4898|1
3836
msp430 LCD显示程序分享 [复制链接]
1、简单应用
#include "msp430f5529.h"
#include "Dogs102x6.h"
#define CPU_F ((double)25000000)
#define DelayUs(x) __delay_cycles((long)(CPU_F*(double)x/25000000.0))
#define DelayMs(x) __delay_cycles((long)(CPU_F*(double)x/25000.0))
void main( void )
WDTCTL = WDTPW + WDTHOLD;
LCD_Init(); //初始化LCD
Dogs102x6_circleDraw(30,23,8,0);
Dogs102x6_circleDraw(72,23,8,0);
Dogs102x6_circleDraw(51,42,2,0);
Dogs102x6_stringDrawXY(43,50,"WWW",0);
while (1);
2、MspF5529 102*64 LCd 驱动
// 宏命令
#ifndef abs
# define abs(n) (((n) < 0) ? -(n) : (n))
#endif
// For all commands, CD signal must = 0
#define SET_COLUMN_ADDRESS_MSB 0x10 //Set SRAM col. addr. before write, last 4 bits =
// ca4-ca7
#define SET_COLUMN_ADDRESS_LSB 0x00 //Set SRAM col. addr. before write, last 4 bits =
// ca0-ca3
#define SET_POWER_CONTROL 0x2F //Set Power control - booster, regulator, and follower
// on
#define SET_SCROLL_LINE 0x40 //Scroll image up by SL rows (SL = last 5 bits),
// range:0-63
#define SET_PAGE_ADDRESS 0xB0 //Set SRAM page addr (pa = last 4 bits), range:0-8
#define SET_VLCD_RESISTOR_RATIO 0x27 //Set internal resistor ratio Rb/Ra to adjust contrast
#define SET_ELECTRONIC_VOLUME_MSB 0x81 //Set Electronic Volume "PM" to adjust contrast
#define SET_ELECTRONIC_VOLUME_LSB 0x0F //Set Electronic Volume "PM" to adjust contrast (PM =
// last 5 bits)
#define SET_ALL_PIXEL_ON 0xA4 //Disable all pixel on (last bit 1 to turn on all pixels
// - does not affect memory)
#define SET_INVERSE_DISPLAY 0xA6 //Inverse display off (last bit 1 to invert display -
// does not affect memory)
#define SET_DISPLAY_ENABLE 0xAF //Enable display (exit sleep mode & restore power)
#define SET_SEG_DIRECTION 0xA1 //Mirror SEG (column) mapping (set bit0 to mirror
// display)
#define SET_COM_DIRECTION 0xC8 //Mirror COM (row) mapping (set bit3 to mirror display)
#define SYSTEM_RESET 0xE2 //Reset the system. Control regs reset, memory not
// affected
#define NOP 0xE3 //No operation
#define SET_LCD_BIAS_RATIO 0xA2 //Set voltage bias ratio (BR = bit0)
#define SET_CURSOR_UPDATE_MODE 0xE0 //Column address will increment with write operation
// (but no wrap around)
#define RESET_CURSOR_UPDATE_MODE 0xEE //Return cursor to column address from before cursor
// update mode was set
#define SET_ADV_PROGRAM_CONTROL0_MSB 0xFA //Set temp. compensation curve to -0.11%/C
#define SET_ADV_PROGRAM_CONTROL0_LSB 0x90
// Pins from MSP430 connected to LCD
#define CD BIT6
#define CS BIT4
#define RST BIT7
#define BACKLT BIT6
#define SPI_SIMO BIT1
#define SPI_CLK BIT3
// Ports
#define CD_RST_DIR P5DIR
#define CD_RST_OUT P5OUT
#define CS_BACKLT_DIR P7DIR
#define CS_BACKLT_OUT P7OUT
#define CS_BACKLT_SEL P7SEL
#define SPI_SEL P4SEL
#define SPI_DIR P4DIR
// 字体查找表
static const uint8_t FONT6x8[] =
/* 6x8 font, each line is a character each byte is a one pixel wide column
* of that character. MSB is the top pixel of the column, LSB is the bottom
* pixel of the column. 0 = pixel off. 1 = pixel on. */
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, // space
0x00, 0x00, 0xFA, 0x00, 0x00, 0x00, // !
0x00, 0xE0, 0x00, 0xE0, 0x00, 0x00, // "
0x28, 0xFE, 0x28, 0xFE, 0x28, 0x00, // #
0x24, 0x54, 0xFE, 0x54, 0x48, 0x00, // $
0xC4, 0xC8, 0x10, 0x26, 0x46, 0x00, // %
0x6C, 0x92, 0x6A, 0x04, 0x0A, 0x00, // &
0x00, 0x10, 0xE0, 0xC0, 0x00, 0x00, // '
0x00, 0x38, 0x44, 0x82, 0x00, 0x00, // (
0x00, 0x82, 0x44, 0x38, 0x00, 0x00, // )
0x54, 0x38, 0xFE, 0x38, 0x54, 0x00, // *
0x10, 0x10, 0x7C, 0x10, 0x10, 0x00, // +
0x00, 0x02, 0x1C, 0x18, 0x00, 0x00, // ,
0x10, 0x10, 0x10, 0x10, 0x10, 0x00, // -
0x00, 0x00, 0x06, 0x06, 0x00, 0x00, // .
0x04, 0x08, 0x10, 0x20, 0x40, 0x00, // /
//96 Bytes
0x7C, 0x8A, 0x92, 0xA2, 0x7C, 0x00, // 0
0x00, 0x42, 0xFE, 0x02, 0x00, 0x00, // 1
0x42, 0x86, 0x8A, 0x92, 0x62, 0x00, // 2
0x84, 0x82, 0x92, 0xB2, 0xCC, 0x00, // 3
0x18, 0x28, 0x48, 0xFE, 0x08, 0x00, // 4
0xE4, 0xA2, 0xA2, 0xA2, 0x9C, 0x00, // 5
0x3C, 0x52, 0x92, 0x92, 0x0C, 0x00, // 6
0x82, 0x84, 0x88, 0x90, 0xE0, 0x00, // 7
0x6C, 0x92, 0x92, 0x92, 0x6C, 0x00, // 8
0x60, 0x92, 0x92, 0x94, 0x78, 0x00, // 9
0x00, 0x00, 0x28, 0x00, 0x00, 0x00, // :
0x00, 0x00, 0x02, 0x2C, 0x00, 0x00, // ;
0x00, 0x10, 0x28, 0x44, 0x82, 0x00, // <
0x28, 0x28, 0x28, 0x28, 0x28, 0x00, // =
0x00, 0x82, 0x44, 0x28, 0x10, 0x00, // >
0x40, 0x80, 0x8A, 0x90, 0x60, 0x00, // ?
//96*2 = 192 Bytes
0x7C, 0x82, 0xBA, 0x9A, 0x72, 0x00, // @
0x3E, 0x48, 0x88, 0x48, 0x3E, 0x00, // A
0xFE, 0x92, 0x92, 0x92, 0x6C, 0x00, // B
0x7C, 0x82, 0x82, 0x82, 0x44, 0x00, // C
0xFE, 0x82, 0x82, 0x82, 0x7C, 0x00, // D
0xFE, 0x92, 0x92, 0x92, 0x82, 0x00, // E
0xFE, 0x90, 0x90, 0x90, 0x80, 0x00, // F
0x7C, 0x82, 0x92, 0x92, 0x5E, 0x00, // G
0xFE, 0x10, 0x10, 0x10, 0xFE, 0x00, // H
0x00, 0x82, 0xFE, 0x82, 0x00, 0x00, // I
0x04, 0x02, 0x82, 0xFC, 0x80, 0x00, // J
0xFE, 0x10, 0x28, 0x44, 0x82, 0x00, // K
0xFE, 0x02, 0x02, 0x02, 0x02, 0x00, // L
0xFE, 0x40, 0x38, 0x40, 0xFE, 0x00, // M
0xFE, 0x20, 0x10, 0x08, 0xFE, 0x00, // N
0x7C, 0x82, 0x82, 0x82, 0x7C, 0x00, // O
//96*3 = 288 Bytes
0xFE, 0x90, 0x90, 0x90, 0x60, 0x00, // P
0x7C, 0x82, 0x8A, 0x84, 0x7A, 0x00, // Q
0xFE, 0x90, 0x98, 0x94, 0x62, 0x00, // R
0x64, 0x92, 0x92, 0x92, 0x4C, 0x00, // S
0x80, 0x80, 0xFE, 0x80, 0x80, 0x00, // T
0xFC, 0x02, 0x02, 0x02, 0xFC, 0x00, // U
0xF8, 0x04, 0x02, 0x04, 0xF8, 0x00, // V
0xFC, 0x02, 0x1C, 0x02, 0xFC, 0x00, // W
0xC6, 0x28, 0x10, 0x28, 0xC6, 0x00, // X
0xC0, 0x20, 0x1E, 0x20, 0xC0, 0x00, // Y
0x86, 0x8A, 0x92, 0xA2, 0xC2, 0x00, // Z
0x00, 0xFE, 0x82, 0x82, 0x82, 0x00, // [
0x40, 0x20, 0x10, 0x08, 0x04, 0x00, // ''
0x00, 0x82, 0x82, 0x82, 0xFE, 0x00, // ]
0x20, 0x40, 0x80, 0x40, 0x20, 0x00, // ^
0x01, 0x01, 0x01, 0x01, 0x01, 0x00, // _
//96*4 = 384 Bytes
0x00, 0xC0, 0xE0, 0x10, 0x00, 0x00, // `
0x04, 0x2A, 0x2A, 0x2A, 0x1E, 0x00, // a
0xFE, 0x14, 0x22, 0x22, 0x1C, 0x00, // b
0x1C, 0x22, 0x22, 0x22, 0x14, 0x00, // c
0x1C, 0x22, 0x22, 0x14, 0xFE, 0x00, // d
0x1C, 0x2A, 0x2A, 0x2A, 0x18, 0x00, // e
0x00, 0x10, 0x7E, 0x90, 0x40, 0x00, // f
0x18, 0x25, 0x25, 0x25, 0x3E, 0x00, // g
0xFE, 0x10, 0x20, 0x20, 0x1E, 0x00, // h
0x00, 0x22, 0xBE, 0x02, 0x00, 0x00, // i
0x00, 0x04, 0x02, 0x02, 0xBC, 0x00, // j
0x00, 0xFE, 0x08, 0x14, 0x22, 0x00, // k
0x00, 0x82, 0xFE, 0x02, 0x00, 0x00, // l
0x3E, 0x20, 0x1E, 0x20, 0x1E, 0x00, // m
0x3E, 0x10, 0x20, 0x20, 0x1E, 0x00, // n
0x1C, 0x22, 0x22, 0x22, 0x1C, 0x00, // o
//96*5 = 480 Bytes
0x3F, 0x18, 0x24, 0x24, 0x18, 0x00, // p
0x18, 0x24, 0x24, 0x18, 0x3F, 0x00, // q
0x3E, 0x10, 0x20, 0x20, 0x10, 0x00, // r
0x12, 0x2A, 0x2A, 0x2A, 0x24, 0x00, // s
0x20, 0x20, 0xFC, 0x22, 0x24, 0x00, // t
0x3C, 0x02, 0x02, 0x04, 0x3E, 0x00, // u
0x38, 0x04, 0x02, 0x04, 0x38, 0x00, // v
0x3C, 0x02, 0x0C, 0x02, 0x3C, 0x00, // w
0x22, 0x14, 0x08, 0x14, 0x22, 0x00, // x
0x32, 0x09, 0x09, 0x09, 0x3E, 0x00, // y
0x22, 0x26, 0x2A, 0x32, 0x22, 0x00, // z
0x00, 0x10, 0x6C, 0x82, 0x00, 0x00, // {
0x00, 0x00, 0xEE, 0x00, 0x00, 0x00, // |
0x00, 0x82, 0x6C, 0x10, 0x00, 0x00, // }
0x40, 0x80, 0x40, 0x20, 0x40, 0x00, // ~
0x00, 0x60, 0x90, 0x90, 0x60, 0x00, // degrees symbol
//96*6 = 576 Bytes
//Special Characters ** NON-ASCII **
0x00, 0x00, 0xFE, 0x82, 0x82, 0x82, // [
0x82, 0x82, 0x82, 0xFE, 0x00, 0x00 // ]
// Variables
// Store a copy of the lcd memory (8x102) = 816 bytes
// Since we cannot read from the lcd memory, this is a way to keep track of
// what is stored there Two additional byes are used for driver-
// internal purposes
uint8_t dogs102x6Memory[816 + 2];
uint8_t currentPage = 0, currentColumn = 0;
uint8_t backlight = 8;
uint8_t contrast = 0x0F;
// Dog102-6 Initialization Commands
uint8_t Dogs102x6_initMacro[] = {
SET_SCROLL_LINE,
SET_SEG_DIRECTION,
SET_COM_DIRECTION,
SET_ALL_PIXEL_ON,
SET_INVERSE_DISPLAY,
SET_LCD_BIAS_RATIO,
SET_POWER_CONTROL,
SET_VLCD_RESISTOR_RATIO,
SET_ELECTRONIC_VOLUME_MSB,
SET_ELECTRONIC_VOLUME_LSB,
SET_ADV_PROGRAM_CONTROL0_MSB,
SET_ADV_PROGRAM_CONTROL0_LSB,
SET_DISPLAY_ENABLE,
SET_PAGE_ADDRESS,
SET_COLUMN_ADDRESS_MSB,
* @brief Initialize LCD
* @param None
* @return None
void Dogs102x6_init(void)
// Port initialization for LCD operation
CD_RST_DIR |= RST;
// Reset is active low
CD_RST_OUT &= RST;
CD_RST_OUT |= RST;
// Chip select for LCD
CS_BACKLT_DIR |= CS;
// CS is active low
CS_BACKLT_OUT &= ~CS;
// Command/Data for LCD
CD_RST_DIR |= CD;
// CD Low for command
CD_RST_OUT &= ~CD;
// P4.1 option select SIMO
SPI_SEL |= SPI_SIMO;
SPI_DIR |= SPI_SIMO;
// P4.3 option select CLK
SPI_SEL |= SPI_CLK;
SPI_DIR |= SPI_CLK;
// Initialize USCI_B1 for SPI Master operation
// Put state machine in reset
UCB1CTL1 |= UCSWRST;
//3-pin, 8-bit SPI master
UCB1CTL0 = UCCKPH + UCMSB + UCMST + UCMODE_0 + UCSYNC;
// Clock phase - data captured first edge, change second edge
// MSB
// Use SMCLK, keep RESET
UCB1CTL1 = UCSSEL_2 + UCSWRST;
UCB1BR0 = 0x01;
UCB1BR1 = 0;
// Release USCI state machine
UCB1CTL1 &= ~UCSWRST;
UCB1IFG &= ~UCRXIFG;
Dogs102x6_writeCommand(Dogs102x6_initMacro, 13);
// Deselect chip
CS_BACKLT_OUT |= CS;
dogs102x6Memory[0] = 102;
dogs102x6Memory[1] = 8;
* @brief Initialize Backlight
* @param None
* @return None
void Dogs102x6_backlightInit(void)
// Turn on Backlight
CS_BACKLT_DIR |= BACKLT;
CS_BACKLT_OUT |= BACKLT;
// Uses PWM to control brightness
CS_BACKLT_SEL |= BACKLT;
// start at full brightness (8)
TB0CCTL4 = OUTMOD_7;
TB0CCR4 = TB0CCR0 >> 1;
TB0CCR0 = 50;
TB0CTL = TBSSEL_1 + MC_1;
* @brief Set function for the backlight PWM's duty cycle
* @param BackLightLevel The target backlight duty cycle - valued 0~11.
* @return none
void Dogs102x6_setBacklight(uint8_t brightness)
unsigned int dutyCycle = 0, i, dummy;
if (brightness > 0)
dummy = (TB0CCR0 >> 4);
dutyCycle = 12;
for (i = 0; i < brightness; i++)
dutyCycle += dummy;
TB0CCR4 = dutyCycle;
//If the backlight was previously turned off, turn it on.
if (!backlight)
TB0CTL |= MC0;
else
TB0CCTL4 = 0;
TB0CTL &= ~MC0;
backlight = brightness;
* @brief Disable display
* @param None
* @return None
void Dogs102x6_disable(void)
uint8_t cmd[1] = { SYSTEM_RESET };
Dogs102x6_writeCommand(cmd, 1);
cmd[0] = SET_DISPLAY_ENABLE & 0xFE;
* @brief Sends commands to LCD via 3 wire SPI
* @param sCmd Pointer to the commands to be written to the LCD
* @param i Number of commands to be written to the LCD
* @return None
void Dogs102x6_writeCommand(uint8_t *sCmd, uint8_t i)
// Store current GIE state
uint16_t gie = __get_SR_register() & GIE;
// Make this operation atomic
__disable_interrupt();
// CS Low
P7OUT &= ~CS;
// CD Low
P5OUT &= ~CD;
while (i)
// USCI_B1 TX buffer ready?
while (!(UCB1IFG & UCTXIFG)) ;
// Transmit data
UCB1TXBUF = *sCmd;
// Increment the pointer on the array
sCmd++;
// Decrement the Byte counter
i--;
// Wait for all TX/RX to finish
while (UCB1STAT & UCBUSY) ;
// Dummy read to empty RX buffer and clear any overrun conditions
UCB1RXBUF;
// CS High
P7OUT |= CS;
// Restore original GIE state
__bis_SR_register(gie);
* @brief Sends Data to LCD via 3 wire SPI
* @param sData Pointer to the Data to be written to the LCD
* @param i Number of data bytes to be written to the LCD
* @return None
void Dogs102x6_writeData(uint8_t *sData, uint8_t i)
// CS Low
P7OUT &= ~CS;
//CD High
P5OUT |= CD;
while (i)
dogs102x6Memory[2 + (currentPage * 102) + currentColumn] = (uint8_t)*sData;
currentColumn++;
// Boundary check
if (currentColumn > 101)
currentColumn = 101;
// Transmit data and increment pointer
UCB1TXBUF = *sData++;
i--;
UCB1RXBUF;
// CS High
P7OUT |= CS;
* @brief Gets the current contrast level
* @param None
* @return Contrast level
uint8_t Dogs102x6_getContrast(void)
return contrast;
* @brief Gets the current backlight level
* @param None
* @return Backlight level
uint8_t Dogs102x6_getBacklight(void)
return backlight;
* @brief Sets Address of the LCD RAM memory
* (0,0) is the upper left corner of screen.
* @param pa Page Address of the LCD RAM memory to be written (0 - 7)
* @param ca Column Address of the LCD RAM memory to be written (0 - 101)
* @return None
void Dogs102x6_setAddress(uint8_t pa, uint8_t ca)
uint8_t cmd[1];
// Page boundary check
if (pa > 7)
pa = 7;
// Column boundary check
if (ca > 101)
ca = 101;
// Page Address Command = Page Address Initial Command + Page Address
cmd[0] = SET_PAGE_ADDRESS + (7 - pa);
uint8_t H = 0x00;
uint8_t L = 0x00;
uint8_t ColumnAddress[] = { SET_COLUMN_ADDRESS_MSB, SET_COLUMN_ADDRESS_LSB };
currentPage = pa;
currentColumn = ca;
// Separate Command Address to low and high
L = (ca & 0x0F);
H = (ca & 0xF0);
H = (H >> 4);
// Column Address CommandLSB = Column Address Initial Command
// + Column Address bits 0..3
ColumnAddress[0] = SET_COLUMN_ADDRESS_LSB + L;
// Column Address CommandMSB = Column Address Initial Command
// + Column Address bits 4..7
ColumnAddress[1] = SET_COLUMN_ADDRESS_MSB + H;
// Set page address
// Set column address
Dogs102x6_writeCommand(ColumnAddress, 2);
* @brief Sets the contrast
* @param contrast Contrast level (0~31, where 31 is darkest setting)
* @return None
void Dogs102x6_setContrast(uint8_t newContrast)
uint8_t cmd[2];
cmd[0] = SET_ELECTRONIC_VOLUME_MSB;
//check if parameter is in range
if (newContrast > 0x1F)
cmd[1] = 0x1F;
else
cmd[1] = newContrast;
contrast = cmd[1];
Dogs102x6_writeCommand(cmd, 2);
// Save new contrast to initMacro
Dogs102x6_initMacro[8] = newContrast;
* @brief Inverts the screen (pixels on/off) - does not affect LCD memory.
* @param None
* @return None
void Dogs102x6_setInverseDisplay(void)
uint8_t cmd[] = {SET_INVERSE_DISPLAY + 0x01};
* @brief Uninverts the screen (pixels on/off) - does not affect LCD memory.
* @param None
* @return None
void Dogs102x6_clearInverseDisplay(void)
uint8_t cmd[] = {SET_INVERSE_DISPLAY};
* @brief Scrolls image down a number of lines. The scrolling wraps around the screen.
* @param lines number of lines to scroll (0~63)
* @return None
void Dogs102x6_scrollLine(uint8_t lines)
uint8_t cmd[] = {SET_SCROLL_LINE};
if (lines > 0x1F)
cmd[0] |= 0x1F;
else
cmd[0] |= lines;
* @brief Sets all Pixels on
* @param None
* @return None
void Dogs102x6_setAllPixelsOn(void)
uint8_t cmd[] = {SET_ALL_PIXEL_ON + 0x01};
* @brief Returns pixels to normal functioning
* @param None
* @return None
void Dogs102x6_clearAllPixelsOn(void)
uint8_t cmd[] = {SET_ALL_PIXEL_ON};
/****************************DRAWING FUNCTIONS*********************************/
* @brief Sets All pixels Off (in memory as well)
* @param None
* @return None
void Dogs102x6_clearScreen(void)
uint8_t LcdData[] = {0x00};
uint8_t p, c;
// 8 total pages in LCD controller memory
for (p = 0; p < 8; p++)
Dogs102x6_setAddress(p, 0);
// 102 total columns in LCD controller memory
for (c = 0; c < 102; c++)
Dogs102x6_writeData(LcdData, 1);
* @brief Writes a character from FONT6x8[] array to the LCD at (row,col).
* @param row Page Address (0 - 7) (there are 8 pages on the screen, each is 8 pixels tall)
* @param col Column Address (there are 102 columns on the screen)
* @param f Pointer to the character to be written to the LCD
* @param style The style of the text
* - NORMAL = 0 = dark letters with light background
* - INVERT = 1 = light letters with dark background
* @return None
void Dogs102x6_charDraw(uint8_t row, uint8_t col, uint16_t f, uint8_t style)
// Each Character consists of 6 Columns on 1 Page
// Each Page presents 8 pixels vertically (top = MSB)
uint8_t b;
uint16_t h;
uint8_t inverted_char[6];
// Row boundary check
if (row > 7)
row = 7;
if (col > 101)
col = 101;
// handle characters not in our table
if (f < 32 || f > 129)
// replace the invalid character with a '.'
f = '.';
// subtract 32 because FONT6x8[0] is "space" which is ascii 32,
// multiply by 6 because each character is columns wide
h = (f - 32) * 6;
Dogs102x6_setAddress(row, col);
if (style == DOGS102x6_DRAW_NORMAL)
// write character
Dogs102x6_writeData((uint8_t *)FONT6x8 + h, 6);
else
for (b = 0; b < 6; b++)
// invert the character
inverted_char = FONT6x8[h + b] ^ 0xFF;
// write inverted character
Dogs102x6_writeData(inverted_char, 6);
* @brief Writes a character from FONT6x8[] array to the LCD at (x,y).
* @param x Horizontal coordinate (0 - 102)
* @param y Vertical coordinate (0 - 63)
* @return None
void Dogs102x6_charDrawXY(uint8_t x, uint8_t y, uint16_t f, uint8_t style)
// Each Character consists of 6 Columns 8 pixels tall
uint8_t b, row;
uint16_t h;
uint8_t desired_char[12];
// make sure we won't be writing off the screen
if (x >= 102)
x = 101;
if (y >= 64)
y = 63;
f = '.';
// multiply by 6 because each character is 6 columns wide
h = (f - 32) * 6;
// Check if there is a remainder
row = y / 8;
desired_char =
(FONT6x8[h + b] >> (y % 8)) | dogs102x6Memory[2 + (row * 102) + x + b];
desired_char[b + 6] =
FONT6x8[h + b] << (8 - y % 8) | dogs102x6Memory[2 + ((row + 1) * 102) + x + b];
else
desired_char = (FONT6x8[h + b] ^ 0xFF) >> (y % 8);
desired_char[b + 6] = (FONT6x8[h + b] ^ 0xFF) << (8 - y % 8);
Dogs102x6_setAddress(row, x);
// write first line of character
Dogs102x6_writeData(desired_char, 6);
Dogs102x6_setAddress(row + 1, x);
// write second line of character
Dogs102x6_writeData(desired_char + 6, 6);
* @brief Writes a String to the LCD at (row,col).
* @param row Page Address (there are 8 pages on the screen, each is 8 pixels
* tall) (0 - 7)
* @param col Column Address (there are 102 columns on the screen) (0 - 101)
* @param word[] Pointer to the String to be written to the LCD
* @return None
void Dogs102x6_stringDraw(uint8_t row, uint8_t col, char *word, uint8_t style)
uint8_t a = 0;
if (row > 7)
row = 7;
if (col > 101)
col = 101;
while (word[a] != 0)
// check for line feed '/n'
if (word[a] != 0x0A)
//check for carriage return '/r' (ignore if found)
if (word[a] != 0x0D)
//Draw a character
Dogs102x6_charDraw(row, col, word[a], style);
//Update location
col += 6;
//Text wrapping
if (col >= 102)
col = 0;
if (row < 7)
row++;
else
row = 0;
// handle line feed character
else
if (row < 7)
row++;
else
row = 0;
col = 0;
a++;
* @brief Writes a String to the LCD at (x,y).
* @return None
void Dogs102x6_stringDrawXY(uint8_t x, uint8_t y, char *word, uint8_t style)
/* Each Character consists of 6 Columns on 1 Page
* Each Page presents 8 pixels vertically (top = MSB)*/
uint8_t a = 0;
// Draw a character
Dogs102x6_charDrawXY(x, y, word[a], style);
// Update location
x += 6;
// Text wrapping
if (x >= 102)
x = 0;
if (y + 8 < 64)
y += 8;
else
y = 0;
a++;
* @brief Clears one row/page (in memory as well).
* Row 0 is at the top of the screen.
* @param row The row to be cleared (0~7)
* @return None
void Dogs102x6_clearRow(uint8_t row)
uint8_t cmd[] = {0};
uint8_t a = 0;
// Check row boundary
if (row > 7)
row = 7;
Dogs102x6_setAddress(row, 0);
for (a = 0; a < 102; a++)
Dogs102x6_writeData(cmd, 1);
dogs102x6Memory[2 + (row * 102) + a] = 0x00;
* @brief Draws a pixel at (x,y).
* @param x x-coordinate of the point
* @param y y-coordinate of the point
* @param style The style of the pixel
* - NORMAL = 0 = dark pixel
* - INVERT = 1 = inverts pixel
* @return None
void Dogs102x6_pixelDraw(uint8_t x, uint8_t y, uint8_t style)
uint8_t p, temp;
//make sure we won't be writing off the screen
if (x > 101)
x = 101;
if (y > 63)
y = 63;
//determine the page
p = y / 8;
//determine height of pixel within the page
temp = 0x80 >> (y % 8);
//update our array
dogs102x6Memory[2 + (p * 102) + x] |= temp;
else
dogs102x6Memory[2 + (p * 102) + x] &= ~temp;
Dogs102x6_setAddress(p, x);
//draw pixel
Dogs102x6_writeData(dogs102x6Memory + (2 + (p * 102) + x), 1);
* @brief Draws a horizontal line on the LCD.
* @param x1 The horizontal line starting pixel coordinate (0~101)
* @param x2 The horizontal line ending pixel coordinate (0~101)
* @param y The height of the line (pixel row, not page) (0~63)
* @param style The style of the line
* - NORMAL = 0 = dark line, overwrites
* - INVERT = 1 = inverts color on line
* @return None
void Dogs102x6_horizontalLineDraw(uint8_t x1, uint8_t x2, uint8_t y, uint8_t style)
uint8_t temp = 0, p, a;
if (x1 > 101)
x1 = 101;
if (x2 > 101)
x2 = 101;
if (y > 63)
y = 63;
//swap coordinates if x1 is past x2
if (x1 > x2)
temp = x1;
x1 = x2;
x2 = temp;
p = y / 8;
//determine height of line within the page
a = x1;
while (a <= x2)
//draws a dark line through everything
dogs102x6Memory[2 + (p * 102) + a] |= temp;
else
//draws a light line through everything
dogs102x6Memory[2 + (p * 102) + a] &= ~temp;
a++;
Dogs102x6_setAddress(p, x1);
//draw the line
Dogs102x6_writeData(dogs102x6Memory + (2 + (p * 102) + x1), x2 - x1 + 1);
* @brief Draws a vertical line on the LCD.
* @param y1 The vertical line starting pixel coordinate (0~63)
* @param y2 The vertical line ending pixel coordinate (0~63)
* @param x The column of line (0~101)
* @return None
void Dogs102x6_verticalLineDraw(uint8_t y1, uint8_t y2, uint8_t x, uint8_t style)
uint8_t temp1 = 0, temp2 = 0, p1, p2, a;
if (y1 > 63)
y1 = 63;
if (y2 > 63)
y2 = 63;
if (x > 101)
x = 101;
//swap coordinates if y1 is past y2
if (y1 > y2)
temp1 = y1;
y1 = y2;
y2 = temp1;
//determine the first page of line
p1 = y1 / 8;
//determine the last page of line
p2 = y2 / 8;
//mask for last page of line
temp2 = 8 - (y2 % 8);
temp2--;
temp2 = 0xFF << temp2;
//mask for first page of line
// Length that spans across multiple pages
if (p1 != p2)
// Check if there is an offset
if (y1 > 0)
temp1 = 0xFF00 >> (y1 % 8);
temp1 = temp1 ^ 0xFF;
// If there is no offset, set all bits for lower mask
else
temp1 = 0xFF;
// Short length that only spans one page
else
// Clear lower page bits
temp1 = 0;
// mask off y1 from top page bits
a = y1 - (p1 * 8);
a = 0xFF00 >> a;
temp2 = temp2 ^ a;
// Prepare for first page of line
dogs102x6Memory[2 + (p1 * 102) + x] |= temp1;
else
dogs102x6Memory[2 + (p1 * 102) + x] &= ~temp1;
// Set starting address for first page
Dogs102x6_setAddress(p1, x);
//draw first page of line
Dogs102x6_writeData(dogs102x6Memory + (2 + (p1 * 102) + x), 1);
a = p1 + 1;
while (a < p2)
dogs102x6Memory[2 + (a * 102) + x] = 0xFF;
else
dogs102x6Memory[2 + (a * 102) + x] &= 0x00;
Dogs102x6_setAddress(a, x);
// draw middle of line
Dogs102x6_writeData(dogs102x6Memory + (2 + (a * 102) + x), 1);
a++;
// Prepare for last page of line
dogs102x6Memory[2 + (p2 * 102) + x] |= temp2;
else
dogs102x6Memory[2 + (p2 * 102) + x] &= ~temp2;
Dogs102x6_setAddress(p2, x);
//draw last page of line
Dogs102x6_writeData(dogs102x6Memory + (2 + (p2 * 102) + x), 1);
* @brief Draws a line from (x1,y1) to (x2,y2).
* Uses Bresenham's line algorithm.
* @param x1 x-coordinate of the first point
* @param y y-coordinate of the first point
* @param x2 x-coordinate of the second point
* @param y2 y-coordinate of the second point
* @return None
void Dogs102x6_lineDraw(uint8_t x1, uint8_t y1, uint8_t x2, uint8_t y2, uint8_t style)
int8_t x, y, deltay, deltax, d;
int8_t x_dir, y_dir;
if (y1 > 63)
y1 = 63;
if (y2 > 63)
y2 = 63;
if (x1 > 101)
x1 = 101;
if (x2 > 101)
x2 = 101;
// Check if vertical line. Use more efficient vertical line function
if (x1 == x2)
Dogs102x6_verticalLineDraw(y1, y2, x1, style);
// Check if horizontal line. Use more efficient horizontal line function
else if (y1 == y2)
Dogs102x6_horizontalLineDraw(x1, x2, y1, style);
// else it is a diagonal line
else
if (x1 > x2)
x_dir = -1;
else
x_dir = 1;
if (y1 > y2)
y_dir = -1;
else
y_dir = 1;
x = x1;
y = y1;
deltay = abs(y2 - y1);
deltax = abs(x2 - x1);
if (deltax >= deltay)
d = (deltay << 1) - deltax;
while (x != x2)
Dogs102x6_pixelDraw(x, y, style);
if (d < 0)
d += (deltay << 1);
else
d += ((deltay - deltax) << 1);
y += y_dir;
x += x_dir;
else
d = (deltax << 1) - deltay;
while (y != y2)
if (d < 0)
d += (deltax << 1);
else
d += ((deltax - deltay) << 1);
x += x_dir;
y += y_dir;
* @brief Draw a circle of Radius with center at (x,y).
* Uses Bresenham's circle algorithm.
* @param x x-coordinate of the circle's center point
* @param y y-coordinate of the circle's center point
* @param radius Radius of the circle
* @param style The style of the circle
* @return None
void Dogs102x6_circleDraw(uint8_t x, uint8_t y, uint8_t radius, uint8_t style)
int8_t xx, yy, ddF_x, ddF_y, f;
ddF_x = 0;
ddF_y = -(2 * radius);
f = 1 - radius;
xx = 0;
yy = radius;
Dogs102x6_pixelDraw(x + xx, y + yy, style);
Dogs102x6_pixelDraw(x + xx, y - yy, style);
Dogs102x6_pixelDraw(x - xx, y + yy, style);
Dogs102x6_pixelDraw(x - xx, y - yy, style);
Dogs102x6_pixelDraw(x + yy, y + xx, style);
Dogs102x6_pixelDraw(x + yy, y - xx, style);
Dogs102x6_pixelDraw(x - yy, y + xx, style);
Dogs102x6_pixelDraw(x - yy, y - xx, style);
while (xx < yy)
if (f >= 0)
yy--;
ddF_y += 2;
f += ddF_y;
xx++;
ddF_x += 2;
f += ddF_x + 1;
* @brief Loads an image of size = height * width, starting at (row,col).
* The first two bytes of the image should contain the width in pixels
* and the height in rows (height in rows = height in pixels/8)
* @param image[] The image to be loaded.
* @param height The number of rows in the image. Size = Rows * Columns.
* @param width The number of columns in the image. Size = Rows * Columns.
* @param row row of the image's starting location
* @param col column of the image's starting location
* @return None
void Dogs102x6_imageDraw(const uint8_t IMAGE[], uint8_t row, uint8_t col)
// height in rows (row = 8 pixels), width in columns
uint8_t a, height, width;
width = IMAGE[0];
height = IMAGE[1];
for (a = 0; a < height; a++)
Dogs102x6_setAddress(row + a, col);
// Draw a row of the image
Dogs102x6_writeData((uint8_t*)IMAGE + 2 + a * width, width);
* @brief Clears an area of size = height * width, starting at (row,col).
* @return None
void Dogs102x6_clearImage(uint8_t height, uint8_t width, uint8_t row, uint8_t col)
uint8_t a, b;
uint8_t cmd[] = {0x00};
for (b = 0; b < width; b++)
// clear a byte
* @brief :显示汉字,字模取法阴码,顺向,列行式,十六进制 一维数组形式输出
* @param :*P字模数组
* @param :Num,一行显示的个数
* @param :Way,显示方式,Way是0为16*16字体,Way是1为16*32字体,Way是2为32*32字体
* @param :row,从哪行开始显示
* @param :col,从哪列开始显示
* @return None
void Dogs102x6_ChineseDraw(uint8_t *P,uint8_t Num,uint8_t Way,uint8_t row, uint8_t col)
uint8_t a;
uint8_t Count;
switch (Way)
case 0: Count = 2*Num; break;
case 1: Count = 2*Num; break;
case 2: Count = 4*Num; break;
default:break;
for (a = 0; a < Count; a++)
switch (Way)
case 0:
Dogs102x6_setAddress(row + a%2, col+(a/2*16));
Dogs102x6_writeData(P + a*16, 16);
break;
case 1:
Dogs102x6_setAddress(row + a%2, col+(a/2*32));
Dogs102x6_writeData(P + a*32, 32);
break;
case 2:
Dogs102x6_setAddress(row + a%4, col+(a/4*32));
break;
default:break;
* @brief 液晶初试化程序
* @param None
* @return None
void LCD_Init(void)
Dogs102x6_init();
Dogs102x6_backlightInit();
Dogs102x6_clearScreen();
Dogs102x6_setBacklight(10);
好长啊  详情 回复 发表于 2018-3-14 18:02
954
好长啊
