3405|1
2721
LM4F120上电及驱动安装 [复制链接]
接上一篇帖子
【新提醒】LM4F120到手 - 【最爱TI M4】 - 电子工程世界-论坛 https://bbs.eeworld.com.cn/thread-500372-1-1.html
上电后,绿色LED亮,D1是RGB,一直变换,蓝-红-黄-绿,指南介绍有个Hibernation功能,是休眠模式吗?按下SW1、SW2 3S,进入该模式,此时你会看到LED是每三秒闪烁下,之前是连续变化,按下SW2,退出该模式
电脑显示驱动安装失败,
到官网找驱动,重新安装
好了
看到官网开发环境除CCS等常用IDE外还介绍了如下几款,不知道大家有没有用过,mentor也加入到嵌入式阵营了
Atollic TrueSTUDIO
  • Highly powerful Eclipse-based C/C++ compiler and debugger IDE
  • Advanced dual-core debugger with SWV/ETM tracing and crash analyzer
  • Features for software engineering, team collaboration, and improved software quality
  • Supports TI ARM Cortex-M microcontrollers
Sourcery CodeBench from Mentor Embedded
  • Includes compilers, run-time libraries, source- and assembly-level debugger, and more
  • GNU/Linux library optimizer, application simulator and dynamic linker simplify GNU/Linux system footprint
  • Project wizard speeds start-up and initial design
2721
进入hibernate模式,串口输出如下
退出hibernate模式
复位输出信息
