2775|4
125
FIR滤波问题 [复制链接]
void fir_filter(void)
        int i,j;
        float sum;
        float x1[932];
        float h[31]={ 0.01492972,0.01096342,0.01458647,0.0186,0.02309,0.0278,0.03268,0.037587,
                    0.0423831,0.04692,0.051058,0.05466,
                    0.057597,0.059775,0.061111,0.061563,
                    0.0611111,0.0597754,0.05759762,0.05466,
                    0.051058,0.0469205,0.04238,0.037587,
                    0.03268,0.0278036,0.02309,0.0186523,
                    0.01458,0.0109634,0.014929,};
        //x2=1;
        for(i=0;i<900;i++)
        x1[i+31]=Output0[i];//为什么程序每次执行到这就一直停着?
        for(i=0;i<932;i++)
                sum=0.0;
                for(j=0;j<31;j++)
                        if(i >= j)
                        sum+=h[j]*x1[i-j];
                        else
                Output0[i]=(int16)sum>> 15;
求问楼主fir如何软件仿真的,用ccs4,配置好target,显示工程未添加  详情 回复 发表于 2014-12-9 12:37
1559
24
楼主 Output0这个数组在哪定义,有否初始化?
个人签名这孩子,成熟的象征,理智的典范。
125
经验证应该是数组过大溢出所致
不是软件仿真,我是硬件编程  详情 回复 发表于 2014-12-9 13:56
125
不是软件仿真,我是硬件编程
【回帖赢京东卡】说说无线技术那些事儿
即日起—2月28日,参与回帖讨论都有机会赢取【30元京东卡】
