3041|2
1602的显示程序,为什么我的第一行没有显现,而第二行正常呢?
#include
#define uint unsigned int
#define uchar unsigned char
sbit wei=P2^7;
sbit duan=P2^6;
sbit rs=P3^5;
sbit leden=P3^4;
uchar num;
uchar code  table1[]="zhao yao"; //中括号中不可以加参数;
uchar code  table2[]="zhao yao";
void init();
void write_data(uchar);
void write_com(uchar);
void delay(uchar z);
void main()
init();
for(num=0;num<8;num++)
  write_data(table1[num]);
  delay(10);
write_com(0x80+0x40);
  write_data(table2[num]);
  delay(10);
while(1); //此步切不可少
void init()
wei=1;
P0=0xff;
wei=0;
duan=1;
P0=0x00;
duan=0;
leden=0;
write_com(0x38);
write_com(0x0f);
write_com(0x06);
write_com(0x01);//显示清屏
write_com(0x80);//数据指针设置
void write_data( uchar date)
rs=1;
P0=date;
delay(1);
leden=1;
delay(5);
leden=0;
delay(2);
void write_com(uchar com)
rs=0;
P0=com;
delay(1);
leden=1;
delay(5);
leden=0;
delay(2);
void delay(uchar z)
uchar x,y;
for(x=0;x for(y=0;y<110;y--);
此帖出自单片机论坛
路过,学习!  详情 回复 发表于 2009-3-14 10:41
SORRY
void delay(uchar z)
uchar x,y;
很明显的错误,改了它,就好了
此帖出自单片机论坛
赞赏
查看全部赞赏
56
Re: [求助] 1602
路过,学习!
此帖出自单片机论坛
