3547|0
59
Freescale 2009 seminar之七Interfacing Display Peripherals to the i.MX Processors [复制链接]
Interfacing Display Peripherals to i.MX Processors
►Display technology for multimedia applications
►Overview of display support on i.MX
►Guidelines on display interfacing with i.MX Processor
Display Technology for Multimedia Applications
►Monochrome and low resolution LCD display is suitable for basic and low cost media player applications where richness of display is not a requirement.
►These displays usually connect through serial (I2C or SPI) interface as their display data rate is very low.
►Use of one or two LEDsis enough for backlight generation. White LED is not a requirement (since multi color support is not needed) and this keeps the cost low.
CON-T0289_Interfacing Display Peripherals to the i.MX Proces.pdf
595.87 KB, 下载次数: 0
售价: 2 分芯积分  [记录]  [购买]
此帖出自NXP MCU论坛
