#define HWREG(x) (*((volatile unsigned long*)(x)))
#define SYSCTL_RCGC1 0x400fe104 //时钟选通控制寄存器,TIMER0选通
#define SYSCTL_RCGC2 0x400fe108 //GPIOC接收时钟并运行
#define SYSCTL_PERIPH_GPIOC 0x00000004
#define SYSCTL_PERIPH_TIMER0 0x00010000 //依据时钟选通控制寄存器RCGCCn位定义
#define TIMER0_BASE 0x40030000
#define TIMER_0_CTL 0x0000000c
#define TIMER_0_CFG 0x00000000
#define TIMER_0_TAMR 0x00000004
#define TIMER_0_IMR 0x00000018
#define TIMER_0_ICR 0x00000024
#define TIMER_0_TAILR 0x00000028
#define TIMER_CTL_TEAN 0x00000001
#define TIMER_CFG_32_BIT_OS 0x00000001
#define TIMER_CFG_32_BIT_PER 0x00000002
#define TIMER_A 0x000000ff
#define TIMER_TIMA_TIMEOUT 0x00000001
#define TIMER_INT_DATA 15000000
#define NVIC_EN0 0xe000e100
#define INT_GPIOA 16
#define INT_TIMER0A 35
#define GPIO_PORTC_BASE 0x40006000
#define GPIO_0_DIR 0x00000400
#define GPIO_0_AFSEL 0x00000420
#define GPIO_0_DATA 0x00000000
#define GPIO_0_DR2R 0x00000500
#define GPIO_0_ODR 0x0000050c
#define GPIO_0_DEN 0x0000051c
#define PINS1 0x00000020 // GPIO pin 5
__asm void CPUcpsie (void)
CPSIE I
BX LR
void Timer0A_ISR(void)
HWREG(TIMER0_BASE+TIMER_0_ICR) = TIMER_TIMA_TIMEOUT;
HWREG(GPIO_PORTC_BASE+(GPIO_0_DATA+(PINS1<<2))) =(HWREG(GPIO_PORTC_BASE+(GPIO_0_DATA)+(PINS1<<2)))^PINS1;
HWREG(TIMER0_BASE+TIMER_0_CTL)|=TIMER_A&(TIMER_CTL_TEAN);
int main(void)
HWREG(SYSCTL_RCGC1)|=SYSCTL_PERIPH_TIMER0 & 0x0ffffffff;
HWREG(SYSCTL_RCGC2)|=SYSCTL_PERIPH_GPIOC & 0x0ffffffff;
HWREG(GPIO_PORTC_BASE+GPIO_0_DIR)|=PINS1; //GPIOPORTC5设置为输出
HWREG(GPIO_PORTC_BASE+GPIO_0_AFSEL)&=~PINS1; //GPIOPROTC5定义为普通I/O口
HWREG(GPIO_PORTC_BASE+GPIO_0_DR2R)|=PINS1; //2mA驱动
//HWREG(GPIO_PORTC_BASE+GPIO_0_ODR)|=PINS1;
HWREG(GPIO_PORTC_BASE+GPIO_0_DEN)|=PINS1;
HWREG(GPIO_PORTC_BASE+(GPIO_0_DATA+(PINS1<<2)))=~PINS1;
HWREG(TIMER0_BASE+TIMER_0_CTL)&=~(TIMER_CTL_TEAN); //禁止TIMER0
HWREG(TIMER0_BASE+TIMER_0_CFG)= TIMER_CFG_32_BIT_OS>>24; //配置GPTMCFG为32为定时器模式,但右移24位why?
HWREG(TIMER0_BASE+TIMER_0_TAMR)= TIMER_CFG_32_BIT_PER&255; //配置为周期定时器模式
HWREG(TIMER0_BASE+TIMER_0_TAILR)= TIMER_INT_DATA /4; //装载间隔值
HWREG(TIMER0_BASE+TIMER_0_IMR)|=TIMER_TIMA_TIMEOUT; //TIMERA0中断使能
HWREG(TIMER0_BASE+TIMER_0_CTL)|=TIMER_A&(TIMER_CTL_TEAN); //启动TIMER0
HWREG(NVIC_EN0)=1<<(INT_TIMER0A-INT_GPIOA); //使能TIEMER0中断
CPUcpsie();
while(1);
