- #include <Adafruit_NeoPixel.h>
- #define PIN 6 //LED'in Din pinini yazın
- #define NUM_LEDS 256 //Kaç tane LED'iniz varsa buraya yazın
- #define BRIGHTNESS 20
- Adafruit_NeoPixel strip = Adafruit_NeoPixel(NUM_LEDS, PIN, NEO_GRB + NEO_KHZ800);
- int mod;
- int lastmod;
- String veri;
- int randommod;
- int parlaklik = 0;
- void setup() {
- Serial.begin(9600);
- veri.reserve(5);
- strip.begin();
- strip.show();
- strip.setBrightness(BRIGHTNESS);
- Serial.println("WS2812准备就绪");
- Serial.println("串口输入1-21");
- void loop() {
- switch (mod) {
- case 1:
- Serial.println("RGBLoop");
- RGBLoop();
- break;
- case 2:
- Serial.println("Strobe");
- Strobe(0xff, 0xff, 0xff, 10, 50, 1000);
- break;
- case 3:
- Serial.println("HalloweenEyes");
- HalloweenEyes(0xff, 0x00, 0x00, 1, 4, true, random(5, 50), random(10, 50), random(50, 300));
- break;
- case 4:
- Serial.println("NewKITT RightToLeft");
- NewKITT(0xff, 0, 0, 8, 10, 50);
- break;
- case 5:
- Serial.println("Twinkle");
- Twinkle(0xff, 0, 0, 10, 100, false);
- break;
- case 6:
- Serial.println("TwinkleRandom");
- break;
- case 7:
- Serial.println("Sparkle");
- Sparkle(0xff, 0xff, 0xff, 0);
- break;
- case 8:
- Serial.println("SnowSparkle");
- SnowSparkle(0x10, 0x10, 0x10, 20, random(100, 1000));
- break;
- case 9:
- Serial.println("RunningLights");
- RunningLights(0xff, 0xff, 0x00, 50);
- break;
- case 10:
- Serial.println("colorWipe");
- colorWipe(0x00, 0xff, 0x00, 50);
- colorWipe(0xff, 0x00, 0x00, 50);
- break;
- case 11:
- Serial.println("rainbowCycle");
- rainbowCycle(20);
- break;
- case 12:
- Serial.println("theaterChase");
- theaterChase(0xff, 0, 0, 50);
- break;
- case 13:
- Serial.println("theaterChaseRainbow");
- theaterChaseRainbow(50);
- break;
- case 14:
- Serial.println("Fire");
- Fire(55, 120, 15);
- break;
- case 15:
- Serial.println("BouncingBalls");
- meteorRain(0xff, 0xff, 0xff, 10, 64, true, 30);
- break;
- case 16:
- Serial.println("meteorRain");
- break;
- case 17:
- Serial.println("Red");
- setAll(255, 0, 0);
- break;
- case 18:
- Serial.println("Green");
- setAll(0, 255, 0);
- break;
- case 19:
- Serial.println("Blue");
- setAll(0, 0, 255);
- break;
- case 20:
- Serial.println("ON");
- randommod = random(1, 19);
- switch (randommod) {
- case 1:
- RGBLoop();
- break;
- case 2:
- break;
- case 3:
- break;
- case 4:
- break;
- case 5:
- break;
- case 6:
- break;
- case 7:
- break;
- case 8:
- break;
- case 9:
- break;
- case 10:
- break;
- case 11:
- rainbowCycle(20);
- break;
- case 12:
- break;
- case 13:
- break;
- case 14:
- break;
- case 15:
- break;
- case 16:
- break;
- case 17:
- break;
- case 18:
- break;
- case 19:
- break;
- break;
- case 21:
- Serial.println("OFF");
- setAll(0, 0, 0);
- break;
- default:
- break;
- void meteorRain(byte red, byte green, byte blue, byte meteorSize, byte meteorTrailDecay, boolean meteorRandomDecay, int SpeedDelay) {
- setAll(0, 0, 0);
- for (int i = 0; i < NUM_LEDS + NUM_LEDS; i++) {
- for (int j = 0; j < NUM_LEDS; j++) {
- if ( (!meteorRandomDecay) || (random(10) > 5) ) {
- fadeToBlack(j, meteorTrailDecay );
- if (serialEvent() != false) break;
- for (int j = 0; j < meteorSize; j++) {
- if ( ( i - j < NUM_LEDS) && (i - j >= 0) ) {
- setPixel(i - j, red, green, blue);
- showStrip();
- delay(SpeedDelay);
- void fadeToBlack(int ledNo, byte fadeValue) {
- #ifdef ADAFRUIT_NEOPIXEL_H
- uint32_t oldColor;
- uint8_t r, g, b;
- int value;
- oldColor = strip.getPixelColor(ledNo);
- r = (oldColor & 0x00ff0000UL) >> 16;
- g = (oldColor & 0x0000ff00UL) >> 8;
- b = (oldColor & 0x000000ffUL);
- r = (r <= 10) ? 0 : (int) r - (r * fadeValue / 256);
- g = (g <= 10) ? 0 : (int) g - (g * fadeValue / 256);
- b = (b <= 10) ? 0 : (int) b - (b * fadeValue / 256);
- strip.setPixelColor(ledNo, r, g, b);
- #endif
- #ifndef ADAFRUIT_NEOPIXEL_H
- leds[ledNo].fadeToBlackBy( fadeValue );
- #endif
- void BouncingBalls(byte red, byte green, byte blue, int BallCount) {
- float Gravity = -9.81;
- int StartHeight = 1;
- float Height[BallCount];
- float ImpactVelocityStart = sqrt( -2 * Gravity * StartHeight );
- float ImpactVelocity[BallCount];
- float TimeSinceLastBounce[BallCount];
- int Position[BallCount];
- long ClockTimeSinceLastBounce[BallCount];
- float Dampening[BallCount];
- for (int i = 0 ; i < BallCount ; i++) {
- ClockTimeSinceLastBounce[i] = millis();
- Height[i] = StartHeight;
- Position[i] = 0;
- ImpactVelocity[i] = ImpactVelocityStart;
- TimeSinceLastBounce[i] = 0;
- Dampening[i] = 0.90 - float(i) / pow(BallCount, 2);
- while (true) {
- TimeSinceLastBounce[i] = millis() - ClockTimeSinceLastBounce[i];
- Height[i] = 0.5 * Gravity * pow( TimeSinceLastBounce[i] / 1000 , 2.0 ) + ImpactVelocity[i] * TimeSinceLastBounce[i] / 1000;
- if ( Height[i] < 0 ) {
- Height[i] = 0;
- ImpactVelocity[i] = Dampening[i] * ImpactVelocity[i];
- if ( ImpactVelocity[i] < 0.01 ) {
- Position[i] = round( Height[i] * (NUM_LEDS - 1) / StartHeight);
- setPixel(Position[i], red, green, blue);
- showStrip();
- setAll(0, 0, 0);
- void Fire(int Cooling, int Sparking, int SpeedDelay) {
- static byte heat[NUM_LEDS];
- int cooldown;
- for ( int i = 0; i < NUM_LEDS; i++) {
- cooldown = random(0, ((Cooling * 10) / NUM_LEDS) + 2);
- if (cooldown > heat[i]) {
- heat[i] = 0;
- } else {
- heat[i] = heat[i] - cooldown;
- for ( int k = NUM_LEDS - 1; k >= 2; k--) {
- heat[k] = (heat[k - 1] + heat[k - 2] + heat[k - 2]) / 3;
- if ( random(255) < Sparking ) {
- int y = random(7);
- heat[y] = heat[y] + random(160, 255);
- for ( int j = 0; j < NUM_LEDS; j++) {
- setPixelHeatColor(j, heat[j] );
- showStrip();
- void setPixelHeatColor (int Pixel, byte temperature) {
- byte t192 = round((temperature / 255.0) * 191);
- byte heatramp = t192 & 0x3F;
- heatramp <<= 2;
- if ( t192 > 0x80) {
- setPixel(Pixel, 255, 255, heatramp);
- } else if ( t192 > 0x40 ) {
- setPixel(Pixel, 255, heatramp, 0);
- } else {
- setPixel(Pixel, heatramp, 0, 0);
- void theaterChaseRainbow(int SpeedDelay) {
- byte *c;
- for (int j = 0; j < 256; j++) {
- for (int q = 0; q < 3; q++) {
- for (int i = 0; i < NUM_LEDS; i = i + 3) {
- c = Wheel( (i + j) % 255);
- setPixel(i + q, *c, *(c + 1), *(c + 2));
- showStrip();
- setPixel(i + q, 0, 0, 0);
- void theaterChase(byte red, byte green, byte blue, int SpeedDelay) {
- for (int j = 0; j < 10; j++) {
- setPixel(i + q, red, green, blue);
- showStrip();
- void rainbowCycle(int SpeedDelay) {
- byte *c;
- uint16_t i, j;
- for (j = 0; j < 256 * 5; j++) {
- for (i = 0; i < NUM_LEDS; i++) {
- c = Wheel(((i * 256 / NUM_LEDS) + j) & 255);
- setPixel(i, *c, *(c + 1), *(c + 2));
- showStrip();
- byte * Wheel(byte WheelPos) {
- static byte c[3];
- if (WheelPos < 85) {
- c[0] = WheelPos * 3;
- c[1] = 255 - WheelPos * 3;
- c[2] = 0;
- } else if (WheelPos < 170) {
- WheelPos -= 85;
- c[0] = 255 - WheelPos * 3;
- c[1] = 0;
- c[2] = WheelPos * 3;
- } else {
- WheelPos -= 170;
- c[0] = 0;
- c[1] = WheelPos * 3;
- c[2] = 255 - WheelPos * 3;
- return c;
- void colorWipe(byte red, byte green, byte blue, int SpeedDelay) {
- for (uint16_t i = 0; i < NUM_LEDS; i++) {
- setPixel(i, red, green, blue);
- showStrip();
- void RunningLights(byte red, byte green, byte blue, int WaveDelay) {
- int Position = 0;
- for (int j = 0; j < NUM_LEDS * 2; j++)
- Position++;
- for (int i = 0; i < NUM_LEDS; i++) {
- setPixel(i, ((sin(i + Position) * 127 + 128) / 255)*red,
- ((sin(i + Position) * 127 + 128) / 255)*green,
- ((sin(i + Position) * 127 + 128) / 255)*blue);
- showStrip();
- delay(WaveDelay);
- void SnowSparkle(byte red, byte green, byte blue, int SparkleDelay, int SpeedDelay) {
- setAll(red, green, blue);
- int Pixel = random(NUM_LEDS);
- setPixel(Pixel, 0xff, 0xff, 0xff);
- showStrip();
- delay(SparkleDelay);
- setPixel(Pixel, red, green, blue);
- showStrip();
- void Sparkle(byte red, byte green, byte blue, int SpeedDelay) {
- showStrip();
- setPixel(Pixel, 0, 0, 0);
- void TwinkleRandom(int Count, int SpeedDelay, boolean OnlyOne) {
- setAll(0, 0, 0);
- for (int i = 0; i < Count; i++) {
- setPixel(random(NUM_LEDS), random(0, 255), random(0, 255), random(0, 255));
- showStrip();
- if (OnlyOne) {
- setAll(0, 0, 0);
- void Twinkle(byte red, byte green, byte blue, int Count, int SpeedDelay, boolean OnlyOne) {
- setAll(0, 0, 0);
- setPixel(random(NUM_LEDS), red, green, blue);
- showStrip();
- if (OnlyOne) {
- setAll(0, 0, 0);
- void NewKITT(byte red, byte green, byte blue, int EyeSize, int SpeedDelay, int ReturnDelay) {
- RightToLeft(red, green, blue, EyeSize, SpeedDelay, ReturnDelay);
- LeftToRight(red, green, blue, EyeSize, SpeedDelay, ReturnDelay);
- void CenterToOutside(byte red, byte green, byte blue, int EyeSize, int SpeedDelay, int ReturnDelay) {
- for (int i = ((NUM_LEDS - EyeSize) / 2); i >= 0; i--) {
- setAll(0, 0, 0);
- setPixel(i, red / 10, green / 10, blue / 10);
- for (int j = 1; j <= EyeSize; j++) {
- setPixel(i + j, red, green, blue);
- setPixel(i + EyeSize + 1, red / 10, green / 10, blue / 10);
- setPixel(NUM_LEDS - i, red / 10, green / 10, blue / 10);
- setPixel(NUM_LEDS - i - j, red, green, blue);
- setPixel(NUM_LEDS - i - EyeSize - 1, red / 10, green / 10, blue / 10);
- showStrip();
- delay(ReturnDelay);
- void OutsideToCenter(byte red, byte green, byte blue, int EyeSize, int SpeedDelay, int ReturnDelay) {
- for (int i = 0; i <= ((NUM_LEDS - EyeSize) / 2); i++) {
- setAll(0, 0, 0);
- showStrip();
- void LeftToRight(byte red, byte green, byte blue, int EyeSize, int SpeedDelay, int ReturnDelay) {
- for (int i = 0; i < NUM_LEDS - EyeSize - 2; i++) {
- setAll(0, 0, 0);
- if (serialEvent() != false) break;;
- showStrip();
- void RightToLeft(byte red, byte green, byte blue, int EyeSize, int SpeedDelay, int ReturnDelay) {
- for (int i = NUM_LEDS - EyeSize - 2; i > 0; i--) {
- setAll(0, 0, 0);
- showStrip();
- void HalloweenEyes(byte red, byte green, byte blue, int EyeWidth, int EyeSpace, boolean Fade, int Steps, int FadeDelay, int EndPause) {
- randomSeed(analogRead(0));
- int i;
- int StartPoint = random( 0, NUM_LEDS - (2 * EyeWidth) - EyeSpace );
- int Start2ndEye = StartPoint + EyeWidth + EyeSpace;
- for (i = 0; i < EyeWidth; i++) {
- setPixel(StartPoint + i, red, green, blue);
- setPixel(Start2ndEye + i, red, green, blue);
- showStrip();
- if (Fade == true) {
- float r, g, b;
- for (int j = Steps; j >= 0; j--) {
- r = j * (red / Steps);
- g = j * (green / Steps);
- b = j * (blue / Steps);
- setPixel(StartPoint + i, r, g, b);
- setPixel(Start2ndEye + i, r, g, b);
- showStrip();
- delay(FadeDelay);
- setAll(0, 0, 0);
- delay(EndPause);
- void Strobe(byte red, byte green, byte blue, int StrobeCount, int FlashDelay, int EndPause) {
- for (int j = 0; j < StrobeCount; j++) {
- showStrip();
- delay(FlashDelay);
- setAll(0, 0, 0);
- showStrip();
- delay(EndPause);
- void RGBLoop() {
- for (int j = 0; j < 3; j++ ) {
- for (int k = 0; k < 256; k++) {
- switch (j) {
- case 0: setAll(k, 0, 0); if (serialEvent() != false) break; break;
- case 1: setAll(0, k, 0); if (serialEvent() != false) break; break;
- case 2: setAll(0, 0, k); if (serialEvent() != false) break; break;
- showStrip();
- if (serialEvent() != false)break;
- for (int k = 255; k >= 0; k--) {
- switch (j) {
- showStrip();
- void showStrip() {
- strip.show();
- #endif
- FastLED.show();
- #endif
- void setPixel(int Pixel, byte red, byte green, byte blue) {
- strip.setPixelColor(Pixel, strip.Color(red, green, blue));
- #endif
- leds[Pixel].r = red;
- leds[Pixel].g = green;
- leds[Pixel].b = blue;
- #endif
- void setAll(byte red, byte green, byte blue) {
- for (int i = 0; i < NUM_LEDS; i++ ) {
- showStrip();
- bool serialEvent() {
- if (Serial.available()) {
- veri = Serial.readString();
- if (veri.charAt(0) == 'b') {
- veri = veri.substring(1, 4);
- parlaklik = veri.toInt();
- parlaklik = map(parlaklik, 0, 100, 0, 255);
- strip.setBrightness(parlaklik);
- else {
- mod = veri.toInt();
- return true;
- return false;
