刚弄来一块板子,配置内核(选择config_tft1024x768),编译后放上去,板子正常启动,以下是输出信息:
Copy linux kernel from 0x00050000 to 0x30008000, size = 0x00200000 ... done
zImage magic = 0x016f2818
Setup linux parameters at 0x30000100
linux command line is: "noinitrd root=/dev/mtdblock2 init=/linuxrc console=ttySAC0"
MACH_TYPE = 782
NOW, Booting Linux......
Uncompressing Linux........................................................................................................
Linux version 2.6.13 (root@localhost.cricket) (gcc version 3.4.1) #7 Sun Nov 15 01:32:06 HKT 2009
CPU: ARM920Tid(wb) [41129200] revision 0 (ARMv4T)
Machine: SBC2440
ATAG_INITRD is deprecated; please update your bootloader.
Memory policy: ECC disabled, Data cache writeback
CPU S3C2440A (id 0x32440001)
BUG: mapping for 0x19000000 at 0xd0000000 overlaps vmalloc space
S3C2440: core 405.000 MHz, memory 101.250 MHz, peripheral 50.625 MHz
S3C2410 Clocks, (c) 2004 Simtec Electronics
CPU0: D VIVT write-back cache
CPU0: I cache: 16384 bytes, associativity 64, 32 byte lines, 8 sets
CPU0: D cache: 16384 bytes, associativity 64, 32 byte lines, 8 sets
Built 1 zonelists
Kernel command line: noinitrd root=/dev/mtdblock2 init=/linuxrc console=ttySAC0
irq: clearing pending ext status 00000200
irq: clearing subpending status 00000007
irq: clearing subpending status 00000002
PID hash table entries: 512 (order: 9, 8192 bytes)
timer tcon=00000000, tcnt a4ca, tcfg 00000200,00000000, usec 00001e57
Console: colour dummy device 80x30
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Memory: 64MB = 64MB total
Memory: 61056KB available (2545K code, 1008K data, 144K init)
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
NET: Registered protocol family 16
USB Power Control, (c) 2004 Simtec Electronics
S3C2440: Initialising architecture
S3C2440: IRQ Support
S3C2440: Clock Support, UPLL 96.000 MHz
SCSI subsystem initialized
usbcore: registered new driver hub
S3C2410 DMA Driver, (c) 2003-2004 Simtec Electronics
DMA channel 0 at c4800000, irq 33
DMA channel 1 at c4800040, irq 34
DMA channel 2 at c4800080, irq 35
DMA channel 3 at c48000c0, irq 36
NetWinder Floating Point Emulator V0.97 (double precision)
devfs: 2004-01-31 Richard Gooch (rgooch@atnf.csiro.au)
devfs: boot_options: 0x1
yaffs Oct 30 2009 00:32:57 Installing.
Initializing Cryptographic API
Console: switching to colour frame buffer device 100x30
S3C24X0 fb0: s3c2410fb frame buffer device initialize done
GPIO L3 bus interface for S3C2440, installed
S3C2410 RTC, (c) 2004 Simtec Electronics
s3c2410-rtc s3c2410-rtc: rtc disabled, re-enabling
leds initialized
s3c2410_serial0 at MMIO 0x50000000 (irq = 70) is a S3C2440
s3c2410_serial1 at MMIO 0x50004000 (irq = 73) is a S3C2440
s3c2410_serial2 at MMIO 0x50008000 (irq = 76) is a S3C2440
io scheduler noop registered
io scheduler anticipatory registered
io scheduler deadline registered
io scheduler cfq registered
RAMDISK driver initialized: 16 RAM disks of 4096K size 1024 blocksize
loop: loaded (max 8 devices)
nbd: registered device at major 43
Cirrus Logic CS8900A driver for Linux (Modified for SMDK2410)
eth0: CS8900A rev E at 0xd0000300 irq=53, no eeprom , addr: 08: 0:3E:26:0A:5B
Linux video capture interface: v1.00
ovcamchip: v2.27 for Linux 2.6 : OV camera chip I2C driver
Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
ide: Assuming 50MHz system bus speed for PIO modes; override with idebus=xx
ide_s3c2440_init
ide0: S3C2410 IDE interface
S3C24XX NAND Driver, (c) 2004 Simtec Electronics
s3c2440-nand: mapped registers at c4880000
s3c2440-nand: timing: Tacls 9ns, Twrph0 39ns, Twrph1 9ns
NAND device: Manufacturer ID: 0xec, Chip ID: 0x76 (Samsung NAND 64MiB 3,3V 8-bit)
NAND_ECC_NONE selected by board driver. This is not recommended !!
Scanning device for bad blocks
Bad eraseblock 288 at 0x00480000
Creating 3 MTD partitions on "NAND 64MiB 3,3V 8-bit":
0x00000000-0x00030000 : "bootloader"
0x00050000-0x00250000 : "kernel"
0x00250000-0x03ffc000 : "root"
s3c2410-ohci s3c2410-ohci: S3C24XX OHCI
s3c2410-ohci s3c2410-ohci: new USB bus registered, assigned bus number 1
s3c2410-ohci s3c2410-ohci: irq 42, io mem 0x49000000
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
Initializing USB Mass Storage driver...
usbcore: registered new driver usb-storage
USB Mass Storage support registered.
usbcore: registered new driver usbhid
drivers/usb/input/hid-core.c: v2.01:USB HID core driver
usbcore: registered new driver ov511
drivers/usb/media/ov511.c: v1.64 for Linux 2.5 : ov511 USB Camera Driver
usbcore: registered new driver gspca
drivers/usb/media/gspca/gspca_core.c: gspca driver 00.60.00 registered
mice: PS/2 mouse device common for all mice
ts: Compaq touchscreen protocol output
s3c2410 TouchScreen successfully loaded
i2c /dev entries driver
s3c2440-i2c s3c2440-i2c: slave address 0x10
s3c2440-i2c s3c2440-i2c: bus frequency set to 98 KHz
s3c2440-i2c s3c2440-i2c: i2c-0: S3C I2C adapter
mmci-s3c2410: probe: mapped sdi_base=c4d00000 irq=37 irq_cd=60 dma=0.
mmci-s3c2410: initialisation done.
SBC2440 SOUND driver register
SBC2440 SOUND driver probe!
SBC2440 UDA1341 audio driver initialized
oprofile: using timer interrupt.
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 4096 (order: 3, 32768 bytes)
TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
TCP reno registered
TCP bic registered
NET: Registered protocol family 17
MMC: sd_app_op_cond: at least one card is busy - trying again.
MMC: sd_app_op_cond locked busy. Probably have broken SD-Card.
yaffs: dev is 32505858 name is "mtdblock2"
yaffs: Attempting MTD mount on 31.2, "mtdblock2"
block 141 is bad
VFS: Mounted root (yaffs filesystem).
Mounted devfs on /dev
Freeing init memory: 144K
[31/Dec/1969:23:59:59 +0000] boa: server version Boa/0.94.13
[31/Dec/1969:23:59:59 +0000] boa: server built Feb 28 2004 at 21:47:23.
[31/Dec/1969:23:59:59 +0000] boa: starting server pid=272, port 80
Please press Enter to activate this console. Could not read calibration: /etc/pointercal
Create pluginlibman in libqpe
Unable to open /usr/share/zoneinfo/zone.tab
Timezone data must be installed at /usr/share/zoneinfo/
Unable to open '/usr/share/zoneinfo/America/New_York'
TimeZone::data Can't create a valid data object for 'America/New_York'
TzCache::location unable to find America/New_York
initEnvironment() Invalid TimeZone America/New_York
Use QPEApplication's PluginLibraryManager
QMemoryFile::QMemoryFile("/opt/qtopia/etc/dict/dawg")
Created QMemoryfile for /opt/qtopia/etc/dict/dawg with a size of 189396
Setting up QCop to QPE/System
channel QPE/Card added
channel QPE/Server added
channel QPE/IME added
QuickLauncher running
channel QPE/Application/quicklauncher added
channel QPE/QuickLauncher-308 added
Registered QPE/QuickLauncher-308
