社区导航
查看: 3107|回复: 0
[资料分享] TI C6000中各种数据类型的定义
1569
TA的帖子
Rank: 2
发表于 2018-3-11 18:19:13 | 显示全部楼层 |阅读模式
TI C6000  DSP/BIOS中的匈牙利记法为:
  Sm开头的表示8-bit类型;
    Md开头的表示16-bit类型;
    Lg开头的表示32-bit类型;
    Int表示有符号整型;
  Uns表示无符号类型;
    Bits表示按bit计算类型;
[cpp] view plain copy
*   Copyright (c) Texas Instruments Inc 2002, 2003, 2004, 2005
*   Use of this software is controlled by the terms and conditions found in the
*   license agreement under which this software has been supplied.
*  ======== tistdtypes.h ========
* These types are also defined by other TI components.  They are bracketed
* with _TI_STD_TYPES to avoid warnings for duplicate definition.
* You may get warnings about duplicate type definitions when using this
* header file with earlier versions of DSP/BIOS and CSL.
* You can use the '-pds303' compiler option to suppress these warnings.
#ifndef _TI_STD_TYPES
#define _TI_STD_TYPES
* This '#ifndef STD_' is needed to protect from duplicate definitions
* of Int, Uns, etc. in DSP/BIOS v4.x (e.g. 4.90, 4.80) since these versions
* of DSP/BIOS did not contain the '#ifndef_TI_STD_TYPES' logic.
#ifndef STD_
* Aliases for standard C types
typedef int                 Int;
typedef unsigned            Uns;
typedef char                Char;
/* pointer to null-terminated character sequence */
typedef char                *String;
typedef void                *Ptr;       /* pointer to arbitrary type */
typedef unsigned short      Bool;       /* boolean */
#endif /* STD_ */
* Uint8, Uint16, Uint32, etc are defined to be "smallest unit of
* available storage that is large enough to hold unsigned or integer
* of specified size".
/* Handle the 6x ISA */
#if defined(_TMS320C6X)
/* Unsigned integer definitions (32bit, 16bit, 8bit) follow... */
typedef unsigned int    Uint32_t;
typedef unsigned short  Uint16_t;
typedef unsigned char   Uint8_t;
/* Signed integer definitions (32bit, 16bit, 8bit) follow... */
typedef int             Int32_t;
typedef short           Int16_t;
typedef char            Int8_t;
/* Handle the 54x, 55x and 28x ISAs */
#elif defined(_TMS320C5XX) || defined(__TMS320C55X__) || defined(_TMS320C28X)
typedef unsigned long   Uint32;
typedef unsigned short  Uint16;
typedef unsigned char   Uint8;
typedef long            Int32;
typedef short           Int16;
typedef char            Int8;
#else
/* Other ISAs not supported */
#error <tistdtypes.h> is not supported for this target
#endif  /* defined(_6x_) */
#endif  /* _TI_STD_TYPES */
使用道具 举报
本版积分规则
站长推荐上一条 /1 下一条
  • 论坛活动 E手掌握
    扫码关注
    EEWORLD 官方微信
  • EE福利  唾手可得
    扫码关注
    EE福利 唾手可得
GMT+8, 2018-12-15 11:11 , Processed in 0.076756 second(s), 18 queries , Gzip On, MemCache On.
