288|2
431
【🚀SO-Arm100 机械臂 ROS2 配置保姆级教程】MoveIt Setup Assistant 从 0 到 1 ... [复制链接]
邀请:@wsdymg   @bigbat   @okhxyyo   @汤权   参与回复
get?code=NGUxYmFhN2IyYzQ0MTdmOGYxNjgxYmEzOTk2ZDNlYzMsMTc0MTc4OTk1NTU4NA==
视频讲解:
Package仓库地址:LitchiCheng/ros2_package
启动moveit_setup_assistant
ros2 launch moveit_setup_assistant setup_assistant.launch.py
get?code=NmQ5YWRkMDg5MzlhZmY3Zjc5MjlmNWM2ZDJhOWM5MzEsMTc0MTc4OTk1NTU4NA==
选择导入urdf文件,如果urdf中引用的package搜索不到,会直接崩溃,需要先source install/setup.bash,具体参考《ROS2导入机械臂URDF竟有这些坑?SO-ARM100 Rivz可视化避坑指南》
[moveit_setup_assistant-1] Qt: Session management error: networkIdsList argument is NULL[moveit_setup_assistant-1] terminate called after throwing an instance of 'ament_index_cpp::PackageNotFoundError'
[moveit_setup_assistant-1]   what():  package 'display_urdf_launch' not found, searching: [/opt/ros/humble]
[moveit_setup_assistant-1] Stack trace (most recent call last):
[moveit_setup_assistant-1] #31   Object "/usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5.15.3", at 0x7e3740172e46, in QApplicationPrivate::sendMouseEvent(QWidget*, QMouseEvent*, QWidget*, QWidget*, QWidget**, QPointer<QWidget>&, bool, bool)
[moveit_setup_assistant-1] #30   Object "/usr/lib/x86_64-linux-gnu/libQt5Core.so.5.15.3", at 0x7e373f4b9e39, in QCoreApplication::notifyInternal2(QObject*, QEvent*)
get?code=YWM2ODAwOWUwNGEyMjkzYzJlY2U1Yjg4ZmIxYTMyZWEsMTc0MTc4OTk1NTU4NA==
点击Load Files,加载完成后,右侧会出现模型,和Rviz中一样,可以拖动显示
get?code=NTFkZDRlZDg1MjI4MzgxNWEwMjRlY2NiNGExN2I2YzUsMTc0MTc4OTk1NTU4NA==
下一步点击左侧的Self-Collsions配置关节碰撞相关的参数,如果没有出现link,勾上右下角的show enabled pairs
get?code=NDlmOTBmOWEwNWVlOTEwNmMwYzM3NGExNWQ4NjlkMTAsMTc0MTc4OTk1NTU4NA==
然后可以点击Generate Collision Matrix生成碰撞矩阵
get?code=ZWU2NjAzZTk5MDgwNGU4ODNhMmEyM2M5NDE0ZDA2YzEsMTc0MTc4OTk1NTU4NA==
点击左侧Virtual Joint,配置虚关节,用来将基座放置在哪儿
get?code=MDJhZWNkYzcwNTU1ZTIwYzliNmE4YWQ2NzBjMzg4NDEsMTc0MTc4OTk1NTU4NA==
配置Planning Groups,这个作用在Moveit规划的文章里面我们用过,就是要指定规划的组名,比如so-arm100-groups,就是这里了,运动学求解器选择一个即可,OMPL的planning我们选常用的RTTConnect
get?code=ZDc1ZjEzNmExZWZjMzdmOGVmYzk4OWVlZTg2NDIzNDksMTc0MTc4OTk1NTU4NA==
add joints,需要把这个组里面规划的关节都选中,最后配好的效果如下
get?code=NTI0MGMxZTJmMmYzODNhNzQwMjg1MjMzOWUxMDM4NTksMTc0MTc4OTk1NTU4NA==
创建机器人位姿,如home位置
get?code=YzQyM2M0ODI2ZTJjODY5YjFkOWU4OTU1MzlhMDdmNGYsMTc0MTc4OTk1NTU4NA==
没有末端夹爪或其他执行器,End Effectors不用管
get?code=ZTE5NWU3ZTQyYWE5OWEzYTllYTAzMGNiOWIzNDljMDgsMTc0MTc4OTk1NTU4NA==
增加ros2_control到urdf文件中
get?code=ODg2YzAxNTJmMGU3N2RkOWE0MmQ4OTBjMjRhNjU0MzQsMTc0MTc4OTk1NTU4NA==
自动添加关节轨迹控制器到Planning Group中
get?code=NzQ5MTNkNDk5MjM4NTNkZjQ1MDY2ODdlMzI5M2FiYjUsMTc0MTc4OTk1NTU4NA==
Moveit Controllers也是同样,电机auto
get?code=NzNhY2E5NDAyNDdiNjNmNjRlMDE1ZjM4YWY3OTFkYjQsMTc0MTc4OTk1NTU4NA==
没有感知器件,如3d传感器,点云之类的也不用配置
get?code=MzM4NzFiZmY1MGJmNmM1NDMwODk2NDcwZWY3ZGZjYTUsMTc0MTc4OTk1NTU4NA==
检查下等下要生成的文件,默认都是勾上的
get?code=MTYzYjA3MjgxNGYzODgwMmQwZjI5MDRmMTYyNmUyNTIsMTc0MTc4OTk1NTU4NA==
添加作者信息
get?code=MGIyZjQ1ZjU3YzAzNDU1NWNlYTExYWZiNzc1NTg2NzIsMTc0MTc4OTk1NTU4NQ==
选择工作空间下src中新建一个package,比如so_arm100_moveit,然后生成的包就会到里面
get?code=YWMyODcxNTkyMTIxYjI2MzRiOWFjZjU2MWM2MjYwYjksMTc0MTc4OTk1NTU4NQ==
编译运行
colcon build --packages-select so_arm100_moveit
ros2 launch so_arm100_moveit demo.launch.py
get?code=Y2E2ZjJjOGFjZWZiYTEwMzE2MDVhM2UwMjRjNjI0MWMsMTc0MTc4OTk1NTU4NQ==
看来ROS2导入机械臂URDF竟有这些坑?还得好好读读   详情 回复 发表于 7 天前
7002
挺长的,有问题可以留言  详情 回复 发表于 7 天前
431
Jacktang 发表于 2025-3-13 07:27 看来ROS2导入机械臂URDF竟有这些坑?还得好好读读
挺长的,有问题可以留言
