1206|7
【极海APM32F407】5,跑一下内部温度传感器例子 [复制链接]
极海的这款芯片,在ADC1也有温度传感器。
而且例程中使能了DMA功能:
void DMA_Init(uint32_t* Buf)
    /* DMA Configure */
    DMA_Config_T dmaConfig;
    /* Enable DMA clock */
    RCM_EnableAHB1PeriphClock(RCM_AHB1_PERIPH_DMA2);
    /* size of buffer*/
    dmaConfig.bufferSize = 1;
    /* set memory Data Size*/
    dmaConfig.memoryDataSize = DMA_MEMORY_DATA_SIZE_HALFWORD;
    /* Set peripheral Data Size*/
    dmaConfig.peripheralDataSize = DMA_PERIPHERAL_DATA_SIZE_HALFWORD;
    /* Enable Memory Address increase*/
    dmaConfig.memoryInc = DMA_MEMORY_INC_DISABLE;
    /* Disable Peripheral Address increase*/
    dmaConfig.peripheralInc = DMA_PERIPHERAL_INC_DISABLE;
    /* Reset Circular Mode*/
    dmaConfig.loopMode = DMA_MODE_CIRCULAR;
    /* set priority*/
    dmaConfig.priority = DMA_PRIORITY_HIGH;
    /* read from peripheral*/
    dmaConfig.dir = DMA_DIR_PERIPHERALTOMEMORY;
    /* Set memory Address*/
    dmaConfig.memoryBaseAddr = (uint32_t)Buf;
    /* Set Peripheral Address*/
    dmaConfig.peripheralBaseAddr = (uint32_t)&ADC1->REGDATA;
    dmaConfig.channel = DMA_CHANNEL_0;
    dmaConfig.fifoMode = DMA_FIFOMODE_DISABLE;
    dmaConfig.fifoThreshold = DMA_FIFOTHRESHOLD_FULL;
    dmaConfig.peripheralBurst = DMA_PERIPHERALBURST_SINGLE;
    dmaConfig.memoryBurst = DMA_MEMORYBURST_SINGLE;
    DMA_Config(DMA2_Stream0, &dmaConfig);
    /* Clear DMA TF flag*/
    DMA_ClearIntFlag(DMA2_Stream0, DMA_INT_TCIFLG0);
    /* Enable DMA Interrupt*/
    DMA_EnableInterrupt(DMA2_Stream0, DMA_INT_TCIFLG);
    DMA_Enable(DMA2_Stream0);
那么在主循环中就判断DMA有没有数据就行了,有就执行串口打印功能:
while (1)
        if (DMA_ReadStatusFlag(DMA2_Stream0, DMA_FLAG_TCIFLG0))
            DataBuf = DMA_ConvertedValue;
            VSensorValue = (float)DataBuf/4095*3.3;
             * According to actual test data of multiple bathes of chips,
             * V28 is adopted instead of V25 for this example. And 0.7782v is the voltage for 28¡æ
            TSensorValue = (VSensorValue - 0.7782f)/0.0024f + 28;
            printf("\r\n");
            printf("ADC REGDATA = 0x%04X \r\n", DataBuf);
            printf("Volatage    = %f V \r\n", VSensorValue);
            printf("Temperature    = %f ¡æ \r\n", TSensorValue);
            Delay(0xFFFFFF);
            DMA_ClearStatusFlag(DMA2_Stream0, DMA_FLAG_TCIFLG0);
以下是运行结果,由于没有串口线引出,只有打断点来观察。
多谢版主大大解答,非常感谢!   详情 回复 发表于 2023-6-1 22:26
7244
内部温度传感器应该还算精准吧?
还行,刚上电10来度,跑一跑20来度  详情 回复 发表于 2023-5-31 09:26
wangerxian 发表于 2023-5-31 09:11 内部温度传感器应该还算精准吧?
还行,刚上电10来度,跑一跑20来度
7244
ddllxxrr 发表于 2023-5-31 09:26 还行,刚上电10来度,跑一跑20来度
上电才十来度?这检测不等于环境温度?
等晚上再好好看看,应该是芯片温度  详情 回复 发表于 2023-5-31 12:46
wangerxian 发表于 2023-5-31 09:51 上电才十来度?这检测不等于环境温度?
等晚上再好好看看,应该是芯片温度
7048
对比环境温度差距大不大,可以做日常的温度使用吗?
好似不可以,测外界温度用NTC就是热敏电阻十分容易,片上温度只能测机箱内温度  详情 回复 发表于 2023-6-1 20:29
lugl4313820 发表于 2023-6-1 07:49 对比环境温度差距大不大,可以做日常的温度使用吗?
7048
ddllxxrr 发表于 2023-6-1 20:29 好似不可以,测外界温度用NTC就是热敏电阻十分容易,片上温度只能测机箱内温度
多谢版主大大解答,非常感谢!
