527
41
求助啊,楼主,我用的是CY7C68013A+24LC64,已下载saleae.icc和设备管理器已识别,也用的saleae 1.1.15,但是打开连接出现问题,不知楼主是否也遇见过类似问题System crash dump file: C:/Documents and Settings/Administrator/Application Data/Saleae LLC/Logic/Errors/10_29_2016__15_09_20.dmp
Logic Assert Information
Version: 1.1.15
System: Windows 5.1 Service Pack 3
File: ..\source\LogicAnalyzerDevice.cpp
Function: LogicAnalyzerDevice::ReadEeprom, Line: 393
Error: LogicAnalyzerDevice::ReadEeprom failed after 3 tries.
Most recent messages:
Using Font 'Tahoma' with point size '9'  [ Main.cpp; WinMain; 173 ]
Current Path: D:/saleae logic analyzer 1.1.15  [ Environment.cpp; Environment::Environment; 42 ]
Release Mode; analyzer path is D:/saleae logic analyzer 1.1.15/Analyzers  [ Environment.cpp; Environment::Environment; 53 ]
Analyzer file name: CanAnalyzer.dll, suffix: dll  [ AnalyzerManager.cpp; AnalyzerManager::LoadAnalyzersAtPath; 61 ]
Analyzer file name: Dmx512Analyzer.dll, suffix: dll  [ AnalyzerManager.cpp; AnalyzerManager::LoadAnalyzersAtPath; 61 ]
Analyzer file name: I2cAnalyzer.dll, suffix: dll  [ AnalyzerManager.cpp; AnalyzerManager::LoadAnalyzersAtPath; 61 ]
Analyzer file name: I2sAnalyzer.dll, suffix: dll  [ AnalyzerManager.cpp; AnalyzerManager::LoadAnalyzersAtPath; 61 ]
Analyzer file name: ManchesterAnalyzer.dll, suffix: dll  [ AnalyzerManager.cpp; AnalyzerManager::LoadAnalyzersAtPath; 61 ]
Analyzer file name: OneWireAnalyzer.dll, suffix: dll  [ AnalyzerManager.cpp; AnalyzerManager::LoadAnalyzersAtPath; 61 ]
Analyzer file name: SerialAnalyzer.dll, suffix: dll  [ AnalyzerManager.cpp; AnalyzerManager::LoadAnalyzersAtPath; 61 ]
Analyzer file name: SimpleParallelAnalyzer.dll, suffix: dll  [ AnalyzerManager.cpp; AnalyzerManager::LoadAnalyzersAtPath; 61 ]
Analyzer file name: SpiAnalyzer.dll, suffix: dll  [ AnalyzerManager.cpp; AnalyzerManager::LoadAnalyzersAtPath; 61 ]
Analyzer file name: UnioAnalyzer.dll, suffix: dll  [ AnalyzerManager.cpp; AnalyzerManager::LoadAnalyzersAtPath; 61 ]
  [ UsbDevice.cpp; UsbDevice::UsbDevice; 55 ]
  [ UsbDevice.cpp; UsbDevice::IsFirmwareDownloaded; 96 ]
0 endpoints  [ UsbDevice.cpp; UsbDevice::IsFirmwareDownloaded; 100 ]
  [ UsbDevice.cpp; UsbDevice::DownloadFirmware; 123 ]
~LogicDevice()  [ WindowsUsbDevice.cpp; WindowsUsbDevice::~WindowsUsbDevice; 57 ]
  [ UsbDevice.cpp; UsbDevice::~UsbDevice; 60 ]
connect_count=0  [ DataFacade.cpp; DataFacade::OnConnect; 605 ]
connect_count=1  [ DataFacade.cpp; DataFacade::OnConnect; 605 ]
setting PrimaryDisplay's Session to empty.  [ PrimaryDisplay.cpp; PrimaryDisplay::SetSession; 423 ]
4 endpoints  [ UsbDevice.cpp; UsbDevice::IsFirmwareDownloaded; 100 ]
  [ LogicAnalyzerDevice.cpp; LogicAnalyzerDevice::LogicAnalyzerDevice; 21 ]
  [ LogicAnalyzerDevice.cpp; LogicAnalyzerDevice::GetIdFromDevice; 227 ]
RecoverableException: WinUsb_ReadPipe failed; ÖØμt I/O 2ù×÷Ôú½øDDÖD¡£
  [ WindowsUsbDevice.cpp; WindowsUsbDevice::Read; 140 ]
这个问题解决了没  详情 回复 发表于 2018-5-21 23:10
527
42
还有个问题,烧录完saleae.iic后,EZ-USB interface就无法识别FX2LP,若想重新烧录IIC文件,如何操作啊,谢谢
看我最后一张图的说明,最下面一行  详情 回复 发表于 2016-10-29 23:34
527
43
能否传下usbee suite pro的安装包啊
2002
24
44
springvirus 发表于 2016-10-29 14:21
还有个问题,烧录完saleae.iic后,EZ-USB interface就无法识别FX2LP,若想重新烧录IIC文件,如何操作啊,谢 ...
看我最后一张图的说明,最下面一行
1706
45
深度和采样速率最大多大呢???能高快板子玩玩???
117
46
springvirus 发表于 2016-10-29 14:17
求助啊,楼主,我用的是CY7C68013A+24LC64,已下载saleae.icc和设备管理器已识别,也用的saleae 1.1.15,但 ...
这个问题解决了没
放弃了,买了个成品  详情 回复 发表于 2018-5-24 16:31
527
47
anmko 发表于 2018-5-21 23:10
这个问题解决了没
放弃了,买了个成品
我的只支持1.0几的版本,也放弃了  详情 回复 发表于 2018-5-27 20:14
117
48
springvirus 发表于 2018-5-24 16:31
放弃了,买了个成品
我的只支持1.0几的版本,也放弃了
49
这个问题解决了没
看了错误报告说是读取EPROM错误,回去我换小容量EPROM试一下,或者24Cxx部分的硬件都做成跟原版一样的看看
楼主的动手能力一流的。很nice!
