补 0
            left = '0' + left
        num_binary = left
def display_zh(text, x, y):
    for i in range(len(text)):
        display_zh_character(text[i], x + i * 16, y)
def display_en(text, x, y):
        display_en_character(text[i], x + i * 8, y)
while True:
    oled.fill(0)
    display_zh('得捷第三期', 25, 3)
视频:
b9cca6a877b114eaa5f39662880dcf31
0f330bc0d8e48c916a5dd511728552ee
任务3:控制蜂鸣器播放音乐(必做任务)
使用Seeed Studio XIAO ESP32C3控制蜂鸣器发出不同频率的声音,并播放一段音乐
利用板载蜂鸣器实现:
通过控制PWM频率来实现不同的音符,并且通过音符的延时来控制节奏。
关键代码:
NOTE_C4 = 262
NOTE_D4 = 294
NOTE_E4 = 330
NOTE_F4 = 349
NOTE_G4 = 392
NOTE_A4 = 440
NOTE_B4 = 494
NOTE_C5 = 523
NOTE_D5 = 587
NOTE_E5 = 659
NOTE_F5 = 698
NOTE_G5 = 784
NOTE_A5 = 880
NOTE_B5 = 988
# Music notes of the song, 0 is a rest/pulse
notes = [
    NOTE_E4, NOTE_G4, NOTE_A4, NOTE_A4, 0,
    NOTE_A4, NOTE_B4, NOTE_C5, NOTE_C5, 0,
    NOTE_C5, NOTE_D5, NOTE_B4, NOTE_B4, 0,
    NOTE_A4, NOTE_G4, NOTE_A4, 0,
    NOTE_A4, NOTE_C5, NOTE_D5, NOTE_D5, 0,
    NOTE_D5, NOTE_E5, NOTE_F5, NOTE_F5, 0,
    NOTE_E5, NOTE_D5, NOTE_E5, NOTE_A4, 0,
    NOTE_A4, NOTE_C5, NOTE_B4, NOTE_B4, 0,
    NOTE_C5, NOTE_A4, NOTE_B4, 0,
    NOTE_A4, NOTE_A4,
    #Repeat of first part
    #End of Repeat
    NOTE_E5, 0, 0, NOTE_F5, 0, 0,
    NOTE_E5, NOTE_E5, 0, NOTE_G5, 0, NOTE_E5, NOTE_D5, 0, 0,
    NOTE_D5, 0, 0, NOTE_C5, 0, 0,
    NOTE_B4, NOTE_C5, 0, NOTE_B4, 0, NOTE_A4,
# Durations (in ms) of each music note of the song
# Quarter Note is 250 ms when songSpeed = 1.0
durations = [
    125, 125, 250, 125, 125,
    125, 125, 375, 125,
    125, 125, 375, 125,
    125, 125, 125, 250, 125,
    250, 125, 250, 125,
    125, 125, 375, 375,
    250, 125,
    #Rpeat of First Part
    125, 125, 375, 125,
    125, 125, 375, 125,
    250, 125, 250, 125,
    125, 125, 375, 375,
    #End of Repeat
    250, 125, 375, 250, 125, 375,
    125, 125, 125, 125, 125, 125, 125, 125, 375,
    125, 125, 125, 125, 125, 500,
视频
2b4e64232be305c61f3c6e93fa7a9f16
任务4:连接WiFi网络(必做任务)
将Seeed Studio XIAO ESP32C3连接到WiFi网络,并访问互联网信息
搭配器件:Seeed Studio XIAO ESP32C3Seeed Studio Expansion Board Base for XIAORF ANT 2.4GHZ/5.5GHZ PCB TRACE
利用了ESP32的强大的网络功能,将外置天线连接到模块上的IPEX座了。
购买的这个天线似乎要好一点。
连接网络成功并正确获取到时间,并在 OLED 上显示当前时间,以1S的时间打印并在OLED上跳动。
核心代码:
# Execute the functions
scan_and_connect()
# 从时间服务器获取时间
ntptime.settime()
while True:
    # 获取当前时间戳,此处加了8小时的时区差
    current_time = utime.time() + 8 * 60 * 60
    print("Current Time:", current_time)
    # 将时间戳转换为本地时间
    local_time_value = utime.localtime(current_time)
    print("Local Time:", local_time_value)
    # 根据日期时间转换,便于打印和显示
    local_data = "{:02d}-{:02d}-{:02d}".format(local_time_value[0], local_time_value[1], local_time_value[2])
    local_time = "{:02d}:{:02d}:{:02d}".format(local_time_value[3], local_time_value[4], local_time_value[5])
    print(local_data)
    print(local_time)
    # 更新显示内容
    oled.fill(0)
    oled.text(local_data, 10, 25)
    oled.text(local_time, 10, 40)
    oled.show()
    # 延时1秒
    utime.sleep(1)
视频:
3c70c1b0ddc7e9d03ac982ea454cc72e
db30ecec3359a2c35902e09f67e88887
任务5:使用外部传感器(必做任务)
连接环境光传感器或温湿度传感器,获取传感器的数值,并转换成真实的物理量
搭配器件: Seeed Studio XIAO ESP32C3Seeed Studio Expansion Board Base for XIAO、 Grove - AHT20 I2C Industrial Grade Temperature and Humidity SensorGrove - Light Sensor v1.2
首先看连接方式:
温湿度传感器模块 连接至扩展板的 I2C 接口(开关旁边)。将 光传感器模块 连接至扩展板的 A0-D0 接口(蜂鸣器旁边)。
可以先找到ATH20的库文件,上传到开发板中,我是手动添加进去的。
库地址:https://pypi.org/search/?q=aht20
核心代码:
from machine import Pin, SoftI2C, ADC
import ssd1306
import utime
import time
from ahtx0 import AHT20
i2c = SoftI2C(scl=Pin(7), sda=Pin(6))
oled_width = 128
oled_height = 64
oled = ssd1306.SSD1306_I2C(oled_width, oled_height, i2c)
# 清空屏幕,并显示任务要求
oled.fill(0)
oled.text("ESP32 _ C3 fifth", 0, 0)
oled.text("ATH20:", 0, 16)
oled.text("Humi:", 0, 32)
oled.text("Light:", 0, 48)
oled.show()
# aht20
aht = AHT20(i2c)
# 光照部分
adc = ADC(Pin(2))
adc.atten(ADC.ATTN_11DB)
adc.width(ADC.WIDTH_12BIT)  #4095
while True:
    temp = aht.temperature
    humi = aht.relative_humidity
    light_adc = adc.read()
    # 计算光照强度单位Lux
    light_lux = light_adc * 350 * 1.0 / 4095
    # 算出电阻值单位K
    light_res = (4095 - light_adc) * 10.0 / light_adc
    print("Temp(°):\n");
    print('{:.2f}'.format(temp))
    print("Humi(%):\n");
    print('{:.2f}'.format(humi))
    print("Light(lux)\n");
    print('{:.2f}'.format(light_lux))
    print("Light(K)\n");
    print('{:.2f}'.format(light_res))
    # 清除变化部分的内容
    oled.fill_rect(64,16,64,48,0)
    oled.text('{:.2f}'.format(temp), 64, 16)
    oled.text('{:.2f}'.format(humi), 64, 32)
    oled.text('{:.2f}'.format(light_lux), 64, 48)
    oled.show()
    # 延时1秒
    time.sleep(1)
视频:
b99ac0d756a05bc1eda47db565b96d69
相关连接:
MicroPython for ESP32C3 | Seeed Studio Wiki
2. OLED屏幕显示文字 (itprojects.cn)
类 WLAN – 控制内置 WiFi 接口 — MicroPython中文 1.17 文档
Python & CircuitPython | Adafruit AHT20 Temperature & Humidity Sensor | Adafruit Learning System
这个似乎是官方连接:
Seeed Studio XIAO ESP32C3 - 完整的Wi-Fi子系统和BLE(蓝牙低功耗)功能,支持电池充电,超低功耗模式,丰富的接口 - Seeed Studio
找管理要个模版,省的后期还要改     详情 回复 发表于 2023-11-24 11:35
6534
找管理要个模版,省的后期还要改
在爱好的道路上不断前进,在生活的迷雾中播撒光引
