3011|1
108
【TI首届低功耗设计大赛】智能手表之无线控制智能家居 [复制链接]
void GUI_Buletooth( void )
        WM_HWIN hButton0;
        WM_HWIN hButton1;
        WM_HWIN hButton2;
        WM_HWIN hText;
        USART_printf(USART1, "a");//给msp430传输指令,建立连接,允许传输数据
        WinPara.hBuletooth = WM_CreateWindowAsChild(0, 0,
        WinPara.xSizeWin, WinPara.ySizeWin,
        WinPara.hWinMain,
        WM_CF_SHOW | WM_CF_STAYONTOP,
        _cbBuletooth, 0);
         hDlg = GUI_CreateDialogBox(_aDialogCreate, GUI_COUNTOF(_aDialogCreate), &_cbCallback, WinPara.hBuletooth, 0, 0);
        hButton0 = BUTTON_CreateEx(10, 280,
        40, 20,
                                WinPara.hBuletooth,
        WM_CF_SHOW | WM_CF_HASTRANS,
        0, GUI_ID_BUTTON3);
        BUTTON_SetText(hButton0, "Exit");
        BUTTON_SetFont(hButton0, GUI_FONT_13B_1);
        BUTTON_SetBkColor(hButton0, BUTTON_CI_UNPRESSED,GUI_WHITE);
        BUTTON_SetBkColor(hButton0, BUTTON_CI_PRESSED,GUI_BLUE);
        hButton1 = BUTTON_CreateEx(130, 205,
        100, 40,
                                WinPara.hBuletooth,
        0, GUI_ID_BUTTON1);
        BUTTON_SetBitmapEx(hButton1,BUTTON_BI_UNPRESSED,&bmOFF,2,2);
        BUTTON_SetBitmapEx(hButton1,BUTTON_BI_PRESSED,&bmON,2,2);
/*        BUTTON_SetText(hButton1, "ON|OFF");
        BUTTON_SetFont(hButton1, GUI_FONT_20B_ASCII);
        BUTTON_SetBkColor(hButton1, BUTTON_CI_UNPRESSED,GUI_WHITE);
        BUTTON_SetBkColor(hButton1, BUTTON_CI_PRESSED,GUI_BLUE);*/
        hButton2 = BUTTON_CreateEx(130, 255,
        100, 40,
        WinPara.hBuletooth,
        0, GUI_ID_BUTTON2);
        BUTTON_SetBitmapEx(hButton2,BUTTON_BI_UNPRESSED,&bmOFF,2,2);
        BUTTON_SetBitmapEx(hButton2,BUTTON_BI_PRESSED,&bmON,2,2);
/*        BUTTON_SetText(hButton2, "ON|OFF");
        BUTTON_SetFont(hButton2, GUI_FONT_20B_ASCII);
        BUTTON_SetBkColor(hButton2, BUTTON_CI_UNPRESSED,GUI_WHITE);
        BUTTON_SetBkColor(hButton2, BUTTON_CI_PRESSED,GUI_BLUE);*/
        hText = TEXT_CreateEx(0, 235,
        60, 30,
        WinPara.hBuletooth,
        WM_CF_SHOW,
        TEXT_CF_HCENTER|TEXT_CF_VCENTER,
        GUI_ID_TEXT7,
        "Status:");
        TEXT_SetFont(hText,GUI_FONT_20_ASCII);
        TEXT_SetTextColor(hText, GUI_BLUE);
        hText = TEXT_CreateEx(60, 220,
        70, 20,
        WinPara.hBuletooth,
        WM_CF_SHOW,
        GUI_ID_TEXT8,
        "Fan OFF");
        TEXT_SetTextColor(hText, GUI_YELLOW);
        hText = TEXT_CreateEx(60, 265,
        70, 20,
        WinPara.hBuletooth,
        WM_CF_SHOW,
        GUI_ID_TEXT9,
        "Light OFF");
*回调函数
*       _cbCallback
* Purpose:
*   Callback function of the dialog
static void _cbCallback(WM_MESSAGE * pMsg) {
  int i, NCode, Id, Value;
  WM_HWIN hDlg, hItem;
  hDlg = pMsg->hWin;
  switch (pMsg->MsgId) {
  case WM_INIT_DIALOG:
    hItem = WM_GetDialogItem(hDlg, GUI_ID_GRAPH0);
    /* Add graphs */
    for (i = 0; i < GUI_COUNTOF(_aColor); i++) {
      _aValue = rand() % 180;
      _ahData = GRAPH_DATA_YT_Create(_aColor, 500, 0, 0);
      GRAPH_AttachData(hItem, _ahData);
    /* Set graph attributes */
    GRAPH_SetGridDistY(hItem, 25);
    GRAPH_SetGridVis(hItem, 1);
    GRAPH_SetGridFixedX(hItem, 1);
    GRAPH_SetUserDraw(hItem, _UserDraw);
    /* Create and add vertical scale */
    _hScaleV = GRAPH_SCALE_Create( 35, GUI_TA_RIGHT, GRAPH_SCALE_CF_VERTICAL, 200);
    GRAPH_SCALE_SetTextColor(_hScaleV, GUI_YELLOW);
    GRAPH_AttachScale(hItem, _hScaleV);
        GRAPH_SCALE_SetFactor(_hScaleV, 0.4f);
        GRAPH_SCALE_SetNumDecs(_hScaleV,1);
    /* Create and add horizontal scale */
    _hScaleH = GRAPH_SCALE_Create(105, GUI_TA_HCENTER, GRAPH_SCALE_CF_HORIZONTAL, 80);
    GRAPH_SCALE_SetTextColor(_hScaleH, GUI_DARKGREEN);
    GRAPH_AttachScale(hItem, _hScaleH);
        GRAPH_SCALE_SetPos(_hScaleH,105);
    /* Init check boxes */
    hItem = WM_GetDialogItem(hDlg, GUI_ID_CHECK2);
    CHECKBOX_SetText(hItem, "L");
    hItem = WM_GetDialogItem(hDlg, GUI_ID_CHECK3);
    CHECKBOX_SetText(hItem, "T");
    hItem = WM_GetDialogItem(hDlg, GUI_ID_CHECK4);
    CHECKBOX_SetText(hItem, "R");
    hItem = WM_GetDialogItem(hDlg, GUI_ID_CHECK5);
    CHECKBOX_SetText(hItem, "B");
    hItem = WM_GetDialogItem(hDlg, GUI_ID_CHECK0);
    CHECKBOX_SetText(hItem, "Stop");
    hItem = WM_GetDialogItem(hDlg, GUI_ID_CHECK1);
    CHECKBOX_SetText(hItem, "Grid");
    CHECKBOX_SetState(hItem, 1);
    hItem = WM_GetDialogItem(hDlg, GUI_ID_CHECK6);
    CHECKBOX_SetText(hItem, "HScroll");
    hItem = WM_GetDialogItem(hDlg, GUI_ID_CHECK7);
    CHECKBOX_SetText(hItem, "VScroll");
    hItem = WM_GetDialogItem(hDlg, GUI_ID_CHECK8);
    CHECKBOX_SetText(hItem, "MirrorX");
    /* Init slider widgets */
    hItem = WM_GetDialogItem(hDlg, GUI_ID_SLIDER0);
    SLIDER_SetRange(hItem, 0, 10);
    SLIDER_SetValue(hItem, 5);
    SLIDER_SetNumTicks(hItem, 6);
    hItem = WM_GetDialogItem(hDlg, GUI_ID_SLIDER1);
    SLIDER_SetRange(hItem, 0, 20);
    /* Init radio widget */
    hItem = WM_GetDialogItem(hDlg, GUI_ID_RADIO0);
    RADIO_SetText(hItem, "3D", 0);
    RADIO_SetText(hItem, "flat", 1);
    RADIO_SetText(hItem, "-", 2);
    /* Init button widget */
    hItem = WM_GetDialogItem(hDlg, GUI_ID_BUTTON0);
    WM_SetStayOnTop(hItem, 1);
    break;
  case WM_NOTIFY_PARENT:
    Id    = WM_GetId(pMsg->hWinSrc);      /* Id of widget */
    NCode = pMsg->Data.v;                 /* Notification code */
    switch (NCode) {
    case WM_NOTIFICATION_CLICKED:
      switch (Id) {
      case GUI_ID_BUTTON0:
        _ToggleFullScreenMode(hDlg);
        break;
      break;
    case WM_NOTIFICATION_VALUE_CHANGED:
      switch (Id) {
      case GUI_ID_CHECK0:
        /* Toggle stop mode */
        _Stop ^= 1;
        break;
      case GUI_ID_CHECK1:
        /* Toggle grid */
        GRAPH_SetGridVis(hItem, CHECKBOX_IsChecked(WM_GetDialogItem(hDlg, GUI_ID_CHECK1)));
        break;
      case GUI_ID_CHECK2:
      case GUI_ID_CHECK3:
      case GUI_ID_CHECK4:
      case GUI_ID_CHECK5:
        /* Toggle border */
        GRAPH_SetBorder(hItem,
                        CHECKBOX_IsChecked(WM_GetDialogItem(hDlg, GUI_ID_CHECK2)) * 40,
                        CHECKBOX_IsChecked(WM_GetDialogItem(hDlg, GUI_ID_CHECK3)) * 5,
                        CHECKBOX_IsChecked(WM_GetDialogItem(hDlg, GUI_ID_CHECK4)) * 5,
                        CHECKBOX_IsChecked(WM_GetDialogItem(hDlg, GUI_ID_CHECK5)) * 5);
        break;
      case GUI_ID_SLIDER0:
        /* Set horizontal grid spacing */
        Value = SLIDER_GetValue(pMsg->hWinSrc) * 10;
        GRAPH_SetGridDistX(hItem, Value);
        GRAPH_SCALE_SetTickDist(_hScaleH, Value);
        break;
      case GUI_ID_SLIDER1:
        /* Set vertical grid spacing */
        Value = SLIDER_GetValue(pMsg->hWinSrc) * 5;
        GRAPH_SetGridDistY(hItem, Value);
        GRAPH_SCALE_SetTickDist(_hScaleV, Value);
        break;
      case GUI_ID_RADIO0:
        /* Set the widget effect */
        switch (RADIO_GetValue(pMsg->hWinSrc)) {
        case 0:
          WIDGET_SetEffect(hItem, &WIDGET_Effect_3D);
          break;
        case 1:
          WIDGET_SetEffect(hItem, &WIDGET_Effect_Simple);
          break;
        case 2:
          WIDGET_SetEffect(hItem, &WIDGET_Effect_None);
          break;
        break;
      case GUI_ID_CHECK6:
        /* Toggle horizontal scroll bar */
        if (CHECKBOX_IsChecked(WM_GetDialogItem(hDlg, GUI_ID_CHECK6))) {
          GRAPH_SetVSizeX(hItem, 500);
        } else {
          GRAPH_SetVSizeX(hItem, 0);
        break;
      case GUI_ID_CHECK7:
        /* Toggle vertical scroll bar */
        if (CHECKBOX_IsChecked(WM_GetDialogItem(hDlg, GUI_ID_CHECK7))) {
          GRAPH_SetVSizeY(hItem, 300);
        } else {
          GRAPH_SetVSizeY(hItem, 0);
        break;
      case GUI_ID_CHECK8:
        /* Toggle alignment */
          if (CHECKBOX_IsChecked(WM_GetDialogItem(hDlg, GUI_ID_CHECK8))) {
            GRAPH_DATA_YT_SetAlign(_ahData, GRAPH_ALIGN_LEFT);
            GRAPH_DATA_YT_MirrorX (_ahData, 1);
          } else {
            GRAPH_DATA_YT_SetAlign(_ahData, GRAPH_ALIGN_RIGHT);
            GRAPH_DATA_YT_MirrorX (_ahData, 0);
        break;
      break;
    break;
  default:
    WM_DefaultProc(pMsg);
坐个沙发  详情 回复 发表于 2014-11-16 00:11
415
坐个沙发
个人签名只要你心中有梦想,你人在哪里,梦想就在哪里!
