2095|0
3238
MTK7688 OP U盘测试 [复制链接]
             简介
Widora出厂固件默认支持了VFAT,EXFAT,EXT4等文件系统格式。如果U盘或TF卡不是这几种格式,请格式化成此种格式。
一般U盘对应的设备文件在/dev/下sda,sdb,sdc这些,而SD卡则是mmcblk0,mmcblk0p1等。
挂载
插入U盘,默认串口控制台会打印如下:
root@Widora:/# [ 2531.690000] usb 1-1: new high-speed USB device number 2 usingm[ 2531.840000 usb-storage 1-1:1.0: USB Mass Storage device detected            [ 2531.850000 scsi host0: usb-storage 1-1:1.0                                  [ 2532.850000 scsi 0:0:0:0: Direct-Access     SanDisk  Cruzer Blade     1.27 P6[ 2532.860000 sd 0:0:0:0: [sda 15330304 512-byte logical blocks: (7.84 GB/7.3)[ 2532.870000 sd 0:0:0:0: [sda Write Protect is off                           [ 2532.870000 sd 0:0:0:0: [sda Write cache: disabled, read cache: enabled, doA[ 2532.900000  sda: sda1                                                       [ 2532.910000 sd 0:0:0:0: [sda Attached SCSI removable disk                   [ 2533.190000 FAT-fs (sda1): Volume was not properly unmounted. Some data may .
U盘会自动挂载至“/tmp/mounts/“目录:
root@Widora:/# cd /tmp/mounts/                                                  root@Widora:/tmp/mounts# ls                                                     USB-A1
此时进入USB-A1可以看到U盘的文件列表:
root@Widora:/tmp/mounts# cd USB-A1/                                             root@Widora:/tmp/run/mountd/sda1# ls       test 1.mp3
TF卡挂载同理,也会挂载至”/tmp/mounts/“目录。
此内容由EEWORLD论坛网友wateras1原创,如需转载或用于商业用途需征得作者同意并注明出处
此帖出自无线连接论坛
个人签名淘宝:https://viiot.taobao.com/Q群243090717
多年专业物联网行业经验,个人承接各类物联网外包项目
