社区导航
搜索
查看: 1414|回复: 1
[求助] F5529的DMA采集ADC问题
TA的帖子
Rank: 1
发表于 2018-7-16 19:08 | 显示全部楼层 |阅读模式
刚用了一下TI的DMA采集ADC的例程,发现,不能使用,无法进入DMA中断,因此采不到数据,有解决办法吗?代码如下:
  • /* --COPYRIGHT--,BSD
  • * Copyright (c) 2017, Texas Instruments Incorporated
  • * All rights reserved.
  • * Redistribution and use in source and binary forms, with or without
  • * modification, are permitted provided that the following conditions
  • * are met:
  • * *  Redistributions of source code must retain the above copyright
  • *    notice, this list of conditions and the following disclaimer.
  • * *  Redistributions in binary form must reproduce the above copyright
  • *    notice, this list of conditions and the following disclaimer in the
  • *    documentation and/or other materials provided with the distribution.
  • * *  Neither the name of Texas Instruments Incorporated nor the names of
  • *    its contributors may be used to endorse or promote products derived
  • *    from this software without specific prior written permission.
  • * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
  • * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
  • * THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
  • * PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
  • * CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
  • * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
  • * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
  • * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
  • * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
  • * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
  • * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
  • * --/COPYRIGHT--*/
  • //! DMA - Single Transfer using ADC12 trigger by TIMER_A, on Channel 0
  • //!  This software uses TBCCR1 as a sample and convert input into the A0 of
  • //!  ADC12. ADC12IFG is used to trigger a DMA transfer and DMA interrupt
  • //!  triggers when DMA transfer is done. TB1 is set as an output and P1.0 is
  • //!  toggled when DMA ISR is serviced.
  • //!  ACLK = REFO = 32kHz, MCLK = SMCLK = default DCO 1048576Hz
  • //!                 MSP430F552x
  • //!         /|\|              XIN|-
  • //!          | |                 | 32kHz
  • //!          --|RST          XOUT|-
  • //!            |             P1.0|-> LED
  • //!            |         P5.7/TB1|-> TIMER_A_B1 output
  • //!            |          P6.0/A0|<- A0
  • //! This example uses the following peripherals and I/O signals.  You must
  • //! review these and change as needed for your own board:
  • //! - DMA peripheral
  • //! - ADC12 peripheral
  • //! - GPIO Port peripheral
  • //! - A0
  • //! This example uses the following interrupt handlers.  To use this example
  • //! in your own application you must add these interrupt handlers to your
  • //! vector table.
  • //! - DMA_VECTOR
  • #include "driverlib.h"
  • //ADC conversion result is stored in this variable
  • uint16_t DMA_DST;
  • void main (void)
  •     //Stop Watchdog Timer
  •     WDT_A_hold(WDT_A_BASE);
  •     //Clear P1.0 LED off
  •     GPIO_setOutputLowOnPin(
  •         GPIO_PORT_P1,
  •         GPIO_PIN0
  •     //Set P1.0 to output direction
  •     GPIO_setAsOutputPin(
  •         GPIO_PORT_P1,
  •         GPIO_PIN0
  •     //P5.7/TB1 option select Output direction
  •     GPIO_setAsPeripheralModuleFunctionOutputPin(
  •         GPIO_PORT_P5,
  •         GPIO_PIN7
  •     //Enable A/D channel A0
  •     GPIO_setAsPeripheralModuleFunctionInputPin(
  •         GPIO_PORT_P6,
  •         GPIO_PIN0
  •     //Set up Timer A
  •     Timer_A_initCompareModeParam initCompParam = {0};
  •     initCompParam.compareRegister = TIMER_A_CAPTURECOMPARE_REGISTER_1;
  •     initCompParam.compareInterruptEnable = TIMER_A_CAPTURECOMPARE_INTERRUPT_DISABLE;
  •     initCompParam.compareOutputMode = TIMER_A_OUTPUTMODE_RESET_SET;
  •     initCompParam.compareValue = 0x8000;
  •     Timer_A_initCompareMode(TIMER_A0_BASE, &initCompParam);
  •     //Start timer A0
  •     Timer_A_initUpDownModeParam initUpDownParam = {0};
  •     initUpDownParam.clockSource = TIMER_A_CLOCKSOURCE_SMCLK;
  •     initUpDownParam.clockSourceDivider = TIMER_A_CLOCKSOURCE_DIVIDER_1;
  •     initUpDownParam.timerPeriod = 0xFFFE;
  •     initUpDownParam.timerInterruptEnable_TAIE = TIMER_A_TAIE_INTERRUPT_DISABLE;
  •     initUpDownParam.captureCompareInterruptEnable_CCR0_CCIE =
  •         TIMER_A_CCIE_CCR0_INTERRUPT_DISABLE;
  •     initUpDownParam.timerClear = TIMER_A_DO_CLEAR;
  •     initUpDownParam.startTimer = true;
  •     Timer_A_initUpDownMode(TIMER_A0_BASE, &initUpDownParam);
  •     //Initialize and setup the ADC12 Module
  •      * Base Address of the ADC12 Module
  •      * Use internal ADC12 bit as sample/hold signal to start conversion
  •      * USE MODOSC 5MHZ Digital Oscillator as clock source
  •      * Use default clock divider of 1
  •     ADC12_A_init(ADC12_A_BASE,
  •         ADC12_A_SAMPLEHOLDSOURCE_3,
  •         ADC12_A_CLOCKSOURCE_ADC12OSC,
  •         ADC12_A_CLOCKDIVIDER_1);
  •     ADC12_A_enable(ADC12_A_BASE);
  •      * For memory buffers 0-7 sample/hold for 256 clock cycles
  •      * For memory buffers 8-15 sample/hold for 4 clock cycles (default)
  •      * Enable Multiple Sampling
  •     ADC12_A_setupSamplingTimer(ADC12_A_BASE,
  •         ADC12_A_CYCLEHOLD_128_CYCLES,
  •         ADC12_A_CYCLEHOLD_4_CYCLES,
  •         ADC12_A_MULTIPLESAMPLESENABLE);
  •     //Configure Memory Buffer
  •      * Configure memory buffer 0
  •      * Map input A0 to memory buffer 0
  •      * Vref+ = AVcc
  •      * Vref- = AVss
  •      * Memory buffer 0 is not the end of a sequence
  •     ADC12_A_configureMemoryParam configureMemoryParam = {0};
  •     configureMemoryParam.memoryBufferControlIndex = ADC12_A_MEMORY_0;
  •     configureMemoryParam.inputSourceSelect = ADC12_A_INPUT_A0;
  •     configureMemoryParam.positiveRefVoltageSourceSelect = ADC12_A_VREFPOS_AVCC;
  •     configureMemoryParam.negativeRefVoltageSourceSelect = ADC12_A_VREFNEG_AVSS;
  •     configureMemoryParam.endOfSequence = ADC12_A_NOTENDOFSEQUENCE;
  •     ADC12_A_configureMemory(ADC12_A_BASE ,&configureMemoryParam);
  •     //Enable/Start sampling and conversion
  •      * Start the conversion into memory buffer 0
  •      * Use the single-channel, single-conversion mode
  •     ADC12_A_startConversion(ADC12_A_BASE,
  •         ADC12_A_MEMORY_0,
  •         ADC12_A_REPEATED_SINGLECHANNEL);
  •     //Disable the DMA from preempting a Read-Modify-Write Operation in the CPU
  •     DMA_disableTransferDuringReadModifyWrite();
  •     //Initialize and Setup DMA Channel 0
  •      * Configure DMA channel 0
  •      * Configure channel for repeated single transfers
  •      * DMA interrupt flag will be set after every 1 transfer
  •      * Use DMA Trigger Source 24 (ADC12xIFG)
  •      * Transfer Word-to-Word
  •      * Trigger upon Rising Edge of Trigger Source Signal
  •     DMA_initParam initParam = {0};
  •     initParam.channelSelect = DMA_CHANNEL_0;
  •     initParam.transferModeSelect = DMA_TRANSFER_REPEATED_SINGLE;
  •     initParam.transferSize = 1;
  •     initParam.triggerSourceSelect = DMA_TRIGGERSOURCE_24;
  •     initParam.transferUnitSelect = DMA_SIZE_SRCWORD_DSTWORD;
  •     initParam.triggerTypeSelect = DMA_TRIGGER_RISINGEDGE;
  •     DMA_init(&initParam);
  •      * Use ADC12 Memory Buffer 0 as source
  •      * Don't move the source address after every transfer
  •     DMA_setSrcAddress(DMA_CHANNEL_0,
  •         ADC12_A_getMemoryAddressForDMA(ADC12_A_BASE,
  •             ADC12_A_MEMORY_0),
  •         DMA_DIRECTION_UNCHANGED);
  •      * Use DMA_DST as destination
  •      * Increment destination address after every transfer
  •     DMA_setDstAddress(DMA_CHANNEL_0,
  •         (uint32_t)(uintptr_t)&DMA_DST,
  •         DMA_DIRECTION_INCREMENT);
  •     //Enable DMA channel 0 interrupt
  •     DMA_clearInterrupt(DMA_CHANNEL_0);
  •     DMA_enableInterrupt(DMA_CHANNEL_0);
  •     //Enable transfers on DMA channel 0
  •     DMA_enableTransfers(DMA_CHANNEL_0);
  •     //LPM0 w/ interrupts
  •     __bis_SR_register(LPM0_bits + GIE);
  •     //For Debugger
  •     __no_operation();
  • //DMA Interrupt Service Routine
  • #if defined(__TI_COMPILER_VERSION__) || defined(__IAR_SYSTEMS_ICC__)
  • #pragma vector=DMA_VECTOR
  • __interrupt
  • #elif defined(__GNUC__)
  • __attribute__((interrupt(DMA_VECTOR)))
  • #endif
  • void DMA_ISR (void)
  •     switch (__even_in_range(DMAIV,16)){
  •         case 0: break;
  •         case 2:         //DMA0IFG = DMA Channel 0
  •             //Toggle P1.0 - PLACE BREAKPOINT HERE AND CHECK DMA_DST VARIABLE
  •             GPIO_toggleOutputOnPin(
  •                 GPIO_PORT_P1,
  •                 GPIO_PIN0
  •             break;
  •         case 4: break;  //DMA1IFG = DMA Channel 1
  •         case 6: break;  //DMA2IFG = DMA Channel 2
  •         case 8: break;  //DMA3IFG = DMA Channel 3
  •         case 10: break; //DMA4IFG = DMA Channel 4
  •         case 12: break; //DMA5IFG = DMA Channel 5
  •         case 14: break; //DMA6IFG = DMA Channel 6
  •         case 16: break; //DMA7IFG = DMA Channel 7
  •         default: break;
使用道具 举报
TA的帖子
Rank: 1
 楼主| 发表于 2018-7-16 19:19 | 显示全部楼层
例程工程
dma_ex4_singleTransferADC12.rar
270.02 KB, 下载次数: 9
DMA采集ADC官方例程
使用道具 举报
  • 论坛活动 E手掌握
    扫码关注
    EEWORLD 官方微信
  • EE福利  唾手可得
    扫码关注
    EE福利 唾手可得
GMT+8, 2020-5-26 16:29 , Processed in 0.120740 second(s), 22 queries , Gzip On, MemCache On.
