3311|4
3238
基于NRF905的无线模块编程代码 [复制链接]
//#include
#include
//#include
//#define MULTITX_PROGRAM in Target->Options->C51
#include "def.h"
#include "nRf905\nRF905.h"
#include "elseFiles\func.h"
                            //#include "print\print.h"
#define ID_H 0x4e
#define ID_L 0x05
unsigned char TxFlag=0;
#define TIME_DELAY_DEF 0
#define TIME_LIMIT_DEF 15
unsigned char time_delay = TIME_DELAY_DEF;
unsigned char time_limit = TIME_LIMIT_DEF;
unsigned char TxBuf[4];
unsigned char RxBuf[32];
//定时器中断函数
#pragma vector=TIMERA0_VECTOR
__interrupt void timer_A(void)
  //WDTCTL=WDT_ARST_1000;         //0.5s中断一次,喂狗一次
        if (time_delay
void ChangeModeAndTx()
                unsigned char i = 0;
                unsigned int randt;
//P0=P0>>1;        //调试用
//if (P0==0x0f) P0=0xff;
                if (nRF905State != RXSTATE)
                        SetRxMode();
                while(CheckCD())
                        i++;
                        randt = ID_H*0x100 + ID_L;
                //        randt = i*rand()/0x100;
                        time_delay_for(randt);
                SetTxMode();
                TxPacket(TxBuf);                //发送数据包
                SetRxMode();
//具体核对代码可根据需要修改,这里只是作一个示范
unsigned char CheckACKData()
        unsigned char i,j;
        j=RxBuf[0];
        for (i=0;i         {
                if (RxBuf[j*2]==ID_H && RxBuf[j*2+1]==ID_L)
                        return 1;
//        for (i=0;i<0x20;i++) print_Hex(RxBuf,0);
        return 0;
//准备发送下一组数据,具体代码可根据需要修改,这里同样是示范
void DataContinue()
        TxFlag++;
        TxBuf[2] = TxFlag;
void DataAgain()
        TxBuf[2] = TxFlag;
//P0=P0>>1;        //调试用
void main()
//        unsigned int i,j;
    WDTCTL=WDTPW+WDTHOLD;    //先关闭看门狗
    //P2DIR = 0X08 ;
    TACTL=TASSEL0+TACLR;        //选择时钟为ACLK,并且清除计数器
    CCTL0=CCIE;                   //CCR0允许中断
    CCR0=3276;                  //0.1s中断一次
    TACTL |= MC0;                 //设置工作模式为增计数模式
    _EINT();                       //开总中断
    //_BIS_SR(LPM3_bits);           //进入低功耗模式3
        TxBuf[0] = ID_H;
        TxBuf[1] = ID_L;
        TxBuf[2] = TxFlag;
        //<初始化>
        //print_init();
        nRF905Init();
        Config905();
//        SetTxMode();
//        srand( ID_H*0x100 + ID_L );        //通过2字节的ID生成随机数种子
//P0=0xff;
        //print_Str("MUltiTx_v0.1\n\r");
        ChangeModeAndTx();
        while(1)
//                while(P1&0x01 == 1);        //等待按键
                while (CheckDR()==0)        //等待接收端的ACK响应
                        if (time_delay                         {
                        else        //<超时,数据重发>
                                DataAgain();
                                ChangeModeAndTx();
//P0=P0>>1;        //调试用
                //print_Str("\n\r#");
                //print_Hex(time_delay,0);
                RxPacket(RxBuf);
                if ( CheckACKData() )        //接收端返回ACK响应
                        //print_Str("\n\rNext");
                        DataContinue();        //准备发送下一组数据
                        ChangeModeAndTx();
                else                //返回的响应不符合要求继续等待
                        //print_Str("\n\r#AG");
                        DataAgain();
自己是菜鸟,学习学习  详情 回复 发表于 2014-4-2 15:16
5015
裸片初长成(初级)
是测试通过的吗?
3238
回复 沙发 wstt 的帖子
是,这个程序通过了!
89
这程序不全面呀。
52
自己是菜鸟,学习学习
