6139|3
6892
串口转以太网代码怎样改进 [复制链接]
int main(void)
    unsigned long ulUser0, ulUser1;
    unsigned char pucMACAddr[8];
    unsigned long ulLoop;
    // If running on Rev A2 silicon, turn the LDO voltage up to 2.75V.  This is
    // a workaround to allow the PLL to operate reliably.
    if(REVISION_IS_A2)
        SysCtlLDOSet(SYSCTL_LDO_2_75V);
    // Set the processor to run at 50 MHz, allowing UART operation at up to
    // 3.125 MHz.
    SysCtlClockSet(SYSCTL_SYSDIV_4 | SYSCTL_USE_PLL | SYSCTL_OSC_MAIN |
                   SYSCTL_XTAL_8MHZ);
    // Enable the peripherals used by the application.
    SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOA);
    SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOB);
    SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOD);
    SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOF);
    SysCtlPeripheralEnable(SYSCTL_PERIPH_UART0);
    SysCtlPeripheralEnable(SYSCTL_PERIPH_UART1);
    SysCtlPeripheralEnable(SYSCTL_PERIPH_ETH);
    // Enable the peripherals that should continue to run when the processor
    // is sleeping.
    SysCtlPeripheralSleepEnable(SYSCTL_PERIPH_GPIOA);
    SysCtlPeripheralSleepEnable(SYSCTL_PERIPH_GPIOB);
    SysCtlPeripheralSleepEnable(SYSCTL_PERIPH_GPIOD);
    SysCtlPeripheralSleepEnable(SYSCTL_PERIPH_GPIOF);
    SysCtlPeripheralSleepEnable(SYSCTL_PERIPH_UART0);
    SysCtlPeripheralSleepEnable(SYSCTL_PERIPH_UART1);
    SysCtlPeripheralSleepEnable(SYSCTL_PERIPH_ETH);
    // Enable peripheral clock gating.  Note that this is required in order to
    // measure the the processor usage.
    SysCtlPeripheralClockGating(true);
    // Set the priorities of the interrupts used by the application.
    IntPrioritySet(INT_UART0, 0x00);
    IntPrioritySet(INT_UART1, 0x00);
    IntPrioritySet(INT_ETH, 0x20);
    IntPrioritySet(FAULT_SYSTICK, 0x40);
    // Configure SysTick for a periodic interrupt.
    SysTickPeriodSet(SysCtlClockGet() / SYSTICKHZ);
    SysTickEnable();
    SysTickIntEnable();
    // Enable Port F for Ethernet LEDs.
    //  LED0        Bit 3   Output
    //  LED1        Bit 2   Output
    GPIODirModeSet(GPIO_PORTF_BASE, GPIO_PIN_2 | GPIO_PIN_3, GPIO_DIR_MODE_HW);
    GPIOPadConfigSet(GPIO_PORTF_BASE, GPIO_PIN_2 | GPIO_PIN_3,
                     GPIO_STRENGTH_2MA, GPIO_PIN_TYPE_STD);
    // Set the link status based on the LED0 signal (which defaults to link
    // status in the PHY).
    g_bLinkStatusUp = GPIOPinRead(GPIO_PORTF_BASE, GPIO_PIN_3) ? false : true;
    // Initialize the configuration parameter module.
    ConfigInit();
    // Get the MAC address from the UART0 and UART1 registers in NV ram.
    FlashUserGet(&ulUser0, &ulUser1);
    // Convert the 24/24 split MAC address from NV ram into a MAC address
    // array.
    pucMACAddr[0] = ulUser0 & 0xff;
    pucMACAddr[1] = (ulUser0 >> 8) & 0xff;
    pucMACAddr[2] = (ulUser0 >> 16) & 0xff;
    pucMACAddr[3] = ulUser1 & 0xff;
    pucMACAddr[4] = (ulUser1 >> 8) & 0xff;
    pucMACAddr[5] = (ulUser1 >> 16) & 0xff;
    // Initialize the lwIP TCP/IP stack.
    lwIPInit(pucMACAddr, g_sParameters.ulStaticIP, g_sParameters.ulSubnetMask,
             g_sParameters.ulGatewayIP, ((g_sParameters.ucFlags &
             CONFIG_FLAG_STATICIP) ? IPADDR_USE_STATIC : IPADDR_USE_DHCP));
    // Setup the device locator service.
    LocatorInit();
    LocatorMACAddrSet(pucMACAddr);
    LocatorAppTitleSet((char *)g_sParameters.ucModName);
    // Initialize the serial port module.
    SerialInit();
    // Initialize the telnet module.
    TelnetInit();
    // Initialize the UPnP session.
    UPnPInit();
    // Initialize the HTTPD web server.
    httpd_init();
    // Configure SSI and CGI processing for our configuration web forms.
    ConfigWebInit();
    // Start the remote software update module.
    SoftwareUpdateInit(SoftwareUpdateRequeSTCallback);
    // Wait for an IP address to be assigned to the board before we try to
    // initiate any connections.
    while(!lwIPLocalIPAddrGet())
        // Do nothing until we get our IP address assigned.
        SysCtlSleep();
    // Initialize the telnet session(s).
    for(ulLoop = 0; ulLoop < MAX_S2E_PORTS; ulLoop++)
        // Are we to operate as a telnet server?
        if((g_sParameters.sPort[ulLoop].ucFlags & PORT_FLAG_TELNET_MODE) ==
           PORT_TELNET_SERVER)
            // Yes - start listening on the required port.
            TelnetListen(g_sParameters.sPort[ulLoop].usTelnetLocalPort,
                         ulLoop);
        else
            // No - we are a client so initiate a connection to the desired
            // IP address using the configured ports.
            TelnetOpen(g_sParameters.sPort[ulLoop].ulTelnetIPAddr,
                       g_sParameters.sPort[ulLoop].usTelnetRemotePort,
                       g_sParameters.sPort[ulLoop].usTelnetLocalPort, ulLoop);
    // Main Application Loop (for systems with no RTOS).  Run every SYSTICK.
    while(true)
        // Wait for an event to occur.
        SysCtlSleep();
        // Check for an IP update request.
        if(g_bChangeIPAddress == true)
            // Delay 2 seconds or so to allow the response page to get back
            // to the browser before we initiate the IP address change.
            SysCtlDelay((SysCtlClockGet() / 3) * 2);
            // Actually update the IP address.
            g_bChangeIPAddress = false;
            ConfigUpdateIPAddress();
        // Check for bootloader request.
        if((g_bStartBootloader == true) || (g_bFirmwareUpdate == true))
            // Delay a couple of seconds to let any pending web server
            // transmission to complete.  Each loop within SysCtlDelay is
            // 3 instructions long so this delays approximately 2 seconds.
            // Initiate the Software Update Process in the Ethernet
            // Bootloader.
            SoftwareUpdateBegin();
            // Should never get here, but stall just in case.
            while(1)
用上述代码解决下面的问题:
      解决以下问题:
1.串口收数并处理,然后通过网口传输出去。
2.网口收数处理,然后从串口发出。
不明白你的目的,改成啥样啊  详情 回复 发表于 2010-9-30 16:19
个人签名一个为理想不懈前进的人,一个永不言败人!
欢迎光临网上店铺!
6892
大虾们,赶快帮我分析分析!等你们支招啊!
欢迎光临网上店铺!
2641
收发用中断,放缓冲区,主线程中处理就行了,我就是这样做的,现在双工1M都没有问题了,上位机编了个虚拟串口,当透明串口传输用
不明白你的目的,改成啥样啊
