4317|11
7815
57
裸片初长成(中级)
【DIY?强势插广告】lualualua........ [复制链接]
原谅我头一回做了个可耻的搬运工~~~~
不过,从github上搬运,好歹也显得比较高大上一点点
eLua - Lua for microcontrollers
eLua stands for Embedded Lua and the project aims to offer the full implementation of the Lua Programming Language to the embedded world, extending it with specific features for efficient and portable software embedded development. For more details please visit the project page.
If you’ve just downloaded eLua and are looking to get started check out using eLua.
General Features
eLua allows you to develop and run Lua programs on a wide variety of microcontrollers.
Some aspects of eLua are:
  • Transforms hardware into a commodity: Design and code your products for eLua and make them as hardware-independent as possible. Upgrade or completely change your hardware in the future and save time and money, using the approved source code with little or no modifications.
  • Source code portability: Like in Lua, you program in C, Lua or a mixture of both and your program runs in a wide varied of (sometimes radically different) platforms and architectures supported. Full control of the platform.: eLua runs on the "bare-metal". There is no Operating System between your programs and the microcontroller. Develop on targets: fully functional Lua and a dedicated shell on the microcontroller itself. No need to install a specific development environment on the PC side, other than a serial or ehternet console/terminal emulator. You can also use any text editor, save your programs in sd/mmc and other media and use them directly in your platforms.
  • Flexible products: Add modern high level script-language capabilities to your projects, resulting in highly adaptable, field-programable and reconfigurable designs. Efficient (and cheap!) future evolution to your systems.
  • Learn embedded: Simple interactive and interpreted experimenting cycle. Use your desktop programming skills to become an embedded systems developer in no time and with a lot of fun.
  • Embedded RAD: Prototype and experiment on a Rapid Application Develop model. Test your ideas directly on the target platforms and cheap development kits. No need for simulators or future code adaptations.
  • Ready to use kits: A big (and growing!) number of Open Source hardware and commercially available platforms supported. Prototype cheap and fast and design your final hardware later using the produced code.
  • Longevity: Add user configuration and scripting capabilities to your projects, making them adaptable to the always changing contexts of industrial processes, evolving engineering, automation standards, field optimizations etc…​
  • Worry-free Licence: eLua is free and open-source software and we promote it as much as we can. But our MIT licence (the same as Lua’s) allows you to use eLua in your commercial and private-code products as well. Nothing to ask, no royalties to pay, just tell the world you’re using eLua.
For more information about the functionality (implemented and planned) in eLua check our status page.
Documentation
Online documentation can be found on the web for the most recent release version and development versions in the get better section of the project website.
Project documentation can be generated for the version of the project associated with this document by following the instructions in the README.TXT file in the doc directory.
Contacts
eLua authors and main developers can be contacted at:
Bogdan Marinescu: bogdan.marinescu -at- eluaproject -dot- net
Dado Sutter: dadosutter -at- eluaproject -dot- net
James Snyder: jbsnyder -at- eluaproject -dot- net
You are also welcomed to share your questions and suggestions on our Mail Discussion List
然后就没有然后了?  详情 回复 发表于 2016-6-14 17:59
强者为尊,弱者,死无葬身之地
7815
57
裸片初长成(中级)
重点,翻译几点
elua,就是 embedded lua,对啊。
lua和python类似,但是,lua比python更小。
比如这个elua,它目前融合了多个模块,但总体加起来也就40K(Flash)。
40K是个什么概念?
物联网领域大名鼎鼎的 Contiki 全功能时也就是40K左右。
当然,这个elua我曾经瞅了瞅它的组成,其实他真的就跟一个简单的由脚本语言构成的操作系统没啥卵区别。
lua其实并不小众,当然和python比起来,确实不够它出名,lua其实在游戏领域用的特别多。
另外,纯C,对的,纯C.
lua也好,elua也好,都是纯C库。
这个,我知道你们非常介意,我也很介意
强者为尊,弱者,死无葬身之地
7815
57
裸片初长成(中级)
PS: elua和lua一样,都是MIT协议。
MIT协议,简单地说,基本就是一个你想怎样就怎样的协议。
强者为尊,弱者,死无葬身之地
6040
204
不懂帮顶,撸啊撸啊撸啊撸。。。
24
能不能给几个移植好的例子,让大家先体验一下?最好是比较主流的板子。
1297
果然是第一次搬运,这广告效果一般般,没有实例,一点都没有动心。继续努力!!
7815
57
裸片初长成(中级)
额,我正在想我又作死开坑了,好吧好吧~~~
强者为尊,弱者,死无葬身之地
7815
57
裸片初长成(中级)
刚我瞅了瞅,官方对stm32系列的板子有了不少移植,杠杠的,应该不会特别苦逼才是
强者为尊,弱者,死无葬身之地
24
带着大家玩一玩吧
7815
57
裸片初长成(中级)
dcexpert 发表于 2016-5-25 11:43
带着大家玩一玩吧
试试吧,反正俺也没好好玩过lua
强者为尊,弱者,死无葬身之地
24
然后就没有然后了?
7815
57
裸片初长成(中级)
okgogogogo 发表于 2016-6-14 17:59
然后就没有然后了?
只是习惯性拖拉而已~~~~~~
强者为尊,弱者,死无葬身之地
