4622|0
【SensorTag】the ninth week:sensortag原码剖析 [复制链接]
不说那些参数,因为这个参数是配对用的。也不说那些传感器怎么用地。我想就了解下LED是怎么控制地。
Sensor LED能控制么?????答案是肯定地。我用usb dongle时发现用usb dongle可以控制LED。只要控制LED,就可以控制我的继电器。我的设计就完成了。
那么Sensortag又是怎么把LED点亮地呢?这又要看程序啦。
我的程序在:
C:\Texas Instruments\BLE-CC254x-1.4.0\Projects\ble\SensorTag\Source
SensorTag是靠广播联接地。也就是说不用什么密码。
首先传感器之类在回调函数中处理:
  1. /*********************************************************************
  2. * PROFILE CALLBACKS
  3. */
  4. // GAP Role Callbacks
  5. static gapRolesCBs_t sensorTag_PeripheralCBs =
  6. {
  7.   peripheralStateNotificationCB,  // Profile State Change Callbacks
  8.   NULL                            // When a valid RSSI is read from controller (not used by application)
  9. };
  10. // GAP Bond Manager Callbacks
  11. static gapBondCBs_t sensorTag_BondMgrCBs =
  12. {
  13.   NULL,                     // Passcode callback (not used by application)
  14.   NULL                      // Pairing / Bonding state Callback (not used by application)
  15. };
  16. // Simple GATT Profile Callbacks
  17. static sensorCBs_t sensorTag_BarometerCBs =
  18. {
  19.   barometerChangeCB,        // Characteristic value change callback
  20. };
  21. static sensorCBs_t sensorTag_IrTempCBs =
  22. {
  23.   irTempChangeCB,           // Characteristic value change callback
  24. };
  25. static sensorCBs_t sensorTag_AccelCBs =
  26. {
  27.   accelChangeCB,            // Characteristic value change callback
  28. };
  29. static sensorCBs_t sensorTag_HumidCBs =
  30. {
  31.   humidityChangeCB,         // Characteristic value change callback
  32. };
  33. static sensorCBs_t sensorTag_MagnetometerCBs =
  34. {
  35.   magnetometerChangeCB,     // Characteristic value change callback
  36. };
  37. static sensorCBs_t sensorTag_GyroCBs =
  38. {
  39.   gyroChangeCB,             // Characteristic value change callback
  40. };
  41. static testCBs_t sensorTag_TestCBs =
  42. {
  43.   testChangeCB,             // Charactersitic value change callback
  44. };
  45. static ccCBs_t sensorTag_ccCBs =
  46. {
  47. ccChangeCB,               // Charactersitic value change callback
  48. };
  49. static gapRolesParamUpdateCB_t paramUpdateCB =
  50. {
  51.   gapRolesParamUpdateCB,
  52. };
复制代码
处理过程:
  2. * @fn      SensorTag_ProcessEvent
  3. *
  4. * @brief   Simple BLE Peripheral Application Task event processor.  This function
  5. *          is called to process all events for the task.  Events
  6. *          include timers, messages and any other user defined events.
  7. *
  8. * @param   task_id  - The OSAL assigned task ID.
  9. * @param   events - events to process.  This is a bit map and can
  10. *                   contain more than one event.
  11. *
  12. * @return  events not processed
  13. */
  14. uint16 SensorTag_ProcessEvent( uint8 task_id, uint16 events )
  15. {
  16.   VOID task_id; // OSAL required parameter that isn't used in this function
  17.   if ( events & SYS_EVENT_MSG )
  18.   {
  19.     uint8 *pMsg;
  20.     if ( (pMsg = osal_msg_receive( sensorTag_TaskID )) != NULL )
  21.     {
  22.       sensorTag_ProcessOSALMsg( (osal_event_hdr_t *)pMsg );
  23.       // Release the OSAL message
  24.       VOID osal_msg_deallocate( pMsg );
  25.     }
  26.     // return unprocessed events
  27.     return (events ^ SYS_EVENT_MSG);
  28.   }
  29.   // Handle system reset (long press on side key)
  30.   if ( events & ST_SYS_RESET_EVT )
  31.   {
  32.     if (sysResetRequest)
  33.     {
  34.       HAL_SYSTEM_RESET();
  35.     }
  36.     return ( events ^ ST_SYS_RESET_EVT );
  37.   }
  38.   if ( events & ST_START_DEVICE_EVT )
  39.   {
  40.     // Start the Device
  41.     VOID GAPRole_StartDevice( &sensorTag_PeripheralCBs );
  42.     // Start Bond Manager
  43.     VOID GAPBondMgr_Register( &sensorTag_BondMgrCBs );
  44.     return ( events ^ ST_START_DEVICE_EVT );
  45.   }
  46.   //////////////////////////
  47.   //    IR TEMPERATURE    //
  48.   //////////////////////////
  49.   if ( events & ST_IRTEMPERATURE_READ_EVT )
  50.   {
  51.     if ( irTempEnabled )
  52.     {
  53.       if (HalIRTempStatus() == TMP006_DATA_READY)
  54.       {
  55.         readIrTempData();
  56.         osal_start_timerEx( sensorTag_TaskID, ST_IRTEMPERATURE_READ_EVT, sensorTmpPeriod-TEMP_MEAS_DELAY );
  57.       }
  58.       else if (HalIRTempStatus() == TMP006_OFF)
  59.       {
  60.         HalIRTempTurnOn();
  61.         osal_start_timerEx( sensorTag_TaskID, ST_IRTEMPERATURE_READ_EVT, TEMP_MEAS_DELAY );
  62.       }
  63.     }
  64.     else
  65.     {
  66.       //Turn off Temperatur sensor
  67.       VOID HalIRTempTurnOff();
  68.       VOID resetCharacteristicValue(IRTEMPERATURE_SERV_UUID,SENSOR_DATA,0,IRTEMPERATURE_DATA_LEN);
  69.       VOID resetCharacteristicValue(IRTEMPERATURE_SERV_UUID,SENSOR_CONF,ST_CFG_SENSOR_DISABLE,sizeof ( uint8 ));
  70.     }
  71.     return (events ^ ST_IRTEMPERATURE_READ_EVT);
  72.   }
  73.   //////////////////////////
  74.   //    Accelerometer     //
  75.   //////////////////////////
  76.   if ( events & ST_ACCELEROMETER_SENSOR_EVT )
  77.   {
  78.     if(accConfig != ST_CFG_SENSOR_DISABLE)
  79.     {
  80.       readAccData();
  81.       osal_start_timerEx( sensorTag_TaskID, ST_ACCELEROMETER_SENSOR_EVT, sensorAccPeriod );
  82.     }
  83.     else
  84.     {
  85.       VOID resetCharacteristicValue( ACCELEROMETER_SERV_UUID, SENSOR_DATA, 0, ACCELEROMETER_DATA_LEN );
  86.       VOID resetCharacteristicValue( ACCELEROMETER_SERV_UUID, SENSOR_CONF, ST_CFG_SENSOR_DISABLE, sizeof ( uint8 ));
  87.     }
  88.     return (events ^ ST_ACCELEROMETER_SENSOR_EVT);
  89.   }
  90.   //////////////////////////
  91.   //      Humidity        //
  92.   //////////////////////////
  93.   if ( events & ST_HUMIDITY_SENSOR_EVT )
  94.   {
  95.     if (humiEnabled)
  96.     {
  97.       HalHumiExecMeasurementStep(humiState);
  98.       if (humiState == 2)
  99.       {
  100.         readHumData();
  101.         humiState = 0;
  102.         osal_start_timerEx( sensorTag_TaskID, ST_HUMIDITY_SENSOR_EVT, sensorHumPeriod );
  103.       }
  104.       else
  105.       {
  106.         humiState++;
  107.         osal_start_timerEx( sensorTag_TaskID, ST_HUMIDITY_SENSOR_EVT, HUM_FSM_PERIOD );
  108.       }
  109.     }
  110.     else
  111.     {
  112.       resetCharacteristicValue( HUMIDITY_SERV_UUID, SENSOR_DATA, 0, HUMIDITY_DATA_LEN);
  113.       resetCharacteristicValue( HUMIDITY_SERV_UUID, SENSOR_CONF, ST_CFG_SENSOR_DISABLE, sizeof ( uint8 ));
  114.     }
  115.     return (events ^ ST_HUMIDITY_SENSOR_EVT);
  116.   }
  117.   //////////////////////////
  118.   //      Magnetometer    //
  119.   //////////////////////////
  120.   if ( events & ST_MAGNETOMETER_SENSOR_EVT )
  121.   {
  122.     if(magEnabled)
  123.     {
  124.       if (HalMagStatus() == MAG3110_DATA_READY)
  125.       {
  126.         readMagData();
  127.       }
  128.       else if (HalMagStatus() == MAG3110_OFF)
  129.       {
  130.         HalMagTurnOn();
  131.       }
  132.       osal_start_timerEx( sensorTag_TaskID, ST_MAGNETOMETER_SENSOR_EVT, sensorMagPeriod );
  133.     }
  134.     else
  135.     {
  136.       HalMagTurnOff();
  137.       resetCharacteristicValue( MAGNETOMETER_SERV_UUID, SENSOR_DATA, 0, MAGNETOMETER_DATA_LEN);
  138.       resetCharacteristicValue( MAGNETOMETER_SERV_UUID, SENSOR_CONF, ST_CFG_SENSOR_DISABLE, sizeof ( uint8 ));
  139.     }
  140.     return (events ^ ST_MAGNETOMETER_SENSOR_EVT);
  141.   }
  142.   //////////////////////////
  143.   //        Barometer     //
  144.   //////////////////////////
  145.   if ( events & ST_BAROMETER_SENSOR_EVT )
  146.   {
  147.     if (barEnabled)
  148.     {
  149.       if (barBusy)
  150.       {
  151.         barBusy = FALSE;
  152.         readBarData();
  153.         osal_start_timerEx( sensorTag_TaskID, ST_BAROMETER_SENSOR_EVT, sensorBarPeriod );
  154.       }
  155.       else
  156.       {
  157.         barBusy = TRUE;
  158.         HalBarStartMeasurement();
  159.         osal_start_timerEx( sensorTag_TaskID, ST_BAROMETER_SENSOR_EVT, BAR_FSM_PERIOD );
  160.       }
  161.     }
  162.     else
  163.     {
  164.       resetCharacteristicValue( BAROMETER_SERV_UUID, SENSOR_DATA, 0, BAROMETER_DATA_LEN);
  165.       resetCharacteristicValue( BAROMETER_SERV_UUID, SENSOR_CONF, ST_CFG_SENSOR_DISABLE, sizeof ( uint8 ));
  166.       resetCharacteristicValue( BAROMETER_SERV_UUID, SENSOR_CALB, 0, BAROMETER_CALI_LEN);
  167.     }
  168.     return (events ^ ST_BAROMETER_SENSOR_EVT);
  169.   }
  170.   //////////////////////////
  171.   //      Gyroscope       //
  172.   //////////////////////////
  173.   if ( events & ST_GYROSCOPE_SENSOR_EVT )
  174.   {
  175.     uint8 status;
  176.     status = HalGyroStatus();
  177.     if(gyroEnabled)
  178.     {
  179.       if (status == HAL_GYRO_STOPPED)
  180.       {
  181.         HalGyroSelectAxes(sensorGyroAxes);
  182.         HalGyroTurnOn();
  183.         osal_start_timerEx( sensorTag_TaskID, ST_GYROSCOPE_SENSOR_EVT, GYRO_STARTUP_TIME);
  184.       }
  185.       else
  186.       {
  187.         if(sensorGyroUpdateAxes)
  188.         {
  189.           HalGyroSelectAxes(sensorGyroAxes);
  190.           sensorGyroUpdateAxes = FALSE;
  191.         }
  192.         if (status == HAL_GYRO_DATA_READY)
  193.         {
  194.           readGyroData();
  195.           osal_start_timerEx( sensorTag_TaskID, ST_GYROSCOPE_SENSOR_EVT, sensorGyrPeriod - GYRO_STARTUP_TIME);
  196.         }
  197.         else
  198.         {
  199.           // Gyro needs to be activated;
  200.           HalGyroWakeUp();
  201.           osal_start_timerEx( sensorTag_TaskID, ST_GYROSCOPE_SENSOR_EVT, GYRO_STARTUP_TIME);
  202.         }
  203.       }
  204.     }
  205.     else
  206.     {
  207.       HalGyroTurnOff();
  208.       resetCharacteristicValue( GYROSCOPE_SERV_UUID, SENSOR_DATA, 0, GYROSCOPE_DATA_LEN);
  209.       resetCharacteristicValue( GYROSCOPE_SERV_UUID, SENSOR_CONF, ST_CFG_SENSOR_DISABLE, sizeof( uint8 ));
  210.     }
  211.     return (events ^ ST_GYROSCOPE_SENSOR_EVT);
  212.   }
  213. #if defined ( PLUS_BROADCASTER )
  214.   if ( events & ST_ADV_IN_CONNECTION_EVT )
  215.   {
  216.     uint8 turnOnAdv = TRUE;
  217.     // Turn on advertising while in a connection
  218.     GAPRole_SetParameter( GAPROLE_ADVERT_ENABLED, sizeof( uint8 ), &turnOnAdv );
  219.     return (events ^ ST_ADV_IN_CONNECTION_EVT);
  220.   }
  221. #endif // PLUS_BROADCASTER
  222.   // Discard unknown events
  223.   return 0;
  224. }
复制代码
我找了很久也没找到LED方面的,又往下盾发现了这个:
  2. * @fn      testChangeCB
  3. *
  4. * @brief   Callback from Test indicating a value change
  5. *
  6. * @param   paramID - parameter ID of the value that was changed.
  7. *
  8. * @return  none
  9. */
  10. static void testChangeCB( uint8 paramID )
  11. {
  12.   if( paramID == TEST_CONF_ATTR )
  13.   {
  14.     uint8 newValue;
  15.     Test_GetParameter( TEST_CONF_ATTR, &newValue );
  16.     if (newValue & TEST_MODE_ENABLE)
  17.     {
  18.       testMode = TRUE;
  19.     }
  20.     else
  21.     {
  22.       testMode = FALSE;
  23.     }
  24.     if (testMode)
  25.     {
  26.       // Test mode: possible to operate LEDs. Key hits will cause notifications,
  27.       // side key does not influence connection state
  28.       if (newValue & 0x01)
  29.       {
  30.         HalLedSet(HAL_LED_1,HAL_LED_MODE_ON);
  31.       }
  32.       else
  33.       {
  34.         HalLedSet(HAL_LED_1,HAL_LED_MODE_OFF);
  35.       }
  36.       if (newValue & 0x02)
  37.       {
  38.         HalLedSet(HAL_LED_2,HAL_LED_MODE_ON);
  39.       }
  40.       else
  41.       {
  42.         HalLedSet(HAL_LED_2,HAL_LED_MODE_OFF);
  43.       }
  44.     }
  45.     else
  46.     {
  47.       // Normal mode; make sure LEDs are reset and attribute cleared
  48.       HalLedSet(HAL_LED_1,HAL_LED_MODE_OFF);
  49.       HalLedSet(HAL_LED_2,HAL_LED_MODE_OFF);
  50.       newValue = 0x00;
  51.       Test_SetParameter( TEST_CONF_ATTR, 1, &newValue );
  52.     }
  53.   }
  54. }
复制代码
这个就是LED的原码。从上边可以分析出只要每一比特为1且后边是1的就是第一个LED亮,是2为第二个LED亮,是0为两个全灭。
恩,看来我只要找到一种方法能发出一种广播,并且UUID发对就可以控制LED,把LED换成控制信号,就可控制我的继电器从而控制开关。
感觉离结束不远了。欲知后事如何且听下文分解。
此帖出自无线连接论坛
