社区导航
搜索
查看: 1891|回复: 11
[求助] TM4C1294ncpdt新画板子不能下载程序
46
TA的帖子
Rank: 2
发表于 2018-9-10 18:07 | 显示全部楼层 |阅读模式
CCS连接测试如下
The controller cannot monitor the value on the EMU[1] pin.
The controller cannot control the timing on output pins.
The controller cannot control the timing on input pins.
The scan-path link-delay has been set to exactly '0' (0x0000).
-----[Perform the Integrity scan-test on the JTAG IR]------------------------
This test will use blocks of 64 32-bit words.
This test will be applied just once.
Do a test using 0xFFFFFFFF.
Scan tests: 1, skipped: 0, failed: 0
Do a test using 0x00000000.
Scan tests: 2, skipped: 0, failed: 0
Do a test using 0xFE03E0E2.
Scan tests: 3, skipped: 0, failed: 0
Do a test using 0x01FC1F1D.
Scan tests: 4, skipped: 0, failed: 0
Do a test using 0x5533CCAA.
Scan tests: 5, skipped: 0, failed: 0
Do a test using 0xAACC3355.
Scan tests: 6, skipped: 0, failed: 0
All of the values were scanned correctly.
The JTAG IR Integrity scan-test has succeeded.
-----[Perform the Integrity scan-test on the JTAG DR]------------------------
The JTAG DR Integrity scan-test has succeeded.
[End: Texas Instruments XDS110 USB Debug Probe_0]
CCS调试错误如下
CORTEX_M4_0: Error connecting to the target: (Error -2062 @ 0x0) Unable to halt device. Reset the device, and retry the operation. If error persists, confirm configuration, power-cycle the board, and/or try more reliable JTAG settings (e.g. lower TCLK). (Emulation package 7.0.100.0)
用MDK能扫描到芯片ID。
实在解决不了了?希望哪位有类似经历的大佬给点解决思路,谢谢。
使用道具 举报
5635
TA的帖子
454
Rank: 9Rank: 9Rank: 9
发表于 2018-9-11 08:18 | 显示全部楼层
你试了几块板子啊?
要不再焊块试试
排除焊接问题
使用道具 举报
2789
TA的帖子
Rank: 6Rank: 6
发表于 2018-9-11 08:48 来自手机 | 显示全部楼层
买块lm4f232更省事
使用道具 举报
46
TA的帖子
Rank: 2
 楼主| 发表于 2018-9-11 09:03 | 显示全部楼层
公司项目用的,能用开发板?
使用道具 举报
46
TA的帖子
Rank: 2
蓝雨夜 发表于 2018-9-11 08:18
你试了几块板子啊?
要不再焊块试试
排除焊接问题
焊接了2块都是这样的
项目用开发板很正常呀,撸码的与画板子的分开,撸码的可以先撸起来,画板子的硬件没有问题的时直接换个板子测试下不就行了,如果画板子的渣,项目就一直拖着了……你这边个连芯片都找不到,要不焊工太渣,要不就是画  详情 回复 发表于 2018-9-11 09:36
那就要看看你硬件了!最小系统查查看了!  详情 回复 发表于 2018-9-11 09:32
使用道具 举报
5635
TA的帖子
454
发表于 2018-9-11 09:32 | 显示全部楼层
LiHuiyang 发表于 2018-9-11 09:03
焊接了2块都是这样的
那就要看看你硬件了!最小系统查查看了!
查了,我怀疑是不是芯片FLASh锁了,不能下载程序。  详情 回复 发表于 2018-9-11 11:55
使用道具 举报
2789
TA的帖子
Rank: 6Rank: 6
发表于 2018-9-11 09:36 | 显示全部楼层
焊接了2块都是这样的
项目用开发板很正常呀,撸码的与画板子的分开,撸码的可以先撸起来,画板子的硬件没有问题的时直接换个板子测试下不就行了,如果画板子的渣,项目就一直拖着了……你这边个连芯片都找不到,要不焊工太渣,要不就是画的板子有问题呀!
使用道具 举报
1286
TA的帖子
Rank: 3Rank: 3
发表于 2018-9-11 09:55 | 显示全部楼层
看提示The controller cannot monitor the value on the EMU[1] pin,应该是你画的板子有线没有连接到单片机的引脚,你查查pcb板吧,应该是有没有连线的情况,不行用飞线接起来,试试吧。
时钟电路,复位电路,电源都是正常的,那只能找找是不是接触不良这方面的原因了。  详情 回复 发表于 2018-9-11 11:54
使用道具 举报
46
TA的帖子
Rank: 2
 楼主| 发表于 2018-9-11 11:50 | 显示全部楼层
strong161 发表于 2018-9-11 09:36
项目用开发板很正常呀,撸码的与画板子的分开,撸码的可以先撸起来,画板子的硬件没有问题的时直接换个板 ...
程序是用开发板调的,也画了自己的板子准备用在项目上,结果下不了程序,很尴尬啊。电源电压3.246V,晶振也起振了。
使用道具 举报
46
TA的帖子
Rank: 2
 楼主| 发表于 2018-9-11 11:54 | 显示全部楼层
alan000345 发表于 2018-9-11 09:55
看提示The controller cannot monitor the value on the EMU[1] pin,应该是你画的板子有线没有连接到单片 ...
使用道具 举报
46
TA的帖子
Rank: 2
 楼主| 发表于 2018-9-11 11:55 | 显示全部楼层
蓝雨夜 发表于 2018-9-11 09:32
那就要看看你硬件了!最小系统查查看了!
使用道具 举报
TA的帖子
Rank: 1
发表于 2018-11-7 13:06 | 显示全部楼层
用示波器看一看Jtag口几条线的波形
使用道具 举报
站长推荐上一条 /1 下一条
  • 论坛活动 E手掌握
    扫码关注
    EEWORLD 官方微信
  • EE福利  唾手可得
    扫码关注
    EE福利 唾手可得
GMT+8, 2019-7-19 22:08 , Processed in 0.345133 second(s), 17 queries , Gzip On, MemCache On.
