3005|6
怎么支持大容量SD卡 [复制链接]
使用wince 6   打上r2及到2009。4月的所有补丁
硬件:S3C2443
以下是调试过程中的输出:
SendCommand (0xd2998b60, 0x0005, 0x00000000, 0x0005, 0x0) starts
CreaGetCommandResponse returned SD_API_STATUS_RESPONSE_TIMEOUT (COMMAND_TIMED_OUT)!
SendCommand (0xd2998b60, 0x0000, 0x00000000, 0x0000, 0x0) starts
SendCommand (0xd2998b60, 0x0008, 0x0000015a, 0x0008, 0x0) starts
*(vm_pSDIReg->SDIRSP0) = 0x15a
                              GetCommandResponse returned SD_API_STATUS_SUCCESS
SendCommand (0xd2998b60, 0x0001, 0x00300000, 0x0004, 0x0) starts
SendCommand (0xd2998b60, 0x0037, 0x00000000, 0x0001, 0x0) starts
*(vm_pSDIReg->SDIRSP0) = 0x400120
SendCommand (0xd2998b60, 0x0029, 0x40300000, 0x0004, 0x0) starts
*(vm_pSDIReg->SDIRSP0) = 0xff8000
INFO: Plug: Mapped Irq 0x3 to SendCommand (0xd2998b60, 0x0000, 0x00000000, 0x0000, 0x0) starts
*(vm_pSDIReg->SDIRSP0) = 0x120
SendCommand (0xd2998b60, 0x0029, 0x40100000, 0x0004, 0x0) starts
*(vm_pSDIReg->SDIRSP0) = 0xc0ff8000
SendCommand (0xd2998b60, 0x0002, 0x00000000, 0x0003, 0x0) starts
*(vm_pSDIReg->SDIRSP3) = 0x9900914f
                                   *(vm_pSDIReg->SDIRSP2) = 0x38b38fa5
        *(vm_pSDIReg->SDIRSP1) = 0x44303447
      *(vm_pSDIReg->SDIRSP0) = 0x2544d53
SendCommand (0xd2998b60, 0x0003, 0x00000000, 0x0007, 0x0) starts
*(vm_pSDIReg->SDIRSP0) = 0x6b940520
SendCommand (0xd2998b60, 0x0009, 0x6b940000, 0x0003, 0x0) starts
*(vm_pSDIReg->SDIRSP3) = 0xa400051
                                  *(vm_pSDIReg->SDIRSP2) = 0x1d877f80
        *(vm_pSDIReg->SDIRSP1) = 0x5b590000
     *(vm_pSDIReg->SDIRSP0) = 0x400e0032
SendCommand (0xd2998b60, 0x000d, 0x6b940000, 0x0001, 0x0) starts
*(vm_pSDIReg->SDIRSP0) = 0x700
SendCommand (0xd2998b60, 0x0007, 0x6b940000, 0x0002, 0x0) starts
SendCommand (0xd2998b60, 0x0037, 0x6b940000, 0x0001, 0x0) starts
*(vm_pSDIReg->SDIRSP0) = 0x920
SD_READ Dma 0x00000008, 0x0001
SendCommand (0xd2998b60, 0x0033, 0x00000000, 0x0001, 0x1) starts
SendCommand (0xd2998b60, 0x002a, 0x00000000, 0x0001, 0x0) starts
SendCommand (0xd2998b60, 0x0006, 0x00000002, 0x0001, 0x0) starts
SD_READ Dma 0x00000200, 0x0001
SendCommand (0xd2998b60, 0x0011, 0x00000000, 0x0001, 0x1) starts
*(vm_pSDIReg->SDIRSP0) = 0x900
SendCommand (0xd2998b60, 0x0011, 0x00400000, 0x0001, 0x1) starts
从回应信息*(vm_pSDIReg->SDIRSP0) = 0xc0ff8000看,可以知道该卡是sdhc卡。但结果启动wince 6后,看到存储卡。 那位DX指导一下
关于wince5 支持大容量SD卡的
http://support.microsoft.com/default.aspx/kb/933809
楼主怎么识别出来的啊????  详情 回复 发表于 2010-3-30 16:58
81
打补丁还是不行的,还要修改一些配置,环境变量以及驱动的一些命令。
59
Mark一下 一起学习
84
引用 1 楼 gooogleman 的回复:
在SendCommand函数中 添加ResponseR7,如下
    case ResponseR5:
    case ResponseR6:
    case ResponseR7:// 增加的行
            vm_pSDIReg->SDICCON = WAIT_FOR_RESPONSE | START_COMMAND | COMMAND_START_BIT | (Cmd & MAX_CMD_VALUE);
在GetCommandResponse函数中,添加
        case ResponseR1:
        case ResponseR1b:
        case ResponseR7://增加的行
            *(respBuff    ) = (BYTE)(START_BIT | TRANSMISSION_BIT | pRequest->CommandCode);
            *(respBuff + 1) = (BYTE)(vm_pSDIReg->SDIRSP0      );
            *(respBuff + 2) = (BYTE)(vm_pSDIReg->SDIRSP0 >> 8 );
            *(respBuff + 3) = (BYTE)(vm_pSDIReg->SDIRSP0 >> 16);
            *(respBuff + 4) = (BYTE)(vm_pSDIReg->SDIRSP0 >> 24);
            *(respBuff + 5) = (BYTE)(END_RESERVED | END_BIT);
还需要修改那些?我已经在catalog中选中了 SD bus Driver(IMGSDBUS2)
已经识别出来了  。
怎么识别的啊?,改哪个函数啊?WINCE500下?
61
引用 4 楼 zrz4066 的回复:
已经识别出来了 。
楼主怎么识别出来的啊????
