5460|4
LM3S中uart初始化只有,只有uart0有用,uart1没数据出来 [复制链接]
我在uart_echo例程基础上增加了uart1,但是uart1没法使用,只有uart0可以用。以下是我的程序,看看有问题不?
    // Enable the (non-GPIO) peripherals used by this example.  PinoutSet()
    // already enabled GPIO Port A.
SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOA);
SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOD);
    SysCtlPeripheralEnable(SYSCTL_PERIPH_UART0);
SysCtlPeripheralEnable(SYSCTL_PERIPH_UART1);
    // Enable processor interrupts.
    IntMasterEnable();
    // Set GPIO A0 and A1 as UART pins.
    GPIOPinTypeUART(GPIO_PORTA_BASE, GPIO_PIN_0 | GPIO_PIN_1);
GPIOPinTypeUART(GPIO_PORTD_BASE, GPIO_PIN_2 | GPIO_PIN_3);
    // Configure the UART for 115,200, 8-N-1 operation.
    UARTConfigSetExpClk(UART0_BASE, SysCtlClockGet(), 115200,
                            (UART_CONFIG_WLEN_8 | UART_CONFIG_STOP_ONE |
                             UART_CONFIG_PAR_NONE));
UARTConfigSetExpClk(UART1_BASE, SysCtlClockGet(), 115200,
    // Enable the UART interrupt.
    IntEnable(INT_UART0);
    UARTIntEnable(UART0_BASE, UART_INT_RX | UART_INT_RT);
IntEnable(INT_UART1);
    UARTIntEnable(UART1_BASE, UART_INT_RX | UART_INT_RT);
以上是主程序中的初始化。
以下是UART1的中断程序:
void UART1IntHandler(void)
    unsigned long ulStatus;
    // Get the interrrupt status.
    ulStatus = UARTIntStatus(UART1_BASE, true);
    // Clear the asserted interrupts.
    UARTIntClear(UART1_BASE, ulStatus);
    // Loop while there are characters in the receive FIFO.
    while(UARTCharsAvail(UART1_BASE))
        // Read the next character from the UART and write it back to the UART.
        UARTCharPutNonBlocking(UART1_BASE,
                                   UARTCharGetNonBlocking(UART1_BASE));
楼主 我想问你下。  你同时调试2个串口  串口0对应PC机上的stellaris虚拟串口。 但是串口1呢~~对应PC机上的哪个串口~~? 求解  详情 回复 发表于 2011-8-1 15:25
2131
至上芯片
UART1IntHandler 在中断向量中定义了吗?
在startup_rvmdk.s中增加
如:
      EXPORT  __Vectors
__Vectors
        DCD     StackMem + Stack            ; Top of Stack
        DCD     Reset_Handler               ; Reset Handler
        DCD     NmiSR                       ; NMI Handler
        DCD     FaultISR                    ; Hard Fault Handler
        DCD     IntDefaultHandler           ; The MPU fault handler
        DCD     IntDefaultHandler           ; The bus fault handler
        DCD     IntDefaultHandler           ; The usage fault handler
        DCD     0                           ; Reserved
        DCD     0                           ; Reserved
        DCD     0                           ; Reserved
        DCD     0                           ; Reserved
        DCD     IntDefaultHandler           ; SVCall handler
        DCD     IntDefaultHandler           ; Debug monitor handler
        DCD     0                           ; Reserved
        DCD     IntDefaultHandler           ; The PendSV handler
        DCD     IntDefaultHandler           ; The SysTick handler
        DCD     IntDefaultHandler           ; GPIO Port A
        DCD     IntDefaultHandler           ; GPIO Port B
        DCD     IntDefaultHandler           ; GPIO Port C
        DCD     IntDefaultHandler           ; GPIO Port D
        DCD     IntDefaultHandler           ; GPIO Port E
        DCD     UARTIntHandler              ; UART0 Rx and Tx
        DCD     UART1IntHandler           ; UART1 Rx and Tx
个人签名处处留心皆学问!
63
还要在startup_rvmdk.s中加上
extern UARTIntHandler;
extern UART1IntHandler;
也可以不改动startup_rvmdk.s,在程序中加上
UARTIntRegister(UART0_BASE,UARTIntHandler);
UARTIntRegister(UART1_BASE,UART1IntHandler);
赞赏
查看全部赞赏
1282
回复 板凳 blackwc2006 的帖子
学习了!!
58
回复 4楼 fxw451 的帖子
【回帖赢京东卡】说说无线技术那些事儿
即日起—2月28日,参与回帖讨论都有机会赢取【30元京东卡】
