7937|14
56
版主在没?为什么串口接受超过8个字节就出错啊? [复制链接]
//设置串口读写时间
COMMTIMEOUTS CommTimeOuts;
GetCommTimeouts (m_hComm, &CommTimeOuts);
CommTimeOuts.ReadIntervalTimeout = MAXDWORD;
CommTimeOuts.ReadTotalTimeoutMultiplier = 0;
CommTimeOuts.ReadTotalTimeoutConstant = 0;
CommTimeOuts.WriteTotalTimeoutMultiplier = 10;
CommTimeOuts.WriteTotalTimeoutConstant = 1000;
if(!SetCommTimeouts( m_hComm, &CommTimeOuts ))
TRACE( _T("SetCommTimeouts 返回错误") );
//关闭串口
CloseHandle (m_hComm);
m_hComm = INVALID_HANDLE_VALUE;
return FALSE;
//指定端口监测的事件集
SetCommMask (m_hComm, EV_RXCHAR);
//分配串口设备缓冲区
SetupComm(m_hComm,512,512);
//初始化缓冲区中的信息
PurgeComm(m_hComm,PURGE_TXCLEAR|PURGE_RXCLEAR);
关键代码如下,读线程中
        //清空串口
PurgeComm(ceSeries->m_hComm, PURGE_RXCLEAR | PURGE_TXCLEAR );
SetCommMask (ceSeries->m_hComm, EV_RXCHAR | EV_CTS | EV_DSR );
while (TRUE)
if (WaitCommEvent(ceSeries->m_hComm,&evtMask,0))
删除这句可以接受大于16进制的数据,但是是错误的。保留则只收得到8个字节的数据,数据正确举例:16个字节,第一次只能读8个,正确,第2次读8个,也正确,改成GetCommMask效果一样,
//表示串口收到字符
if (evtMask & EV_RXCHAR)
ClearCommError(ceSeries->m_hComm,&dwReadErrors,&cmState);
willReadLen = cmState.cbInQue ;
if (willReadLen <= 0)
continue;
//分配内存
readBuf = new BYTE[willReadLen];
ZeroMemory(readBuf,willReadLen);
//读取串口数据
ReadFile(ceSeries->m_hComm, readBuf, willReadLen, &actualReadLen,0);
我也遇到相同的问题了,谢谢楼主!  详情 回复 发表于 2010-6-5 18:18
55
来人啊,救人啊
53
找个例子参考一下
程序串口参考的Windows CE嵌入式高级编程及其实例详解(用C++实现)中的串口编程,现在问题了,问下大家遇见过没?怎么样解决的?
75
我顶
ding
83
给你个参考代码,你这应该是前面的初始化有问题
// 定义串口设置参数表格
const CString PorTbl[6] = {_T("COM1:"),_T("COM2:"),_T("COM3:"),_T("COM4:"),_T("COM5:"), _T("COM6:")};
const DWORD BaudTbl[6] = {4800, 9600, 19200, 38400, 57600,115200};
const DWORD DataBitTbl[2] = {7, 8};
const BYTE  StopBitTbl[3] = {ONESTOPBIT, ONE5STOPBITS, TWOSTOPBITS};
const BYTE  ParityTbl[4] = {NOPARITY, ODDPARITY, EVENPARITY, MARKPARITY};
BOOL CSerialPortDlg::OnInitDialog()
        CDialog::OnInitDialog();
        // Set the icon for this dialog.  The framework does this automatically
        //  when the application's main window is not a dialog
        SetIcon(m_hIcon, TRUE);                        // Set big icon
        SetIcon(m_hIcon, FALSE);                // Set small icon
        CenterWindow(GetDesktopWindow());        // center to the hpc screen
        // TODO: Add extra initialization here
        m_ComboBaud.SetCurSel(5);                        /* 默认波特率为: 115200 */
        m_ComboData.SetCurSel(1);                        /* 默认数据位为: 8位 */
        m_ComboParity.SetCurSel(0);                        /* 默认校验为: 无 */
        m_ComboPort.SetCurSel(0);                        /* 默认端口为: COM1 */
        m_ComboStop.SetCurSel(0);                        /* 默认停止位为: 1位 */
        m_ButClose.EnableWindow(FALSE);                /* "关闭端口"按键无效 */
        m_hComm = INVALID_HANDLE_VALUE;                /* 串口操作句柄无效 */
        m_ExitThreadEvent = NULL;                        /* 串口接收线程退出事件无效 */
        m_strRecDisp = _T("");                                /* 接收显示字符为空 */
        UpdateData(FALSE);                                // 更新显示
        return TRUE;  // return TRUE  unless you set the focus to a control
函数名称: CSerialPortDlg::OnDestroy
描    述: 窗口销毁事件处理函数
输入参数: 无
输出参数: 无
返    回: 无
void CSerialPortDlg::OnDestroy()
        CDialog::OnDestroy();
        // TODO: Add your message handler code here
函数名称: CALLBACK CSerialPortDlg::OnCommRecv
描    述: 串口接收数据成功回调函数
输入参数: 无
输出参数: 无
返    回: FALSE: 失败;    TRUE: 成功
void CALLBACK CSerialPortDlg::OnCommRecv(CWnd* pWnd, char *buf, int buflen)
{        CString tmp;
        CSerialPortDlg * pDlg = (CSerialPortDlg*)pWnd;
        CEdit *pRecvStrEdit = (CEdit*)pDlg->GetDlgItem(IDC_REC_DISP);
        /* 取得控件指针 */
        for (int i = 0; i < buflen; i++, buf++)
                tmp.Format(_T("%c"), *buf);                                                /* 将字符转换为字符串 */
                pDlg->m_strRecDisp += tmp;
        pRecvStrEdit->SetWindowText(pDlg->m_strRecDisp);        /* 显示在窗口上 */
函数名称: CSerialPortDlg::CommRecvTread
描    述: 串口接收线程
输入参数: LPVOID lparam: 线程参数,创建线程时传入
输出参数: 无
返    回: 0: 线程退出, 返回值没特殊含义
DWORD CSerialPortDlg::CommRecvTread(LPVOID lparam)
        DWORD dwLength;
        char *recvBuf = new char[1024];
        CSerialPortDlg *pDlg = (CSerialPortDlg*)lparam;
        while(TRUE)
        {        /* 等待线程退出事件 */
                if (WaitForSingleObject(pDlg->m_ExitThreadEvent, 0) == WAIT_OBJECT_0)
                        break;
                if (pDlg->m_hComm != INVALID_HANDLE_VALUE)
                {        /* 从串口读取数据 */
                        BOOL fReadState = ReadFile(pDlg->m_hComm, recvBuf, 1024, &dwLength, NULL);
                        if(!fReadState)
                                //MessageBox(_T("无法从串口读取数据!"));
                        else
                                if(dwLength != 0)
                                        OnCommRecv(pDlg, recvBuf, dwLength);                        /* 接收成功调用回调函数 */
        delete[] recvBuf;
        return 0;
函数名称: CSerialPortDlg::OpenPort
描    述: 打开串口
输入参数: LPCTSTR Port: 串口名,如"COM0:","COM1:"
                  int BaudRate: 波特率
                  int DataBits: 数据位, 取值为7或8
                  int StopBits: 停止位
                  int Parity  : 奇偶校验位
输出参数: 无
BOOL CSerialPortDlg::OpenPort(LPCTSTR Port, int BaudRate, int DataBits, int StopBits, int Parity)
        // 打开串口
        m_hComm = CreateFile(Port, GENERIC_READ | GENERIC_WRITE, 0, 0, OPEN_EXISTING, 0, 0);
        if(m_hComm == INVALID_HANDLE_VALUE)
                MessageBox(_T("无法打开端口或端口已打开! 请检查是否已被占用, 例如GPRS占用UART0."));
                return FALSE;
        GetCommState(m_hComm, &dcb);                                                /* 读取串口的DCB */
        dcb.BaudRate = BaudRate;
        dcb.ByteSize = DataBits;
        dcb.Parity = Parity;
        dcb.StopBits = StopBits;
        dcb.fParity = FALSE;        /* 禁止奇偶校验 */
        dcb.fBinary = TRUE;
        dcb.fDtrControl = 0;        /* 禁止流量控制 */
        dcb.fRtsControl = 0;
        dcb.fOutX = 0;
        dcb.fInX = 0;
        dcb.fTXContinueOnXoff = 0;
        //设置状态参数
        SetCommMask(m_hComm, EV_RXCHAR);                                        /* 串口事件:接收到一个字符 */
        SetupComm(m_hComm, 16384, 16384);                                        /* 设置接收与发送的缓冲区大小 */
        if(!SetCommState(m_hComm, &dcb))                                        /* 设置串口的DCB */
                MessageBox(_T("无法按当前参数配置端口,请检查参数!"));
                ClosePort();
                return FALSE;
        //设置超时参数
        GetCommTimeouts(m_hComm, &CommTimeOuts);
        CommTimeOuts.ReadIntervalTimeout = 100;                                /* 接收字符间最大时间间隔 */
        CommTimeOuts.ReadTotalTimeoutMultiplier = 1;
        CommTimeOuts.ReadTotalTimeoutConstant = 100;                /* 读数据总超时常量 */
        CommTimeOuts.WriteTotalTimeoutMultiplier = 0;
        CommTimeOuts.WriteTotalTimeoutConstant = 0;
        if(!SetCommTimeouts(m_hComm, &CommTimeOuts))
                MessageBox(_T("无法设置超时参数!"));
                ClosePort();
                return FALSE;
        PurgeComm(m_hComm, PURGE_TXCLEAR | PURGE_RXCLEAR);         /* 清除收/发缓冲区 */
        return TRUE;
函数名称: CSerialPortDlg::OnOpenCom
描    述: "打开端口" 按键单击事件代码
输入参数: 无
输出参数: 无
返    回: 无
void CSerialPortDlg::OnOpenCom()
        // TODO: Add your control notification handler code here
        DWORD IDThread;
        HANDLE hRecvThread;        /* 接收线程句柄 */
        UpdateData(TRUE);
        CString strPort = PorTbl[m_ComboPort.GetCurSel()];                                /* 查表获取参数值 */
        DWORD baud                = BaudTbl[m_ComboBaud.GetCurSel()];
        DWORD databit   = DataBitTbl[m_ComboData.GetCurSel()];
        BYTE stopbit    = StopBitTbl[m_ComboStop.GetCurSel()];
        BYTE parity                = ParityTbl[m_ComboParity.GetCurSel()];
        BOOL ret = OpenPort(strPort, baud, databit, stopbit, parity);        /* 打开串口 */
        if (ret == FALSE)
                return;
        m_ExitThreadEvent = CreateEvent(NULL, TRUE, FALSE, NULL);                /* 创建串口接收线程退出事件*/
        // 创建串口接收线程
        hRecvThread = CreateThread(0, 0, CommRecvTread, this, 0, &IDThread);
        if (hRecvThread == NULL)
                MessageBox(_T("创建接收线程失败!"));
                return;
        CloseHandle(hRecvThread);
        m_ButOpen.EnableWindow(FALSE);        /* 打开端口按键禁止 */
        m_ButClose.EnableWindow(TRUE);        /* 关闭端口按键使能 */
        MessageBox(_T("打开") + strPort + _T("成功!"));
函数名称: CSerialPortDlg::ClosePort
描    述: 关闭串口
输入参数: 无
输出参数: 无
BOOL CSerialPortDlg::ClosePort()
        if(m_hComm != INVALID_HANDLE_VALUE)
                SetCommMask(m_hComm, 0);
                PurgeComm(m_hComm, PURGE_TXCLEAR | PURGE_RXCLEAR);        /* 清除收/发缓冲 */
                CloseHandle(m_hComm);        /* 关闭串口操作句柄 */
                return TRUE;
        return FALSE;
描    述: "关闭端口" 按键单击事件代码
输入参数: 无
输出参数: 无
返    回: 无
void CSerialPortDlg::OnCloseCom()
                if (m_ExitThreadEvent != NULL)
                SetEvent(m_ExitThreadEvent);                                        /* 通知线程退出 */
                Sleep(1000);
                CloseHandle(m_ExitThreadEvent);
        m_ButOpen.EnableWindow(TRUE);                                                /* 打开端口按键禁止 */
        m_ButClose.EnableWindow(FALSE);                                                /* 关闭端口按键使能 */
        ClosePort();
函数名称: CSerialPortDlg::OnSend
描    述: "发送" 按键单击事件代码
输入参数: 无
输出参数: 无
返    回: 无
void CSerialPortDlg::OnSend()
                DWORD dwactlen;
        if (m_hComm == INVALID_HANDLE_VALUE)
                MessageBox(_T("串口未打开!"));
                return;
        UpdateData(TRUE);
        int len = m_strSendEdit.GetLength();                                 /* 取得输入字符串长度 */
        char *psendbuf = new char[len];
        for(int i = 0; i < len;i++)
                psendbuf = (char)m_strSendEdit.GetAt(i);                 /* 转换为单字节字符 */
        WriteFile(m_hComm, psendbuf, len, &dwactlen, NULL);         /* 从串口发送数据 */
        delete[] psendbuf;
函数名称: CSerialPortDlg::OnClearSend
描    述: "清除发送缓冲区" 按键单击事件代码
输入参数: 无
输出参数: 无
返    回: 无
void CSerialPortDlg::OnClearSend()
        m_strSendEdit = _T("");                                                        /* 清除发送区的字符 */
        UpdateData(FALSE);
函数名称: CSerialPortDlg::OnClearRec
描    述: "清除接收缓冲区" 按键单击事件代码
输入参数: 无
输出参数: 无
返    回: 无
void CSerialPortDlg::OnClearRec()
        SetDlgItemText(IDC_REC_DISP,m_strRecDisp);                /* 清除接收区的字符 */
82
//设置串口参数
        commParam.BaudRate = 19200;                // 设置波特率
        commParam.fBinary = TRUE;                // 设置二进制模式,此处必须设置TRUE
        commParam.fParity = FALSE;                // 支持奇偶校验
        commParam.ByteSize = 8;                        // 8位数据位
        commParam.Parity = NOPARITY;                // 无校验模式
        commParam.StopBits = ONESTOPBIT;        // 1位停止位
        commParam.fOutxCtsFlow = FALSE;                // No CTS output flow control
        commParam.fOutxDsrFlow = FALSE;                // No DSR output flow control
        commParam.fDtrControl = DTR_CONTROL_DISABLE; /* 禁止流量控制 */
        // DTR flow control type
        commParam.fDsrSensitivity = FALSE;        // DSR sensitivity
        commParam.fTXContinueOnXoff = FALSE;        // XOFF continues Tx
        commParam.fOutX = FALSE;                // No XON/XOFF out flow control
        commParam.fInX = FALSE;                        // No XON/XOFF in flow control
        commParam.fErrorChar = FALSE;                // Disable error replacement
        commParam.fNull = FALSE;                // Disable null stripping
        commParam.fRtsControl = RTS_CONTROL_DISABLE; // RTS flow control
        commParam.fAbortOnError = FALSE;        // 当串口发生错误,并不终止串口读写
我的DCB结构是这样的,应该没问题啊!!!
同样的代码在Pocket pc 2003中测试正常,是不是我的mini2440驱动有问题?
63
引用 8 楼 wswwxk 的回复:
PC上正常的东东,在CE下不一定正常
78
引用 8 楼 wswwxk 的回复:
你可以找个串口调试工具 测试一下 看看是不是驱动的问题 如果用串口调试工具测试没有问题,那就看你的应用程序吧
66
ding 精彩
85
才用wince串口调试助手测试了,接受正常,现在可以确定是应用程序的问题,大家帮忙看看,想下哪里的问题,我实在是找不出来了,项目急用啊,救我
87
问题解决了,回调函数初了问题,现在正常了,谢谢大家
75
我也遇到相同的问题了,谢谢楼主!
