视频讲解
安装环境依赖
sudo apt-get install ros-humble-tf2-ros ros-humble-tf2-geometry-msgs ros-humble-tf-transformations
创建一个包名为tf_test_pkg的包
ros2 pkg create --build-type ament_python tf_test_pkg --dependencies rclpy tf2_ros geometry_msgs
依赖为tf2_ros,geometry_msgs
在tf_test_pkg/tf_test_pkg中创建tf_publisher.py
import rclpy
from rclpy.node import Node
from geometry_msgs.msg import TransformStamped
import tf2_ros
import math
class TFPublisher(Node):
def __init__(self):
super().__init__('tf_publisher')
self.tf_broadcaster = tf2_ros.TransformBroadcaster(self)
self.timer = self.create_timer(0.1, self.broadcast_tf)
self.pitch = 0.0
def broadcast_tf(self):
t = TransformStamped()
t.header.stamp = self.get_clock().now().to_msg()
t.header.frame_id = '/base_link'
t.child_frame_id = '/test_link'
# 设置平移
t.transform.translation.x = 1.0
t.transform.translation.y = 0.0
t.transform.translation.z = 0.0
# 增加pitch角度
self.pitch += 0.2
if self.pitch > 2 * math.pi:
self.pitch -= 2 * math.pi
# 设置旋转(仅pitch变化)
from tf_transformations import quaternion_from_euler
q = quaternion_from_euler(0, self.pitch, 0)
t.transform.rotation.x = q[0]
t.transform.rotation.y = q[1]
t.transform.rotation.z = q[2]
t.transform.rotation.w = q[3]
# 发布TF变换
self.tf_broadcaster.sendTransform(t)
def main(args=None):
rclpy.init(args=args)
tf_publisher = TFPublisher()
rclpy.spin(tf_publisher)
tf_publisher.destroy_node()
rclpy.shutdown()
if __name__ == '__main__':
main()
同样的,创建tf_subscriber.py
import rclpy
import tf2_ros
from tf2_ros.buffer import Buffer
from tf2_ros.transform_listener import TransformListener
class TFSubscriber(Node):
def __init__(self):
super().__init__('tf_subscriber')
self.tf_buffer = Buffer()
self.tf_listener = TransformListener(self.tf_buffer, self)
self.timer = self.create_timer(1.0, self.lookup_transform)
def lookup_transform(self):
try:
trans = self.tf_buffer.lookup_transform(
'base_link', 'test_link', rclpy.time.Time())
self.get_logger().info(f"Translation: {trans.transform.translation}")
self.get_logger().info(f"Rotation: {trans.transform.rotation}")
except (tf2_ros.LookupException, tf2_ros.ConnectivityException, tf2_ros.ExtrapolationException):
self.get_logger().warn("Could not find transform between /base_link and /test_link")
tf_subscriber = TFSubscriber()
rclpy.spin(tf_subscriber)
tf_subscriber.destroy_node()
rclpy.shutdown()
main()
修改setup.py,增加内容如下:
entry_points={
'console_scripts': [
'tf_publisher = tf_test_pkg.tf_publisher:main',
'tf_subscriber = tf_test_pkg.tf_subscriber:main',
编译运行
colcon build --packages-select tf_test_pkg
source install/setup.bash
ros2 run tf_test_pkg tf_publisher
ros2 run tf_test_pkg tf_subscriber
rviz2配置
设置固定坐标系
启动 Rviz 后,在 Rviz 窗口左侧的 “Displays” 面板中,找到 “Global Options” 部分,点击 “Fixed Frame” 右侧的下拉框,选择 /base_link 作为固定坐标系。这一步很关键,因为 Rviz 会以固定坐标系为参考来显示其他坐标系的位置和姿态。
添加 TF 显示插件
在 Rviz 窗口左侧 “Displays” 面板的上方,点击 “Add” 按钮,在弹出的 “Add Display” 对话框中,选择 “TF” 选项,然后点击 “OK”。此时,“Displays” 面板中会新增一个 “TF” 条目。
调整 TF 显示设置
在 “Displays” 面板中展开 “TF” 条目
- Marker Scale:用于调整坐标系箭头的大小。你可以根据实际情况增大或减小该值,使显示效果更清晰。
- Show Axes:勾选该选项会显示每个坐标系的坐标轴(X 轴为红色,Y 轴为绿色,Z 轴为蓝色),方便直观地了解坐标系的方向。
- Show Names:勾选此选项会在每个坐标系旁边显示其名称(如 /base_link 和 /test_link),便于识别不同的坐标系。
