387|0
410
【ACM32G103RCT6开发板测评】+ 串口printf [复制链接]
测试串口打印功能。
一、硬件部分
板卡上的仿真器带有虚拟串口,连接到ACM32G103的串口2接口
二、程序部分
2.1、hal_uart.c
这部分程序在SDK驱动程序中已经对串口的接口进行定义,不需要程序再重新定义
*[url=home.php?mod=space&uid=159083]@brief[/url]  : Initialize the UART MSP: CLK, GPIO, NVIC
*@param : huart: uart handle with UART parameters.
*@return: None
__weak void HAL_UART_MspInit(UART_HandleTypeDef *huart)
      NOTE: This function should be modified, when the callback is needed,
      the HAL_UART_MspInit can be implemented in the user file.
    /* For Example */
    GPIO_InitTypeDef    GPIO_Uart = {0};
    if (huart->Instance == UART1)
        /* Enable Clock */
        __HAL_RCC_UART1_CLK_ENABLE();
        __HAL_RCC_GPIOA_CLK_ENABLE();
        /* A9:Tx  A10:Rx */
        GPIO_Uart.Pin       = GPIO_PIN_9 | GPIO_PIN_10;
        GPIO_Uart.Mode      = GPIO_MODE_AF_PP;
        GPIO_Uart.Pull      = GPIO_PULLUP;
        GPIO_Uart.Drive     = GPIO_DRIVE_LEVEL3;
        GPIO_Uart.Alternate = GPIO_FUNCTION_1;
        HAL_GPIO_Init(GPIOA, &GPIO_Uart);
        if (huart->Init.HwFlowCtl & UART_HWCONTROL_CTS)
            /* A11:CTS */
            GPIO_Uart.Pin = GPIO_PIN_11;
        if (huart->Init.HwFlowCtl & UART_HWCONTROL_RTS)
            /* A12:RTS */
            GPIO_Uart.Pin = GPIO_PIN_12;
        /* NVIC Config */
        NVIC_ClearPendingIRQ(UART1_IRQn);
        NVIC_SetPriority(UART1_IRQn, 5);
        NVIC_EnableIRQ(UART1_IRQn);
    else if (huart->Instance == UART2)
        /* Enable Clock */
        __HAL_RCC_UART2_CLK_ENABLE();
        /* A2:Tx  A3:Rx */
        GPIO_Uart.Pin       = GPIO_PIN_2 | GPIO_PIN_3;
            /* A0:CTS */
            GPIO_Uart.Pin = GPIO_PIN_0;
            /* A1:RTS */
            GPIO_Uart.Pin = GPIO_PIN_1;
        /* NVIC Config */
        NVIC_ClearPendingIRQ(UART2_IRQn);
        NVIC_SetPriority(UART2_IRQn, 5);
        NVIC_EnableIRQ(UART2_IRQn);
    else if(huart->Instance == UART3)
        /* Enable Clock */
        __HAL_RCC_GPIOB_CLK_ENABLE();
        __HAL_RCC_UART3_CLK_ENABLE();
        /* B10:Tx  B11:Rx */
        GPIO_Uart.Pin       = GPIO_PIN_10 | GPIO_PIN_11;
        HAL_GPIO_Init(GPIOB, &GPIO_Uart);
            /* B13:CTS */
            GPIO_Uart.Pin = GPIO_PIN_13;
            GPIO_Uart.Alternate = GPIO_FUNCTION_0;
            /* B14:RTS */
            GPIO_Uart.Pin = GPIO_PIN_14;
        /* NVIC Config */
        NVIC_ClearPendingIRQ(UART3_IRQn);
        NVIC_SetPriority(UART3_IRQn, 5);
        NVIC_EnableIRQ(UART3_IRQn);
    else if(huart->Instance == UART4)
        /* Enable Clock */
        __HAL_RCC_UART4_CLK_ENABLE();
        /* A0:Tx  A1:Rx */
        GPIO_Uart.Pin       = GPIO_PIN_0 | GPIO_PIN_1;
        GPIO_Uart.Alternate = GPIO_FUNCTION_3;
            /* B7:CTS */
            GPIO_Uart.Pin = GPIO_PIN_7;
            GPIO_Uart.Alternate = GPIO_FUNCTION_4;
            /* A15:RTS */
            GPIO_Uart.Pin = GPIO_PIN_15;
        /* NVIC Config */
        NVIC_ClearPendingIRQ(UART4_IRQn);
        NVIC_SetPriority(UART4_IRQn, 5);
        NVIC_EnableIRQ(UART4_IRQn);
2.3、usart.c
初始化串口2
#include "main.h"
UART_HandleTypeDef uart2_handle;
void usart_init(uint32_t baudrate)
	uart2_handle.Instance        = UART2;
	uart2_handle.Init.BaudRate   = baudrate;
	uart2_handle.Init.WordLength = UART_WORDLENGTH_8B;
	uart2_handle.Init.StopBits   = UART_STOPBITS_1;
	uart2_handle.Init.Parity     = UART_PARITY_NONE;
	uart2_handle.Init.Mode       = UART_MODE_TX_RX;
	uart2_handle.Init.HwFlowCtl  = UART_HWCONTROL_NONE;
	HAL_UART_Init(&uart2_handle);
	HAL_UART_SetDebugUart(uart2_handle.Instance);
2.4、main.c
主程序
#include "main.h"
int main(void)
	HAL_Init();
	SystemClock_Config();
	init_led();
	usart_init(115200);
	while(1)
		HAL_Delay(500);
		led1_tog();
		printf("https://bbs.eeworld.com.cn/\r\n");
2.5、软件配置
三、运行结果
下载程序,复位开发板后,串口输出
开源项目 更多>>
