3800|5
STM32驱动LSM6DSL,读FIFO数据一直为0 [复制链接]
我用STM32 SPI驱动LSM6DSL读取加速度计和陀螺仪数据
如果不使用FIFO,用其输出源寄存器 OUTX_L_G OUTX_H_G等等   读取的数据没有问题的
配置如下
  1. uint8_t whoami,rst;
  2.         memset(&md_cfg,0,sizeof(md_cfg));
  3.         memset(&int1_ctrl,0,sizeof(int1_ctrl));
  4.
  5.         lsm6dsl_ctx.read_reg = mt_Spi_Read;
  6.         lsm6dsl_ctx.write_reg = mt_Spi_Write;
  7.         lsm6dsl_device_id(&lsm6dsl_ctx, &whoami);
  8.         if ( whoami != LSM6DSL_ID )
  9.         {
  10.                 while(1)
  11.                 {
  12.                         printf("lsm6dsl not found\n");
  13.                         Delay_ms(500);
  14.                 }
  15.         }
  16.         printf("detect lsm6dsl success Device ID = %02x\n",whoami);
  17.         lsm6dsl_reset_set(&lsm6dsl_ctx, PROPERTY_ENABLE);//复位--恢复默认配置
  18.         do
  19.         {
  20.                 lsm6dsl_reset_get(&lsm6dsl_ctx, &rst);
  21.         } while (rst);
  22. //正常读配置
  23.         lsm6dsl_xl_full_scale_set(&lsm6dsl_ctx, FS_8g);//配置加速度满量程
  24.     lsm6dsl_gyro_full_scale_set(&lsm6dsl_ctx, FS_2000dps);//配置角速度满量程
  25.     lsm6dsl_block_data_update_set(&lsm6dsl_ctx, PROPERTY_ENABLE);//使能BDU  即读完后才更新数据
  26.     lsm6dsl_xl_data_rate_set(&lsm6dsl_ctx, XL_1kHz66Hz);//设置ODR 并开启加速度计
  27. lsm6dsl_gyro_data_rate_set(&lsm6dsl_ctx, GY_1kHz66Hz);//设置ODR 并开启陀螺仪
复制代码
但是我用FIFO定时去读取,读出来的数据一直是零,包括FIFO_DIFF_[10:0] FIFO中未读数据的个数也是零
感觉就是FIFO没有起来,但是过了几秒钟。通过读FIFO_SMART_FULL    FIFO就要满了,奇怪的是次数FIFO中的未读数据还是零
FIFO配置如下:
  2.
  3.         memset(&md_cfg,0,sizeof(md_cfg));
  4.         memset(&int1_ctrl,0,sizeof(int1_ctrl));
  5.
  6.         lsm6dsl_ctx.read_reg = mt_Spi_Read;
  7.         lsm6dsl_ctx.write_reg = mt_Spi_Write;
  8.         lsm6dsl_device_id(&lsm6dsl_ctx, &whoami);
  9.         if ( whoami != LSM6DSL_ID )
  10.         {
  11.                 while(1)
  12.                 {
  13.                         printf("lsm6dsl not found\n");
  14.                         Delay_ms(500);
  15.                 }
  16.         }
  17.         printf("detect lsm6dsl success Device ID = %02x\n",whoami);
  18.         lsm6dsl_reset_set(&lsm6dsl_ctx, PROPERTY_ENABLE);//复位--恢复默认配置
  19.         do
  20.         {
  21.                 lsm6dsl_reset_get(&lsm6dsl_ctx, &rst);
  22.         } while (rst);
  23.
  24.
  25.
  26.         //配置FIFO
  27.         lsm6dsl_fifo_mode_set(&lsm6dsl_ctx,BYPASS);
  28.
  29.     lsm6dsl_block_data_update_set(&lsm6dsl_ctx, PROPERTY_ENABLE);//使能BDU
  30.
  31.     //IF_INC=1(CTRL3_C)
  32.     lsm6dsl_auto_increment_set(&lsm6dsl_ctx,PROPERTY_ENABLE);//使能IF_INC
  33.
  34.         //rounding gyro+xl
  35.     lsm6dsl_rounding_mode_set(&lsm6dsl_ctx,GYRO_XL);
  36.
  37.
  38.     //设置FIFO触发 FIFO ODR和DEC
  39.     //1.有效数据信号用于写FIFO当XL/Gyro数据准备或者步数检测  DATA_VALID_SEL_FIFO=0
  40.     lsm6dsl_fifo_data_valid_set(&lsm6dsl_ctx,XL_GY_DRDY_STEP_DETECT);
  41.     //2.使能写FIFO基于XL/Gyro数据准备 TIMER_PEDO_FIFO_DRDY
  42.     lsm6dsl_fifo_write_mode_set(&lsm6dsl_ctx,ON_DRDY);
  43.
  44.
  45.     //2.设置FIFO ODR  F(ODR) = min(max(ODR_XL,ODR_G),ODR_FIFO)
  46.     lsm6dsl_fifo_data_rate_set(&lsm6dsl_ctx,FIFO_52Hz);
  47.     //3.FIFO_CTRL3和FIFO_CTRL4--DEC 每一笔数据都将存储FIFO
  48.     lsm6dsl_xl_decimation_set(&lsm6dsl_ctx,XL_NO_DEC);
  49.     lsm6dsl_gyro_decimation_set(&lsm6dsl_ctx,GY_NO_DEC);
  50.
  51.     //FIFO深度不受阈值影响
  52.     lsm6dsl_fifo_stop_on_thr_set(&lsm6dsl_ctx,PROPERTY_DISABLE);
  53.
  54.     //2.FIFO_CTRL5--FIFO_ODR    设置FIFO_ODR=52HZ
  55.     lsm6dsl_xl_full_scale_set(&lsm6dsl_ctx, FS_8g);//配置加速度满量程
  56.     lsm6dsl_gyro_full_scale_set(&lsm6dsl_ctx, FS_2000dps);//配置角速度满量程
  57.     lsm6dsl_xl_data_rate_set(&lsm6dsl_ctx, XL_52Hz);//设置ODR 并开启加速度计
  58.     lsm6dsl_gyro_data_rate_set(&lsm6dsl_ctx, GY_52Hz);//设置ODR 并开启陀螺仪
  59.
  60.     //3.FIFO_CTRL5--FIFO MODE   设置FIFO MODE 为当FIFO满时停止放入数据
  61.     lsm6dsl_fifo_mode_set(&lsm6dsl_ctx,CONTINUOS);
复制代码
求大神指导下,为何FIFO起不来,看了ST的LSM6DSL应用笔记,试了很多次  不知道为何FIFO读出来的数据总是零,包括FIFO中的未读数据FIFO_DIFF[10:0]也是零 很奇怪。。。
我用的官方1.8的驱动
ok  解决了 改用1.6驱动了。。。
1.6的驱动哪里可以参考?我想通过FIFO触发中断,现在一直无法触发中断,想参考一下
9936
21
我找到一个1.5的
lsm6dsl.rar (38.97 KB, 下载次数: 43)
个人签名虾扯蛋,蛋扯虾,虾扯蛋扯虾
5134
236
管理员
@ruson525 看楼上
