5390|3
G2553+NRF24L01,为什么每次发送数据第一次总是能够接受成功,后来就乱码了??? [复制链接]
程序如下:
一、发送:
  1、 主程序:
#include
#include "nrf24L01.h"
#include "time.h"
char TxBuf[5]=
        //0x03,0x03,0x03,0x03,0x05,0x06,0x07,0x08,
        //0x09,0x10,0x11,0x12,0x13,0x14,0x15,0x16,
        //0x17,0x18,0x19,0x20,0x21,0x22,0x23,0x24,
        0x31,0x26,0x27,0x28,0x29,//0x30,0x31,0x32,
void main(void)
        WDTCTL = WDTPW + WDTHOLD;
        RF24L01_IO_set();//初始化SPI引脚
        init_NRF24L01();//初始化NRF24L01模块
        Init_timeA();
        while(1)
2、其他程序:
1)nrf24l01.c
#include
char  TX_ADDRESS[TX_ADR_WIDTH]= {0x34,0x43,0x10,0x10,0x01};        //本地地址
char  RX_ADDRESS[RX_ADR_WIDTH]= {0x34,0x43,0x10,0x10,0x01};        //接收地址
char  sta;
void RF24L01_IO_set(void);
char SPI_RW(char data);
char SPI_Read(char reg);
char SPI_RW_Reg(char reg, char value);
char SPI_Read_Buf(char reg, char *pBuf, char uchars);
char SPI_Write_Buf(char reg, char *pBuf, char uchars);
void SetRX_Mode(void);
char nRF24L01_RxPacket(char* rx_buf);
void nRF24L01_TxPacket(char * tx_buf);
void init_NRF24L01(void);
//===========================RF24L01端口设置==========================================
         * RF24L01发送
         * CE->P1.5
         * SCK->P1.4
         * CSN->P1.6
         * MISO->P1.1
         * MOSI->P1.2
         * IRQ->P1.7
#ifdef HW_SPI
        P1DIR |= BIT5 + BIT6;//NRFCE,NRFCSN输出
        P1DIR &= ~BIT7; //IRQ输入
        //引脚初始化为SPI功能
        P1SEL = BIT1 + BIT2 + BIT4;//UCA0SOMI,UCA0SIMO,UCA0CLK
        P1SEL2 = BIT1 + BIT2 + BIT4;
        //SPI功能配置
        UCA0CTL1 |= UCSWRST;
        UCA0CTL0 |= UCMSB + UCMST + UCSYNC;  // 3-pin, 8-bit SPI master
        UCA0CTL1 |= UCSSEL_2;// SMCLK
        UCA0BR0 = 0;
        UCA0BR1 = 0;
        UCA0MCTL = 0;    // No modulation
        UCA0CTL1 &= ~UCSWRST;  // **Initialize USCI state machine**
#else
        P1DIR |= BIT2 + BIT4;//UCA0SIMO,UCA0CLK
        P1DIR &= ~BIT1;//UCA0SOMI
#endif
//函数:uint SPI_RW(uint uchar)
//功能:NRF24L01的SPI写时序
#ifdef HW_SPI
        while(!(IFG2 & UCA0TXIFG));
        UCA0TXBUF = data;
        while(!(IFG2 & UCB0RXIFG));
        return UCA0RXBUF;
#else
        char i,temp=0;
           for(i=0;i<8;i++) // output 8-bit
                if((data & 0x80)==0x80)
                        RF24L01_MOSI_1;         // output 'uchar', MSB to MOSI
                else
                        RF24L01_MOSI_0;
                data = (data << 1);            // shift next bit into MSB..
                temp <<=1;
                RF24L01_SCK_1;                // Set SCK high..
                RF24L01_MISO_IN;
                if(RF24L01_MISO_read)
                temp |=0x01;
                RF24L01_SCK_0;              // ..then set SCK low again
    return(temp);                             // return read uchar
#endif
//函数:uchar SPI_Read(uchar reg)
//功能:NRF24L01的SPI时序
        char reg_val;
        RF24L01_CSN_0;           // CSN low, initialize SPI communication...
        SPI_RW(reg);            // Select register to read from..
        reg_val = SPI_RW(0);    // ..then read registervalue
        RF24L01_CSN_1;         // CSN high, terminate SPI communication
        return(reg_val);       // return register value
//功能:NRF24L01读写寄存器函数
        char status1;
        RF24L01_CSN_0;                   // CSN low, init SPI transaction
        status1 = SPI_RW(reg);      // select register
        SPI_RW(value);             // ..and write value to it..
        RF24L01_CSN_1;                   // CSN high again
        return(status1);            // return nRF24L01 status uchar
//函数:uint SPI_Read_Buf(uchar reg, uchar *pBuf, uchar uchars)
//功能: 用于读数据,reg:为寄存器地址,pBuf:为待读出数据地址,uchars:读出数据的个数
char SPI_Read_Buf(char reg, char *pBuf, char chars)
        char status2,uchar_ctr;
        RF24L01_CSN_0;                                    // Set CSN low, init SPI tranaction
        status2 = SPI_RW(reg);                       // Select register to write to and read status uchar
        for(uchar_ctr=0;uchar_ctr         {
                pBuf[uchar_ctr] = SPI_RW(0);    //
        RF24L01_CSN_1;
        return(status2);                    // return nRF24L01 status uchar
//函数:uint SPI_Write_Buf(uchar reg, uchar *pBuf, uchar uchars)
//功能: 用于写数据:为寄存器地址,pBuf:为待写入数据地址,uchars:写入数据的个数
char SPI_Write_Buf(char reg, char *pBuf, char chars)
        char status1,uchar_ctr;
        RF24L01_CSN_0;             //SPI使能
        for(uchar_ctr=0; uchar_ctr         {
                SPI_RW(*pBuf++);
        RF24L01_CSN_1;           //关闭SPI
        return(status1);                      //
//函数:void SetRX_Mode(void)
//功能:数据接收配置
        RF24L01_CE_0 ;
        SPI_RW_Reg(WRITE_REG + CONFIG, 0x0f);                   // IRQ收发完成中断响应,16位CRC        ,主接收
        RF24L01_CE_1;
        __delay_cycles(130);//注意不能太小
//函数:unsigned char nRF24L01_RxPacket(unsigned char* rx_buf)
//功能:数据读取后放如rx_buf接收缓冲区中
    char revale=0;
        sta=SPI_Read(STATUS);             // 读取状态寄存其来判断数据接收状况
        if(sta&0x40)                 // 判断是否接收到数据 RX_DR
            RF24L01_CE_0 ;                         //SPI使能
            SPI_Read_Buf(R_RX_PLOAD,rx_buf,TX_PLOAD_WIDTH);// read receive payload from RX_FIFO buffer
            revale =1;                        //读取数据完成标志
        SPI_RW_Reg(WRITE_REG+STATUS,sta);   //接收到数据后RX_DR,TX_DS,MAX_PT都置高为1,通过写1来清楚中断标志
        return revale;
//函数:void nRF24L01_TxPacket(char * tx_buf)
//功能:发送 tx_buf中数据
        RF24L01_CE_0 ;                        //StandBy I模式
        SPI_Write_Buf(WRITE_REG + RX_ADDR_P0, TX_ADDRESS, TX_ADR_WIDTH); // 装载接收端地址
        SPI_Write_Buf(W_TX_PLOAD, tx_buf, TX_PLOAD_WIDTH);                          // 装载数据
   //     SPI_RW_Reg(WRITE_REG + CONFIG, 0x0e);                    // IRQ收发完成中断响应,16位CRC,主发送
        RF24L01_CE_1;                 //置高CE,激发数据发送
        //inerDelay_us(10);
//NRF24L01初始化
        _delay_cycles(100);
        RF24L01_CE_0;    // chip enable
        RF24L01_CSN_1;   // Spi disable
        //RF24L01_SCK_0;
        SPI_Write_Buf(WRITE_REG + TX_ADDR, TX_ADDRESS, TX_ADR_WIDTH);    // 写本地地址
        SPI_Write_Buf(WRITE_REG + RX_ADDR_P0, RX_ADDRESS, RX_ADR_WIDTH); // 写接收端地址
        SPI_RW_Reg(WRITE_REG + EN_AA, 0x01);      //  频道0自动        ACK应答允许
        SPI_RW_Reg(WRITE_REG + EN_RXADDR, 0x01);  //  允许接收地址频道0,
        SPI_RW_Reg(WRITE_REG + RF_CH, 0);        //   设置信道工作为2.4GHZ,收发必须一致
        SPI_RW_Reg(WRITE_REG + RX_PW_P0, RX_PLOAD_WIDTH); //设置接收数据长度,本次设置为32字节
        SPI_RW_Reg(WRITE_REG + RF_SETUP, 0x07);   //设置发射速率为1MHZ,发射功率为最大值0dB
        SPI_RW_Reg(WRITE_REG + CONFIG, 0x0E);   // IRQ收发完成中断响应,16位CRC        ,主发射模式
2)time.c
#include
#include "time.h"
void Init_timeA(void)
        TACTL = TACLR;//计数器清零
        CCTL0 = CCIE;//使能定时中断
        CCR0 = 50000;//时间间隔50ms
        TACTL = TASSEL_2 + MC_1;//SMCLK ,增计数模式
        _EINT();//使能全局中断
//定时器中断函数入口
#pragma vector=TIMER0_A0_VECTOR
__interrupt void Timer_A(void)
        nRF24L01_TxPacket(TxBuf);
        //SPI_RW_Reg(WRITE_REG+STATUS,0xff);
二、接受:
1、主程序:
#include"msp430g2553.h"
#include "time.h"
//#include "uart.h"
char RxBuf[5];
void main(void)
        P1DIR |= BIT0;
        P1OUT |= ~BIT0;
        RF24L01_IO_set(); //初始化SPI引脚
        init_NRF24L01(); //初始化NRF24L01模块
        Init_timeA();
        //Init_Uart();
        while(1)
2、其他程序
1)nrf24l01.C:与发送基本一致
2)time.c:
#include
#include "time.h"
//#include "uart.h"
        CCR0 = 500000;//时间间隔50ms
        _EINT();//使能全局中断
//定时器中断函数入口
        SetRX_Mode();//接受模式
        if(nRF24L01_RxPacket(RxBuf))
                P1DIR |= BIT0;
                P1OUT |= BIT0;//灯亮
接收后没寄存器没有清零被占用了  详情 回复 发表于 2015-10-29 00:56
2781
419
nrf24l01.h文件中的发送长度的宏定义改为你要发送的个数,5个,而不是32
2781
419
把nrf24l01.h的头文件贴出来看看
接收后没寄存器没有清零被占用了
