3937|1
42
LM图形库(Graphics Library)的函数意思 [复制链接]
图形库手册中说的这个函数是什么意思啊?大家知道怎么编写吗?或者可以帮忙解释一下:
2.2.1.6  Pixel DrawMultiple
Draws a horizontal sequence of pixels on the screen.
Prototype:
void PixelDrawMultiple( void *pvDisplayData,
                                            long lX,
                                            long lY,
                                            long lX0,   *1*
                                            long lCount,  *2*
                                            long lBPP,  *3*
                                            const unsigned char *pucData, *4*
                                            const unsigned char *pucPalette  *5*)
参数:
lX0 is sub-pixel offset within the pixel data(应该是像素点不能超过范围), which is valid for 1 or 4 bit per pixel formats(这句是什么意思?)
lCount is the number of pixel to draw.(麻烦也顺便说明一下哈)
lBPP is the number of bits per pixel; must be 1,4, or 8(什么意思?)
pucData is a pointer to the pixel data. For 1 and 4 bit per pixel formats, the most significant bit(s) represent the left-most pixel.
pucPalette is a pointer to the palette used to draw the pixels.
函数功能描述:
This function draws a horizontal sequence of pixels on the screen, using the supplied palette. For 1 bit per pixel format, the palette contains pre-translated colors; for 4 and 8 bit per pixel formats, the palette contains 24-bit RGB values that must be translated before being written to the display.
麻烦大侠拨冗一顾,给小弟以指点!或许跟我一样的学习者大家讨论讨论~
个人签名相信自己,相信未来
42
有这样的资料
忽然想起来去年显示BMP图片的事情来了。然后把以前的资料拿来看看。把这个弄明白了。
在BMP图片中,可以读到这样的值:
biBitCount=1:黑白二色图
biBitCount=4:16色图
biBitCount=8:256色图
biBitCount=24:24位真彩色图
应该是一个意思。
其他的内容还在考虑中,也希望曾经做过这方面内容的大侠能够给指点迷津。
个人签名相信自己,相信未来
