1297|0
6907
TI C2000的中断程序解析 [复制链接]
void main()
           CSL_init();//CSL函数初始化
           Htimer = TIMER_open(TIMER_DEV0,TIMER_OPEN_RESET);//打开定时器 0,返回定
时器句柄
           TimerEventId = TIMER_getEventId(Htimer);//取得定时事件 ID
           TIMER_config(Htimer,&Mtimer_configA);//配置定时器
           Hgpio  = GPIO_open(GPIO_DEV0,GPIO_OPEN_RESET);//打开 IO
           GPIO_config(Hgpio,&Mgpio_config);//配置 IO
           IRQ_setVecs(vectors);//重新设置中断向量,
           IRQ_globalEnable();//全局中断使能
           IRQ_nmiEnable();
           IRQ_map(TimerEventId,14);//把定时中断重新映射到 14
           IRQ_reset(TimerEventId);
           IRQ_enable(TimerEventId);//
           TIMER_start(Htimer);//定时开始
    while(1);//死循环
           TIMER_close(Htimer);
           GPIO_close(Hgpio);
*  中断服务程序
interrupt void c_int14(void)//中断服务程序
    if(flag==0)
                GPIO_pinWrite(Hgpio,GPIO_PIN3,flag);
                flag=1;
           else
                GPIO_pinWrite(Hgpio,GPIO_PIN3,1); //点灯
                flag=0;
* Global symbols defined here and exported out of this file
    .global _vectors//全局标号,可以在别处使用.
    .global _c_int00
    .global _vector1
    .global _vector2
    .global _vector3
    .global _vector4
    .global _vector5
    .global _vector6
    .global _vector7
    .global _vector8
   .global _vector9
    .global _vector10
    .global _vector11
    .global _vector12
    .global _vector13
    .global _c_int14  ; Hookup the c_int14 ISR in main()
    .global _vector15
* Global symbols referenced in this file but defined somewhere else.
* Remember that your interrupt service routines need to be referenced here.
    .ref _c_int00//相当于 extern,在这里引用,在别处定义
* This is a macro that instantiates one entry in the interrupt service table.
VEC_ENTRY .macro addr//定义中断向量入口地址
    STW   B0,*--B15;保存B0 内容,中断产生后执行的第一条指令
    MVKL  addr,B0;
      MVKH  addr,B0;//把地址装入 B0
    B     B0;跳转至 B0 中存储的地址
    LDW   *B15++,B0;恢复B0内容; 由于C6000流水线的原因,跳转后仍然可以执行多条指
    NOP   2
    NOP
    NOP
    .endm
* This is a dummy interrupt service routine used to initialize the IST.
_vec_dummy:未定义中断服务程序
  B     B3;其他没有定义的中断跳转至 B3 存储的地址
  NOP  5
* This is the actual interrupt service table (IST). It is properly aligned and
* is located in the subsection .text:vecs. This means if you don't explicitly
* specify this section in your linker command file, it will default and link
* into the .text section. Remember to set the ISTP register to point to this
* table.
.sect ".text:vecs";定义段
.align 1024;1024 字节对边界对齐
_vectors:
_vector0:    VEC_ENTRY _c_int00      ;RESET  跳转到_c_int00 ,_c_int00是 c语言程序的入口
_vector1:    VEC_ENTRY _vec_dummy  ;NMI
_vector2:    VEC_ENTRY _vec_dummy  ;RSVD
_vector3:    VEC_ENTRY _vec_dummy ;  所有未定义中断均跳转到同一地址
_vector4:    VEC_ENTRY _vec_dummy
_vector5:    VEC_ENTRY _vec_dummy
_vector6:    VEC_ENTRY _vec_dummy
_vector7:    VEC_ENTRY _vec_dummy
_vector8:    VEC_ENTRY _vec_dummy
_vector9:    VEC_ENTRY _vec_dummy
_vector10:  VEC_ENTRY _vec_dummy
_vector11:  VEC_ENTRY _vec_dummy
_vector12:  VEC_ENTRY _vec_dummy
_vector13:  VEC_ENTRY _vec_dummy
_vector14:  VEC_ENTRY _c_int14  ; Hookup the c_int14 ISR in main()  定时中断中断向量
_vector15:  VEC_ENTRY _vec_dummy
