2665|0
565
【GD32L233C-START评测】14、RT-Thread内核、finsh移植到GD32L233 [复制链接]
相关文章:
【GD32L233C-START评测】1、优点与缺点都很明显的GD32L233C-START(开箱)
【GD32L233C-START评测】2、非阻塞方式点灯,blink,blink,blink……
【GD32L233C-START评测】3、pwm实现呼吸灯
【GD32L233C-START评测】4、串口不定长数据接收
【GD32L233C-START评测】5、Flash读写——使用内部Flash存储数据
【GD32L233C-START评测】6、硬件I2C驱动0.96吋OLED
【GD32L233C-START评测】7、硬件SPI1驱动RC522
【GD32L233C-START评测】8、获取MCU96位唯一ID、SRAM、FLASH大小
【GD32L233C-START评测】9、IAP程序升级——基于YMODEM协议
【GD32L233C-START评测】10、使用内部参考电压校准adc,adc采样更准确
【GD32L233C-START评测】11、GD32 ISP软件还不支持GD32L233
【GD32L233C-START评测】12、按键——外部中断
【GD32L233C-START评测】13、I2C驱动环境光和接近传感器RPR-0521RS
1、安装RT-Thread keil Pack
或者离线下载安装
https://www.rt-thread.org/download/mdk/RealThread.RT-Thread.3.1.5.pack
2、在工程中勾选RTOS中的kernel shell
3、编译报错
4、配置时钟#error "TODO 1: OS Tick Configuration."
//   #error "TODO 1: OS Tick Configuration."
	SysTick_Config(SystemCoreClock / RT_TICK_PER_SECOND);
	NVIC_SetPriority(SysTick_IRQn, 0x00U);
void SysTick_Handler(void)
	void rt_os_tick_callback(void);
	rt_os_tick_callback();
5、配置串口#error "TODO 2: Enable the hardware uart and config baudrate."
//#error "TODO 2: Enable the hardware uart and config baudrate."
	extern	void SerialInit(void);
    SerialInit();
	/* enable COM GPIO clock */
    rcu_periph_clock_enable(RCU_GPIOA);
    /* enable USART clock */
    rcu_periph_clock_enable(RCU_USART0);
    /* connect port to USART TX */
    gpio_af_set(GPIOA, GPIO_AF_7, GPIO_PIN_9);
    /* connect port to USART RX */
    gpio_af_set(GPIOA, GPIO_AF_7, GPIO_PIN_10);
    /* configure USART TX as alternate function push-pull */
    gpio_mode_set(GPIOA, GPIO_MODE_AF, GPIO_PUPD_PULLUP, GPIO_PIN_9);
    gpio_output_options_set(GPIOA, GPIO_OTYPE_PP, GPIO_OSPEED_10MHZ, GPIO_PIN_10);
    /* configure USART RX as alternate function push-pull */
    gpio_mode_set(GPIOA, GPIO_MODE_AF, GPIO_PUPD_PULLUP, GPIO_PIN_10);
    /* USART configure */
    usart_deinit(USART0);
    usart_word_length_set(USART0, USART_WL_8BIT);
    usart_stop_bit_set(USART0, USART_STB_1BIT);
    usart_parity_config(USART0, USART_PM_NONE);
    usart_baudrate_set(USART0, 115200U);
    usart_receive_config(USART0, USART_RECEIVE_ENABLE);
    usart_transmit_config(USART0, USART_TRANSMIT_ENABLE);
    usart_enable(USART0);
6、串口输出#error "TODO 3: Output the string 'str' through the uart."
//#error "TODO 3: Output the string 'str' through the uart."
	extern void _rt_hw_console_output( const char *str );
	_rt_hw_console_output(str);
	rt_size_t i = 0, size = 0;
    char a = '\r';
    size = rt_strlen(str);
    for (i = 0; i < size; i++)
        if (*(str + i) == '\n')
            usart_data_transmit(USART0, (uint32_t )a);
            while((usart_flag_get(USART0, USART_FLAG_TC) == RESET));
        usart_data_transmit(USART0, (uint32_t)*(str + i));
7、串口输入#error "TODO 4: Read a char from the uart and assign it to 'ch'."
//#error "TODO 4: Read a char from the uart and assign it to 'ch'."
	extern char _rt_hw_console_getchar(void);
    ch= _rt_hw_console_getchar();
    /* the initial value of ch must < 0 */
    int ch = -1;
    if (usart_flag_get(USART0, USART_FLAG_RBNE) != RESET)
        ch = usart_data_receive(USART0);
    else
        rt_thread_mdelay(10);
    return ch;
8PendSV_HandlerHardFault_Handler重复定义
 PendSV_HandlerHardFault_Handler两个中断,RT-Thread系统处理,屏蔽掉gd32l23x_it.c中的即可。
9finsh_config.h未包含
rtconfig.h中包含finsh_config.h
10、创建led线程
static rt_thread_t led_thread = RT_NULL;
void LedInit(void)
	/* enable the LED GPIO clock */
    /* configure LED GPIO pin */
    gpio_mode_set(GPIOA, GPIO_MODE_OUTPUT, GPIO_PUPD_NONE, GPIO_PIN_7 | GPIO_PIN_8);
    gpio_output_options_set(GPIOA, GPIO_OTYPE_PP, GPIO_OSPEED_50MHZ, GPIO_PIN_7 | GPIO_PIN_8);
    /* reset LED GPIO pin */
    gpio_bit_reset(GPIOA, GPIO_PIN_7 | GPIO_PIN_8);
static void led_thread_entry(void *parameter)
    while (1)
		gpio_bit_toggle(GPIOA, GPIO_PIN_7|GPIO_PIN_8);
        rt_thread_mdelay(1000);
		rt_kprintf("led blink\r\n");
void LedThreadStart(void)
	led_thread = rt_thread_create( "led",     /*线程名字*/
							led_thread_entry,/*线程入口函数*/
							RT_NULL,/*线程入口函数参数*/
							256,    /*线程栈大小*/
							4 ,    /*线程优先级*/
							20);   /*线程时间片*/
	rt_thread_startup (led_thread);
11、硬件初始化
 rt_hw_board_init函数中包含led初始化函数。
12、在main函数中调用启动led线程
int main(void)
    LedThreadStart();
    return 0;
13、现象
此帖出自GD32 MCU论坛
个人签名stm32/LoRa物联网:304350312
