社区导航
搜索
查看: 2421|回复: 0
Toyato的 Hybrid和汽车方面的课程资料
181
TA的帖子
Rank: 5Rank: 5
发表于 2010-3-25 16:50:42 | 显示全部楼层 |阅读模式
无意在网上找到的,因此把目录整理出来,有兄弟需要的发邮件给我yulzhu@gmail.com,注明需要哪一部分,直接发怕有些问题。
混合动力有关材料
Toyota Series - Hybrid
Hybrid01 Hybrid System Overview.pdf
Hybrid02 Hybrid System Operation.pdf
Hybrid03 High-Voltage battery.pdf
Hybrid04 Engine.pdf
Hybrid05 Chassis.pdf
Hybrid06 Body Electrical.pdf
Hybrid07 Appendix.pdf
Toyota Series - Hybrid Diagnosis
Hybrid11 Principles of Operation.pdf
Hybrid12 Engine Control System.pdf
Hybrid13 Fuel and EVAP System.pdf
Hybrid14 Hybrid Vehicle Control System.pdf
Hybrid15 HV Battery Control System.pdf
Hybrid16 Brake System.pdf
Hybrid17 Electric Power System.pdf
Hybrid18 Other Systems.pdf
Hybrid19 Appendix.pdf
电气系统
Toyota Series - Electrical
01 Electrical Fundamentals with questions.pdf
02 Electrical Circuits with questions.pdf
03 Electrical Components with questions.pdf
04 Analog vs Digital Meters with questions.pdf
05 Wire, Terminal and Connector Repair w/qu.pdf
06 Automotive Batteries with questions.pdf
07 Toyota Starting Systems with questions.pdf
08 Toyota Charging Systems with questions.pdf
09 Understanding Toyota Wiring Diagram.pdf
10 Electrical Diagnostic Tools.pdf
11 Diagnosing Body Electrical Problems.pdf
12 Semiconductors with questions.pdf
13 Transistors with questions.pdf
14 Computers / Logic Gates with questions.pdf
15 Overview of Sensors & Actuators w/quest.pdf
16 Electronic Transmission #1 - Operation.pdf
17 Electronic Transmission #2 - Diagnosis w/quest.pdf
18 Shift Interlock System.pdf
Elec01 Essential Electrical Concepts.pdf
Elec02 Electrical Circuits.pdf
Elec03 The Battery.pdf
Elec04 The Starting System.pdf
Elec05 The Charging System.pdf
Elec06 Introduction to Electrical Signals.pdf
Elec07 Appendix.pdf
Elec11 Electrical Circuit Theory.pdf
Elec12 Using the Electrical Wiring Diagram.pdf
Elec13 Electrical Diagnostic Tools.pdf
Elec14 Six-Step Troubleshooting Plan.pdf
Elec15 Diagnosing Body Electrical Problems.pdf
Elec16 General Development of Multiplexing.pdf
Elec17 Appendix.pdf
引擎
Toyota Series - Engine Performance OBD
20 EFI#1 EFI System Overview.pdf
21 EFI#2 Air Induction System.pdf
22 EFI#3 Fuel Delivery & Injection Controls.pdf
23 EFI#4 Ignition System.pdf
24 Engine Controls #1 - Input Sensors.pdf
25 Engine Controls #2 - ECU/Outputs.pdf
26 Engine Controls #3 - Idle Speed Control.pdf
27 Engine Controls #4 - Diagnosis.pdf
Toyota Series - Engine Performance OBD-II
31 Sensors#1 - Mode Sensors and Switches.pdf
32 Sensors#2 - Thermistors with questions.pdf
33 Sensors#3 - Position Sensors with questions.pdf
34 Sensors#4 - Air Flow Sensors with questions.pdf
35 Sensors#5 - Pressure Sensors with questions.pdf
36 Sensors#6 - Speed Sensors with questions.pdf
37 Sensors#6 - Oxygen / Air Fuel Sensors w/ques.pdf
38 Sensors#8 - Knock Sensors with questions.pdf
39 Ignition#1 - Ignition Overview w/questions.pdf
40 Ignition#2 - Electronic Spark Advance w/quest.pdf
41 Ignition#3 - Distributor / Distributorless w/qu.pdf
42 Fuel System#1 - Overview with questions.pdf
43 Fuel System#2 - Injection Duration w/ques.pdf
44 Fuel System#3 - Closed Loop /Fuel Trim w/qu.pdf
46 OBDII#1 - Overview of On-Board Diagnostics.pdf
47 OBDII#2 - Serial Data.pdf
48 OBDII#3 - Data Interpretation.pdf
55 Emission#1 - Chemistry of Combustion.pdf
56 Emission#2 - Emission Analysis.pdf
57 Emission#3 - Engine Sub Systems.pdf
58 Emission#4 - Closed Loop Feedback Systems.pdf
59 Emission#5 - Electronic Spark Advance.pdf
60 Emission#6 - Idle Speed Control Systems.pdf
61 Emission#7 - Exhaust Gas Recirculation.pdf
62 Emission#8 - Evaporative Emission Control.pdf
63 Emission#9 - Positive Crankcase Ventilation.pdf
64 Emission#10 - Catalytic Converter.pdf
65 Emission#11 - Secondary Air.pdf
Toyota Series - Automatic Transmissions
AT01 Fundamentals of Automatic Transmissions.pdf
AT02 Torque Converter.pdf
AT03 Simpson Planetary Gear Unit.pdf
AT04 Gear Selection and Function.pdf
AT05 Power Flow.pdf
AT06 Automatic Transmission Fluid.pdf
AT07 Transmission Oil Pump.pdf
AT08 valve Body Circuits.pdf
AT09 A340H Transfer.pdf
AT10 Electrical Control.pdf
AT11 Transmission Check, Adjustments and Diagnosis.pdf
AT12 Shift Lock System.pdf
AT13 Appendix.pdf
AT21 Automatic Transmission Basics.pdf
AT22 U-Series Transaxle.pdf
AT23 Valve Body Circuits.pdf
AT24 Electronic Control System.Pdf
AT25 Diagnostic Procedures.pdf
AT26 Diagnostic Tester.pdf
AT27 Remanufactured Transmission.pdf
AT28 Appendix.pdf
Toyota Series - Brakes
Brake01 Fundamental Principles.pdf
Brake02 Master Cylinder.pdf
Brake03 Drum Brakes.pdf
Brake04 Disc Brakes.pdf
Brake05 Brake Booster.pdf
Brake06 Parking Brake.pdf
Brake07 Brake Diagnosis.pdf
Brake08 Hydraulic Control.pdf
Brake09 Anti-Lock Brakes.pdf
Brake10 ABS Diagnosis.pdf
Brake11 Other ABS Actuators.pdf
Brake12 Traction Control System (TRAC).pdf
Brake13 Appendix.pdf
此帖出自汽车电子论坛
本版积分规则
  • 论坛活动 E手掌握
    扫码关注
    EEWORLD 官方微信
  • EE福利  唾手可得
    扫码关注
    EE福利 唾手可得
GMT+8, 2019-1-22 15:06 , Processed in 0.077059 second(s), 16 queries , Gzip On, MemCache On.
