直接领略流水灯的乐趣吧!
/* Copyright 2004 by SEED Electronic Technology LTD. */
/* All rights reserved. SEED Electronic Technology LTD. */
/* Restricted rights to use, duplicate or disclose this code are */
/* granted through contract. */
#include <csl.h>
#include <csl_pll.h>
#include <csl_chip.h>
#include <csl_gpio.h>
#include <stdio.h>
void delay();
/*锁相环的设置*/
PLL_Config myConfig = {
0, //IAI: the PLL locks using the same process that was underway
//before the idle mode was entered
1, //IOB: If the PLL indicates a break in the phase lock,
//it switches to its bypass mode and restarts the PLL phase-locking //sequence
24, //PLL multiply value; multiply 24 times
1 //Divide by 2 PLL divide value; it can be either PLL divide value
//(when PLL is enabled), or Bypass-mode divide value
//(PLL in bypass mode, if PLL multiply value is set to 1)
void UserGpio(void)
int val;
/* Enable a pin as GPIO pin */
GPIO_pinEnable (GPIO_PIN1);
/* Write a value to a GPIO pin */
GPIO_pinWrite(GPIO_PIN1, 2);
/* Reads the value in a general purpose input pin */
val = GPIO_pinRead(GPIO_PIN1);
printf("Read GPIO_GPIO_PIN1 value = %d\n", val);
//printf("GPIO register address %d\n", GPIO_ADDR(val));
/* reads IOO and IO7 pin values */
val=GPIO_pinRead (GPIO_PIN0| GPIO_PIN1);
/* DiEnable a GPIO */
GPIO_pinDisable (GPIO_PIN1);
/* Writes value to non-parallel registers using GPIO_config */
//GPIO_config( myConfig);
main()
int i = 10;
/*初始化CSL库*/
CSL_init();
/*设置系统的运行速度为144MHz*/
PLL_config(&myConfig);
/*确定方向为输出*/
GPIO_RSET(IODIR,0xFF);
for(i = 0;i<0x0a;i++)
/*全亮*/
GPIO_RSET(IODATA,0xff);
delay();
/*全灭*/
GPIO_RSET(IODATA,0x0);
delay();
/*循环闪烁*/
for(i = 10; i >= 0; i--)
GPIO_RSET(IODATA,0x1);
delay();
delay();
GPIO_RSET(IODATA,0x2);
delay();
delay();
GPIO_RSET(IODATA,0x4);
delay();
delay();
GPIO_RSET(IODATA,0x8);
delay();
delay();
GPIO_RSET(IODATA,0x10);
delay();
delay();
GPIO_RSET(IODATA,0x40);
delay();
delay();
GPIO_RSET(IODATA,0x80);
delay();
delay();
UserGpio();
// 延时函数
void delay()
Uint32 j = 0,k = 0;
for(j = 0;j<0x0c;j++)
for(k= 0;k<0xffff;k++)
