社区导航
搜索
查看: 599|回复: 1
[原创] mtk7688 之openwr下的gpio应用编程
3560
TA的帖子
Rank: 8Rank: 8
荣誉会员勋章
发表于 2018-4-16 13:39 | 显示全部楼层 |阅读模式
             在上一篇我是在终端中通过读写文件实现了对GPIO的操作(http://bbs.eeworld.com.cn/thread-641726-1-1.html), 这篇主要是对上一篇的应用程序编写,通过读写文件来实现相关功能,相关代码如下:
#ifndef __GPIO_H__
#define __GPIO_H__
#ifdef __cplusplus
extern "C" {
#endif
/* GPIO value */
#define GPIO_HIGH     1
#define GPIO_LOW      0
/* GPIO direction code */
#define GPIO_INPUT       0
#define GPIO_OUTPUT      1
#define GPIO_OUTPUT_HIGH 2
#define GPIO_OUTPUT_LOW  3
/* GPIO error code */
#define GPIO_SUCCESS            1
#define GPIO_INVALID_RESOURCE  -1
#define GPIO_ERROR_READ        -2
#define GPIO_ERROR_WRITE       -3
#define GPIO_ERROR_DIRECTION   -4
* Read specified GPIO pin
* @param pin_number specified the pin
* @return integer value of GPIO if success.
*  return negative integer error code if fail.
int  gpio_read(int pin_number);
* Write specified GPIO pin
* @param value could be GPIO_HIGH or GPIO_LOW
* @return 1 if success.
int  gpio_write(int pin_number, int value);
* set direction of specified GPIO pin
* @param direction could be GPIO_IN or GPIO_OUT, GPIO_OUT_HIGH, GPIO_OUT_LOW
int  gpio_set_direction(int pin_number, int direction);
* get direction of specified GPIO pin
* @return positive integer direction code if success.
int  gpio_get_direction(int pin_number);
* export specified GPIO pin
int gpio_export(int pin_number);
* unexport specified GPIO pin
int gpio_unexport(int pin_number);
* Return 1 if specified GPIO pin is exported
* @return 1 if GPIO pin is exported.
*  return 0 if GPIO pin is not exported
int gpio_is_exported(int pin_number);
#ifdef __cplusplus
#endif
#include <stdio.h>
#include <stdlib.h>
#include <errno.h>
#include <string.h>
#include <unistd.h>
#include <fcntl.h>
#include <sys/stat.h>
#include "gpio.h"
#define FILENAME_SIZE  128
#define GPIO_PATH "/sys/class/gpio"
* Export specified GPIO pin
int gpio_export(int pin_number) {
        char buf[FILENAME_SIZE];
        int  fp;
        int  length;
        if ( gpio_is_exported(pin_number) )
                return GPIO_SUCCESS;
        //write to export file
        fp = open(GPIO_PATH "/export", O_WRONLY);
        if ( fp == -1) {
                return GPIO_INVALID_RESOURCE;
        length = snprintf(buf, sizeof(buf), "%d", pin_number);
        if (write(fp, buf, length * sizeof(char)) == -1) {
                close(fp);
        close(fp);
        return gpio_is_exported(pin_number);
int gpio_is_exported(int pin_number) {
        struct stat dir;
        //check if the gpioXX directory exists
        snprintf(buf, sizeof(buf), GPIO_PATH "/gpio%d/", pin_number);
        if (stat(buf, &dir) == 0 && S_ISDIR(dir.st_mode)) {
        } else {
                return 0;
int gpio_unexport(int pin_number) {
        int  fp;
        int  length;
        //write to unexport file
        fp = open(GPIO_PATH "/unexport", O_WRONLY);
        if ( fp == -1) {
                close(fp);
        close(fp);
int  gpio_read(int pin_number) {
        int  fp;
        if ( !gpio_is_exported(pin_number) ) {
                if ( 1 != gpio_export(pin_number) )
        //read value file
        snprintf(buf, sizeof(buf),  "%s/gpio%d/value", GPIO_PATH, pin_number);
        fp = open(buf, O_RDWR);
        if ( fp == -1) {
        if ( lseek(fp, 0, SEEK_SET) < 0 ) {
                close(fp);
        if (read(fp, buf, 2 * sizeof(char)) != 2) {
                close(fp);
                return GPIO_ERROR_READ;
        close(fp);
        return (int) strtol(buf, NULL, 10);
int  gpio_write(int pin_number, int value) {
        int  fp;
        int  length;
        //write to value file
        if ( fp == -1) {
                close(fp);
        length = snprintf(buf, sizeof(buf), "%d", value);
        if ( write(fp, buf, length * sizeof(char)) == -1) {
                close(fp);
                return GPIO_ERROR_WRITE;
        close(fp);
* @param direction could be GPIO_INPUT or GPIO_OUTPUT, GPIO_OUTPUT_HIGH, GPIO_OUTPUT_LOW
int  gpio_set_direction(int pin_number, int direction) {
        int  fp;
        int  length;
        //write direction file
        snprintf(buf, sizeof(buf),  "%s/gpio%d/direction", GPIO_PATH, pin_number);
        if ( fp == -1) {
                close(fp);
        switch (direction) {
                case GPIO_OUTPUT:
                        length = snprintf(buf, sizeof(buf), "out");
                        break;
                case GPIO_INPUT:
                        length = snprintf(buf, sizeof(buf), "in");
                        break;
                case GPIO_OUTPUT_HIGH:
                        length = snprintf(buf, sizeof(buf), "high");
                        break;
                case GPIO_OUTPUT_LOW:
                        length = snprintf(buf, sizeof(buf), "low");
                        break;
                default:
                        close(fp);
                        return GPIO_ERROR_DIRECTION;
                close(fp);
        close(fp);
int  gpio_get_direction(int pin_number) {
        int  fp;
        int  length;
        int  result;
        //read direction file
        fp = open(buf, O_RDONLY);
        if ( fp == -1) {
                close(fp);
        memset(buf, '\0', sizeof(buf));
        length = read(fp, buf, sizeof(buf));
        close(fp);
        if (length <= 0) {
        if (strncmp(buf, "out", 3) == 0) {
                result = GPIO_OUTPUT;
        } else if (strncmp(buf, "in", 2) == 0) {
                result = GPIO_INPUT;
        } else if (strncmp(buf, "high", 4) == 0) {
                result = GPIO_OUTPUT_HIGH;
        } else if (strncmp(buf, "low", 3) == 0) {
                result = GPIO_OUTPUT_LOW;
        } else {
                result = GPIO_ERROR_DIRECTION;
        return result;
#include "gpio.h"
#include <unistd.h>
#include <stdio.h>
void blink(int pin) {
        printf("blink GPIO %d for 100 times\n", pin);
        fflush(stdout);
        if ( 1 == gpio_export(pin) ) {
                if ( 1 == gpio_set_direction(pin, GPIO_OUTPUT) ) {
                        //blink
                        int value = GPIO_HIGH;
                        int i;
                        for ( i = 0; i < 100; i++ ) {
                                printf("blink %d\n", i);
                                value = (value == GPIO_HIGH) ? GPIO_LOW : GPIO_HIGH;
                                gpio_write( pin, value );
                                sleep(1);
int main() {
        blink(11);  //blink on gpio11
这个GPIO封装的还是不错,对于已经集成了相关GPIO驱动的功能的openwrt来说,还是很方便的,这个主要涉及linux的应用开发,没有涉及到具体的GPIO的驱动+GPIO的应用开发,灵活性感觉还是很一般,接下来我就完整的围绕openwrt系统来实现一个GPIO的闪烁的功能,
主要涉及到GPIO的驱动的编写以及内核加载,GPIO应用开发的编写以及opkg的安装。
此内容由EEWORLD论坛网友wateras1原创,如需转载或用于商业用途需征得作者同意并注明出处
此帖出自RF/无线论坛
example.c
554 Bytes, 下载次数: 3
gpio.c
6.9 KB, 下载次数: 2
gpio.h
3.23 KB, 下载次数: 2
淘宝:https://viiot.taobao.com/Q群243090717
多年专业物联网行业经验,个人承接各类物联网外包项目
使用道具 举报
1908
TA的帖子
Rank: 6Rank: 6
发表于 2018-4-16 14:37 | 显示全部楼层
学习
使用道具 举报
本版积分规则
  • 论坛活动 E手掌握
    扫码关注
    EEWORLD 官方微信
  • EE福利  唾手可得
    扫码关注
    EE福利 唾手可得
GMT+8, 2019-3-26 06:36 , Processed in 0.102935 second(s), 17 queries , Gzip On, MemCache On.
