2649|1
Micropython spectrometer (光谱仪) [复制链接]
来自:https://myspectral.com/project/lumini-t/
Lumini T Spectrometric Camera
Now available from stock!
USB Spectrometric camera. Ultrafast. Rugged. Multiplatform software, which will remain always free. Main applications are in light monitoring, chemical kinetics spectrometry or laser measurement. Spectrometer, radiometer, colorimeter fully programmable.
Lumini T can be operated from a PC, laptop, Raspberry Pi or other portable rigs.
The software is running in a web browser window, running on:=0.95emWindows 10
  • Linux (Debian 6 or newer, or Ubuntu 18 or newer are recommended)
  • Raspberry Pi, Raspian or Debian are recommended
Case study: a datalogger for outdoor measurements of light spectra
We have had the chance to collaborate in a programming / dancing workshop to create a fully portable and automated datalogger with automatic exposure for outdoor and indoor measurements.
As a result, video shows the overlay of realtime spectrum from trees, walls and vegetation on top of the elegant dance moves of a professional contemporary dancer. Improptu, no preparation.
The technical part took several hours. The video work and processing was longer than the actual technical work.
USB光谱仪,超快,坚固耐用,免费的多平台软件。主要应用于光监测、化学光谱分析或激光测量。光谱仪,辐射计,色度计完全可编程。Lumini T可以通过PC,笔记本电脑,Raspberry Pi或其他便携式设备进行操作。
软件在Web浏览器窗口中运行,可运行于:
  • Windows 10
  • Linux(建议使用Debian 6或更高版本,或Ubuntu 18或更高版本)
  • 建议使用Raspberry Pi,Raspian或Debian
技术指标 Lumini T,手持式USB光谱仪
测量 辐照度(PAR *),(NDVI *),(RGB *),CMYK *,X,Y *色温(CCT CIE 17.4-1987)*,显色指数CRI *,CQS *,CIE1931 *,CIE1976 *, C78.377-2008 *,IEC-SDCM *频谱图λp*,λD*
波长范围 340〜890纳米
光学分辨率 <8nm
波长精度 0.5纳米
测量时间 0.12ms〜10秒
内置光源 无,(*最多可内置三个光源,无法实现某些灯光组合)
电源 USB电缆供电,无内置电池
存储 microSD卡或USB2.0
尺寸 130长x 25宽x 25高毫米
重量 0.3公斤
更多图片
