4957|0
3646
msp430串口接收调试 [复制链接]
一、串口调试出错
        串口接收配置需要注意的是开启总中断( __enable_interrupt(); ),不能仅开启串口接收中断。
[cpp] view plain copy
#include
//RS485芯片方向控制
void set_rs485_dir(char tx_rx)
{ //1---发送,0接收
  if (tx_rx==1)
    P9OUT|=(BIT6+BIT7);
  else
    P9OUT&=~(BIT6+BIT7);
  P9DIR|=(BIT6+BIT7);
void delay(char num)
  while(num--);
int main(void)
  WDTCTL = WDTPW + WDTHOLD;                 // Stop WDT
  //串口2 初始化
  P9SEL|= BIT4+BIT5;      //对于P5 6,7为模块功能
  P9DIR|=BIT4;
  P9DIR&=~BIT5;
  UCA2CTL1 |= UCSWRST;                      // **Put state machine in reset**
  UCA2CTL1 |= UCSSEL_2;                     // SMCLK
  UCA2BR0 = 109;
  UCA2BR1 = 0;
  UCA2MCTL |= UCBRS_1 + UCBRF_0;            // Modulation UCBRSx=1, UCBRFx=0
  UCA2CTL1 &= ~UCSWRST;                     // **Initialize USCI state machine**
  UCA2IE |= UCRXIE;                         // Enable USCI_A0 RX interrupt
  __enable_interrupt();//容易忽略
     set_rs485_dir(1);//发送
     delay(3000);
     while (!(UCA2IFG&UCTXIFG));             // USCI_A2 TX buffer ready?
     UCA2TXBUF = 0x55;                  // TX -> RXed character
     delay(3000);
     set_rs485_dir(0);//接收
     delay(3000);
     while(1)
       delay(2000);
#pragma vector=USCI_A2_VECTOR
__interrupt void USCI_A2_ISR(void)
  switch(__even_in_range(UCA2IV,4))
       case 0:break;                             // Vector 0 - no interrupt
       case 2:                                   // Vector 2 - RXIFG
       delay(30);
       while (!(UCA2IFG&UCTXIFG));               // USCI_A0 TX buffer ready?
       UCA2TXBUF = UCA2RXBUF;                    // TX -> RXed character
       delay(30);
       break;
       case 4:break;                             // Vector 4 - TXIFG
       default: break;
