本版名称: 【stm32/stm8】
版       主: astwyg
EEWORLD欢迎您,请先注册登录
[资料下载] 用最新库玩转智林STM32开发板(之四)------点亮真彩屏
驱动智林STM32开发板,真彩屏首先设定PINC为输出
所有子函数都在TFT018.c中
编译运行,则在屏幕显示如下:
STM32F EVAL BOARD
Version 1.0
ZERO Research
www.the0.net
整个工程有如下文件:
Source Group1
STM32f10x.s
lcd:
TFT018.c
uinit:
main.c
lib:
stm32f10xR.lib(这个不用编,是MDK目录下的库文件包进来就行)
大家可把main.c直接考到工程中
http://shop35738797.taobao.com/
* File Name : main.c
* Author : ddllxxrr
* Date First Issued : 08/08/2008
* Description : Main program body
/* Includes ------------------------------------------------------------------*/
#include "stm32f10x_lib.h"
#include "TFT018.h"
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
TIM_OCInitTypeDef TIM_OCInitStructure;
vu16 CCR3_Val = 0x500;
ErrorStatus HSEStartUpStatus;
/* Private function prototypes -----------------------------------------------*/
void RCC_Configuration(void);
void GPIO_Configuration(void);
void NVIC_Configuration(void);
/* Private functions ---------------------------------------------------------*/
* Function Name : main
* Input : None
* Output : None
* Return : None
int main(void)
#ifdef DEBUG
debug();
#endif
/* System Clocks Configuration */
RCC_Configuration();
/* NVIC Configuration */
NVIC_Configuration();
/* GPIO Configuration */
GPIO_Configuration();
/* Time base configuration */
TIM_TimeBaseStructure.TIM_Period = 0x5000;
TIM_TimeBaseStructure.TIM_Prescaler = 0x00;
TIM_TimeBaseStructure.TIM_ClockDivision = 0x0;
TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure);
/* Output Compare Toggle Mode configuration: Channel1 */
TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;
TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
TIM_OCInitStructure.TIM_Pulse =CCR3_Val ;
TIM_OC3Init(TIM2, &TIM_OCInitStructure);
/* TIM enable counter */
TIM_Cmd(TIM2, ENABLE);
LCD_Init();
LCD_Clear_Screen(Blue);
while(1)
for(;;) {
//GPIOB->ODR &= ~LED; // switch on LED
//Delay(2000000);
//GPIOB->ODR |= LED; // switch off LED
//Delay(2000000);
Font = 0;
LCD_PutString(10,30,"STM32F EVAL BOARD",Cyan,Blue);
Font = 1;
LCD_PutString(38,46,"Version 1.0",Green,Blue);
Font = 0;
LCD_PutString(30,65,"ZERO Research",Yellow,Blue);
LCD_PutString(36,81,"www.the0.net\",Magenta,Blue);
* Function Name : RCC_Configuration
* Description : Configures the different system clocks.
* Input : None
* Output : None
* Return : None
/* RCC system reset(for debug purpose) */
RCC_DeInit();
/* Enable HSE */
RCC_HSEConfig(RCC_HSE_ON);
/* Wait till HSE is ready */
HSEStartUpStatus = RCC_WaitForHSEStartUp();
if(HSEStartUpStatus == SUCCESS)
/* HCLK = SYSCLK */
RCC_HCLKConfig(RCC_SYSCLK_Div1);
/* PCLK2 = HCLK */
RCC_PCLK2Config(RCC_HCLK_Div1);
/* PCLK1 = HCLK/4 */
RCC_PCLK1Config(RCC_HCLK_Div4);
/* Flash 2 wait state */
FLASH_SetLatency(FLASH_Latency_2);
/* Enable Prefetch Buffer */
FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
/* PLLCLK = 8MHz * 9 = 72 MHz */
RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9);
/* Enable PLL */
RCC_PLLCmd(ENABLE);
/* Wait till PLL is ready */
while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET)
/* Select PLL as system clock source */
RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
/* Wait till PLL is used as system clock source */
while(RCC_GetSYSCLKSource() != 0x08)
/* TIM2 clock enable */
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE);
/* GPIOA clock enable */
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);
/* GPIOC clock enable */
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE);
* Function Name : GPIO_Configuration
* Description : Configure the TIM2 Pins.
* Input : None
* Output : None
* Return : None
GPIO_InitTypeDef GPIO_InitStructure;
/* GPIOA Configuration:TIM2 Channel1, 2, 3 and 4 in Output */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_2 | GPIO_Pin_3;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_Init(GPIOA, &GPIO_InitStructure);
/* GPIOC Configuration because the PORTC is connect the lcd */
/* so the PIN is ...... */
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
GPIO_Init(GPIOC,&GPIO_InitStructure);
* Function Name : NVIC_Configuration
* Description : Configure the nested vectored interrupt controller.
* Input : None
* Output : None
* Return : None
NVIC_InitTypeDef NVIC_InitStructure;
#ifdef VECT_TAB_RAM
/* Set the Vector Table base location at 0x20000000 */
NVIC_SetVectorTable(NVIC_VectTab_RAM, 0x0);
#else /* VECT_TAB_FLASH */
/* Set the Vector Table base location at 0x08000000 */
NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x0);
#endif
/* Enable the TIM2 global Interrupt */
NVIC_InitStructure.NVIC_IRQChannel = TIM2_IRQChannel;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStructure);
#ifdef DEBUG
* Function Name : assert_failed
* Description : Reports the name of the source file and the source line number
* where the assert error has occurred.
* Input : - file: pointer to the source file name
* - line: assert error line source number
* Output : None
* Return : None
void assert_failed(u8* file, u32 line)
/* User can add his own implementation to report the file name and line number,
ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
while(1)
#endif
/******************* (C) COPYRIGHT 2007 STMicroelectronics *****END OF FILE****/
附件
 EEWORLD提示:为减少服务器的压力,请尽量不要使用迅雷等下载软件。
2009-4-8 21:35
zl4.rar (21.66 KB)
2009-4-8 21:35, 下载次数: 84
推荐博客
智林淘宝三店:http://shop35738797.taobao.com
TOP↑
Re: 用最新库玩转智林STM32开发板(之四)------点亮真彩屏
顶自己一下
TOP↑
看来还是挺贵的啊,还要狂发帖,哈哈。
TOP↑
下来看看是否物有所值!
顺便学习下!
TOP↑
贵的啊,我要发帖发帖在发帖!
TOP↑
顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶
TOP↑
好东西啊。。。。。。。
TOP↑
24小时排行榜
最近访问的版块
