6673|15
9720
24
STM32F746G-DISCO 使用SOCKET客户端与电脑通信 [复制链接]
STM32F746G-DISCO 使用SOCKET客户端通过网络与电脑通信实验
MDK5提供了BSD Client for STM32F746G-Discovery的例程
打开MDK5Pack Installer
在右边选STM32F746
左边选择BSD Client STM32F746G-Discovery
Copy选择一个项目的保存路径点OK
我的MDK版本在创建项目后Network是红色的
编译提示Error #540: 'Keil.MDK-Pro::Network:CORE:Release:6.5.0' component is not available for target 'STM32F746 Flash', pack 'Keil.MDK-Middleware.6.5.0' is not selected
遇到这个问题打开”Select Software Packs for Target’STM32F746 Flash’窗口
在弹出的窗口里去掉”Use latest versions of all installed Software Packs”的勾选
展开Keil::MDK-Middleware去掉7.0.0-beta选择6.5.0
打开BSD_Client.c选择Configuration Wizard配置目标Socket服务器的IP和端口号
我的服务器IP设置了192.168.1.19端口1001
在官方的代码里有一个处理Socket的函数
  Thread 'Client': BSD Client socket process
static void Client (void const *arg) {
  SOCKADDR_IN addr;
  int sock, res;
  char dbuf[4];
  uint8_t p2val,lshf;
  while (1) {
    sock = socket (AF_INET, SOCKTYPE, 0);
    addr.sin_port      = htons(PORT_NUM);
    addr.sin_family    = PF_INET;
    addr.sin_addr.s_b1 = IP1;
    addr.sin_addr.s_b2 = IP2;
    addr.sin_addr.s_b3 = IP3;
    addr.sin_addr.s_b4 = IP4;
    connect (sock, (SOCKADDR *)&addr, sizeof (addr));
    lshf  = 1;
    p2val = 0x01;
    while (1) {
      // Shift the LEDs
      LED_SetOut (p2val);
      p2val = lshf ? (p2val << 1) : (p2val >> 1);
      if (p2val == 0x80) lshf = 0;
      if (p2val == 0x01) lshf = 1;
      // Send the data to LED Server.
      dbuf[0] = BLINKLED;
      dbuf[1] = p2val;
      res = send (sock, (char *)&dbuf, 2, 0);
      if (res < 0) {
        break;
      osDelay (100 * SPEED);
    closesocket (sock);
原来的函数里没有实现Socket接收函数
为了不影响通信我建了两个线程,一个用于接收,一个用于发送
SOCKADDR_IN addr;
int sock, res = 0;
int startFlag = 0;
static void PrintResult(int result)
    char * str = "                                                         ";
    char printStr[60];
    switch(res)
        case BSD_ERROR:
            str =     "General Error";
            break;
        case BSD_ERROR_SOCKET:
            str =    "Invalid socket descriptor";
            break;
        case BSD_ERROR_PARAMETER:
            str =    "Invalid parameter";
            break;
        case BSD_ERROR_WOULDBLOCK:
            str =    "It would have blocked";
            break;
        case BSD_ERROR_NOMEMORY:
            str =    "Not enough memory in memory pool";
            break;
        case BSD_ERROR_CLOSED:
            str =    "Connection is closed or aborted";
            break;
        case BSD_ERROR_LOCKED:
            str =    "Socket is locked by another thread";
            break;
        case BSD_ERROR_TIMEOUT:
            str =    "Socket, Host Resolver timeout";
            break;
        case BSD_ERROR_INPROGRESS:
            str =    "Host Name resolving in progress";
            break;
        case BSD_ERROR_NONAME:
            str =    "Host Name not existing";
            break;
    strncpy(printStr,str,20);
    printStr[20] = '\0';
    GLCD_DrawString         (5*16, 6*24, (char*)printStr);
    strncpy(printStr,str+20,20);
    GLCD_DrawString         (5*16, 7*24, (char*)printStr);
//HOSTENT *gethostbyname (const char *name, int *err);
static void Recevice(void const *arg)
        char dbuf[50];
        while(1)
                res = recv (sock, (char *)&dbuf, 50, 0);
                GLCD_DrawString         (5*16, 5*24, (char*)dbuf);
                PrintResult(res);
static void Send(void const *arg)
        char dbuf[50];
        uint16_t i;
        while (1) {
            while(1)
                    sprintf(dbuf,"STM32F746G-DISCO Send %d",i++);
                    res = send (sock, dbuf, strlen(dbuf), 0);
                    PrintResult(res);
                    if(res < 0)
                        break;
            closesocket (sock);
        osThreadCreate (osThread(Send), NULL);
        osThreadCreate (osThread(Recevice), NULL);
代码写好后下载到开发板
然后编写C#上位机程序
using System;
using System.IO;
using System.Net;
using System.Net.Sockets;
using System.Text;
using System.Threading;
namespace SocketServer
    class Program
        private static byte[] result = new byte[1024];
        private static int myProt = 1001;   //端口
        static Socket serverSocket;
        static void Main(string[] args)
            //服务器IP地址
            IPAddress ip = IPAddress.Parse("192.168.1.19");
            serverSocket = new Socket(AddressFamily.InterNetwork, SocketType.Stream, ProtocolType.Tcp);
            serverSocket.Bind(new IPEndPoint(ip, myProt));  //绑定IP地址:端口
            serverSocket.Listen(10);    //设定最多10个排队连接请求
            Console.WriteLine("启动监听{0}成功", serverSocket.LocalEndPoint.ToString());
            //收发数据
            int i = 0;
            Socket clientSocket = serverSocket.Accept();
            new Thread((ThreadStart)delegate
                while (true)
                    try
                        clientSocket.Send(Encoding.ASCII.GetBytes(String.Format("Server Send {0}\0", i++)));
                        //通过clientSocket接收数据
                        int receiveNumber = clientSocket.Receive(result);
                        Console.WriteLine("接收客户端{0}消息:{1}", clientSocket.RemoteEndPoint.ToString(), Encoding.ASCII.GetString(result, 0, receiveNumber));
                        Thread.Sleep(100);
                    catch (Exception ex)
                        Console.WriteLine(ex.Message);
                        clientSocket.Shutdown(SocketShutdown.Both);
                        clientSocket.Close();
            }).Start();
            Console.ReadLine();
运行后的效果
上位机
此帖出自stm32/stm8论坛
看懂了一点流层是一样的,LPC里的SOCKET通信用的RTL实时库  详情 回复 发表于 2017-8-13 11:06
点赞 关注(4)
个人签名虾扯蛋,蛋扯虾,虾扯蛋扯虾
293
支持版主,多多分享F7应用哦。
网络相关的应用都不懂啊,看看
此帖出自stm32/stm8论坛
4177
虾哥,f7的这个板子是不是有以太网的接口的呀。
此帖出自stm32/stm8论坛
有啊,socket就是通过以太网接口和电脑通信的。  详情 回复 发表于 2016-3-18 08:57
9720
24
此帖出自stm32/stm8论坛
明白了哈。谢谢啦。  详情 回复 发表于 2016-3-18 09:03
个人签名虾扯蛋,蛋扯虾,虾扯蛋扯虾
4177
明白了哈。谢谢啦。
此帖出自stm32/stm8论坛
1228
请问一下,我这例程怎么没法复制,老出现这个
此帖出自stm32/stm8论坛
你在复制项目的时候 目标路径选择的哪儿?  详情 回复 发表于 2016-3-24 11:27
喝最烈的酒,..DIY最实用的东西
9720
24
此帖出自stm32/stm8论坛
e盘的根目录下,还试了一个e盘下的一个文件夹  详情 回复 发表于 2016-3-24 12:53
个人签名虾扯蛋,蛋扯虾,虾扯蛋扯虾
1228
此帖出自stm32/stm8论坛
确定你的E盘是可写的硬盘 试着用管理员身份打开MDK试试 还是不行可以到MDK的安装目录下把工程复制出来 我的目录是D:\Keil5\ARM\Pack\Keil\STM32F7xx_DFP\2.2.0\MDK\Boards\ST\STM32F746G_Discovery\Middleware\Ne  详情 回复 发表于 2016-3-24 13:49
喝最烈的酒,..DIY最实用的东西
9720
24
确定你的E盘是可写的硬盘
试着用管理员身份打开MDK试试
我的目录是D:\Keil5\ARM\Pack\Keil\STM32F7xx_DFP\2.2.0\MDK\Boards\ST\STM32F746G_Discovery\Middleware\Network\BSD_Client
记得复制好的工程要把只读属性去掉
此帖出自stm32/stm8论坛
哦 明白了 谢谢  详情 回复 发表于 2016-3-24 13:51
个人签名虾扯蛋,蛋扯虾,虾扯蛋扯虾
1228
littleshrimp 发表于 2016-3-24 13:49
确定你的E盘是可写的硬盘
试着用管理员身份打开MDK试试
哦 明白了 谢谢
此帖出自stm32/stm8论坛
喝最烈的酒,..DIY最实用的东西
542
此帖出自stm32/stm8论坛
加EE小助手好友,
入技术交流群
EE服务号
精彩活动e手掌握
EE订阅号
热门资讯e网打尽
聚焦汽车电子软硬件开发
认真关注技术本身
能教教我吗
此帖出自stm32/stm8论坛
按照提示跑一下例程试试  详情 回复 发表于 2017-7-21 12:00
9720
24
江海度余生 发表于 2017-7-21 11:20
能教教我吗
按照提示跑一下例程试试
此帖出自stm32/stm8论坛
littleshrimp 发表于 2017-7-21 12:00
按照提示跑一下例程试试
我搞好了,不过是JAVA上位机和LPC的板子,STM32 还不会
此帖出自stm32/stm8论坛
例程的代码很精简 你可以读一下 原理和lpc差不多的  详情 回复 发表于 2017-8-13 04:30
9720
24
此帖出自stm32/stm8论坛
此帖出自stm32/stm8论坛
