【stm32F7英雄联盟大赛】多功能测试仪器-STM32F7 FFT性能测试每秒1358次算不算快?
今天对STM32F746做了一些FFT性能测试,将2048*4字节的数据从FLASH复制到RAM、做1024点的快速傅里叶变化、求模、取最大值,每转换100次在LCD上显示一次,转换794200次历时584814毫秒,平均每秒转换次数约1358次速度算不算快呢? 具体实验内容如下
新键一个项目
指定位置并给项目取个名字 设备型号选择STM32F746NG 在Manage Run-Time Environment里按照下图勾选后点OK Manage Project Items里将文件夹更名 在Source文件更里添加三个C文件,取名为”stm32fft test.c” “fft.c” “fft data.c” 添加文件后的目录结构
在Options for Target里找到C/C++ 选项卡在Define里添加ARM_MATH_CM7 __FPU_PRESENT=1启用FPU Debug里选择ST-Link Debugger Contex-M Target Driver Setup里的ort选择SW
将代码修改为附件里的源码编译下载后的效果
代码: stm32f746 fft test.c
- #include <stdint.h>
- #include "Board_GLCD.h"
- #include "GLCD_Config.h"
- #include "stm32f7xx_hal.h"
- extern GLCD_FONT GLCD_Font_16x24;
- extern void fft(void);
- char buff[50];
- uint32_t ms = 0;
- uint32_t counter = 0;
- * System Clock Configuration
- * System Clock source = PLL (HSE)
- * SYSCLK(Hz) = 216000000
- * HCLK(Hz) = 216000000
- * AHB Prescaler = 1
- * APB1 Prescaler = 4
- * APB2 Prescaler = 2
- * HSE Frequency(Hz) = 25000000
- * PLL_M = 25
- * PLL_N = 432
- * PLL_P = 2
- * PLL_Q = 9
- * VDD(V) = 3.3
- * Main regulator output voltage = Scale1 mode
- * Flash Latency(WS) = 7
- static void SystemClock_Config (void) {
- RCC_ClkInitTypeDef RCC_ClkInitStruct;
- RCC_OscInitTypeDef RCC_OscInitStruct;
- /* Enable HSE Oscillator and activate PLL with HSE as source */
- RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
- RCC_OscInitStruct.HSEState = RCC_HSE_ON;
- RCC_OscInitStruct.HSIState = RCC_HSI_OFF;
- RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
- RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
- RCC_OscInitStruct.PLL.PLLM = 25;
- RCC_OscInitStruct.PLL.PLLN = 432;
- RCC_OscInitStruct.PLL.PLLP = RCC_PLLP_DIV2;
- RCC_OscInitStruct.PLL.PLLQ = 9;
- HAL_RCC_OscConfig(&RCC_OscInitStruct);
- /* Activate the OverDrive to reach the 216 MHz Frequency */
- HAL_PWREx_EnableOverDrive();
- /* Select PLL as system clock source and configure the HCLK, PCLK1 and PCLK2 clocks dividers */
- RCC_ClkInitStruct.ClockType = (RCC_CLOCKTYPE_SYSCLK | RCC_CLOCKTYPE_HCLK | RCC_CLOCKTYPE_PCLK1 | RCC_CLOCKTYPE_PCLK2);
- RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
- RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
- RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV4;
- RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV2;
- HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_7);
- * Configure the MPU attributes as Write Through for SRAM1/2
- * The Base Address is 0x20010000 since this memory interface is the AXI.
- * The Region Size is 256KB, it is related to SRAM1 and SRAM2 memory size.
- static void MPU_Config (void) {
- MPU_Region_InitTypeDef MPU_InitStruct;
- /* Disable the MPU */
- HAL_MPU_Disable();
- /* Configure the MPU attributes as WT for SRAM */
- MPU_InitStruct.Enable = MPU_REGION_ENABLE;
- MPU_InitStruct.BaseAddress = 0x20010000;
- MPU_InitStruct.Size = MPU_REGION_SIZE_256KB;
- MPU_InitStruct.AccessPermission = MPU_REGION_FULL_ACCESS;
- MPU_InitStruct.IsBufferable = MPU_ACCESS_NOT_BUFFERABLE;
- MPU_InitStruct.IsCacheable = MPU_ACCESS_CACHEABLE;
- MPU_InitStruct.IsShareable = MPU_ACCESS_NOT_SHAREABLE;
- MPU_InitStruct.Number = MPU_REGION_NUMBER0;
- MPU_InitStruct.TypeExtField = MPU_TEX_LEVEL0;
- MPU_InitStruct.SubRegionDisable = 0x00;
- MPU_InitStruct.DisableExec = MPU_INSTRUCTION_ACCESS_ENABLE;
- HAL_MPU_ConfigRegion(&MPU_InitStruct);
- /* Enable the MPU */
- HAL_MPU_Enable(MPU_PRIVILEGED_DEFAULT);
- * CPU L1-Cache enable
- static void CPU_CACHE_Enable (void) {
- /* Enable I-Cache */
- SCB_EnableICache();
- /* Enable D-Cache */
- SCB_EnableDCache();
- void SysTick_Handler(void)
- ms++;
- HAL_IncTick();
- int main (void) {
- int16_t i;
- MPU_Config(); /* Configure the MPU */
- CPU_CACHE_Enable(); /* Enable the CPU Cache */
- HAL_Init(); /* Initialize the HAL Library */
- SystemClock_Config(); /* Configure the System Clock */
- GLCD_Initialize ();
- GLCD_SetBackgroundColor (GLCD_COLOR_BLUE);
- GLCD_SetForegroundColor (GLCD_COLOR_WHITE);
- GLCD_ClearScreen ();
- GLCD_SetFont (&GLCD_Font_16x24);
- GLCD_DrawString (5*16, 1*24, " STM32F746 FFT TEST ");
- while(1)
- for(i=0;i<100;i++)
- fft();
- counter++;
- sprintf(buff,"fft test counter:%d",counter);
- GLCD_DrawString (5*16, 2*24, buff);
- sprintf(buff,"fft test ms:%d ",ms);
- GLCD_DrawString (5*16, 3*24, buff);
复制代码fft.c
- #include "arm_math.h"
- #include "arm_const_structs.h"
- #define TEST_LENGTH_SAMPLES 2048
- * External Input and Output buffer Declarations for FFT Bin Example
- extern float32_t testInput_f32_10khz[TEST_LENGTH_SAMPLES];
- static float32_t testInput_f32_10khz_RAM[2048];
- static float32_t testOutput[TEST_LENGTH_SAMPLES/2];
- * Global variables for FFT Bin Example
- uint32_t fftSize = 1024;
- uint32_t ifftFlag = 0;
- uint32_t doBitReverse = 1;
- /* Reference index at which max energy of bin ocuurs */
- uint32_t refIndex = 213, testIndex = 0;
- * Max magnitude FFT Bin test
- void fft(void)
- arm_status status;
- float32_t maxValue;
- status = ARM_MATH_SUCCESS;
- memcpy(testInput_f32_10khz_RAM,testInput_f32_10khz,sizeof(testInput_f32_10khz));
- /* Process the data through the CFFT/CIFFT module */
- arm_cfft_f32(&arm_cfft_sR_f32_len1024, testInput_f32_10khz_RAM, ifftFlag, doBitReverse);
- /* Process the data through the Complex Magnitude Module for
- calculating the magnitude at each bin */
- arm_cmplx_mag_f32(testInput_f32_10khz_RAM, testOutput, fftSize);
- /* Calculates maxValue and returns corresponding BIN value */
- arm_max_f32(testOutput, fftSize, &maxValue, &testIndex);
- if(testIndex != refIndex)
- status = ARM_MATH_TEST_FAILURE;
- ** Loop here if the signals fail the PASS check.
- ** This denotes a test failure
- if( status != ARM_MATH_SUCCESS)
- while(1);
复制代码fft data.c
- Test Input signal contains 10KHz signal + Uniformly distributed white noise
- const float32_t testInput_f32_10khz[2048] =
- -0.865129623056441, 0.000000000000000, -2.655020678073846, 0.000000000000000, 0.600664612949661, 0.000000000000000, 0.080378093886515, 0.000000000000000,
- -2.899160484012034, 0.000000000000000, 2.563004262857762, 0.000000000000000, 3.078328403304206, 0.000000000000000, 0.105906778385130, 0.000000000000000,
- 0.048366940168201, 0.000000000000000, -0.145696461188734, 0.000000000000000, -0.023417155362879, 0.000000000000000, 2.127729174988954, 0.000000000000000,
- -1.176633086028377, 0.000000000000000, 3.690223557991855, 0.000000000000000, -0.622791766173194, 0.000000000000000, 0.722837373872203, 0.000000000000000,
- 2.739754205367484, 0.000000000000000, -0.062610410524552, 0.000000000000000, -0.891296810967338, 0.000000000000000, -1.845872258871811, 0.000000000000000,
- 1.195039415434387, 0.000000000000000, -2.177388969045026, 0.000000000000000, 1.078649103637905, 0.000000000000000, 2.570976050490193, 0.000000000000000,
- -1.383551403404574, 0.000000000000000, 2.392141424058873, 0.000000000000000, 2.858002843205065, 0.000000000000000, -3.682433899725536, 0.000000000000000,
- -3.488146646451150, 0.000000000000000, 1.323468578888120, 0.000000000000000, -0.099771155430726, 0.000000000000000, 1.561168082500454, 0.000000000000000,
- 1.025026795103179, 0.000000000000000, 0.928841900171200, 0.000000000000000, 2.930499509864950, 0.000000000000000, 2.013349089766430, 0.000000000000000,
- 2.381676148486737, 0.000000000000000, -3.081062307950236, 0.000000000000000, -0.389579115537544, 0.000000000000000, 0.181540149166620, 0.000000000000000,
- -2.601953341353208, 0.000000000000000, 0.333435137783218, 0.000000000000000, -2.812945856162965, 0.000000000000000, 2.649109640172910, 0.000000000000000,
- -1.003963025744654, 0.000000000000000, 1.552460768755035, 0.000000000000000, 0.088641345335247, 0.000000000000000, -2.519951327113426, 0.000000000000000,
- -4.341348988610527, 0.000000000000000, 0.557772429359965, 0.000000000000000, -1.671267412948494, 0.000000000000000, 0.733951350960387, 0.000000000000000,
- 0.409263788034864, 0.000000000000000, 3.566033071952806, 0.000000000000000, 1.882565173848352, 0.000000000000000, -1.106017073793287, 0.000000000000000,
- 0.154456720778718, 0.000000000000000, -2.513205795512153, 0.000000000000000, 0.310978660939421, 0.000000000000000, 0.579706500111723, 0.000000000000000,
- 0.000086383683251, 0.000000000000000, -1.311866980897721, 0.000000000000000, 1.840007477574986, 0.000000000000000, -3.253005768451345, 0.000000000000000,
- 1.462584328739432, 0.000000000000000, 1.610103610851738, 0.000000000000000, 0.761914676858907, 0.000000000000000, 0.974541361089834, 0.000000000000000,
- 0.686845845885983, 0.000000000000000, 1.849153122025191, 0.000000000000000, 0.787800410401453, 0.000000000000000, -1.187438909666279, 0.000000000000000,
- -0.754937911044720, 0.000000000000000, 0.084373858395232, 0.000000000000000, -2.600269011710521, 0.000000000000000, -0.962982842142644, 0.000000000000000,
- -0.369328108540868, 0.000000000000000, 0.810791418361879, 0.000000000000000, 3.587016488699641, 0.000000000000000, -0.520776145083723, 0.000000000000000,
- 0.640249919627884, 0.000000000000000, 1.103122489464969, 0.000000000000000, 2.231779881455556, 0.000000000000000, -1.308035392685241, 0.000000000000000,
- 0.424070304330106, 0.000000000000000, -0.200383932651189, 0.000000000000000, -2.365526783356541, 0.000000000000000, -0.989114757436628, 0.000000000000000,
- 2.770807688959777, 0.000000000000000, -0.444172737462307, 0.000000000000000, 0.079760979374078, 0.000000000000000, -0.005199118412183, 0.000000000000000,
- -0.664712668309527, 0.000000000000000, -0.624171857561896, 0.000000000000000, 0.537306979007338, 0.000000000000000, -2.575955675497642, 0.000000000000000,
- 1.562363235756780, 0.000000000000000, 1.814069369848895, 0.000000000000000, -1.293428583392509, 0.000000000000000, -1.026188449495686, 0.000000000000000,
- -2.981771815588717, 0.000000000000000, -4.223468103075124, 0.000000000000000, 2.672674782004045, 0.000000000000000, -0.856096801117735, 0.000000000000000,
- 0.048517345512563, 0.000000000000000, -0.026860721136222, 0.000000000000000, 0.392932277758187, 0.000000000000000, -1.331740855093099, 0.000000000000000,
- -1.894292129477081, 0.000000000000000, -1.425006468460681, 0.000000000000000, -2.721772427617057, 0.000000000000000, -1.616831100216806, 0.000000000000000,
- 3.551177651488947, 0.000000000000000, -0.069685667896087, 0.000000000000000, -3.134634907409102, 0.000000000000000, -0.263627598944639, 0.000000000000000,
- -1.650469945991350, 0.000000000000000, -2.203580339374399, 0.000000000000000, -0.872203246123242, 0.000000000000000, 1.230782812607287, 0.000000000000000,
- 0.257288860093291, 0.000000000000000, 1.989083106173137, 0.000000000000000, -1.985638729453261, 0.000000000000000, -1.416185105842892, 0.000000000000000,
- -1.131097688325772, 0.000000000000000, -2.245130805416057, 0.000000000000000, -1.938873996219074, 0.000000000000000, 2.043608361562645, 0.000000000000000,
- -0.583727989880841, 0.000000000000000, -1.785266378212929, 0.000000000000000, 1.961457586224753, 0.000000000000000, 1.139400099963223, 0.000000000000000,
- -1.979519343363991, 0.000000000000000, 2.003023322818429, 0.000000000000000, 0.229004069076829, 0.000000000000000, 3.452808862193135, 0.000000000000000,
- 2.882273808365857, 0.000000000000000, -1.549450501844438, 0.000000000000000, -3.283872089931876, 0.000000000000000, -0.327025884099064, 0.000000000000000,
- -0.054979977136430, 0.000000000000000, -1.192280531479012, 0.000000000000000, 0.645539328365578, 0.000000000000000, 2.300832863404618, 0.000000000000000,
- -1.092951789535240, 0.000000000000000, -1.017368249363773, 0.000000000000000, -0.142673056169787, 0.000000000000000, 0.831073544881250, 0.000000000000000,
- -2.314612531587064, 0.000000000000000, -2.221456299106321, 0.000000000000000, 0.460261143885226, 0.000000000000000, 0.050585301888595, 0.000000000000000,
- 0.364373329183988, 0.000000000000000, -1.685956552069538, 0.000000000000000, 0.050664512351055, 0.000000000000000, -0.193355783902718, 0.000000000000000,
- -0.158660446046828, 0.000000000000000, 2.394156453841953, 0.000000000000000, -1.562965718554525, 0.000000000000000, -2.199750600869900, 0.000000000000000,
- 1.544984022381773, 0.000000000000000, -1.988307216807315, 0.000000000000000, -0.628240722541046, 0.000000000000000, -1.436235771505429, 0.000000000000000,
- 1.677013691147313, 0.000000000000000, 1.600741781678228, 0.000000000000000, -0.757380959134706, 0.000000000000000, -4.784797439515566, 0.000000000000000,
- 0.265121462834569, 0.000000000000000, 3.862029485934378, 0.000000000000000, 2.386823577249430, 0.000000000000000, -3.655779745436893, 0.000000000000000,
- -0.763541621368016, 0.000000000000000, -1.182140388432962, 0.000000000000000, -1.349106114858063, 0.000000000000000, -2.287533624396759, 0.000000000000000,
- -0.028603745188423, 0.000000000000000, -1.353580755934427, 0.000000000000000, 0.461602380352937, 0.000000000000000, -0.059599055078928, 0.000000000000000,
- -0.929946734342228, 0.000000000000000, 0.065773089295561, 0.000000000000000, 1.106565863102982, 0.000000000000000, 4.719295086373593, 0.000000000000000,
- -2.108377703544395, 0.000000000000000, -2.226393620240159, 0.000000000000000, 1.375668397437521, 0.000000000000000, -0.960772428525443, 0.000000000000000,
- -2.156313465390571, 0.000000000000000, 1.126060012375311, 0.000000000000000, 2.756485137030720, 0.000000000000000, 0.739639690862600, 0.000000000000000,
- 3.914769510295006, 0.000000000000000, 1.685232785586675, 0.000000000000000, 4.079058040970612, 0.000000000000000, -1.174598301660513, 0.000000000000000,
- -2.885776587275580, 0.000000000000000, -0.241073635188767, 0.000000000000000, 3.080489872502403, 0.000000000000000, -2.051244183999421, 0.000000000000000,
- 0.664330486845139, 0.000000000000000, -1.697798999370016, 0.000000000000000, 1.452369423649782, 0.000000000000000, -1.523532831019280, 0.000000000000000,
- 0.171981186587481, 0.000000000000000, -4.685274721583927, 0.000000000000000, -1.336175835319380, 0.000000000000000, 1.419070770428945, 0.000000000000000,
- -0.035791601713475, 0.000000000000000, 2.291937971632081, 0.000000000000000, -1.962559313450293, 0.000000000000000, -4.831595589339301, 0.000000000000000,
- -1.857055284000925, 0.000000000000000, 2.606271522635512, 0.000000000000000, -0.576447978738030, 0.000000000000000, 0.082299166967720, 0.000000000000000,
- 1.888399453494614, 0.000000000000000, -3.564705298046079, 0.000000000000000, -0.939357831083889, 0.000000000000000, -1.903578203697778, 0.000000000000000,
- -2.642492215447250, 0.000000000000000, -0.182990405251017, 0.000000000000000, 3.742026478011174, 0.000000000000000, 0.104295803798333, 0.000000000000000,
- 1.848678195370347, 0.000000000000000, -1.887384346896369, 0.000000000000000, 0.365048973046045, 0.000000000000000, -0.889638010354219, 0.000000000000000,
- 1.173877118428863, 0.000000000000000, -1.178562827540109, 0.000000000000000, 0.610271645685184, 0.000000000000000, 1.831284815697871, 0.000000000000000,
- 0.449575390102283, 0.000000000000000, 1.597171905253443, 0.000000000000000, 3.918574971904773, 0.000000000000000, 0.868104027970404, 0.000000000000000,
- 0.582643134746494, 0.000000000000000, 2.321256382353331, 0.000000000000000, -0.238118642223180, 0.000000000000000, -2.890287868054370, 0.000000000000000,
- 0.970995414625622, 0.000000000000000, 0.666137930891283, 0.000000000000000, -0.202435718709502, 0.000000000000000, 2.057930200518194, 0.000000000000000,
- 3.120583443719949, 0.000000000000000, -0.863945271701041, 0.000000000000000, 0.906848893874630, 0.000000000000000, -1.434124930222570, 0.000000000000000,
- 0.754659384848783, 0.000000000000000, -5.224154442713778, 0.000000000000000, 2.330229744098967, 0.000000000000000, 1.113946320164698, 0.000000000000000,
- 0.523324920322840, 0.000000000000000, 1.750740911548348, 0.000000000000000, -0.899333972913577, 0.000000000000000, 0.228705845203506, 0.000000000000000,
- -1.934782624767648, 0.000000000000000, -3.508386237231303, 0.000000000000000, -2.107108523073510, 0.000000000000000, 0.380587645474815, 0.000000000000000,
- -0.476200877183279, 0.000000000000000, -2.172086712642198, 0.000000000000000, 1.795372535780299, 0.000000000000000, -2.100318983391055, 0.000000000000000,
- -0.022571122461405, 0.000000000000000, 0.674514020010955, 0.000000000000000, -0.148872569390857, 0.000000000000000, 0.298175890592737, 0.000000000000000,
- -1.134244492493590, 0.000000000000000, -3.146848422289455, 0.000000000000000, -1.357950199087602, 0.000000000000000, 0.667362732020878, 0.000000000000000,
- -3.119397998316724, 0.000000000000000, -1.189341126297637, 0.000000000000000, -1.532744386856668, 0.000000000000000, -1.672972484202534, 0.000000000000000,
- -2.042283373871558, 0.000000000000000, -1.479481547595924, 0.000000000000000, -0.002668662875396, 0.000000000000000, 0.262737760129546, 0.000000000000000,
- 2.734456080621830, 0.000000000000000, -0.671945925075102, 0.000000000000000, -3.735078262179111, 0.000000000000000, -0.161705013319883, 0.000000000000000,
- 0.748963512361001, 0.000000000000000, 1.128046374367600, 0.000000000000000, 0.649651335592966, 0.000000000000000, 1.880020215025867, 0.000000000000000,
- -1.095632293842306, 0.000000000000000, 1.197764876160487, 0.000000000000000, 0.323646656252985, 0.000000000000000, -1.655502751114502, 0.000000000000000,
- 3.666399062961496, 0.000000000000000, -0.334060899735197, 0.000000000000000, -2.119056978738397, 0.000000000000000, 3.721375117275012, 0.000000000000000,
- 0.044874186872307, 0.000000000000000, -2.733053897593234, 0.000000000000000, 1.590700278891042, 0.000000000000000, 3.215711772781902, 0.000000000000000,
- -1.792085012843801, 0.000000000000000, -0.405797188885475, 0.000000000000000, -0.628080020080892, 0.000000000000000, -1.831815840843960, 0.000000000000000,
- 2.973656862522834, 0.000000000000000, -0.212032655138417, 0.000000000000000, 0.372437389437234, 0.000000000000000, -1.614030579023492, 0.000000000000000,
- -0.704900996358698, 0.000000000000000, 1.123700273452105, 0.000000000000000, -0.136371848130819, 0.000000000000000, 3.020284357635585, 0.000000000000000,
- -0.550211350877649, 0.000000000000000, 5.101256236381711, 0.000000000000000, 3.367051512192333, 0.000000000000000, -4.385131946669234, 0.000000000000000,
- -3.967303337694391, 0.000000000000000, -0.965894936640022, 0.000000000000000, 0.328366945264681, 0.000000000000000, 0.199041562924914, 0.000000000000000,
- 1.067681999025495, 0.000000000000000, -1.939516091697170, 0.000000000000000, -1.092980954328824, 0.000000000000000, 0.273786079368066, 0.000000000000000,
- -0.040928322190265, 0.000000000000000, -0.118368078577437, 0.000000000000000, 1.766589628899997, 0.000000000000000, 1.738321311635393, 0.000000000000000,
- -2.895012794321649, 0.000000000000000, 1.213521771395142, 0.000000000000000, 0.922971726633985, 0.000000000000000, 1.091516563636489, 0.000000000000000,
- 3.226378465469620, 0.000000000000000, 1.149169778666974, 0.000000000000000, -1.695986327709386, 0.000000000000000, -0.974803077355813, 0.000000000000000,
- -4.898035507513607, 0.000000000000000, 1.622719302889447, 0.000000000000000, 0.583891313586579, 0.000000000000000, -1.677182424094957, 0.000000000000000,
- -1.915633132814685, 0.000000000000000, -1.980150370851616, 0.000000000000000, 0.604538269404190, 0.000000000000000, 0.939862406149365, 0.000000000000000,
- -1.266939874246416, 0.000000000000000, -1.494771249200063, 0.000000000000000, 0.278042784093988, 0.000000000000000, 0.326627416008916, 0.000000000000000,
- -1.914530157643303, 0.000000000000000, 1.908947721862196, 0.000000000000000, 0.531819285694044, 0.000000000000000, 3.056856632319658, 0.000000000000000,
- -0.389241827774643, 0.000000000000000, -2.418606606780420, 0.000000000000000, 0.915299238878703, 0.000000000000000, -0.098774174295283, 0.000000000000000,
- -0.906199428444304, 0.000000000000000, 0.316716451217743, 0.000000000000000, -4.367700643578311, 0.000000000000000, 1.491687997515293, 0.000000000000000,
- -1.962381126288365, 0.000000000000000, -0.700829196527045, 0.000000000000000, 3.028958963615630, 0.000000000000000, -2.313461067462598, 0.000000000000000,
- -1.431933239886712, 0.000000000000000, -0.831153039725342, 0.000000000000000, 3.939495598250743, 0.000000000000000, 0.342974753984771, 0.000000000000000,
- -2.768330763002974, 0.000000000000000, -2.744010370019008, 0.000000000000000, 3.821352685212561, 0.000000000000000, 4.551065271455856, 0.000000000000000,
- 3.270136437041298, 0.000000000000000, -3.188028411950982, 0.000000000000000, -0.777075012417436, 0.000000000000000, 0.097110650265216, 0.000000000000000,
- 1.221216137608812, 0.000000000000000, -1.325824244541822, 0.000000000000000, -2.655296734084113, 0.000000000000000, -1.074792144885704, 0.000000000000000,
- 2.770401584439407, 0.000000000000000, 5.240270645610543, 0.000000000000000, 0.108576672208892, 0.000000000000000, -1.209394350650142, 0.000000000000000,
- 1.403344353838785, 0.000000000000000, -0.299032904177277, 0.000000000000000, 4.074959450638227, 0.000000000000000, 1.718727473952107, 0.000000000000000,
- -3.061349227080806, 0.000000000000000, -1.158596888541269, 0.000000000000000, 3.381858904662625, 0.000000000000000, 0.957339964054052, 0.000000000000000,
- 0.179900074904899, 0.000000000000000, -3.909641902506081, 0.000000000000000, 0.805717289408649, 0.000000000000000, 2.047413793928261, 0.000000000000000,
- -1.273580225826614, 0.000000000000000, -2.681359186869971, 0.000000000000000, -0.721241345822093, 0.000000000000000, -1.613090681569475, 0.000000000000000,
- 0.463138804815955, 0.000000000000000, 0.377223507800954, 0.000000000000000, 2.046550684968141, 0.000000000000000, 0.178508732797712, 0.000000000000000,
- -0.477815330358845, 0.000000000000000, 3.763355908332053, 0.000000000000000, 1.300430303035163, 0.000000000000000, -0.214625793857725, 0.000000000000000,
- 1.343267891864081, 0.000000000000000, -0.340007682433245, 0.000000000000000, 2.062703194680005, 0.000000000000000, 0.042032160234235, 0.000000000000000,
- 0.643732569732250, 0.000000000000000, -1.913502543857589, 0.000000000000000, 3.771340762937158, 0.000000000000000, 1.050024807363386, 0.000000000000000,
- -4.440489488592649, 0.000000000000000, 0.444904302066643, 0.000000000000000, 2.898702265650048, 0.000000000000000, 1.953232980548558, 0.000000000000000,
- 2.761564952735079, 0.000000000000000, 1.963537633260397, 0.000000000000000, -2.168858472916215, 0.000000000000000, -4.116235357699841, 0.000000000000000,
- 4.183678271896528, 0.000000000000000, 0.600422284944681, 0.000000000000000, -0.659352647255126, 0.000000000000000, -0.993127338218109, 0.000000000000000,
- -2.463571314945747, 0.000000000000000, 0.937720951545881, 0.000000000000000, -3.098957308429730, 0.000000000000000, -2.354719140045463, 0.000000000000000,
- -0.417285119323949, 0.000000000000000, 2.187974075975947, 0.000000000000000, 1.101468905172585, 0.000000000000000, -3.185800678152109, 0.000000000000000,
- 2.357534709345083, 0.000000000000000, 0.246645606729407, 0.000000000000000, 4.440905650784504, 0.000000000000000, -2.236807716637866, 0.000000000000000,
- -2.171481518317550, 0.000000000000000, -2.029571795072690, 0.000000000000000, 0.135599790431348, 0.000000000000000, -1.277965265520191, 0.000000000000000,
- -1.927976233157507, 0.000000000000000, -5.434492783745394, 0.000000000000000, -2.026375829312657, 0.000000000000000, 1.009666016819321, 0.000000000000000,
- 0.238549782367247, 0.000000000000000, -0.516403923971309, 0.000000000000000, -0.933977817429352, 0.000000000000000, 0.155803015935614, 0.000000000000000,
- -0.396194809997929, 0.000000000000000, -0.915178100253214, 0.000000000000000, 0.666329367985015, 0.000000000000000, -1.517991149945785, 0.000000000000000,
- 0.458266744144822, 0.000000000000000, -1.242845974381418, 0.000000000000000, 0.057914823556477, 0.000000000000000, 0.994101307476875, 0.000000000000000,
- -2.387209849199325, 0.000000000000000, 0.459297048883826, 0.000000000000000, 0.227711405683905, 0.000000000000000, 0.030255073506117, 0.000000000000000,
- -1.323361608181337, 0.000000000000000, -4.650244457426706, 0.000000000000000, 0.062908579526021, 0.000000000000000, 3.462831028244432, 0.000000000000000,
- 1.303608183314856, 0.000000000000000, -1.430415193881612, 0.000000000000000, -1.672886118942142, 0.000000000000000, 0.992890699210099, 0.000000000000000,
- -0.160814531784247, 0.000000000000000, -1.238132939350430, 0.000000000000000, -0.589223271459376, 0.000000000000000, 2.326363810561534, 0.000000000000000,
- -4.433789496230785, 0.000000000000000, 1.664686987538929, 0.000000000000000, -2.366128834617921, 0.000000000000000, 1.212421570743837, 0.000000000000000,
- -4.847914267690055, 0.000000000000000, 0.228485221404712, 0.000000000000000, 0.466139765470957, 0.000000000000000, -1.344202776943546, 0.000000000000000,
- -1.012053673330574, 0.000000000000000, -2.844980626424742, 0.000000000000000, -1.552703722026340, 0.000000000000000, -1.448830983885038, 0.000000000000000,
- 0.127010756753980, 0.000000000000000, -1.667188263752299, 0.000000000000000, 3.424818052085100, 0.000000000000000, 0.956291135453840, 0.000000000000000,
- -3.725533331754662, 0.000000000000000, -1.584534272368832, 0.000000000000000, -1.654148210472472, 0.000000000000000, 0.701610500675698, 0.000000000000000,
- 0.164954538683927, 0.000000000000000, -0.739260064712987, 0.000000000000000, -2.167324026090101, 0.000000000000000, -0.310240491909496, 0.000000000000000,
- -2.281790349106906, 0.000000000000000, 1.719655331305361, 0.000000000000000, -2.997005923606441, 0.000000000000000, -1.999301431556852, 0.000000000000000,
- -0.292229010068828, 0.000000000000000, 1.172317994855851, 0.000000000000000, 0.196734885241533, 0.000000000000000, 2.981365193477068, 0.000000000000000,
- 2.637726016926352, 0.000000000000000, 1.434045125217982, 0.000000000000000, 0.883627180451827, 0.000000000000000, -1.434040761445747, 0.000000000000000,
- -1.528891971086553, 0.000000000000000, -3.306913135367542, 0.000000000000000, -0.399059265470646, 0.000000000000000, -0.265674394285178, 0.000000000000000,
- 3.502591252855384, 0.000000000000000, 0.830301156604454, 0.000000000000000, -0.220021317046083, 0.000000000000000, -0.090553770476646, 0.000000000000000,
- 0.771863477047951, 0.000000000000000, 1.351209629105760, 0.000000000000000, 3.773699756201963, 0.000000000000000, 0.472600118752329, 0.000000000000000,
- 2.332825668012222, 0.000000000000000, 1.853747950314528, 0.000000000000000, 0.759515251766178, 0.000000000000000, 1.327112776215496, 0.000000000000000,
- 2.518730296237868, 0.000000000000000, 0.764450208786353, 0.000000000000000, -0.278275349491296, 0.000000000000000, -0.041559465082020, 0.000000000000000,
- 1.387166083167787, 0.000000000000000, 2.612996769598122, 0.000000000000000, -0.385404831721799, 0.000000000000000, 2.005630016170309, 0.000000000000000,
- -0.950500047307998, 0.000000000000000, -1.166884021392492, 0.000000000000000, 1.432973552928162, 0.000000000000000, 2.540370505384567, 0.000000000000000,
- -1.140505295054501, 0.000000000000000, -3.673358835201185, 0.000000000000000, -0.450691288038056, 0.000000000000000, 1.601024294408014, 0.000000000000000,
- 0.773213556014045, 0.000000000000000, 2.973873693246168, 0.000000000000000, -1.361548406382279, 0.000000000000000, 1.409136332424815, 0.000000000000000,
- -0.963382518314713, 0.000000000000000, -2.031268227368161, 0.000000000000000, 0.983309972085586, 0.000000000000000, -3.461412488471631, 0.000000000000000,
- -2.601124929406039, 0.000000000000000, -0.533896239766343, 0.000000000000000, -2.627129008866350, 0.000000000000000, 0.622111169161305, 0.000000000000000,
- -1.160926365580422, 0.000000000000000, -2.406196188132628, 0.000000000000000, -1.076870362758737, 0.000000000000000, -1.791866820937175, 0.000000000000000,
- -0.749453071522325, 0.000000000000000, -5.324156615990973, 0.000000000000000, -1.038698022238289, 0.000000000000000, -2.106629944730630, 0.000000000000000,
- 0.659295598564773, 0.000000000000000, 0.520940881580988, 0.000000000000000, -0.055649203928700, 0.000000000000000, 0.292096765423137, 0.000000000000000,
- -4.663743901790872, 0.000000000000000, -0.125066503391666, 0.000000000000000, -2.452620252445380, 0.000000000000000, -0.712128227397468, 0.000000000000000,
- -0.048938037970968, 0.000000000000000, -1.821520226003361, 0.000000000000000, 0.810106421304257, 0.000000000000000, -0.196636623956257, 0.000000000000000,
- -0.701769836763804, 0.000000000000000, 2.460345045649201, 0.000000000000000, 3.506597671641116, 0.000000000000000, -2.711322611972225, 0.000000000000000,
- -0.658079876600542, 0.000000000000000, -2.040082099646173, 0.000000000000000, 2.201668355395807, 0.000000000000000, 1.181507395879711, 0.000000000000000,
- -1.640739552179682, 0.000000000000000, -1.613393726467190, 0.000000000000000, -1.156741241731352, 0.000000000000000, 2.527773464519963, 0.000000000000000,
- -0.497040638009502, 0.000000000000000, -0.975817112895589, 0.000000000000000, -2.866830755546166, 0.000000000000000, 1.120214498507878, 0.000000000000000,
- 5.986771654661698, 0.000000000000000, 0.398219252656757, 0.000000000000000, -3.545606013198135, 0.000000000000000, 0.312398099396191, 0.000000000000000,
- -2.265327979531788, 0.000000000000000, 0.792121001107366, 0.000000000000000, -3.736145137670100, 0.000000000000000, 0.762228883650802, 0.000000000000000,
- 2.283545661214646, 0.000000000000000, 3.780020629583529, 0.000000000000000, 3.117260228608810, 0.000000000000000, -2.011159255609613, 0.000000000000000,
- 0.279107700476072, 0.000000000000000, 2.003369134246936, 0.000000000000000, -1.448171234480257, 0.000000000000000, 0.584697150310140, 0.000000000000000,
- 0.919508663636197, 0.000000000000000, -3.071349141675388, 0.000000000000000, -1.555923649263667, 0.000000000000000, 2.232497079438850, 0.000000000000000,
- -0.012662139119883, 0.000000000000000, 0.372825540734715, 0.000000000000000, 2.378543590847629, 0.000000000000000, 1.459053407813062, 0.000000000000000,
- -0.967913907390927, 0.000000000000000, 1.322825200678212, 0.000000000000000, -1.033775820061824, 0.000000000000000, -1.813629552693142, 0.000000000000000,
- 4.794348161661486, 0.000000000000000, 0.655279811518676, 0.000000000000000, -2.224590138589720, 0.000000000000000, 0.595329481295766, 0.000000000000000,
- 3.364055988866225, 0.000000000000000, 1.863416422998127, 0.000000000000000, 1.930305751828105, 0.000000000000000, -0.284467053432545, 0.000000000000000,
- -0.923374905878938, 0.000000000000000, 1.922988234041399, 0.000000000000000, 0.310482143432719, 0.000000000000000, 0.332122302397134, 0.000000000000000,
- -1.659487472408966, 0.000000000000000, -1.865943507877961, 0.000000000000000, -0.186775297569864, 0.000000000000000, -1.700543850628361, 0.000000000000000,
- 0.497157959366735, 0.000000000000000, -0.471244843957418, 0.000000000000000, -0.432013753969948, 0.000000000000000, -4.000189880113231, 0.000000000000000,
- -0.415335170016467, 0.000000000000000, 0.317311950972859, 0.000000000000000, 0.038393428927595, 0.000000000000000, 0.177219909465206, 0.000000000000000,
- 0.531650958095143, 0.000000000000000, -2.711644985175806, 0.000000000000000, 0.328744077805156, 0.000000000000000, -0.938417707547928, 0.000000000000000,
- 0.970379584897379, 0.000000000000000, 1.873649473917137, 0.000000000000000, 0.177938226987023, 0.000000000000000, 0.155609346302393, 0.000000000000000,
- -1.276504241867208, 0.000000000000000, -0.463725075928807, 0.000000000000000, -0.064748250389500, 0.000000000000000, -1.725568534062385, 0.000000000000000,
- -0.139066584804067, 0.000000000000000, 1.975514554117767, 0.000000000000000, -0.807063199499478, 0.000000000000000, -0.326926659682788, 0.000000000000000,
- 1.445727032487938, 0.000000000000000, -0.597151107739100, 0.000000000000000, 2.732557531709386, 0.000000000000000, -2.907130934109188, 0.000000000000000,
- -1.461264832679981, 0.000000000000000, -1.708588604968163, 0.000000000000000, 3.652851925431363, 0.000000000000000, 0.682050868282879, 0.000000000000000,
- -0.281312579963294, 0.000000000000000, 0.554966483307825, 0.000000000000000, -0.981341739340932, 0.000000000000000, 1.279543331141603, 0.000000000000000,
- 0.036589747826856, 0.000000000000000, 2.312073745896073, 0.000000000000000, 1.754682200732425, 0.000000000000000, -0.957515875428627, 0.000000000000000,
- -0.833596942819695, 0.000000000000000, 0.437054368791033, 0.000000000000000, -0.898819399360279, 0.000000000000000, -0.296050580896839, 0.000000000000000,
- -0.785144257649601, 0.000000000000000, -2.541503089003311, 0.000000000000000, 2.225075846758761, 0.000000000000000, -1.587290487902002, 0.000000000000000,
- -1.421404172056462, 0.000000000000000, -3.015149802293631, 0.000000000000000, 1.780874288867949, 0.000000000000000, -0.865812740882613, 0.000000000000000,
- -2.845327531197112, 0.000000000000000, 1.445225867774367, 0.000000000000000, 2.183733236584647, 0.000000000000000, 1.163371072749080, 0.000000000000000,
- 0.883547693520409, 0.000000000000000, -1.224093106684675, 0.000000000000000, -1.854501116331044, 0.000000000000000, 1.783082089255796, 0.000000000000000,
- 2.301508706196191, 0.000000000000000, -0.539901944139077, 0.000000000000000, 1.962315832319967, 0.000000000000000, -0.060709041870503, 0.000000000000000,
- -1.353139923300238, 0.000000000000000, -1.482887537805234, 0.000000000000000, 1.273732601967176, 0.000000000000000, -3.456609915556321, 0.000000000000000,
- -3.752320586540873, 0.000000000000000, 3.536356614978951, 0.000000000000000, 0.206035952043233, 0.000000000000000, 5.933966913773842, 0.000000000000000,
- -0.486633898075490, 0.000000000000000, -0.329595089863342, 0.000000000000000, 1.496414153905337, 0.000000000000000, 0.137868749388880, 0.000000000000000,
- -0.437192030996792, 0.000000000000000, 2.682750615210656, 0.000000000000000, -2.440234892848570, 0.000000000000000, 1.433910252426186, 0.000000000000000,
- -0.415051506104074, 0.000000000000000, 1.982003013708649, 0.000000000000000, 1.345796609972435, 0.000000000000000, -2.335949513404370, 0.000000000000000,
- 1.065988867433025, 0.000000000000000, 2.741844905000464, 0.000000000000000, -1.754047930934362, 0.000000000000000, 0.229252730015575, 0.000000000000000,
- -0.679791016408669, 0.000000000000000, -2.274097820043743, 0.000000000000000, 0.149802252231876, 0.000000000000000, -0.139697151364830, 0.000000000000000,
- -2.773367420505435, 0.000000000000000, -4.403400246165611, 0.000000000000000, -1.468974515184135, 0.000000000000000, 0.664990623095844, 0.000000000000000,
- -3.446979775557143, 0.000000000000000, 1.850006428987618, 0.000000000000000, -1.550866747921936, 0.000000000000000, -3.632874882935257, 0.000000000000000,
- 0.828039662992464, 0.000000000000000, 2.794055182632816, 0.000000000000000, -0.593995716682633, 0.000000000000000, 0.142788156054200, 0.000000000000000,
- 0.552461945119668, 0.000000000000000, 0.842127129738758, 0.000000000000000, 1.414335509600077, 0.000000000000000, -0.311559241382430, 0.000000000000000,
- 1.510590844695250, 0.000000000000000, 1.692217183824300, 0.000000000000000, 0.613760285711957, 0.000000000000000, 0.065233463207770, 0.000000000000000,
- -2.571912893711505, 0.000000000000000, -1.707001531141341, 0.000000000000000, 0.673884968382041, 0.000000000000000, 0.889863883420103, 0.000000000000000,
- -2.395635435233346, 0.000000000000000, 1.129247296359819, 0.000000000000000, 0.569074704779735, 0.000000000000000, 6.139436017480722, 0.000000000000000,
- 0.822158309259017, 0.000000000000000, -3.289872016222589, 0.000000000000000, 0.417612988384414, 0.000000000000000, 1.493982103868165, 0.000000000000000,
- -0.415353391377005, 0.000000000000000, 0.288670764933155, 0.000000000000000, -1.895650228872272, 0.000000000000000, -0.139631694475020, 0.000000000000000,
- 1.445103299005436, 0.000000000000000, 2.877182243683429, 0.000000000000000, 1.192428490172580, 0.000000000000000, -5.964591921763842, 0.000000000000000,
- 0.570859795882959, 0.000000000000000, 2.328333316356666, 0.000000000000000, 0.333755014930026, 0.000000000000000, 1.221901577771909, 0.000000000000000,
- 0.943358697415568, 0.000000000000000, 2.793063983613067, 0.000000000000000, 3.163005066073616, 0.000000000000000, 2.098300664513867, 0.000000000000000,
- -3.915313164333447, 0.000000000000000, -2.475766769064539, 0.000000000000000, 1.720472044894277, 0.000000000000000, -1.273591949275665, 0.000000000000000,
- -1.213451272938616, 0.000000000000000, 0.697439404325690, 0.000000000000000, -0.309902287574293, 0.000000000000000, 2.622575852162781, 0.000000000000000,
- -2.075881936219060, 0.000000000000000, 0.777847545691770, 0.000000000000000, -3.967947986440650, 0.000000000000000, -3.066503371806472, 0.000000000000000,
- 1.193780625937845, 0.000000000000000, 0.214246579281311, 0.000000000000000, -2.610681491162162, 0.000000000000000, -1.261224183972745, 0.000000000000000,
- -1.165071748544285, 0.000000000000000, -1.116548474834374, 0.000000000000000, 0.847202164846982, 0.000000000000000, -3.474301529532390, 0.000000000000000,
- 0.020799541946476, 0.000000000000000, -3.868995473288166, 0.000000000000000, 1.757979409638067, 0.000000000000000, 0.868115130183109, 0.000000000000000,
- 0.910167436737958, 0.000000000000000, -1.878855115563720, 0.000000000000000, 1.710357104174161, 0.000000000000000, -1.468933980990902, 0.000000000000000,
- 1.799544171601169, 0.000000000000000, -4.922332880027887, 0.000000000000000, 0.219424548939720, 0.000000000000000, -0.971671113451924, 0.000000000000000,
- -0.940533475616266, 0.000000000000000, 0.122510114412152, 0.000000000000000, -1.373686254916911, 0.000000000000000, 1.760348103896323, 0.000000000000000,
- 0.391745067829643, 0.000000000000000, 2.521958505327354, 0.000000000000000, -1.300693516405092, 0.000000000000000, -0.538251788309178, 0.000000000000000,
- 0.797184135810173, 0.000000000000000, 2.908800548982588, 0.000000000000000, 1.590902251655215, 0.000000000000000, -1.070323714487264, 0.000000000000000,
- -3.349764443340999, 0.000000000000000, -1.190563529731447, 0.000000000000000, 1.363369471291963, 0.000000000000000, -1.814270299924576, 0.000000000000000,
- -0.023381588315711, 0.000000000000000, 1.719182048679569, 0.000000000000000, 0.839917213252626, 0.000000000000000, 1.006099633839122, 0.000000000000000,
- 0.812462674381527, 0.000000000000000, 1.755814336346739, 0.000000000000000, 2.546848681206319, 0.000000000000000, -1.555300208869455, 0.000000000000000,
- 1.017053811631167, 0.000000000000000, 0.996591039170903, 0.000000000000000, -1.228047247924881, 0.000000000000000, 4.809462271463009, 0.000000000000000,
- 2.318113116151685, 0.000000000000000, -1.206932520679733, 0.000000000000000, 1.273757685623312, 0.000000000000000, 0.724335352481802, 0.000000000000000,
- 1.519876652073198, 0.000000000000000, -2.749670314714158, 0.000000000000000, 3.424042481847581, 0.000000000000000, -3.714668360421517, 0.000000000000000,
- 1.612834197004014, 0.000000000000000, -2.038234723985566, 0.000000000000000, 1.470938786562152, 0.000000000000000, 2.111634918450302, 0.000000000000000,
- 1.030376670151787, 0.000000000000000, -0.420877189003829, 0.000000000000000, -1.502024800532894, 0.000000000000000, 0.452310749163804, 0.000000000000000,
- -1.606059382300987, 0.000000000000000, -4.006159967834147, 0.000000000000000, -2.152801208196508, 0.000000000000000, 1.671674089372579, 0.000000000000000,
- 1.714536333564101, 0.000000000000000, -1.011518543005344, 0.000000000000000, -0.576410282180584, 0.000000000000000, 0.733689809480836, 0.000000000000000,
- 1.004245602717974, 0.000000000000000, 1.010090391888449, 0.000000000000000, 3.811459513385621, 0.000000000000000, -5.230621089271954, 0.000000000000000,
- 0.678044861034399, 0.000000000000000, 1.255935859598107, 0.000000000000000, 1.674521701615288, 0.000000000000000, -1.656695216761705, 0.000000000000000,
- 1.169286028869693, 0.000000000000000, 0.524915416191998, 0.000000000000000, 2.397642885039520, 0.000000000000000, 2.108711400616072, 0.000000000000000,
- 2.037618211018084, 0.000000000000000, -0.623664553406925, 0.000000000000000, 2.984106170984409, 0.000000000000000, 1.132182737400932, 0.000000000000000,
- -2.859274340352130, 0.000000000000000, -0.975550071398723, 0.000000000000000, -1.359935119997407, 0.000000000000000, -2.963308211050121, 0.000000000000000,
- -0.228726662781163, 0.000000000000000, -1.411110379682043, 0.000000000000000, 0.741553355734225, 0.000000000000000, 0.497554254758309, 0.000000000000000,
- 2.371907950598855, 0.000000000000000, 1.063465168988748, 0.000000000000000, -0.641082692081488, 0.000000000000000, -0.855439878540726, 0.000000000000000,
- 0.578321738578726, 0.000000000000000, 3.005809768796194, 0.000000000000000, 1.961458699064065, 0.000000000000000, -3.206261663772745, 0.000000000000000,
- -0.364431989095434, 0.000000000000000, -0.263182496622273, 0.000000000000000, 1.843464680631139, 0.000000000000000, -0.419107530229249, 0.000000000000000,
- 1.662335873298487, 0.000000000000000, -0.853687563304005, 0.000000000000000, -2.584133404357169, 0.000000000000000, 3.466839568922895, 0.000000000000000,
- 0.881671345091973, 0.000000000000000, 0.454620014206908, 0.000000000000000, -1.737245187402739, 0.000000000000000, 2.162713238369243, 0.000000000000000,
- -3.868539002714486, 0.000000000000000, 2.014114855933826, 0.000000000000000, -0.703233831811006, 0.000000000000000, -3.410319935997574, 0.000000000000000,
- -1.851235811006584, 0.000000000000000, 0.909783907894036, 0.000000000000000, 0.091884002136728, 0.000000000000000, -2.688294201131650, 0.000000000000000,
- -0.906134178460955, 0.000000000000000, 3.475054609035133, 0.000000000000000, -0.573927964170323, 0.000000000000000, -0.429542937515399, 0.000000000000000,
- 0.991348618739939, 0.000000000000000, 1.974804904926325, 0.000000000000000, 0.975783450796698, 0.000000000000000, -3.057119549071503, 0.000000000000000,
- -3.899429237481194, 0.000000000000000, 0.362439009175350, 0.000000000000000, -1.124461670265618, 0.000000000000000, 1.806000360163583, 0.000000000000000,
- -2.768333362600288, 0.000000000000000, 0.244387897900379, 0.000000000000000, 0.908767296720926, 0.000000000000000, 1.254669374391882, 0.000000000000000,
- -1.420441929463686, 0.000000000000000, -0.875658895966293, 0.000000000000000, 0.183824603376167, 0.000000000000000, -3.361653917011686, 0.000000000000000,
- -0.796615630227952, 0.000000000000000, -1.660226542658673, 0.000000000000000, 1.654439358307226, 0.000000000000000, 2.782812946709771, 0.000000000000000,
- 1.418064412811531, 0.000000000000000, -0.819645647243761, 0.000000000000000, 0.807724772592699, 0.000000000000000, -0.941967976379298, 0.000000000000000,
- -2.312768306047469, 0.000000000000000, 0.872426936477443, 0.000000000000000, 0.919528961530845, 0.000000000000000, -2.084904575264847, 0.000000000000000,
- -1.972464868459322, 0.000000000000000, -1.050687203338466, 0.000000000000000, 1.659579707007902, 0.000000000000000, -1.820640014705855, 0.000000000000000,
- -1.195078061671045, 0.000000000000000, -1.639773173762048, 0.000000000000000, 1.616744338157063, 0.000000000000000, 4.019216096811563, 0.000000000000000,
- 3.461021102549681, 0.000000000000000, 1.642352734361484, 0.000000000000000, -0.046354693720813, 0.000000000000000, -0.041936252359677, 0.000000000000000,
- -2.393307519480551, 0.000000000000000, -0.341471634615121, 0.000000000000000, -0.392073595257017, 0.000000000000000, -0.219299018372730, 0.000000000000000,
- -2.016391579662071, 0.000000000000000, -0.653096251969787, 0.000000000000000, 1.466353155666821, 0.000000000000000, -2.872058864320412, 0.000000000000000,
- -2.157180779503830, 0.000000000000000, 0.723257479841560, 0.000000000000000, 3.769951308104384, 0.000000000000000, -1.923392042420024, 0.000000000000000,
- 0.644899359942840, 0.000000000000000, -2.090226891621437, 0.000000000000000, -0.277043982890403, 0.000000000000000, -0.528271428321112, 0.000000000000000,
- 2.518120645960652, 0.000000000000000, 1.040820431111488, 0.000000000000000, -4.560583754742486, 0.000000000000000, -0.226899614918836, 0.000000000000000,
- 1.713331231108959, 0.000000000000000, -3.293941019163642, 0.000000000000000, -1.113331444648290, 0.000000000000000, -1.032308423149906, 0.000000000000000,
- 1.593774272982443, 0.000000000000000, -1.246840475090529, 0.000000000000000, -0.190344684920137, 0.000000000000000, -1.719386356896355, 0.000000000000000,
- -2.827721754659679, 0.000000000000000, -0.092438285279020, 0.000000000000000, -0.565844430675246, 0.000000000000000, -1.077916121691716, 0.000000000000000,
- -1.208665809504693, 0.000000000000000, -2.996014266381254, 0.000000000000000, 2.888573323402423, 0.000000000000000, 2.829507048720695, 0.000000000000000,
- -0.859177034120755, 0.000000000000000, -1.969302377743254, 0.000000000000000, 0.777437674525362, 0.000000000000000, -0.124910190157646, 0.000000000000000,
- 0.129875493115290, 0.000000000000000, -4.192139262163992, 0.000000000000000, 3.023496047962126, 0.000000000000000, 1.149775163736637, 0.000000000000000,
- 2.038151304801731, 0.000000000000000, 3.016122489841263, 0.000000000000000, -4.829481812137012, 0.000000000000000, -1.668436615909279, 0.000000000000000,
- 0.958586784636918, 0.000000000000000, 1.550652410058678, 0.000000000000000, -1.456305257976716, 0.000000000000000, -0.079588392344731, 0.000000000000000,
- -2.453213599392345, 0.000000000000000, 0.296795909127105, 0.000000000000000, -0.253426616607643, 0.000000000000000, 1.418937160028195, 0.000000000000000,
- -1.672949529066915, 0.000000000000000, -1.620990298572947, 0.000000000000000, -1.085103073196045, 0.000000000000000, 0.738606361195386, 0.000000000000000,
- -2.097831202853255, 0.000000000000000, 2.711952282071310, 0.000000000000000, 1.498539238246888, 0.000000000000000, 1.317457282535915, 0.000000000000000,
- -0.302765938349717, 0.000000000000000, -0.044623707947201, 0.000000000000000, 2.337405215062395, 0.000000000000000, -3.980689173859100, 0.000000000000000,
复制代码
项目文件
