社区导航
搜索
查看: 727|回复: 3
[原创] 表格形式的Cortex-M0、M3、M4指令对比
TA的帖子
Rank: 3Rank: 3
发表于 2018-8-8 16:27:20 | 显示全部楼层 |阅读模式
M0
M3
M4
Bits
Mnemonic
Operands
Brief description
Flags
M0
ADCS
{Rd,}Rn,Rm
Add with Carry
N,Z,C,V
M3
M4
ADC, ADCS
{Rd,} Rn, Op2
Add with Carry 带进位加法
N,Z,C,V
M0
ADD{S}
{Rd,}Rn,<Rm|#imm>
Add
N,Z,C,V
M3
M4
ADD, ADDS
{Rd,} Rn, Op2
Add
N,Z,C,V
M3
M4
32
ADD, ADDW
{Rd,} Rn, #imm12
Add 寬加法
N,Z,C,V
M0
M3
M4
Memory
ADR
Rd,label
PC-relative Address to Register
M0
ANDS
{Rd,}Rn,Rm
Bitwise AND
N,Z
M3
M4
AND, ANDS
{Rd,} Rn, Op2
Logical AND
N,Z,C
M0
Shift
ASRS
{Rd,}Rm,<Rs|#imm>
Arithmetic Shift Right 算术右移
N,Z,C
M3
M4
ASR, ASRS
Rd, Rm, <Rs|#n>
Arithmetic Shift Right 算術右移
N,Z,C
M0
M3
M4
B{cc}
label
Branch {conditionally}
M3
M4
32
BFC
Rd, #lsb, #width
Bit Field Clear 位段清零
M3
M4
32
BFI
Rd, Rn, #lsb, #width
Bit Field Insert 位段插入
M0
BICS
{Rd,}Rn,Rm
Bit Clear
N,Z
M3
M4
BIC, BICS
{Rd,} Rn, Op2
Bit Clear 按位清零
N,Z,C
M0
M3
M4
BKPT
#imm
Breakpoint
M0
M3
M4
BL
label
Branch with Link
M0
M3
M4
Branch
BLX
Rm
Branch indirect with Link
M0
M3
M4
Branch
BX
Rm
Branch indirect
M3
M4
CBNZ
Rn,label
Compare and Branch if Non Zero
M3
M4
CBZ
Rn,label
Compare and Branch if Zero
M3
M4
32
CLREX
Clear Exclusive
M3
M4
32
CLZ
Rd,Rm
Count Leading Zeros 計算前導零的數目
M0
M3
M4
CMN
Rn,Rm
Compare Negative
N,Z,C,V
M0
M3
M4
CMP
Rn,<Rm|#imm>
Compare
N,Z,C,V
M0
M3
M4
CPSID
i
Change Processor State, Disable Interrupts
M0
M3
M4
CPSIE
i
Change Processor State, Enable Interrupts
M0
M3
M4
32
DMB
Data Memory Barrier
M0
M3
M4
32
DSB
Data Synchronization Barrier
M0
EORS
{Rd,}Rn,Rm
Exclusive OR
N,Z
M3
M4
EOR, EORS
{Rd,} Rn, Op2
Exclusive OR
N,Z,C
M0
M3
M4
32
ISB
Instruction Synchronization Barrier
M3
M4
IT
If-Then condition block
M0
M3
M4
32
Memory
LDM
Rn{!},reglist
Load Multiple registers, increment after
M3
M4
Memory
LDMDB, LDMEA
Rn{!},reglist
Load Multiple registers, decrement before
M3
M4
Memory
LDMFD, LDMIA
Rn{!},reglist
M0
Memory
LDR
Rt,label
Load Register from PC-relative address
M0
M3
M4
LDR
Rt,[Rn,<Rm|#imm>]
Load Register with word
M4
Memory
LDR
Rt, [Rn, #offset]
M0
Memory
LDRB
Rt,[Rn,<Rm|#imm>]
Load Register with byte
M3
M4
LDRB, LDRBT
Rt, [Rn, #offset]
M3
M4
32
Memory
LDRD
Rt,Rt2,[Rn,#offset]
Load Register with two bytes
M3
M4
32
Memory
LDREX
Rt,[Rn,#offset]
Load Register Exclusive
M3
M4
32
Memory
LDREXB
Rt,[Rn]
Load Register Exclusive with Byte
M3
M4
32
Memory
LDREXH
Rt,[Rn]
Load Register Exclusive with Halfword
M0
Memory
LDRH
Rt,[Rn,<Rm|#imm>]
Load Register with halfword
M3
M4
LDRH, LDRHT
Rt, [Rn, #offset]
M0
Memory
LDRSB
Rt,[Rn,<Rm|#imm>]
Load Register with signed byte
M3
M4
Memory
LDRSB, LDRSBT
Rt, [Rn, #offset]
M0
Memory
LDRSH
Rt,[Rn,<Rm|#imm>]
Load Register with signed halfword
M3
M4
LDRSH, LDRSHT
Rt, [Rn, #offset]
M3
M4
Memory
LDRT
Rt, [Rn, #offset]
M0
M3
M4
LSLS
{Rd,}Rn,<Rs|#imm>
Logical Shift Left
N,Z,C
M0
M3
M4
LSRS
{Rd,}Rn,<Rs|#imm>
Logical Shift Right
N,Z,C
M3
M4
32
MLA
Rd, Rn, Rm, Ra
Multiply with Accumulate, 32-bit result 乘加
M3
M4
32
MLS
Rd, Rn, Rm, Ra
Multiply and Subtract, 32-bit result 乘減
M0
MOV{S}
Rd,Rm
Move
N,Z
M3
M4
MOV, MOVS
Rd, Op2
Move
N,Z,C
M3
M4
32
MOVT
Rd, #imm16
Move Top 把16位立即數放到高8位
M3
M4
32
MOVW, MOV
Rd, #imm16
Move 16-bit constant 把16位立即數放到低8位
N,Z,C
M0
M3
M4
32
MRS
Rd,spec_reg
Move to general register from special register
M0
M3
M4
32
MSR
spec_reg,Rm
Move to special register from general register
N,Z,C,V
M0
M3
M4
MUL, MULS
Rd,Rn,Rm
Multiply, 32-bit result
N,Z
M0
MVNS
Rd,Rm
Bitwise NOT
N,Z
M3
M4
MVN, MVNS
Rd, Op2
Bitwise NOT 加載一個數的NOT值
N,Z,C
M0
M3
M4
NOP
No Operation
M3
M4
32
ORN, ORNS
{Rd,} Rn, Op2
Logical OR NOT
N,Z,C
M0
ORRS
{Rd,}Rn,Rm
Logical OR
N,Z
M3
M4
ORR, ORRS
{Rd,} Rn, Op2
Logical OR
N,Z,C
M4
PKHTB, PKHBT
{Rd,} Rn, Rm, Op2
Pack Halfword
M0
M3
M4
POP
reglist
Pop registers from stack
M0
M3
M4
PUSH
reglist
Push registers onto stack
M4
QADD
{Rd,} Rn, Rm
Saturating double and Add
Q
M4
QADD16
{Rd,} Rn, Rm
Saturating Add 16
M4
QADD8
{Rd,} Rn, Rm
Saturating Add 8
M4
QASX
{Rd,} Rn, Rm
Saturating Add and Subtract with Exchange
M4
QDADD
{Rd,} Rn, Rm
Saturating Add
Q
M4
QDSUB
{Rd,} Rn, Rm
Saturating double and Subtract
Q
M4
QSAX
{Rd,} Rn, Rm
Saturating Subtract and Add with Exchange
M4
QSUB
{Rd,} Rn, Rm
Saturating Subtract
Q
M4
QSUB16
{Rd,} Rn, Rm
Saturating Subtract 16
M4
QSUB8
{Rd,} Rn, Rm
Saturating Subtract 8
M3
M4
32
RBIT
Rd, Rn
Reverse Bits 位反轉
M0
M3
M4
REV
Rd,Rm
Byte-Reverse word 字節反轉
M0
M3
M4
32
REV16
Rd,Rm
Byte-Reverse packed halfwords
M0
M3
M4
REVSH
Rd,Rm
Byte-Reverse signed halfword
M0
Shift
RORS
{Rd,}Rn,Rs
Rotate Right
N,Z,C
M3
M4
ROR, RORS
Rd, Rm, <Rs|#n>
Rotate Right
N,Z,C
M3
M4
32
Shift
RRX, RRXS
Rd, Rm
Rotate Right with Extend
N,Z,C
M0
Shift
RSBS
{Rd,}Rn,#0
Reverse Subtract
N,Z,C,V
M3
M4
Shift
RSB, RSBS
{Rd,} Rn, Op2
Reverse Subtract
N,Z,C,V
M4
SADD16
{Rd,} Rn, Rm
Signed Add 16
GE
M4
SDADD8
{Rd,} Rn, Rm
Signed Add 8
GE
M4
SASX
{Rd,} Rn, Rm
Signed Add and Subtract with Exchange
GE
M0
M3
M4
SBC, SBCS
{Rd,}Rn,Rm
Subtract with Carry
N,Z,C,V
M3
M4
32
SBFX
Signed Bit Field Extract
M3
M4
32
SDIV
{Rd,} Rn, Rm
Signed Divide
M0
M3
M4
32
SEV
Send Event
M4
SHADD16
{Rd,} Rn, Rm
Signed Halving Add 16
M4
SHADD8
{Rd,} Rn, Rm
Signed Halving Add 8
M4
SHASX
{Rd,} Rn, Rm
Signed Halving Add and Subtract with Exchange
M4
SHSAX
{Rd,} Rn, Rm
Signed Halving Subtract and Add with Exchange
M4
SHSUB16
{Rd,} Rn, Rm
Signed Halving Subtract 16
M4
SHSUB8
{Rd,} Rn, Rm
Signed Halving Subtract 8
M4
SMLABB, SMLABT,
SMLATB, SMLATT
Rd, Rn, Rm, Ra
Signed Multiply Accumulate Long (halfwords)
Q
M4
SMLAD, SMLADX
Rd, Rn, Rm, Ra
Signed Multiply Accumulate Dual
Q
M3
M4
32
SMLAL
RdLo, RdHi, Rn, Rm
Signed Multiply with Accumulate (32 x 32 + 64),64-bit result
M4
SMLALBB, SMLALBT,
SMLALTB, SMLALTT
RdLo, RdHi, Rn, Rm
Signed Multiply Accumulate Long, halfwords
M4
SMLALD, SMLALDX
RdLo, RdHi, Rn, Rm
Signed Multiply Accumulate Long Dual
M4
SMLAWB, SMLAWT
Rd, Rn, Rm, Ra
Signed Multiply Accumulate, word by halfword
Q
M4
SMLSD
Rd, Rn, Rm, Ra
Signed Multiply Subtract Dual
Q
M4
SMLSLD
RdLo, RdHi, Rn, Rm
Signed Multiply Subtract Long Dual
M4
SMMLA
Rd, Rn, Rm, Ra
Signed Most significant word Multiply Accumulate
M4
SMMLS, SMMLR
Rd, Rn, Rm, Ra
Signed Most significant word Multiply Subtract
M4
SMMUL, SMMULR
{Rd,} Rn, Rm
M4
SMUAD
{Rd,} Rn, Rm
Signed dual Multiply Add
Q
M4
SMULBB, SMULBT
SMULTB, SMULTT
{Rd,} Rn, Rm
Signed Multiply (halfwords)
M3
M4
32
SMULL
RdLo, RdHi, Rn, Rm
Signed Multiply (32 x 32), 64-bit result
M4
SMULWB, SMULWT
{Rd,} Rn, Rm
Signed Multiply word by halfword
M4
SMUSD, SMUSDX
{Rd,} Rn, Rm
Signed dual Multiply Subtract
M3
M4
32
SSAT
Rd, #n, Rm {,shift #s}
Signed Saturate
Q
M4
SSAT16
Rd, #n, Rm
Signed Saturate 16
Q
M4
SSAX
{Rd,} Rn, Rm
Signed Subtract and Add with Exchange
GE
M4
SSUB16
{Rd,} Rn, Rm
Signed Subtract 16
M4
SSUB8
{Rd,} Rn, Rm
Signed Subtract 8
M0
M3
M4
32
Memory
STM
Rn!,reglist
Store Multiple registers, increment after
M3
M4
Memory
STMDB, STMEA
Rn!,reglist
Store Multiple registers, decrement before
M3
M4
Memory
STMFD, STMIA
Rn!,reglist
M0
M3
M4
STR
Rt,[Rn,<Rm|#imm>]
Store Register as word
M0
Memory
STRB
Rt,[Rn,<Rm|#imm>]
Store Register as byte
M3
M4
STRB, STRBT
Rt, [Rn, #offset]
Store Register byte
M3
M4
32
Memory
STRD
Rt, Rt2, [Rn, #offset]
Store Register two words
M3
M4
32
Memory
STREX
Rd, Rt, [Rn, #offset]
Store Register Exclusive
M3
M4
32
Memory
STREXB
Rd, Rt, [Rn]
Store Register Exclusive Byte
M3
M4
32
Memory
STREXH
Rd, Rt, [Rn]
Store Register Exclusive Halfword
M0
Memory
STRH
Rt,[Rn,<Rm|#imm>]
Store Register as halfword
M3
M4
STRH, STRHT
Rt, [Rn, #offset]
M3
M4
Memory
STRT
Rt, [Rn, #offset]
Store Register word
M0
M3
M4
SUB{S}
{Rd,}Rn,<Rm|#imm>
Subtract
N,Z,C,V
M3
M4
SUB, SUBW
{Rd,} Rn, #imm12
Subtract
N,Z,C,V
M0
M3
M4
SVC
#imm
Supervisor Call 系統任務調用
M4
SXTAB
{Rd,} Rn, Rm,{,ROR #}
Extend 8 bits to 32 and add
M4
SXTAB16
Dual extend 8 bits to 16 and add
M4
SXTAH
Extend 16 bits to 32 and add
M4
SXTB16
{Rd,} Rm {,ROR #n}
Signed Extend Byte 16
M0
SXTB
Rd,Rm
Sign extend byte
M3
M4
SXTB
{Rd,} Rm {,ROR #n}
Sign extend byte
M0
SXTH
Rd,Rm
Sign extend halfword
M3
M4
SXTH
{Rd,} Rm {,ROR #n}
M3
M4
32
TBB
[Rn, Rm]
Table Branch Byte
M3
M4
32
TBH
[Rn, Rm, LSL #1]
Table Branch Halfword
M3
M4
32
TEQ
Rn, Op2
Test Equivalence
N,Z,C
M0
TST
Rn,Rm
Logical AND based test
N,Z
M3
M4
TST
Rn, Op2
Test
N,Z,C
M4
UADD16
{Rd,} Rn, Rm
Unsigned Add 16
GE
M4
UADD8
{Rd,} Rn, Rm
Unsigned Add 8
GE
M4
USAX
{Rd,} Rn, Rm
Unsigned Subtract and Add with Exchange
GE
M4
UHADD16
{Rd,} Rn, Rm
Unsigned Halving Add 16
M4
UHADD8
{Rd,} Rn, Rm
Unsigned Halving Add 8
M4
UHASX
{Rd,} Rn, Rm
Unsigned Halving Add and Subtract with Exchange
M4
UHSAX
{Rd,} Rn, Rm
Unsigned Halving Subtract and Add with Exchange
M4
UHSUB16
{Rd,} Rn, Rm
Unsigned Halving Subtract 16
M4
UHSUB8
{Rd,} Rn, Rm
Unsigned Halving Subtract 8
M3
M4
32
UBFX
Unsigned Bit Field Extract
M3
M4
32
UDIV
{Rd,} Rn, Rm
Unsigned Divide
M4
UMAAL
RdLo, RdHi, Rn, Rm
Unsigned Multiply Accumulate Accumulate
Long (32 x32 + 32 +32), 64-bit result
M3
M4
32
UMLAL
RdLo, RdHi, Rn, Rm
Unsigned Multiply with Accumulate
(32 x 32 +64), 64-bit result
M3
M4
32
UMULL
RdLo, RdHi, Rn, Rm
Unsigned Multiply (32 x 32), 64-bit result
M4
UQADD16
{Rd,} Rn, Rm
Unsigned Saturating Add 16
M4
UQADD8
{Rd,} Rn, Rm
Unsigned Saturating Add 8
M4
UQASX
{Rd,} Rn, Rm
Unsigned Saturating Add and Subtract with Exchange
M4
UQSAX
{Rd,} Rn, Rm
Unsigned Saturating Subtract and Add with Exchange
M4
UQSUB16
{Rd,} Rn, Rm
Unsigned Saturating Subtract 16
M4
UQSUB8
{Rd,} Rn, Rm
Unsigned Saturating Subtract 8
M4
USAD8
{Rd,} Rn, Rm
Unsigned Sum of Absolute Differences
M4
USADA8
{Rd,} Rn, Rm, Ra
Unsigned Sum of Absolute Differences and Accumulate
M3
M4
32
USAT
Unsigned Saturate
Q
M4
USAT16
Rd, #n, Rm
Unsigned Saturate 16
Q
M4
UASX
{Rd,} Rn, Rm
Unsigned Add and Subtract with Exchange
GE
M4
USUB16
{Rd,} Rn, Rm
Unsigned Subtract 16
GE
M4
USUB8
{Rd,} Rn, Rm
Unsigned Subtract 8
GE
M4
UXTAB
Rotate, extend 8 bits to 32 and Add
M4
UXTAB16
Rotate, dual extend 8 bits to 16 and Add
M4
UXTAH
Rotate, unsigned extend and Add Halfword
M0
M4
UXTB
Rd,Rm
Zero extend a byte
M3
M4
UXTB
{Rd,} Rm {,ROR #n}
Zero extend a byte
M4
UXTB16
{Rd,} Rm {,ROR #n}
Unsigned Extend Byte 16
M0
UXTH
Rd,Rm
Zero extend a halfword
M3
M4
UXTH
{Rd,} Rm {,ROR #n}
M4F
VABS.F32
Sd, Sm
Floating-point Absolute
M4F
VADD.F32
{Sd,} Sn, Sm
Floating-point Add
M4F
VCMP.F32
Sd, <Sm | #0.0>
Compare two floating-point registers, or one
Floating-point register and zero
FPSCR
M4F
VCMPE.F32
Sd, <Sm | #0.0>
Floating-point register and zero check
M4F
VCVT.S32.F32
Sd, Sm
Convert between floating-point and integer
M4F
VCVT.S16.F32
Sd, Sd, #fbits
Convert between floating-point and fixed point
M4F
VCVTR.S32.F32
Sd, Sm
Convert between floating-point and integer with rounding
M4F
VCVT<B|H>.F32.F16
Sd, Sm
Converts half-precision value to single-precision
M4F
VCVTT<B|T>.F32.F16
Sd, Sm
Converts single-precision register to half-precision
M4F
VDIV.F32
{Sd,} Sn, Sm
Floating-point Divide
M4F
VFMA.F32
{Sd,} Sn, Sm
Floating-point Fused Multiply Accumulate
M4F
VFNMA.F32
{Sd,} Sn, Sm
Floating-point Fused Negate Multiply Accumulate
M4F
VFMS.F32
{Sd,} Sn, Sm
Floating-point Fused Multiply Subtract
M4F
VFNMS.F32
{Sd,} Sn, Sm
Floating-point Fused Negate Multiply Subtract
M4F
VLDM.F<32|64>
Rn{!}, list
Load Multiple extension registers
M4F
VLDR.F<32|64>
<Dd|Sd>, [Rn]
Load an extension register from memory
M4F
VLMA.F32
{Sd,} Sn, Sm
Floating-point Multiply Accumulate
M4F
VLMS.F32
{Sd,} Sn, Sm
Floating-point Multiply Subtract
M4F
VMOV.F32
Sd, #imm
Floating-point Move immediate
M4
VMOV
Sd, Sm
Floating-point Move register
M4
VMOV
Sn, Rt
Copy ARM core register to single precision
M4
VMOV
Sm, Sm1, Rt, Rt2
Copy 2 ARM core registers to 2 single precision
M4
VMOV
Dd[x], Rt
Copy ARM core register to scalar
M4
VMOV
Rt, Dn[x]
Copy scalar to ARM core register
M4
VMRS
Rt, FPSCR
Move FPSCR to ARM core register or APSR
N,Z,C,V
M4
VMSR
FPSCR, Rt
Move to FPSCR from ARM Core register
FPSCR
M4F
VMUL.F32
{Sd,} Sn, Sm
M4F
VNEG.F32
Sd, Sm
Floating-point Negate
M4F
VNMLA.F32
Sd, Sn, Sm
Floating-point Multiply and Add
M4F
VNMLS.F32
Sd, Sn, Sm
Floating-point Multiply and Subtract
M4
VNMUL
{Sd,} Sn, Sm
M4
VPOP
list
Pop extension registers
M4
VPUSH
list
Push extension registers
M4F
VSQRT.F32
Sd, Sm
Calculates floating-point Square Root
M4
VSTM
Rn{!}, list
Floating-point register Store Multiple
M4F
VSTR.F<32|64>
Sd, [Rn]
Stores an extension register to memory
M4F
VSUB.F<32|64>
{Sd,} Sn, Sm
Floating-point Subtract
M0
M3
M4
32
WFE
Wait For Event
M0
M3
M4
32
WFI
Wait For Interrupt
此内容由EEWORLD论坛网友yubinwu原创,如需转载或用于商业用途需征得作者同意并注明出处
此帖出自单片机论坛
使用道具 举报
TA的帖子
Rank: 3Rank: 3
 楼主| 发表于 2018-8-8 16:30:22 | 显示全部楼层
好像宽度变了 arm m0 m3 m4.rar (22.89 KB, 下载次数: 6)
使用道具 举报
1865
TA的帖子
Rank: 6Rank: 6
发表于 2018-8-8 16:32:57 | 显示全部楼层
总结的很详细
使用道具 举报
994
TA的帖子
Rank: 6Rank: 6
发表于 2018-8-9 07:33:20 | 显示全部楼层
谢谢分享!总结的很详细,很好,先收藏,慢慢研究^_^
专注智能产品的研究与开发,专注于电子电路的生产与制造……QQ:2912615383,电子爱好者群: void
使用道具 举报
本版积分规则
  • 论坛活动 E手掌握
    扫码关注
    EEWORLD 官方微信
  • EE福利  唾手可得
    扫码关注
    EE福利 唾手可得
GMT+8, 2019-1-24 21:27 , Processed in 0.198395 second(s), 16 queries , Gzip On, MemCache On.
