社区导航
搜索
查看: 1216|回复: 10
[求助] 请大佬解惑,为什么我这个LCD1602不显示MAX6675K型热电偶测得的温度
TA的帖子
Rank: 1
发表于 2018-5-1 16:06 | 显示全部楼层 |阅读模式
3芯币
我的LCD1602上面始终显示的是0.0°,我用的是普中科技HC6800-MS开发版,请大神指点
我的MAX6675模块正常(没有损坏)接线正确
/**************************定义头文件*****************************************/
#include
#include
#include
//lcd part
#define uchar unsigned char
#define uint unsigned int
#define  LINE1     0
#define  LINE2     1
#define  LINE1_HEAD    0x80
#define  LINE2_HEAD    0xC0
#define  LCD_DELAY_TIME   40
#define  DATA_MODE    0x38
#define  OPEN_SCREEN    0x0C
#define  DISPLAY_ADDRESS   0x80
#define  CLEARSCREEN    LCD_en_command(0x01)
#define  HIGH   1
#define  LOW    0
#define  TRUE    1
#define  FALSE    0
#define  ZERO    0
#define  MSB    0x80
#define  LSB    0x01
#define  LCDIO     P0
sbit LCD1602_RS=P2^6;   //设置RS
sbit LCD1602_RW=P2^5;   //设置RW
sbit LCD1602_EN=P2^7;   //设置E
sbit MAX6675_SO=P1^2;
sbit MAX6675_SCK=P1^0;  //设置6675端口
sbit MAX6675_CS=P1^1;
sbit beep      =P2^1;
uint  H,L,temp_data;
sbit  key3=P3^5;        //设置按键 key3设置按键  key1数据加  key2数据减
sbit  key1=P3^6;
sbit  key2=P3^7;
sbit  led_0=P1^5;       //报警指示灯 led_0 上限指示灯
sbit  led_2=P1^6;                //下限指示灯
uchar flag,s0=0,ms;             //定义变量
bit s1,bit_0=1;                        //定义标志位
uint H_h,H_l,L_h,L_l;
unsigned int TempValue;
unsigned int xiaoshu;         //存储读出来的数据
uchar LCD[10]="0123456789";
unsigned char data disdata[5];
unsigned int Value ,TempValue;
/******************** LCD 函数部份 ***********************************/
void LCD_delay(void)
unsigned char i;
for(i=LCD_DELAY_TIME;i>ZERO;i--)
void LCD_en_command(unsigned char command)
LCD_delay();
LCD1602_RS=LOW;
LCD1602_RW=LOW;
LCD1602_EN=HIGH;
LCDIO=command;
LCD1602_EN=LOW;
void LCD_en_dat(unsigned char dat)
LCD_delay();
LCD1602_RS=HIGH;
LCD1602_RW=LOW;
LCD1602_EN=HIGH;
LCDIO=dat;
LCD1602_EN=LOW;
void LCD_set_xy( unsigned char x, unsigned char y )
unsigned char address;
if (y == LINE1)
  address = LINE1_HEAD + x;
else
     address = LINE2_HEAD + x;
LCD_en_command(address);
void LCD_write_char( unsigned x,unsigned char y,unsigned char dat)
LCD_set_xy( x, y );
LCD_en_dat(dat);
void LCD_write_string(unsigned char X,unsigned char Y,unsigned char *s)
    LCD_set_xy( X, Y );//设置显示XY地址
    while (*s)  // 写字符
     LCDIO=*s;
        LCD_en_dat(*s);
s ++;
void LCD_init(void)
{  //CLEARSCREEN;//clear screen
LCD_en_command(DATA_MODE);//8位模式
LCD_en_command(OPEN_SCREEN);//开显示
LCD_en_command(DISPLAY_ADDRESS);//设定显示起始位
CLEARSCREEN;//清屏
/***********************  延时 *********************************/
void delay_nms(unsigned int n)
    unsigned int i=0,j=0;
    for (i=n;i>0;i--)
     for (j=0;j<1140;j++);
/***********************从MAX6675读取温度*********************************************/
unsigned int ReadMAX6675()
unsigned char count;
MAX6675_CS=1; //关闭MAX6675
MAX6675_CS=0;//置低,使能MAX6675
MAX6675_SCK=1;
Value=0;
for(count=16;count>0;count--) //获取16位MSB
  MAX6675_SCK=0;  //sck置低
  Value=Value<<1;     //左移
    if(MAX6675_SO==1) //取当前值
   Value|=0x0001;
  else
   Value&=0xffff;
  MAX6675_SCK=1;
return Value;
/**************************温度值显示 **************************************************/
void tempdisp()
        disdata[0]=(TempValue/1000)%10+0x30;//千位 +0x30是对应LCD里的ROM字符位置编码
    disdata[1]=(TempValue/100)%10+0x30;//百位  +0x30是对应LCD里的ROM字符位置编码
    disdata[2]=(TempValue/10)%10+0x30;//十位 +0x30是对应LCD里的ROM字符位置编码
    disdata[3]=(TempValue)%10+0x30;//个位  +0x30是对应LCD里的ROM字符位置编码
    disdata[4]=xiaoshu%10+0x30;//分位         +0x30是对应LCD里的ROM字符位置编码
    temp_data=TempValue;
        if(disdata[0]==0x30)
          LCD_write_char(4,LINE1,0x20);        //显示千位
          if(disdata[1]==0x30)
            { LCD_write_char(5,LINE1,0x20);
                  if(disdata[2]==0x30)
               LCD_write_char(6,LINE1,0x20);
                   else  LCD_write_char(6,LINE1,disdata[2]);         //显示十位
           else
          {    LCD_write_char(5,LINE1,disdata[1]); //显示百位
         else
         LCD_write_char(4,LINE1,disdata[0]);           //显示千位
        // LCD_write_char(6,LINE2,disdata[2]);           //显示十位
         LCD_write_char(7,LINE1,disdata[3]);           //显示个位
         LCD_write_char(9,LINE1,disdata[4]);           //显示分位
         LCD_write_string(0,LINE2,"RH:");               //液晶第二行显示上下限
if(flag!=1||s1==0)                                    //闪烁判断语句
         if(H>999)
              LCD_write_char(3,LINE2,LCD[H/1000]);   //如果最高位为零,不显示
         else
                  LCD_write_char(3,LINE2,' ');     //如果最高位不为零,显示
         if(H>99)                                              //如果百位都为零,那么不显示
         LCD_write_char(4,LINE2,LCD[H%1000/100]);//百位有一个不为零,百位显示
         else
             LCD_write_char(4,LINE2,' ');
         if(H>9)                             //同上,十位不显示
          LCD_write_char(5,LINE2,LCD[H%100/10]);  //十位显示
         else
                    LCD_write_char(5,LINE2,' ');
          LCD_write_char(6,LINE2,LCD[H%10]);        //无论如何,个位显示
else LCD_write_string(3,LINE2,"    ");                     //和if(flag!=1||s1==0) 组合成设置时,选项闪烁
          LCD_write_string(8,LINE2,"RL:");                 //解释同上
if(flag!=2||s1==0)
         if(L>999)
            LCD_write_char(11,LINE2,LCD[L/1000]);
         else
            LCD_write_char(11,LINE2,' ');
         if(L>99)
            LCD_write_char(12,LINE2,LCD[L%100/10]);
         else
            LCD_write_char(12,LINE2,' ');
         if(L>9)
             LCD_write_char(13,LINE2,LCD[L%100/10]);
         else
                    LCD_write_char(13,LINE2,' ');
          LCD_write_char(14,LINE2,LCD[L%10]);
else LCD_write_string(11,LINE2,"    ");
void key()                             //按键处理
if(!key1)                               //设置上限
  delay_nms(1);
        if(!key1)
       while(!key1);
           if(flag==1)
           if(H<1024)H++;
                   H_h=H/256;
                   H_l=H%256;
                   SectorErase(0x2000);          //每修改一次上下限数据就写进EEROM
                   byte_write(0x2000,H_h);
                   byte_write(0x2001,H_l);
           else if(flag==2)
            if(L                     L_h=L/256;
                    L_l=L%256;
                    SectorErase(0x2200);
                    byte_write(0x2200,L_h);
                    byte_write(0x2201,L_l);
if(!key2)                            //设置下限
    delay_nms(1);
   if(!key2)
      while(!key2);
          if(flag==1)
              if(H>L+1)H--;             //原则上限不低于下限
                   H_h=H/256;
                   H_l=H%256;
      else if(flag==2)
                  if(L>0)L--;
                    L_h=L/256;
                    L_l=L%256;
if(!key3)                         //设置上限下限切换按键
         delay_nms(1);
         if(!key3)
                while(!key3);
        flag=(flag+1)%3;
void alarm()                          //报警
if(temp_data>=H||temp_data<=L)               //超过上下限蜂鸣器报警 ,正常的LED灯关闭
     bit_0=0;
else
          bit_0=1;
     }                             //正常情况下,蜂鸣器关闭,LED——2常亮
if(temp_data>=H)                         //上限,当测得的值,大于等于设定值得时候,灯常亮
          led_0=0;
else
      led_0=1;
if(temp_data<=L)                        //下限 当实际值小于等于下限值时,led_3常亮
          led_2=0;
else
      led_2=1;
/****************************主 程 序********************************************************/
void main(void)
LCD_init();   //LCD初始化
CLEARSCREEN;        //清屏
delay_nms(10);
  H_h=byte_read(0x2000);
  H_l=byte_read(0x2001);
  L_h=byte_read(0x2200);
  L_l=byte_read(0x2201);
  H=H_h*256+H_l;
  L=L_h*256+L_l;
  if((H>1024)||(L>1024)||(L>=H))     //读EEROM里面的数据
         H=40;
         L=20;                      //如果数据不对,赋予初始值
         H_h=H/256;
         H_l=H%256;
        L_h=L/256;
        L_l=L%256;
        TMOD=0x01;
        TH0=0x3c;
        TL0=0xb0;
        EA=1;
        ET0=1;
        TR0=1;
TempValue=ReadMAX6675();//读取MAX6675 转换后的温度数值;
TempValue=TempValue<<1;         //去掉第15位
TempValue=TempValue>>4;//去掉第0~2位
xiaoshu=TempValue*10;
TempValue=TempValue/4;             //MAX6675最大数值为1023。75,而AD精度为12位,即2的12次方为4096,转换对应数,故要除4;
xiaoshu=xiaoshu/4;                        //与上述同理
if(TempValue>=1024)
{TempValue=1024;}
LCD_write_char( 8,LINE1,0X2e);//显示"点"
LCD_write_char( 10,LINE1,0XDF);//显示"度"
LCD_write_char( 11,LINE1,0X43);//显示"C"
while(TRUE )
     tempdisp();
         key();
         alarm();
void INT_1() interrupt 1
        TH0=0x3c;
        TL0=0xb0;
        s0++; ms++;
        if(bit_0==0)
           beep=~beep;
    else beep=1;
        if(ms%10==0)
        {  ms=0;
           s1=~s1;
        if(s0==100)
        {  s0=0;
          TempValue=ReadMAX6675();        //读取MAX6675 转换后的温度数值;
        TempValue=TempValue>>4;         //去掉第0~2位
        xiaoshu=(TempValue)*10;
        TempValue=(TempValue)/4;                //MAX6675最大数值为1023。75,而AD精度为12位,即2的12次方为4096,转换对应数,故要除4;
        if(TempValue>=1024)
        {TempValue=1024;}
这是1602的显示
这是1602的显示
STC89C51数据手册.pdf
2.75 MB, 下载次数: 1
1602中文资料.pdf
663.24 KB, 下载次数: 1
使用道具 举报
230
TA的帖子
Rank: 3Rank: 3
发表于 2018-5-1 17:18 来自手机 | 显示全部楼层
先调LCD显示,给不同的数看能否正确显示,再调温度测量,可以把测量值直接送LCD显示出来。
使用道具 举报
292
TA的帖子
Rank: 2
发表于 2018-5-1 19:36 | 显示全部楼层
(TempValue/1000)%10
这个余数计算貌似有问题呀
使用道具 举报
411
TA的帖子
Rank: 3Rank: 3
发表于 2018-5-1 20:04 | 显示全部楼层
先把没用的去掉,只留下1602的显示,TempValue随便带入一个数看显示如何。在进一步分析
使用道具 举报
571
TA的帖子
235
Rank: 6Rank: 6
发表于 2018-5-1 21:22 | 显示全部楼层
先调试1602,保证显示没问题,再调试温度传感器。
爱电子,爱生活
使用道具 举报
3478
TA的帖子
Rank: 6Rank: 6
发表于 2018-5-1 22:20 | 显示全部楼层
看程序是个比较麻烦的事情,因为有很大一部分不能排除你的硬件问题,楼主这个完全可以细化一下是转换问题还是显示问题。
使用道具 举报
319
TA的帖子
Rank: 2
发表于 2018-5-2 08:40 | 显示全部楼层
在LCD显示测量温度前先把其屏蔽,并人为设置TempValue、xiaoshu值令其显示,若正确说明程序无问题,应把注意力放在采集的结果是否有效上。
使用道具 举报
430
TA的帖子
Rank: 2
发表于 2018-5-2 10:45 | 显示全部楼层
路过看看
充放电数显全套方案,双口快充慢充检测电流电压,两线三线直流电压表,配套三个8尺寸15*8MM带AV电流电压单位专利数码屏,资料QQ2981074992 邮箱同上
使用道具 举报
4193
TA的帖子
Rank: 9Rank: 9Rank: 9
测评达人
发表于 2018-5-2 16:44 | 显示全部楼层
思路就是先调试LCD显示,先让LCD显示没有问题。
然后,再调温度的程序;
最后,再调温度显示的程序。
使用道具 举报
TA的帖子
Rank: 1
 楼主| 发表于 2018-5-2 16:54 | 显示全部楼层
然后,再调温度的程序;
最后,再调温度显示的程序。
好的,谢谢
使用道具 举报
121
TA的帖子
禁止发言
发表于 2019-11-4 10:58 | 显示全部楼层
这个是MAX6675 设计参考
带有冷端补偿的K型热电偶至数字转换(0°C至+1024°C)
MAX6675冷端温度补偿、热电偶数字转换器可进行冷端温度补偿,并将K型热电偶信号转换成数字信号。数据输出为12位分辨率、SPI™兼容、只读格式。
转换器温度分辨率为0.25°C,可读取温度达+1024°C,热电偶在0°C至+700°C温度范围内精度为8 LSB。
MAX6675采用小尺寸、8引脚SO封装。
MAX6675:典型应用电路MAX6675:典型应用电路放大+
关键特性
  • 冷端温度补偿
  • 简单的SPI兼容串行接口
  • 12位、0.25°C分辨率
  • 热电偶开路检测
应用
  • 电器设备
  • HVAC
  • 工业
使用道具 举报
站长推荐上一条 /7 下一条
  • 论坛活动 E手掌握
    扫码关注
    EEWORLD 官方微信
  • EE福利  唾手可得
    扫码关注
    EE福利 唾手可得
GMT+8, 2019-11-20 05:18 , Processed in 0.323529 second(s), 15 queries , Gzip On, MemCache On.
