350|3
171
《Rust实战》读书笔记——第11章,内内内内核 [复制链接]
郭德纲说于谦办了个VIP 中P,这章作者写的内核那叫一个短小精悍,那真是最里面的那层核,就一个字——能跑。
前3页比较有用——搭建环境。需要用到qemu(虚拟机容器)、bootimage包(构建引导映像),rust源码和llvm-tools(生成编译器)、以及cargo的辅助包。
然后作者写了第0版OS,非常短主要功能是很暴力的直接写内存,按VGA字符标准显示一色块:
#![no_std]
#![no_main]
#![feature(core_intrinsics)]
use core::intrinsics;
use core::panic::PanicInfo;
#[panic_handler]
#[no_mangle]
pub fn panic(_info: &PanicInfo) -> ! {
  intrinsics::abort();
#[no_mangle]
pub extern "C" fn _start() -> ! {
  let framebuffer = 0xb8000 as *mut u8;
  unsafe {
    framebuffer
      .offset(1)
      .write_volatile(0x30);
  loop {}
注意,由于#![no_std],导致很多标准特性都不再可用。
为了在loop中,让cpu能喘口气、处理中断、节点能,在第1版里,加了x86_64::instructions::{hlt},然后在loop里用一句话用来暂时挂起:
hlt();
第2版,加了几行用来处理异常:
#[lang = "eh_personality"]
#[no_mangle]
pub extern "C" fn eh_personality() { }
第3版,作者实现了可以输出彩色字符:
#[allow(unused)]
#[derive(Clone,Copy)]
#[repr(u8)]
enum Color {
  Black = 0x0,    White = 0xF,
  Blue = 0x1,     BrightBlue = 0x9,
  Green = 0x2,    BrightGreen = 0xA,
  Cyan = 0x3,     BrightCyan = 0xB,
  Red = 0x4,      BrightRed = 0xC,
  Magenta = 0x5,  BrightMagenta = 0xD,
  Brown = 0x6,    Yellow = 0xE,
  Gray = 0x7,     DarkGray = 0x8
struct Cursor {
  position: isize,
  foreground: Color,
  background: Color,
impl Cursor {
  fn color(&self) -> u8 {
    let fg = self.foreground as u8;
    let bg = (self.background as u8) << 4;
    fg | bg
  fn print(&mut self, text: &[u8]) {
    let color = self.color();
    for &character in text {
      unsafe {
        framebuffer.offset(self.position).write_volatile(character);
        framebuffer.offset(self.position + 1).write_volatile(color);
      self.position += 2;
第4版,use core::fmt::Write实现了格式化输出:
#![feature(lang_items)]
#![no_std]
#![no_main]
use core::fmt;
use core::fmt::Write;
use x86_64::instructions::{hlt};
#[allow(unused)]
#[derive(Copy, Clone)]
#[repr(u8)]
enum Color {
struct Cursor {
  position: isize,
  foreground: Color,
  background: Color,
impl Cursor {
    fg | bg
      unsafe {
      self.position += 2;
impl fmt::Write for Cursor {
  fn write_str(&mut self, s: &str) -> fmt::Result {
    self.print(s.as_bytes());
    Ok(())
#[panic_handler]
#[no_mangle]
pub fn panic(info: &PanicInfo) -> ! {
  let mut cursor = Cursor {
    position: 0,
    foreground: Color::White,
    background: Color::Red,
  for _ in 0..(80*25) {
    cursor.print(b" ");
  cursor.position = 0;
  write!(cursor, "{}", info).unwrap();
  loop { unsafe { hlt(); }}
#[no_mangle]
#[no_mangle]
  panic!("help!");
所以,最后实现的效果是一段只有底层特性的程序,不太费电,能马马虎虎对付异常,万一出错了能输出。
第369页总结“费了很大的劲实现了这个什么都不会做的功能”,但是我觉得至少搭了个OS的helloworld。
此帖出自编程基础论坛
加一堆 #[] 和不安全操作,为啥不用 C ?   详情 回复 发表于 2024-6-24 14:29
6139
#![no_std]这玩意是个啥
此帖出自编程基础论坛
std是标准库,标准库会调用操作系统进行内存分配。由于这一章本来就是要做个OS内核,所以是在裸机启动的,不能依赖操作系统,所以用这个形式把标准库禁用。  详情 回复 发表于 2024-6-20 12:37
171
Jacktang 发表于 2024-6-20 07:26 由于#![no_std],导致很多标准特性都不再可用 #![no_std]这玩意是个啥
此帖出自编程基础论坛
7166
此帖出自编程基础论坛
默认摸鱼,再摸鱼。2022、9、28
