#include
#define uchar unsigned char
#define uint unsigned int
//#include
#define SID_1 P1OUT |= BIT4 // r/w
#define SID_0 P1OUT &= ~BIT4
#define SCLK_1 P1OUT |= BIT2 // en
#define SCLK_0 P1OUT &= ~BIT2
#define CS_1 P1OUT |= BIT3 // rs
#define CS_0 P1OUT &= ~BIT3
#define DQ P1IN&BIT6
#define DQ_1 P1OUT |=BIT6; //20sbit DQ = P3^2; //数据口define interface
#define DQ_0 P1OUT &=~BIT6;
uint temp; //温度值 variable of temperature
void delay(uchar t) //延时函数
uint x,y;
for(x=t;x>0;x--)
for(y=110;y>0;y--);
uchar CMDAddress;
//sbit RS=P2^5;
//sbit RW=P2^1;
//sbit EN=P2^2;
void sendbyte(unsigned char zdata)
unsigned int i;
for(i=0; i<8; i++)
if((zdata << i) & 0x80)
SID_1;
else
SID_0;
SCLK_0;
SCLK_1;
void write_cmd(uchar cmdcode)
CS_1;
sendbyte(0xf8);
sendbyte(cmdcode & 0xf0);
sendbyte((cmdcode << 4) & 0xf0);
delay(2);
void write_date(uchar Dispdata)
CS_1;
sendbyte(0xfa);
sendbyte(Dispdata & 0xf0);
sendbyte((Dispdata << 4) & 0xf0);
delay(2);
void init() //初始化
delay(100);
write_cmd(0x30); //Extended Function Set(功能设定控制字)基本指令集 ,8位
delay(1);
write_cmd(0x30); //Function Set 基本指令集
delay(1);
write_cmd(0x0c); //(显示开关控制字),全部显示ON,游标OFF,闪烁OFF
delay(1);
write_cmd(0x01); //清屏控制字
delay(15);
write_cmd(0x06); //Entry Mode (进入设定点控制字)光标从左向右加一位移动
delay(1);
void SetAddress(uchar x,uchar y) //设置输入数据位置
switch(y)
case 0:CMDAddress=0x80+x;break;
case 1:CMDAddress=0x90+x;break;
case 2:CMDAddress=0x88+x;break;
case 3:CMDAddress=0x98+x;break;
write_cmd(CMDAddress);
void putstring(uchar x,uchar y,uchar *pdate) //该行是否完
SetAddress(x,y);
while(*pdate!='\0')
write_date(*pdate++);
void show() //显示“温度”
putstring(0,0,"温度:"); //第一排首位子显示“温度”两字
putstring(0,3,"液晶温度显示"); //第三排首位子显示“液晶温度显示”
void display(uint Temp ) // 显示温度值
uint t1,t2,t3 ; //,t0,t1,t2
t1=Temp/100%10;
t2=Temp/10%10;
t3=Temp%10;
write_cmd(0x93);
write_date(0x30+t1);
write_date(0x30+t2);
write_date('.');
write_date(0x30+t3);
write_date(0xA1);
write_date(0xE6);
void delay2(unsigned char i) //延时函数
while(--i);
void Init_Ds18b20(void) //DS18B20初始化send reset and initialization command
DQ_1; //DQ复位,不要也可行。
delay2(1); //稍做延时
DQ_0; //单片机拉低总线
delay2(480); //精确延时,维持至少480us
DQ_1; //释放总线,即拉高了总线
delay2(100); //此处延时有足够,确保能让DS18B20发出存在脉冲。
uchar Read_One_Byte() //读取一个字节的数据read a byte date
//读数据时,数据以字节的最低有效位先从总线移出
uchar i = 0;
uchar dat = 0;
for(i=8;i>0;i--)
DQ_0; //将总线拉低,要在1us之后释放总线
_NOP();
//单片机要在此下降沿后的15us内读数据才会有效。
_NOP(); //至少维持了1us,表示读时序开始
dat >>= 1; //让从总线上读到的位数据,依次从高位移动到低位。
DQ_1; //释放总线,此后DS18B20会控制总线,把数据传输到总线上
delay2(5); //延时7us,此处参照推荐的读时序图,尽量把控制器采样时间放到读时序后的15us内的最后部分
P1DIR &=~BIT6;
if((DQ&BIT6)==1) //控制器进行采样
dat |= 0x80; //总线为1, DQ为1,那就把dat的最高位置1;若为0,不处理,保持0
delay2(60); //此延时不能少,确保读时序的长度60us。
return (dat);
void Write_One_Byte(uchar dat)
uchar i = 0;
for(i=8;i>0;i--)
DQ_0; //拉低总线
_NOP();
_NOP(); //至少维持了1us,表示写时序(包括写0时序或写1时序)开始
if(dat&0x01) //从字节的最低位开始传输
DQ_1;
delay2(60); //指令dat的最低位赋予给总线,必须在拉低总线后的15us内,
else
delay(65); DQ_1;
//因为15us后DS18B20会对总线采样。
//必须让写时序持续至少60us
//写完后,必须释放总线,
dat >>= 1;
delay2(2);
uint Get_Tmp() //获取温度get the temperature
float tt;
uchar a,b;
Init_Ds18b20(); //初始化
Write_One_Byte(0xcc); //忽略ROM指令
Write_One_Byte(0x44); //温度转换指令
Write_One_Byte(0xbe); //读暂存器指令
a = Read_One_Byte(); //读取到的第一个字节为温度LSB
b = Read_One_Byte(); //读取到的第一个字节为温度MSB
temp = b; //先把高八位有效数据赋于temp
temp <<= 8; //把以上8位数据从temp低八位移到高八位
temp = temp|a; //两字节合成一个整型变量
tt = temp*0.0625; //得到真实十进制温度值,DS18B20可以精确到0.0625度
//所以读回数据的最低位代表的是0.0625度
temp = tt*10+0.5; //放大十倍,目的是将小数点后第一位也转换为可显示数字
return temp;
void main()
{WDTCTL = WDTPW + WDTHOLD;
P1DIR = BIT4 + BIT2 + BIT3+BIT6;
delay(50);
init();
delay(10);
show();
while(1)
display(Get_Tmp());
