3386
41
  【花雕动手做】有趣好玩的音乐可视化系列小项目(22)--LED无限魔方
  项目程序之四:音乐反应LED无限魔方
  模块接线:WS2812B接D6
  MAX4466      UNO
  VCC          5V
  GND         GND
  OUT          A0
  项目程序之四:音乐反应LED无限魔方
  模块接线:WS2812B接D6
  MAX4466      UNO
  VCC          5V
  GND         GND
  OUT          A0
#include<FastLED.h>
#define LED_PIN 6
#define NUM_LEDS 60
CRGB leds[NUM_LEDS];
uint8_t hue = 0;
int soundsensor = A0;
void setup() {
  delay(2000);
  FastLED.addLeds<WS2812B, LED_PIN, GRB>(leds, NUM_LEDS);
  FastLED.setBrightness(155);
  pinMode(soundsensor, INPUT);
void loop() {
  int sensval = digitalRead(soundsensor);
  if (sensval == 1) {
    leds[0] = CRGB :: Red;
    fill_solid(leds, NUM_LEDS, CRGB :: Blue);
    rainbow_moving();
    FastLED.show();
    delay(10);
  else {
    leds[0] = CRGB :: Black;
    fill_solid(leds, NUM_LEDS, CRGB :: Black);
    FastLED.show();
    delay(10);
void rainbow_moving() {
  for (int i = 0; i < NUM_LEDS; i++) {
    leds[i] = CHSV(hue + (i * 10), 255, 255);
  EVERY_N_MILLISECONDS(10) {
    hue++;
3386
42
实验场景图  动态图
点击上图查看Gif动图
3386
43
实验的视频记录(2分51秒)
https://v.youku.com/v_show/id_XNTkwMDc0ODcxMg==.html?spm=a2hcb.playlsit.page.1
129
44
太炫酷了~要拍视频哟
3386
45
  项目程序之五:多彩MegunoLink音乐节拍灯
  模块接线:WS2812B接D6
  MAX4466      UNO
  VCC          5V
  GND         GND
  OUT          A0
  模块接线:WS2812B接D6
  MAX4466      UNO
  VCC          5V
  GND         GND
  OUT          A0
#include<FastLED.h>
#include<MegunoLink.h>
#include<Filter.h>
#define N_PIXELS  60
#define MIC_PIN   A0
#define LED_PIN   6
#define NOISE 10
#define TOP   (N_PIXELS+2)
#define LED_TYPE  WS2811
#define BRIGHTNESS  10
#define COLOR_ORDER GRB
CRGB leds[N_PIXELS];
int lvl = 0, minLvl = 0, maxLvl = 10;
ExponentialFilter<long> ADCFilter(5, 0);
void setup() {
  FastLED.addLeds<LED_TYPE, LED_PIN, COLOR_ORDER>(leds, N_PIXELS).setCorrection(TypicalLEDStrip);
  FastLED.setBrightness(BRIGHTNESS);
void loop() {
  int n, height;
  n = analogRead(MIC_PIN);
  n = abs(1023 - n);
  n = (n <= NOISE) ? 0 : abs(n - NOISE);
  ADCFilter.Filter(n);
  lvl = ADCFilter.Current();
  //  Serial.print(n);
  //  Serial.print(" ");
  //  Serial.println(lvl);
  height = TOP * (lvl - minLvl) / (long)(maxLvl - minLvl);
  if (height < 0L) height = 0;
  else if (height > TOP) height = TOP;
  for (uint8_t i = 0; i < N_PIXELS; i++) {
    if (i >= height) leds[i] = CRGB(0, 0, 0);
    else leds[i] = Wheel( map( i, 0, N_PIXELS - 1, 30, 150 ) );
  FastLED.show();
CRGB Wheel(byte WheelPos) {
  if (WheelPos < 85)
    return CRGB(WheelPos * 3, 255 - WheelPos * 3, 0);
  else if (WheelPos < 170) {
    WheelPos -= 85;
    return CRGB(255 - WheelPos * 3, 0, WheelPos * 3);
  } else {
    WheelPos -= 170;
    return CRGB(0, WheelPos * 3, 255 - WheelPos * 3);
3386
46
实验的视频记录(4分50秒)
https://v.youku.com/v_show/id_XNTkwMDgzNDUwMA==.html?spm=a2hcb.playlsit.page.1
3386
47
实验场景图
3386
48
实验的视频记录
https://v.youku.com/v_show/id_XNTkwMDgzNDc1Ng==.html?spm=a2hcb.playlsit.page.1
3386
49
参考LED序列
3386
  项目程序之六:一个用 FastLED 编程的LED无限魔方体
#include <FastLED.h>
#define LED_PIN               6
#define LEDS_PER_SEGMENT      5
#define SEGMENTS              12
#define BRIGHTNESS            200
#define NUM_LEDS              LEDS_PER_SEGMENT * SEGMENTS
#define NUM_LEDS_WITH_SAFETY  NUM_LEDS + 1
CRGB source1[NUM_LEDS_WITH_SAFETY];
CRGB source2[NUM_LEDS_WITH_SAFETY];
CRGB output[NUM_LEDS_WITH_SAFETY];
uint8_t blendAmount = 0;
uint8_t patternCounter = 0;
uint8_t source1Pattern = 0;
uint8_t source2Pattern = 1;
bool useSource1 = false;
void setup() {
  FastLED.addLeds<WS2812B, LED_PIN, GRB>(output, NUM_LEDS_WITH_SAFETY);
  Serial.begin(57600);
void loop() {
    blend(source1, source2, output, NUM_LEDS, blendAmount);   //在两个源之间混合
    if (useSource1) {
      if (blendAmount < 255) blendAmount++;                   //混合“向上”到源 2
    } else {
      if (blendAmount > 0) blendAmount--;                     //将“向下”混合到源 1
  EVERY_N_SECONDS(8) {
    nextPattern();
  runPattern(source1Pattern, source1);                  //同时运行两种模式
  runPattern(source2Pattern, source2);
  FastLED.show();
void nextPattern() {
  patternCounter = (patternCounter + 1) % 5;
  if (useSource1) source1Pattern = patternCounter;
  else source2Pattern = patternCounter;
  useSource1 = !useSource1;
void runPattern(uint8_t pattern, CRGB *LEDarray) {
  switch (pattern) {
    case 0:
      rainbowComet(LEDarray);//彩虹彗星
      break;
    case 1:
      prettyNoise(LEDarray);//漂亮噪声
      break;
    case 2:
      randomStar(LEDarray);//随机星
      break;
    case 3:
      fillRainbow(LEDarray);//填充彩虹
      break;
    case 4:
      pixels(LEDarray);// 像素
      break;
uint8_t xyz(uint8_t x, uint8_t y, uint8_t z) {
/*边缘的坐标从 0 到 5。每条边缘只有 5 个“真实”像素,
   * 所以只有 1 - 5 个 LED。缺少顶点(角)。
   * 如果请求这些顶点之一,则返回一个不显示的安全像素。
   * 我们对立方体内部的坐标也做同样的事情,即不在边缘上。
  uint8_t lps = LEDS_PER_SEGMENT;
  uint8_t safePx = NUM_LEDS;
  if ((x == 0 || x == lps + 1) && (y == 0 || y == lps + 1) && (z == 0 || z == lps + 1)) return safePx;
  // z 方向边缘
  if (x == 0        && y == 0)        return (8 * lps)  - z;      // Seg 7
  if (x == 0        && y == lps + 1)  return (12 * lps) - z;      // Seg 11
  if (x == lps + 1  && y == 0)        return (3 * lps)  + z - 1;  // Seg 3
  if (x == lps + 1  && y == lps + 1)  return (9 * lps)  + z - 1;  // Seg 9
  // y 方向边
  if (x == 0        && z == 0)        return y - 1;               // Seg 0
  if (x == 0        && z == lps + 1)  return (7 * lps)  - y;      // Seg 6
  if (x == lps + 1  && z == 0)        return (3 * lps)  - y;      // Seg 2
  if (x == lps + 1  && z == lps + 1)  return (4 * lps)  + y - 1;  // Seg 4
  // x 方向边
  if (y == 0        && z == 0)        return (8 * lps)  + x - 1;  // Seg 8
  if (y == 0        && z == lps + 1)  return (11 * lps) - x;      // Seg 10
  if (y == lps + 1  && z == 0)        return lps        + x - 1;  // Seg 1
  if (y == lps + 1  && z == lps + 1)  return (6 * lps)  - x;      // Seg 5
  //如果以上都不是,我们的坐标无效
  return safePx;
//------------ Patterns below ------------//
void pixels(CRGB *LEDarray) {
  static uint8_t pos = 0;
  static uint8_t a = 0;
  static uint8_t b = 0;
  //填充所有像素并将它们混合在一起
  for (int c = 0; c <= LEDS_PER_SEGMENT + 1; c++) {
    LEDarray[xyz(a,b,c)] = blend(LEDarray[xyz(a,b,c)], CRGB::Orange, 128);
    LEDarray[xyz(a,c,b)] = blend(LEDarray[xyz(a,c,b)], CRGB::Magenta, 128);
    LEDarray[xyz(c,a,b)] = blend(LEDarray[xyz(c,a,b)], CRGB::Blue, 128);
  EVERY_N_MILLISECONDS(33) {
    //围绕正方形移动的坐标
    if(pos < 15) a++;
    else if (pos <= (LEDS_PER_SEGMENT * 2) + 1) b++;
    else if (pos <= (LEDS_PER_SEGMENT * 3) + 2) a--;
    else b--;
     //再次开始我们到达正方形的尽头
    pos = (pos + 1) % ((LEDS_PER_SEGMENT + 1) * 4);
  fadeToBlackBy(LEDarray, NUM_LEDS, 10);
void fillRainbow(CRGB *LEDarray) {
  uint8_t noise = inoise8(millis()/5);
  fill_rainbow(LEDarray, LEDS_PER_SEGMENT, noise, 10);
  //复制到其他段
  for (int i = 0; i < SEGMENTS; i++) {
    memmove8(&LEDarray[LEDS_PER_SEGMENT * i], &LEDarray[0], LEDS_PER_SEGMENT * sizeof(CRGB));
   //垂直柱子上下移动的白点
  LEDarray[xyz(0, 0, LEDS_PER_SEGMENT - pos)] = CRGB::White;
  LEDarray[xyz(0, LEDS_PER_SEGMENT + 1, pos)] = CRGB::White;
  LEDarray[xyz(LEDS_PER_SEGMENT + 1, LEDS_PER_SEGMENT + 1, LEDS_PER_SEGMENT - pos)] = CRGB::White;
  LEDarray[xyz(LEDS_PER_SEGMENT + 1, 0, pos)] = CRGB::White;
  EVERY_N_MILLISECONDS(20) {
    pos = (pos + 1) % LEDS_PER_SEGMENT;
void rainbowComet(CRGB *LEDarray) {
  static uint8_t easeOutVal = 0;
  static uint8_t easeInVal  = 0;
  //使图案出现在两个段上
  uint8_t ledsPerSegment = LEDS_PER_SEGMENT * 2;
  uint8_t segments = SEGMENTS / 2;
  easeOutVal = ease8InOutQuad(easeInVal);
  easeInVal++;
  uint8_t pos = lerp8by8(0, ledsPerSegment, easeOutVal);
  uint8_t hue =  map(pos, 0, ledsPerSegment, 0, 230);
  LEDarray[pos] = CHSV(hue, 255, 255);
  fadeToBlackBy(LEDarray, ledsPerSegment, 20);
  //复制到其他段
  for (int i = 0; i < segments; i++) {
    memmove8(&LEDarray[ledsPerSegment * i], &LEDarray[0], ledsPerSegment * sizeof(CRGB));
void randomStar(CRGB *LEDarray) {
  EVERY_N_MILLISECONDS(75) {
    LEDarray[random16(0, NUM_LEDS)] = CRGB::LightGrey;
    // 亮度
    uint8_t bNoise = inoise8(i * 100, millis());
    bNoise = constrain(bNoise, 50, 200);
    bNoise = map(bNoise, 50, 200, 20, 80);
    // 色调
    uint8_t hNoise = inoise8(i * 20, millis() / 5);
    hNoise = constrain(hNoise, 50, 200);
    hNoise = map(hNoise, 50, 200, 160, 192);
    if (LEDarray[i].g == 0) {
      LEDarray[i] = CHSV(hNoise, 255, bNoise);
  fadeToBlackBy(LEDarray, NUM_LEDS, 5);//淡入黑色(LED 阵列,NUM LEDS,5 个)
void prettyNoise(CRGB *LEDarray) {
  fill_noise16 (LEDarray, NUM_LEDS, 1, 0, 100, 1, 1, 50, millis() / 3, 5);
3386
51
实验的视频记录(4分37秒)
https://v.youku.com/v_show/id_XNTkwMjkxMjEwMA==.html?spm=a2hcb.playlsit.page.1
3386
52
实验场景图
3386
53
实验的视频记录
优酷:https://v.youku.com/v_show/id_XNTkwNjYzMjIyOA==.html?spm=a2hcb.playlsit.page.1
B站:https://www.bilibili.com/video/BV1hN4y1P7U4/?vd_source=98c6b1fc23b2787403d97f8d3cc0b7e5
3386
54
实验场景图
