3174|4
97
[dm9000a ping 不通] [复制链接]
在x86架构下,vxworks系统,增加dm9000a网卡,现象:ping不通,打印信息输出显示是每次都会进入Link Status change 那个中断,我在该中断中读状态,表明链接是成功的,能读到网卡的速度100M,以及模式,full。muxShow ,ifShow均能看到网卡的信息。知道是什么原因?
调用muxShow和ifShow后的信息如下: > muxShow Current mode: NORMAL Device: fei Unit: 0 Description: Intel 82557 Ethernet Enhanced Network Driver Protocol: IP 4.4 ARP    Type: 2054    Recv 0x390500    Shutdown 0x390930 Protocol: IP 4.4 TCP/IP    Type: 2048    Recv 0x390500    Shutdown 0x3907f0 Device: dm Unit: 0 Description: DM9000A Ethernet Enhanced Network Driver Protocol: IP 4.4 ARP    Type: 2054    Recv 0x390500    Shutdown 0x390930 Protocol: IP 4.4 TCP/IP    Type: 2048    Recv 0x390500    Shutdown 0x3907f0 value = 0 = 0x0 -> ifShow"dm" dm (unit number 0):     Flags: (0x8963) UP BROADCAST RUNNING ARP PROMISCUOUS MULTICAST     Type: ETHERNET_CSMACD     Internet address: 192.168.22.7     Broadcast address:   192.168.22.255     Netmask 0xffffff00 Subnetmask 0xffffff00     Ethernet address is 00:01:02:03:04:05     Metric is 0     Maximum Transfer Unit size is 1500     0 packets received; 1 packets sent     0 multicast packets received     0 multicast packets sent     0 input errors; 0 output errors     0 collisions; 0 dropped value = 0 = 0x0 然后ping 包,发现先进入link status changed的中断,然后进入收中断,包的状态信息显示: 0xf6d1478 (tNetTask): crc error  ! 0xf6d1478 (tNetTask): Physical Layer error ! (我是用logMsg输出的打印信息) 各位大大,知道是什么原因么?  详情 回复 发表于 2010-1-22 14:18
77
对应的网关地址和子网掩码 设置对吗?
90
我的子网掩码0xffffff00
dm9000a的收中断有产生,但状态显示:crc出错和physic layer出错,哪出错了?
63
> muxShow
Device: fei Unit: 0
Device: dm Unit: 0
value = 0 = 0x0
-> ifShow"dm"
dm (unit number 0):
    Metric is 0
value = 0 = 0x0
(我是用logMsg输出的打印信息)
各位大大,知道是什么原因么?
