LPC1752通过查询的方式读取FM25L04B。
2.1 初始化
初始化LPC1752的SSP0模块 ,按着如下步骤进行初始化的操作:
- 在PCONP寄存器置位PCSSP0,允许SSP0模块的电源输出;
- 在PCLK_SSP1寄存器中选择PCLK_SEL0,设置SSP0的时钟为CCLK/4;对SSP0的时钟进行分频,设置为CCLK/4/10;
- 对LPC1752的管脚进行设置;
- 设置 SPI 为主模式, FM25L04 工作在 SPI 模式 0。
- void LPC17xx_SPI_Init(void)
- volatile uint32_t dummy;
- dummy = dummy; /* avoid warning */
- LPC_SC->PCONP |= (1 << 21); /* Enable power to SSPI0 block */
- /* PCLK_SSP0=CCLK */
- LPC_SC->PCLKSEL1 &= ~(3<<10); /* PCLKSP0 = CCLK/4 (25MHz) */
- LPC_SC->PCLKSEL1 |= (1<<10); /* PCLKSP0 = CCLK (100MHz) */
- LPC17xx_SPI_SetSpeed (SPI_SPEED_10MHz);
- LPC_GPIO0->FIODIR |= (1<<16); /* P0.16 CS is output */
- /* P0.15 SCK, P0.17 MISO, P0.18 MOSI are SSP pins. */
- LPC_PINCON->PINSEL0 &= ~( (2UL<<30) ); /* P0.15 cleared */
- LPC_PINCON->PINSEL1 &= ~( (2<<2) | (2<<4) ); /* P0.17, P0.18 cleared */
- LPC_PINCON->PINSEL0 |= ( (2UL<<30) ); /* P0.15 SCK0 */
- LPC_PINCON->PINSEL1 |= ( (2<<2) | (2<<4) ); /* P0.17 MISO0 P0.18 MOSI0 */
- LPC_SSP0->CR0 = ( 7<<0 ); /* 8Bit, CPOL=0, CPHA=0 */
- LPC_SSP0->CR1 = ( 1<<1 ); /* SSP0 enable, master */
- /* wait for busy gone */
- while( LPC_SSP0->SR & ( 1 << SSPSR_BSY ) );
- /* drain SPI RX FIFO */
- while( LPC_SSP0->SR & ( 1 << SSPSR_RNE ) )
- dummy = LPC_SSP0->DR;
复制代码
2.2 读取
读取FM25L04B
图2
FM25L04B的读时序
- uint8_t FM25L04B_Read(uint32_t Dst, uint8_t* RcvBufPt, uint32_t NByte)
- uint8_t addr_a8;
- uint32_t i = 0;
- // if ((Dst+NByte > MAX_ADDR)||(NByte == 0)) return (ERROR);
- addr_a8 = (Dst & 0xffffff00)>>5;
- SPI_FLASH_WP_UNLOCK();
- SPI_FLASH_CS_LOW();
- FM25L04B_ReadWriteByte(READ_CMD|addr_a8);
- FM25L04B_ReadWriteByte(Dst & 0x00ff);
- for (i = 0; i < NByte; i++)
- RcvBufPt[i] = FM25L04B_ReadWriteByte(0xFF);
- SPI_FLASH_CS_HIGH();
- SPI_FLASH_WP_LOCK();
- return 0;
复制代码2.3 写数据
图3
FM25L04B的写时序
- uint8_t FM25L04B_Write(uint32_t Dst, uint8_t* SndbufPt,uint32_t NByte)
- uint8_t addr_a8;
- uint8_t temp = 0,StatRgVal = 0;
- uint32_t i = 0;
- // if (( (Dst+NByte-1 > MAX_ADDR)||(NByte == 0) ))
- // return (ERROR); /* ?????? */
- FM25L04B_ReadWriteByte(RDSR_CMD);
- temp = FM25L04B_ReadWriteByte(0xFF);
- for(i = 0; i < NByte; i++)
- FM25L04B_ReadWriteByte(WREN_CMD);
- FM25L04B_ReadWriteByte(WRITE_CMD|addr_a8);
- FM25L04B_ReadWriteByte((Dst+i)& 0x00ff);
- FM25L04B_ReadWriteByte(SndbufPt[i]);
- do
- StatRgVal = FM25L04B_ReadWriteByte(0xFF);
- while (StatRgVal == 0x03 );
- FM25L04B_ReadWriteByte(WRSR_CMD);
- FM25L04B_ReadWriteByte(temp);
- return 0;
复制代码2.4 测试代码
- uint8_t Recv_buf[16];
- uint8_t Send_buf[16] = {0x01,0x02,0x05,0xe4};
- int main(void)
- SystemInit();
- LPC17xx_SPI_Init();
- FM25L04B_Read(0x0,Recv_buf, sizeof(Recv_buf));
- FM25L04B_Write(0x0,Send_buf, sizeof(Send_buf));
- memset(Recv_buf,0,sizeof(Recv_buf));
- while(1) ;
复制代码
Code.rar
(184 KB, 下载次数: 3, 售价: 2 分芯积分)
