8077|3
刚接触STM32,谁能帮我用SYStick做一个 持续一秒进入一次中断的定时器 [复制链接]
如题,谢谢
此帖出自stm32/stm8论坛
这样应该差不多了吧  详情 回复 发表于 2012-7-16 22:16
177
#include "stm32f10x.h"
//#include"stm32f10x_gpio.h"
#define RCC_GPIO_LED                                 RCC_APB2Periph_GPIOF
#define GPIO_LED_PORT                                GPIOF
#define GPIO_LED1                                    GPIO_Pin_6
#define GPIO_LED2                                    GPIO_Pin_7
#define GPIO_LED3                                    GPIO_Pin_8
#define GPIO_LED4                                    GPIO_Pin_9
#define GPIO_LED_ALL                                 GPIO_LED1 |GPIO_LED2 |GPIO_LED3 |GPIO_LED4
void LED_config(void)
  GPIO_InitTypeDef GPIO_InitStructure;
  /* Enable GPIOB, GPIOC and AFIO clock */
  RCC_APB2PeriphClockCmd(RCC_GPIO_LED | RCC_APB2Periph_AFIO , ENABLE);  //RCC_APB2Periph_AFIO
  /* LEDs pins configuration */
  GPIO_InitStructure.GPIO_Pin = GPIO_LED_ALL;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  GPIO_Init(GPIO_LED_PORT, &GPIO_InitStructure);
void Led_Turn_off_all(u8 n)
        switch(n)
        case 0:
        GPIO_SetBits(GPIOF,GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_6);
        break;
        case 1:
        GPIO_SetBits(GPIOF,GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_7);
        break;
        case 2:
        GPIO_SetBits(GPIOF,GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_8);
        break;
        case 3:
        GPIO_SetBits(GPIOF,GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9);
        break;
void Led_Turn_on_all(u8 n)
   switch(n)
   case 0:
   GPIO_ResetBits(GPIOF,GPIO_Pin_6);
   break;
   case 1:
   GPIO_ResetBits(GPIOF,GPIO_Pin_7);
   break;
   case 2:
   GPIO_ResetBits(GPIOF,GPIO_Pin_8);
   break;
   case 3:
   GPIO_ResetBits(GPIOF,GPIO_Pin_9);
   break;
void LED_Spark(void)
  static __IO uint32_t TimingDelayLocal = 0;
  static __IO u8 n = 0;
  if (TimingDelayLocal != 0x00)         //如果不为0
    if(TimingDelayLocal < 50)  // 后50次熄灭LED指示灯
      Led_Turn_off_all(n);
    else                      // 前50次点亮LED指示灯
      Led_Turn_on_all(n);
    TimingDelayLocal--; // 该函数每一次被调用静态本地变量TimingDelayLocal便会减一
  else
    TimingDelayLocal = 100;
        n++;
          if (n>3) n=0;
* 函数名                  : SysTick_Configuration
* 功能                    : 配置SysTick 时基
* 输入          : 无
* 输出          : 无
* 返回          : 无
void SysTick_Configuration(void)
  /* Setup SysTick Timer for 10 msec interrupts  */
  //时间计算就是 SystemCoreClock/(SystemCoreClock/50)
  if (SysTick_Config(SystemCoreClock / 100)) //SysTick配置函数,传递的参数是初值          1/100S
    /* Vector error */
    while (1);
/* Configure the SysTick handler priority */
  NVIC_SetPriority(SysTick_IRQn, 0x0);//SysTick中断优先级设置
void InterruptConfig(void)
  /* Set the Vector Table base address at 0x08000000 */
  NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x00000);
int main(void)
  LED_config();              //LED使用的GPIO初始化
  Led_Turn_on_all(4);         //点亮所有的LED灯
  SysTick_Configuration();     //SysTick中断配置
  /*主循环 */
  while (1)
此帖出自stm32/stm8论坛
个人签名到底是学习ARM7还是学习STM32,纠结中,求指导。
177
#include "stm32f10x_it.h"
extern void LED_Spark(void);
void SysTick_Handler(void)
   LED_Spark();//LED 启动函数,在中断里自己加的
此帖出自stm32/stm8论坛
177
这样应该差不多了吧
此帖出自stm32/stm8论坛
