7298|15
华大M0+低功耗MCU RTC模块示例 [复制链接]
/*******                 样例使用说明           *************/
/*******                    版本历史            ************/
/*******  日期       版本    负责人  IAR   MDK ***********/
/*****    017-07-14     0.1     CJ    7.70    5.14 **********/
/*******  QQ:3386208645                       ************/
/*******               功能描述                  ***********/
/*   本样例主要涉及时钟模块计数寄存器的写入和读取**********/
/*说明:                                       *************/
/*计数初值写入计数寄存器                       *************/
/*启动计数                                    *************/
/*读取计数寄存器数值                           *************/
/******* 测试环境                              *************/
/*     测试用板:                              *************/
/* SK-L110-TSSOP20 V10                        *************/
/*******辅助工具:                              ************/
/*  JLINK调试工具                           *************/
#define IS_VALID_CLK(x)             (RtcClk32768 == (x)||\
                                    RtcClk32768_1== (x)||\
                                     RtcClk32== (x)||\
                                     RtcClk32_1== (x)||\
                                    RtcClkHxt128 ==(x)||\
                                    RtcClkHxt256 == (x)||\
                                    RtcClkHxt512 == (x)||\
                                    RtcClkHxt1024 == (x))
#define IS_VALID_CYCSEL(x)             (RtcPrads == (x)||\
                                 RtcPradx==(x))
#define IS_VALID_PRDS(x)        (Rtc_None == (x)||\
                              Rtc_05S == (x)||\
                              Rtc_1S == (x)||\
                              Rtc_1Min ==(x)||\
                              Rtc_1H == (x)||\
                              Rtc_1Day ==(x)||\
                              Rtc_1Mon ==(x)||\
                              Rtc_1Mon_1 ==(x))
#define    IS_VALID_IRQ_SEL(x)      (RtcPrdf== (x) ||\
                                      RtcAlmf== (x))
#define    IS_VALID_FUNC(x) ((RtcCount<=(x))&&\
                              (Rtc1HzOutEn>=(x)))
#define    CkDateTime    0x7F
#define    CkDate        0x78
#define    CkTime        0x07
#define RTC_TIMEOUT             1000//test 1s
#define    T1_PORT                 (3)
#define    T1_PIN                  (3)
uint8_t cyccnt=0;
uint8_t u8Alarmcnt=0;
uint8_t flg=0;
stc_rtc_time_t  stcReadTime;
/********************************************************************************** \brief  RTC计数时钟选择
** ** \param [in] enClk时钟源
** ** \retval Ok
en_result_t Rtc_SelClk(en_rtc_clk_t enClk)
   en_result_t enRet = Error;
   ASSERT(IS_VALID_CLK(enClk));
   M0P_RTC->CR1_f.CKSEL = enClk;
   enRet = Ok;
   return enRet;
**\brief  RTC周期中断方式选择
**\param [in] pstccCyc周期中断方式及周期间隔选择
**\retval Ok
en_result_t Rtc_SetCyc(stc_rtc_cyc_sel_t*pstcCyc)
         ASSERT(IS_VALID_CYCSEL(pstcCyc->enCyc_sel));
         ASSERT(IS_VALID_PRDS(pstcCyc->enPrds_sel));
         M0P_RTC->CR0_f.PRDSEL= pstcCyc->enCyc_sel;
         if(pstcCyc->enCyc_sel)
       M0P_RTC->CR0_f.PRDX = pstcCyc->u8Prdx;
         else
                   M0P_RTC->CR0_f.PRDS= pstcCyc->enPrds_sel;
   enRet = Ok;
         returnenRet;
**\brief  RTC时制选择
**\param [in] bmode12时制or24时制
**\retval Ok  设置正常
**\retval ErrorInvalidParameter 设置异常
en_result_t Rtc_SetAmPm(en_rtc_ampm_tenMode)
   switch(enMode)
       case 0:
       case 1:
           M0P_RTC->CR0_f.AMPM = enMode;
           break;
       default:
           return ErrorInvalidParameter;
   enRet = Ok;
   return enRet;
**\brief  RTC闹钟中断设置
**\param [in] pstcAlarmTime闹钟时间时、分、周
**\retval Ok  设置正常
en_result_tRtc_SetAlarmTime(stc_rtc_alarmset_t* pstcAlarmTime)
   en_result_t enRet = Ok;
   ASSERT(NULL != pstcAlarmTime);
   if(Rtc12h == M0P_RTC->CR0_f.AMPM)
       enRet = Check_BCD_Format(pstcAlarmTime->u8Hour,0x00,0x12);
   else
       enRet = Check_BCD_Format(pstcAlarmTime->u8Hour,0x00,0x24);
    if(enRet != Ok)
       return enRet;
   enRet = Check_BCD_Format(pstcAlarmTime->u8Minute,0x00,0x59);
   if(enRet != Ok)
       return enRet;
   //enRet = Check_BCD_Format(pstcAlarmTime->u8Week,0x00,0x06);
   if(enRet != Ok)
       return enRet;
   M0P_RTC->ALMHOUR = pstcAlarmTime->u8Hour;
   M0P_RTC->ALMMIN = pstcAlarmTime->u8Minute;
   M0P_RTC->ALMWEEK = pstcAlarmTime->u8Week;
   enRet = Ok;
   return enRet;
**\brief  RTC闹钟中断时间获取
**\retval Ok  设置正常
en_result_tRtc_GetAlarmTime(stc_rtc_alarmset_t* pstcAlarmTime)
   pstcAlarmTime->u8Minute = M0P_RTC->ALMMIN;
   pstcAlarmTime->u8Hour = M0P_RTC->ALMHOUR;
   pstcAlarmTime->u8Week = M0P_RTC->ALMWEEK;
   enRet = Ok;
   return enRet;
**\brief  RTC 1hz模式选择
**\param [in] bmode 高精度和普通精度
**\retval Ok  设置正常
en_result_t Rtc_Set1HzMode(boolean_t bMode)
   M0P_RTC->CR0_f.HZ1SEL = bMode;
   enRet = Ok;
   return enRet;
**\brief  RTC 1hz补偿值设置
**\param [in] u16Cr 补偿值
**\retval Ok  设置正常
en_result_t Rtc_SetCompCr(uint16_t u16Cr)
   M0P_RTC->COMPEN_f.CR = u16Cr;
   enRet = Ok;
   return enRet;
**\brief  RTC 功能使能设置
**\param [in] enFunc 功能选择
**\retval Ok  设置正常
en_result_t Rtc_EnableFunc(en_rtc_func_tenFunc)
    ASSERT(IS_VALID_FUNC(enFunc));
   switch(enFunc)
       case RtcCount:
           M0P_RTC->CR0_f.START = 1u;
           break;
       case RtcAlarmEn:
           M0P_RTC->CR1_f.ALMEN = 1u;
           break;
       case Rtc_ComenEn:
           M0P_RTC->COMPEN_f.EN = 1u;
           break;
       case Rtc1HzOutEn:
           M0P_RTC->CR0_f.HZ1OE = 1u;
           break;
       default:
   return Ok;
**\brief  RTC 功能禁止设置
**\retval Ok  设置正常
en_result_t Rtc_DisableFunc(en_rtc_func_tenFunc)
   switch(enFunc)
       case RtcCount:
           M0P_RTC->CR0_f.START = 0u;
           break;
       case RtcAlarmEn:
           M0P_RTC->CR1_f.ALMEN = 0u;
           break;
       case Rtc_ComenEn:
           M0P_RTC->COMPEN_f.EN = 0u;
           break;
       case Rtc1HzOutEn:
           M0P_RTC->CR0_f.HZ1OE = 0u;
           break;
       default:
   return Ok;
uint8_t Change_DateTimeFormat(uint8_t u8sr)
         uint8_tu8de=0;
         while(u8sr>=0x10)
                   u8de+=10;
                   u8sr-=0x10;
         u8de+= u8sr;
         return(u8de);
**\brief  RTC 平、闰年检测
**\param [in] u8year 年十进制低两位
**\retval 1  闰年
**\retval 0 平年
uint8_t Rtc_CheckLeapYear(uint8_t u8year)
   uint8_t u8year_shl,u8year_shr;
   u8year_shl = u8year>>2;
   u8year_shr = u8year_shl<<2;
   if(u8year== u8year_shr)
       return 1;
   else
       return 0;
**\brief  RTC根据日期计算周数
**\param [in] pu8Date日期
**\retval week  周数
uint8_t Rtc_CalWeek(uint8_t* pu8Date)
   uint8_t u8week;
   if((Rtc_CheckLeapYear(Change_DateTimeFormat(*(pu8Date+2)))==1))
                   u8week=(Change_DateTimeFormat(*(pu8Date+2))+Change_DateTimeFormat(*(pu8Date+2))/4+Leap_Month_Base[Change_DateTimeFormat(*(pu8Date+1))-1]+Change_DateTimeFormat(*(pu8Date))+2)%7;
         else
                   u8week= (Change_DateTimeFormat(*(pu8Date+2))+Change_DateTimeFormat(*(pu8Date+2))/4+NonLeap_Month_Base[Change_DateTimeFormat(*(pu8Date+1))-1]+Change_DateTimeFormat(*(pu8Date))+2)%7;
   return u8week;
**\brief  RTC根据年月获取天数
**\param [in] u8month月份,u8year年份
**\retval u8day天数
uint8_t Get_Month_Max_Day(uint8_t u8month,uint8_t u8year)
         uint8_tu8day = 0;
         u8day= Cnst_Month_Tbl[u8month - 1];
         if((u8month== 2) && ((u8year % 4) == 0))
                   u8day++;
         return(u8day);//day的格式是bcd码,例如;日为31天,day=0x31
**\param [in] pu8buf日期时间数据,u8len检查数据长度,u8limit_min最小值,u8limit_max最大值
**\retval Error 错误,Ok校验正确
en_result_t Check_BCD_Format(uint8_tu8data,uint8_t u8limit_min, uint8_t u8limit_max)
   if (((u8data & 0x0F) > 0x09) || ((u8data & 0xF0) > 0x90)
   ||(u8data > u8limit_max) || (u8data < u8limit_min))
       return Error;
   return Ok;
**\brief  RTC时间格式检测
**\param [in] pu8TimeDate日期时间数据,u8Mode检测模式
**\retval enRet校验结果
en_result_tRtc_CheckDateTimeFormat(uint8_t* pu8TimeDate,uint8_t u8Mode)
   uint8_t u8i=0;
   uint8_t u8mon_max_day = 0x28;
   uint8_t u8date[3];
   en_result_t enRet;
   while(u8i<7)
       if(u8Mode&&(1<
           switch(u8i)
                case 0:
                    enRet = Check_BCD_Format(*pu8TimeDate,0x00,0x59);//
                    break;
                case 1:
                    enRet =Check_BCD_Format(*pu8TimeDate,0x00,0x59);//
                    break;
                case 2:
                        enRet =Check_BCD_Format(*pu8TimeDate,0x00,0x12);//
                    else
                        enRet =Check_BCD_Format(*pu8TimeDate,0x00,0x24);
                    break;
                case 3:
                    enRet =Check_BCD_Format(*pu8TimeDate,0x00,0x06);
                    break;
                case 4:
                    enRet =Check_BCD_Format(*pu8TimeDate,0x00,0x31);
                    u8date[0] = *pu8TimeDate;
                    break;
               case 5:
                    u8date[1] = *pu8TimeDate;
                    break;
                case 6:
                    enRet =Check_BCD_Format(*pu8TimeDate,0x00,0x99);
                    u8date[2] = *pu8TimeDate;
                    break;
           pu8TimeDate++;
       if(enRet!=Ok)
       return enRet;
       u8i++;
     if((u8Mode&0x10)&&(u8Mode&0x20))
                   if(u8Mode&0x40)
                            u8mon_max_day= Get_Month_Max_Day(Change_DateTimeFormat(u8date[1]),Change_DateTimeFormat(u8date[2]));
                   else
                            u8mon_max_day= Get_Month_Max_Day(Change_DateTimeFormat(u8date[1]), 1);
                   if(u8date[0]>u8mon_max_day)
                            returnError;
         if((u8Mode&0x10)&&(!(u8Mode&0x20)))
                   if(u8date[0]>0x28)
                            returnError;
   enRet = Ok;
         return(enRet);
**\brief  RTC设置时间函数
**\param [in] pstcTimeDate日期时间数据、bUpdateTime是否更改时间、bUpdateDate是否更改日期
**\retval Ok  设置正常
**\retval ErrorTimeout 时间溢出错误
en_result_tRtc_WriteDateTime(stc_rtc_time_t* pstcTimeDate,boolean_t bUpdateTime,
                            boolean_t bUpdateDate)
   int32_t u32TimeOut;
   u32TimeOut = RTC_TIMEOUT;
   uint8_t* pu8TimeDate;
   pu8TimeDate = &pstcTimeDate->u8Second;
   ASSERT(NULL != pstcTimeDate);
   if(1 == M0P_RTC->CR0_f.START)
        M0P_RTC->CR1_f.WAIT = 1;
       while(--u32TimeOut)
           if(M0P_RTC->CR1_f.WAITF)
                break;
       if(u32TimeOut==0)
           return ErrorTimeout;
    if(TRUE == bUpdateTime)
       enRet = Rtc_CheckDateTimeFormat(pu8TimeDate,CkTime);
       if(enRet != Ok)
           return enRet;
       M0P_RTC->SEC = pstcTimeDate->u8Second;
       M0P_RTC->MIN = pstcTimeDate->u8Minute;
       M0P_RTC->HOUR = pstcTimeDate->u8Hour;
   if(TRUE == bUpdateDate)
       enRet = Rtc_CheckDateTimeFormat(pu8TimeDate,CkDate);
       if(enRet != Ok)
           return enRet;
       M0P_RTC->DAY = pstcTimeDate->u8Day;
       M0P_RTC->MON = pstcTimeDate->u8Month;
       M0P_RTC->YEAR = pstcTimeDate->u8Year;
       M0P_RTC->WEEK = pstcTimeDate->u8DayOfWeek;
   M0P_RTC->CR1_f.WAIT = 0;
       while(M0P_RTC->CR1_f.WAITF);
   return enRet;
**\brief  RTC获取时间函数
**\retval Ok  获取正常
en_result_tRtc_ReadDateTime(stc_rtc_time_t* pstcTimeDate)
   uint32_t u32TimeOut;
   uint8_t  u8DayOfWeek, u8BcdSec,u8BcdMin, u8BcdHour, u8Day, u8Month, u8Year;
       while(u32TimeOut--)
           break;
       if(u32TimeOut==0)
   u8BcdSec  = M0P_RTC->SEC;
   u8BcdMin  = M0P_RTC->MIN;
   u8BcdHour = M0P_RTC->HOUR;
   u8Day     = M0P_RTC->DAY;
   u8Month   = M0P_RTC->MON;
   u8Year    = M0P_RTC->YEAR;
   u8DayOfWeek = M0P_RTC->WEEK;
   pstcTimeDate->u8Second = u8BcdSec;//BcdToDec(u8BcdSec);
   pstcTimeDate->u8Minute = u8BcdMin;//BcdToDec(u8BcdMin);
   pstcTimeDate->u8Hour   =u8BcdHour;//BcdToDec(u8BcdHour);
   pstcTimeDate->u8Day    =u8Day;//BcdToDec(u8Day);
   pstcTimeDate->u8Month  =u8Month;//BcdToDec(u8Month);
   pstcTimeDate->u8Year  =u8Year;//BcdToDec(u8Year);
   pstcTimeDate->u8DayOfWeek = u8DayOfWeek;//BcdToDec(u8DayOfWeek);
   return Ok;
**\brief  RTC计数or读写状态获取
**\param [in]
**\retval 计数or读写状态
boolean_t Rtc_RDStatus(void)
   boolean_t bRet;
   bRet = M0P_RTC->CR1_f.WAITF;
   return bRet;
**\brief  RTC闹钟中断使能
**\param [in] enordis中断使能or禁止
**\retval Ok设置成功
en_result_tRtc_EnAlarmIrq(en_rtc_alarmirq_t enIrqEn)
   M0P_RTC->CR1_f.ALMIE = enIrqEn;
   Rtc_ClrIrqStatus(RtcAlmf);//使能中断后清除中断请求标记
   enRet = Ok;
   return enRet;
**\brief  RTC中断请求状态获取
**\param [in] enIrqSel获取哪种中断请求
**\retval 中断请求状态
boolean_t Rtc_GetIrqStatus(en_rtc_status_irq_tenIrqSel)
   boolean_t bRet = FALSE;
   ASSERT(IS_VALID_IRQ_SEL(enIrqSel));
   switch(enIrqSel)
       case RtcPrdf:
           (M0P_RTC->CR1_f.PRDF == 1)?(bRet = TRUE) : (bRet = FALSE);
           break;
       case RtcAlmf :
           (M0P_RTC->CR1_f.ALMF == 1)?(bRet = TRUE) : (bRet = FALSE);
           break;
       default:
           break;
   return bRet;
**\brief  RTC中断请求清除
**\param [in] enIrqSel清除哪种中断请求
**\retval Ok 清除成功
**\retval ErrorInvalidParameter 清除失败
en_result_tRtc_ClrIrqStatus(en_rtc_status_irq_t enIrqSel)
   switch(enIrqSel)
       case RtcPrdf:
           M0P_RTC->CR1_f.PRDF = 0;
           break;
       case  RtcAlmf:
           M0P_RTC->CR1_f.ALMF = 0;
           break;
       default:
   return Ok;
**\brief  RTC中断处理函数接口获取
**\param [in]
**\retval 接口函数地址
static stc_rtc_intern_cb_t*RtcGetInternDataCb(void)
   return &stcRtcIrqCb;
**\brief  RTC总体初始化函数
**\param [in] pstcRtcConfig初始化结构
**\retval Ok初始化成功
**\retval ErrorInvalidParameter 初始化错误
en_result_t Rtc_Init(stc_rtc_config_t*pstcRtcConfig)
   stc_rtc_intern_cb_t* pstcRtcInternCb;
   if(NULL == pstcRtcConfig)
     return Error;
   pstcRtcInternCb = RtcGetInternDataCb();
   enRet = Rtc_SelClk(pstcRtcConfig->enClkSel);
   enRet = Rtc_SetAmPm(pstcRtcConfig->enAmpmSel);
   if(enRet != Ok)
     return enRet;
   if(NULL != pstcRtcConfig->pstcCycSel)
       if(Ok != Rtc_SetCyc(pstcRtcConfig->pstcCycSel))
           return Error;
   if(NULL != pstcRtcConfig->pstcTimeDate)
       if(Ok != Rtc_WriteDateTime(pstcRtcConfig->pstcTimeDate,TRUE,TRUE))
           return Error;
   if(NULL != pstcRtcConfig->pstcIrqCb)
       pstcRtcInternCb->pfnAlarmIrqCb =pstcRtcConfig->pstcIrqCb->pfnAlarmIrqCb;
       pstcRtcInternCb->pfnTimerIrqCb =pstcRtcConfig->pstcIrqCb->pfnTimerIrqCb;
   if(TRUE == pstcRtcConfig->bTouchNvic)
       EnableNvic(RTC_IRQn,DDL_IRQ_LEVEL_DEFAULT,TRUE);
   else
       EnableNvic(RTC_IRQn,DDL_IRQ_LEVEL_DEFAULT,FALSE);
   return enRet;
**\brief  RTC计数禁止函数
**\param [in]
**\retval Ok禁止设置成功
en_result_t Rtc_DeInit(void)
   Rtc_DisableFunc(RtcCount);
   Rtc_DisableFunc(RtcAlarmEn);
   Rtc_DisableFunc(Rtc_ComenEn);
   Rtc_DisableFunc(Rtc1HzOutEn);
   return Ok;
**\brief  RTC中断处理函数
**\param [in]
**\retval
void Rtc_IRQHandler(void)
   pstcRtcInternCb = RtcGetInternDataCb() ;
   if(TRUE == M0P_RTC->CR1_f.ALMF)
       M0P_RTC->CR1_f.ALMF = 0u;
       if(NULL != pstcRtcInternCb->pfnAlarmIrqCb)
           pstcRtcInternCb->pfnAlarmIrqCb();
   if(TRUE == M0P_RTC->CR1_f.PRDF)
       if(NULL != pstcRtcInternCb->pfnTimerIrqCb)
           pstcRtcInternCb->pfnTimerIrqCb();
static void RtcCycCb(void)
   cyccnt++;
   flg = ~flg;
   Gpio_SetIO(3,3,flg);
static void RtcAlarmCb(void)
u8Alarmcnt++;
int32_t main(void)
   stc_rtc_config_t stcRtcConfig;
   stc_rtc_irq_cb_t stcIrqCb;
   stc_rtc_time_t  stcTime;
   stc_rtc_alarmset_t stcAlarm;
   stc_rtc_cyc_sel_t   stcCycSel;
   DDL_ZERO_STRUCT(stcRtcConfig);
   DDL_ZERO_STRUCT(stcIrqCb);
   DDL_ZERO_STRUCT(stcAlarm);
   DDL_ZERO_STRUCT(stcTime);
   DDL_ZERO_STRUCT(stcCycSel);
   Clk_SetPeripheralGate(ClkPeripheralGpio,TRUE);//使能GPIO时钟
   Gpio_SetAnalog(1,4,1);//配置成模拟端口即为晶振口
    Gpio_SetAnalog(1,5,1);
   Clk_Enable(ClkXTL, TRUE);//开启外部晶振32.768
   //Clk_Enable(ClkRCL, TRUE);
   //Clk_Enable(ClkXTH, TRUE);
   Clk_SetPeripheralGate(ClkPeripheralRtc,TRUE);//使能rtc时钟
   stcRtcConfig.enClkSel = RtcClk32768;//RtcClkHxt1024;//RtcClk32;//
   stcRtcConfig.enAmpmSel = Rtc24h;//Rtc12h;//
   stcTime.u8Year = 0x17;
   stcTime.u8Month = 0x06;
   stcTime.u8Day = 0x07;
   stcTime.u8Hour = 0x12;
   stcTime.u8Minute = 0x59;
   stcTime.u8Second = 0x59;
   stcTime.u8DayOfWeek = Rtc_CalWeek(&stcTime.u8Day);
   stcRtcConfig.pstcTimeDate = &stcTime;
   stcIrqCb.pfnAlarmIrqCb = RtcAlarmCb;
   stcIrqCb.pfnTimerIrqCb = RtcCycCb;
   stcRtcConfig.pstcIrqCb = &stcIrqCb;
   stcRtcConfig.bTouchNvic = FALSE;
   Rtc_Init(&stcRtcConfig);
   Rtc_EnableFunc(RtcCount);
   Rtc_ReadDateTime(&stcReadTime);
   while (1);
*EOF (not truncated)
此内容由EEWORLD论坛网友deepskin1213原创,如需转载或用于商业用途需征得作者同意并注明出处
此帖出自单片机论坛
个人签名华大半导体 QQ:3386208645
1985
国产的,支持一下
570
235
支持支持!
个人签名爱电子,爱生活
star_66666 发表于 2018-2-9 16:19
国产的,支持一下
央企品牌,中电旗下的
感谢了!
1985
是吧,只有央企才有钱自己做
1985
deepskin1213 发表于 2018-2-13 15:36
央企品牌,中电旗下的
搞一波免费试用,可以开拓市场
1985
我们工程师都不会用,选型时是不会考虑的
star_66666 发表于 2018-2-14 13:37
搞一波免费试用,可以开拓市场
您指的这种免费适用是在本论坛中搞活动么?另外想跟您沟通一下,方便留个QQ或者电话的联系方式么?
1985
给你发私信
热度不断攀升!欢迎QQ或者微信咨询!
华大单片机特殊端口应用注意事项一芯虎论坛-中国芯中国梦
http://tigerchip.com.cn/forum.php?mod=viewthread&tid=68&fromuid=2
(出处: 芯虎论坛)
好帖不能沉啊!
23
大佬,您微信多少,向您请教几个问题
白虎姐 发表于 2020-1-19 22:55 大佬,您微信多少,向您请教几个问题
QQ:3386208645.也欢迎站内联系。
保持热度。
